Hi.
I am using a GeForce GTX 1050 in my desktop PC, with the linux61-nvidia driver. It updated yesterday to the 535 version of March. After the update, my 3d games no longer work. They are too slow, and CPU usage is nuts. I looks like a driver issue. Everything else works properly (but my wifi which is too slow too, but that might be another issue).
I’ve tried downgrading, but the downgrade utility does not work.
I’ve tried installing the lattest driver from nvidia, but it is a .run file that refuses to install.
I’ve tried reinstalling with the mhwd tool, nothing changes.
I’ve tried reading some topics in this forum, but I cannot find an answer that solves my problem.
Maybe start with at least something like
inxi -Fazy
For your drivers I would say also provide
mhwd -l -li
Device-1: NVIDIA GP107 [GeForce GTX 1050] driver: nvidia v: 535.113.01
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1 driver: X:
loaded: nvidia gpu: nvidia resolution: 1440x900~60Hz
API: EGL v: 1.5 drivers: nvidia platforms: gbm
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 renderer: NVIDIA
GeForce GTX 1050/PCIe/SSE2
API: Vulkan v: 1.3.264 drivers: nvidia surfaces: xcb,xlib
mhwd -li returns:
video-nvidia 2023.03.23 false PCI
Most of the information is missing.
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e8bc9bdb-110c-481e-bd67-929983099554 rw quiet splash
resume=UUID=77c2ae3b-1772-4b7d-86bd-92f4f00ac592 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASRock model: B75M-DGS serial: <superuser required>
UEFI: American Megatrends v: P1.50 date: 03/14/2018
Info: model: Intel Core i3-3220 bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2025 high: 3300 min/max: 1600/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1600 2: 1600 3: 3300
4: 1600 bogomips: 26349
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Micro-Star MSI
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c81 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 89 s-size: 411x263mm (16.18x10.35")
s-diag: 488mm (19.21")
Monitor-1: HDMI-0 res: 1440x900 hz: 60 dpi: 90
size: 408x255mm (16.06x10.04") diag: 481mm (18.94") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 driver: nvidia v: 535.113.01
device-ID: 10de:1c81 surfaces: xcb,xlib
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASRock 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off with: wireplumber status: active
tools: pw-cli,wpctl
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Ralink MT7610U (Archer T2U 2.4G+5G WLAN Adapter driver: mt76x0u
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.6:3
chip-ID: 148f:761a class-ID: 0000 serial: <filter>
IF: wlp0s26u1u6 state: up mac: <filter>
Local Storage: total: 558.92 GiB used: 110.21 GiB (19.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0000 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Force LS SSD
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: SSD serial: <filter> fw-rev: 02.8 scheme: GPT
ID-1: / raw-size: 102.69 GiB size: 100.52 GiB (97.89%)
used: 32.92 GiB (32.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 40%
Processes: 213 Uptime: 31m wakeups: 0 Memory: total: 16 GiB
available: 15.57 GiB used: 3.55 GiB (22.8%) Init: systemd v: 254
Packages: 1264 pm: pacman pkgs: 1254 libs: 421 tools: pamac pm: flatpak
pkgs: 10 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.30
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
> 0000:01:00.0 (0300:10de:1c81) Display controller nVidia Corporation:
video-nvidia-470xx 2023.03.23 false PCI
video-nvidia-390xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Sorry, you replied faster than I was able to post!
I see two legacy drivers, video-nvidia-390xx and video-nvidia-470xx that maybe don’t need to be there.
Ouch, the old BIOS is probably not doing you any favors.
(and yes, I checked, this is the latest version available, its even technically beta)
But still if it worked before …
I suppose we might as well make sure you are up to date:
sudo pacman -Syu
Of course, you could always downgrade to try and check if it works with that … but
How did you try to do this?
Manjaro has its own downgrade:
sudo pacman -Syu manjaro-downgrade
downgrade linux61-nvidia
(note: I would suggest not adding the package(s) to IgnorePkg, if only for now)
Dont do that.
Sorry to you then. ![]()
Probably not … though I dont think they should be affecting anything.
inxi shows 535 in use.
:: Sincronizando las bases de datos de los paquetes...
core está actualizado
extra está actualizado
community está actualizado
multilib está actualizado
:: Iniciando actualización completa del sistema...
