So iI got this cute little 2-1 laptop from the kids for Christmas. Its a Lenovo Flex 5-14IIL05 Laptop. So since i cant leave thiings alone i upgraded the nvme m2 to a 500GB. and well sinve it now had no OS anymore i had a reason to finally go back and try linux again. I played with Arch 7 years ago but didnt do much.
so i tried Arch again. lol and mint and ubuntu and mx and finally settleed on manjaro. all i tried had no sound and no touch screen. i figured out the sound but touch screen requires a kernel edit which in already done in the 5.11-rc1. so i compiled the kernel with makepkg -s and after an hour fished no errors. Next i run makepkg -i for install and i am getting a cannot move error directory not empty. Any ideas what i can try? Near the bottom is what im talking about
Uploading: Screenshot from 2021-01-01 16-12-03.png…
That’s not working out so well and screenshots are not helpful. They’re often hard to read (especially on mobile) and cannot be indexed by search.
Please post the output with Preformatted text </> .
Also see:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
thank you for pointing that out for me. think i got this right now
==> Extracting sources...
-> Extracting linux-5.11.rc1.d1229.g139711f.zip with bsdtar
==> Starting prepare()...
mv: cannot move '/home/mike/build/linux511/src/linux-139711f033f636cc78b6aaf7363252241b9698ef' to '/home/mike/build/linux511/src/linux-5.11/linux-139711f033f636cc78b6aaf7363252241b9698ef': Directory not empty
==> ERROR: A failure occurred in prepare().
Aborting...
~/build/linux511 >>>
Hightlight the text, then click the </> button.
Are you using our PKGBUILD or something else?
lol that took abit.
Yes i am using the one you linked.
the link for directions i am following can be found by googling
compiling-a-custom-linux-kernel-on-manjaro
inxi
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=8bee227c-0205-4d18-993f-f0b0d05f2ca4 rw quiet splash apparmor=1
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Convertible System: LENOVO product: 81X1 v: IdeaPad Flex 5 14IIL05
serial: <filter> Chassis: type: 31 v: IdeaPad Flex 5 14IIL05
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
UEFI: LENOVO v: ECCN30WW date: 09/07/2020
ID-1: BAT0 charge: 39.7 Wh condition: 53.7/52.6 Wh (102%) volts: 12.2/11.5
model: Sunwoda L19D3PD6 type: Li-poly serial: <filter> status: Discharging
cycles: 6
Info: Quad Core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A0
L2 cache: 6 MiB
bogomips: 19048
Speed: 1215 MHz min/max: 400/3600 MHz Core speeds (MHz): 1: 1215 2: 1302
3: 1301 4: 1200 5: 1248 6: 747 7: 815 8: 1212
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:8a56
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus ID: 3-2:2
chip ID: 5986:212a
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver: i915
note: n/a (using device driver) - try sudo/root display ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Lenovo driver: sof-audio-pci
alternate: snd_hda_intel,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3 chip ID: 8086:34f0
Local Storage: total: 465.76 GiB used: 17.2 GiB (3.7%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 111110WD
temp: 37.9 C
ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%) used: 17.2 GiB (3.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 51.0 C mobo: 41.0 C
Processes: 255 Uptime: N/A wakeups: 2 Memory: 7.44 GiB
used: 1.47 GiB (19.7%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1242 lib: 369 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.2.01
Well dont ask me how but i got it to install. i was looking in the zips it spit out and one of them started installing the kernel. rebooted and the touchscreen now works
system
Closed
17 January 2021 01:37
8
