My bluetooth devices cannot be detected by my system
I freshly installed manjaro. But the system cannot detect any of my bluetooth devices
sudo systemctl status bluetooth
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2021-11-18 03:13:46 IST; 9min ago
Docs: man:bluetoothd(8)
Main PID: 740 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 19099)
Memory: 2.5M
CPU: 34ms
CGroup: /system.slice/bluetooth.service
└─740 /usr/lib/bluetooth/bluetoothd
Nov 18 03:13:46 rp bluetoothd[740]: Starting SDP server
Nov 18 03:13:46 rp bluetoothd[740]: Bluetooth management interface 1.20 initialized
Nov 18 03:13:53 rp bluetoothd[740]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc
Nov 18 03:13:53 rp bluetoothd[740]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc
Nov 18 03:13:53 rp bluetoothd[740]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Nov 18 03:13:53 rp bluetoothd[740]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Nov 18 03:13:53 rp bluetoothd[740]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Nov 18 03:13:53 rp bluetoothd[740]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Nov 18 03:13:53 rp bluetoothd[740]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Nov 18 03:13:53 rp bluetoothd[740]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc_xq_552