...el sistema ya está actualizado.
Downgrading from A.L.A. is disabled on the stable branch. To override this behavior, set DOWNGRADE_FROM_ALA to 1.
See https://wiki.manjaro.org/index.php/Downgrading_packages for more details.
cargando los paquetes...
advertencia: revertiendo el paquete linux61-nvidia a una versión anterior (535.113.01-2 => 535.104.05-8)
resolviendo dependencias...
advertencia: no se pudo resolver «nvidia-utils=535.104.05», una dependencia de «linux61-nvidia»
:: El siguiente paquete no se puede actualizar debido a dependencias que no se pudieron resolver:
linux61-nvidia
:: ¿Quiere omitir el siguiente paquete para esta actualización? [s/N]
Me pide resolver nvidia-utils primero…
DOWNGRADE_FROM_ALA=1 downgrade nvidia-utils
advertencia: revertiendo el paquete nvidia-utils a una versión anterior (535.113.01-2 => 535.104.05-1)
buscando conflictos entre paquetes...
error: no se pudo preparar la operación (no se pudo satisfacer las dependencias)
:: instalando nvidia-utils (535.104.05-1) se rompe la dependencia con «nvidia-utils=535.113.01», necesaria para el paquete lib32-nvidia-utils
:: instalando nvidia-utils (535.104.05-1) se rompe la dependencia con «nvidia-utils=535.113.01», necesaria para el paquete linux61-nvidia
Dependen unos de otros.
They have linked dependencies.
I can’t stay awake. Got to get up for work in five hours. Will try again tomorrow. Thanks.
You can downgrade multiple at a time
DOWNGRADE_FROM_ALA=1 downgrade nvidia-utils lib32-nvidia-utils linux61-nvidia
Great!
It has downgraded.
I will test it tomorrow, I can’t stay awake.
Thank you.
Well, after reboot, my PC cannot load the screen for selecting the user.
I had to open a terminal in F2, update the system and reboot, then it loads again, but of course, 3D acceleration is still not working in my games.
I tried to downgrade the drivers with two different versions, no luck.
That makes it seem as if it is not the driver package update(s) at blame.
EDIT: oh I guess I misread that. If the desktop is not booting we do not know.
Sorry, but I dont really know what else I would check for 3D failing on nvidia.
Well … going back and reviewing … it seems you dont say it fails but
So just really poor performance.
Maybe there is something helpful here:
https://wiki.archlinux.org/title/NVIDIA/Troubleshooting#Performance_issues
Let me explain.
I load a game. I see properly the first loading images, the developer, the studio. Then the game starts loading the menu page, and it flickers, more and more, CPU usage is at 100%, the game takes forever to move the mouse, or to acknowledge that I clicked a button.
But that’s just the game. If I Ctrl-Tab, the rest of the system is still working well. I can open the monitor application and kill the steam app, which solves the problem but I cannot play my games.
This didn’t happen before I updated the system, and only games that make use of the GPU are at fault.
I don’t understand why my desktop cannot load after downgrading the driver.
You seem to have both Wayland and X11 installed. Do you experience the same using each of those?
Wayland doesn’t even load. I have to initiate Plasma with X11.
I know that 3D acceleration is lost on older Nvidia cards (in X11), but I’m uncertain where the cut-off point is. Your GTX 1050 don’t seem old enough for that to be an issue. Although, I could be wrong.
These drivers will not peacefully coexist with the newly installed 535xx counterpart. You will need to uninstall those manually:
sudo mhwd -r pci video-nvidia-390xx
sudo mhwd -r pci video-nvidia-470xx
… and, reboot.
The package is not installed.
I don’t know what is going on. A search of nvidia packages show only these:
nvidia-utils
nvidia-settings
linux61-nvidia
mhwd-nvidia
mhwd-nvidia-390xx
mhwd-nvidia-470xx
lib32-nvidia-utils
but trying to remove mhwd-nvidia-370xx says that it messes with mhwd-nvidia-db
The mhwd-nvidia-390xx and mhwd-nvidia-470xx are not the drivers, those are needed by mhwd, they only contain a file with a list of ids.
I don’t know how it’s listed in pamac, but in Octopi, it says:
mhwd-nvidia-390xx
MHWD module-ids for nvidia 390.157
