I just installed Manjaro on an ARM system. I’m already running it on two other machines (one ARM, one x86) with no issues. On this new system, avahi discover and browse return no results. My network is available (I’m typing this from that machine), but Avahi shows nothing, not even on the local machine. I ran sudo systemctl start avahi-daemon, and looked at the output of avahi-daemon --debug, which is as follows:
Found user 'avahi' (UID 974) and group 'avahi' (GID 974).
Successfully dropped root privileges.
avahi-daemon 0.8 starting up.
chroot.c: chroot() helper started
Successfully called chroot().
Successfully dropped remaining capabilities.
chroot.c: chroot() helper got command 02
No service file found in /etc/avahi/services.
Joining mDNS multicast group on interface eth0.IPv6 with address fe80::4ea5:2615:e76:fc80.
New relevant interface eth0.IPv6 for mDNS.
Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.71.
New relevant interface eth0.IPv4 for mDNS.
Joining mDNS multicast group on interface lo.IPv6 with address ::1.
New relevant interface lo.IPv6 for mDNS.
Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
New relevant interface lo.IPv4 for mDNS.
Network interface enumeration completed.
Registering new address record for fe80::4ea5:2615:e76:fc80 on eth0.*.
Registering new address record for 192.168.1.71 on eth0.IPv4.
Registering new address record for ::1 on lo.*.
Registering new address record for 127.0.0.1 on lo.IPv4.
sendmsg() to ff02::fb failed: Network is unreachable
Server startup complete. Host name is flere-imsaho.local. Local service cookie is 4111881056.
The results of avahi-browse -D are:
+ n/a n/a fios-router.home
My /etc/avahi/avahi-daemon.conf is the default, which is the same across the other two machines.
The other two machines have no trouble browsing, showing all the results on the network. The new machine (if it’s relevant, it’s a Raspberry Pi) is plugged into the same router as one of the other machines.
How can I root cause this issue?
