Multi PHP version with apache-fpm and vhost
Hello all,
I am trying to create a web development environment with LAMP.
By following this tutorial I am able to achieve it. link
My problem is I want to user two php version like 7.4 and 8 for my multiple virtual host
I got some information from the arch wiki but not so elaborate or may be I am unable to get the idea from there.
My situation like similar to this problem from a arch forum but it is very old info.
Please anyone have any tutorial on this in Manjaro share with us.
I searched the net but got only with debian and redhat info but not arch or manjaro configuration.
Thanks
hi,
best for multi-versions is to use docker, for example this
Don’t have the time to write a tutorial, but I just drop my PHP configuration files for that scenario.
I guess you have the packages php (= PHP8) and php7 already installed together with php-fpm and php7-fpm and mod_proxy_fcgi like explained in the mentioned tutorial.
Create /etc/httpd/conf/extra/httpd-php-fpm.conf for PHP8:
<IfModule dir_module>
    DirectoryIndex index.php index.html
</IfModule>
<IfModule mime_module>
    AddType application/x-httpd-php .php
</IfModule>
# Redirect to local php-fpm if mod_php is not available
<IfModule !mod_php.c>
    <IfModule proxy_fcgi_module>
        # Enable http authorization headers
        <IfModule setenvif_module>
            SetEnvIfNoCase ^Authorization$ "(.+)" HTTP_AUTHORIZATION=$1
        </IfModule>
        <FilesMatch ".+\.ph(ar|p|tml)$">
            SetHandler "proxy:unix:/run/php-fpm/php-fpm.sock|fcgi://localhost"
        </FilesMatch>
        <FilesMatch ".+\.phps$">
            # Deny access to raw php sources by default
            # To re-enable it's recommended to enable access to the files
            # only in specific virtual host or directory
            Require all denied
        </FilesMatch>
        # Deny access to files without filename (e.g. '.php')
        <FilesMatch "^\.ph(ar|p|ps|tml)$">
            Require all denied
        </FilesMatch>
    </IfModule>
</IfModule>
Create /etc/httpd/conf/extra/httpd-php-fpm7.conf for PHP7:
</IfModule>
</IfModule>
<IfModule !mod_php7.c>
        </IfModule>
            SetHandler "proxy:unix:/run/php-fpm7/php-fpm.sock|fcgi://localhost"
        </FilesMatch>
            Require all denied
        </FilesMatch>
            Require all denied
        </FilesMatch>
    </IfModule>
</IfModule>
Then just load one of them in your vhost config file:
<VirtualHost *:80>
    ServerName project.local
    DocumentRoot /srv/project
    Include conf/extra/httpd-php-fpm.conf
</VirtualHost>
@papajoke Thanks. At the moment I am not thinking to switch to docker but in the long run may be I will switch to Docker.
@Deano Thanks, I am going to try it and give you a feed back on that.
But I already facing a problem, when I try to add this code in http-vhsot.conf file it give me error.
I will post here more details about my config.
      	ServerAdmin webmaster@khandakershahi.local
        DocumentRoot /data/lampp/htdocs/khandakershahi
        ServerName khandakershahi.local
#	ErrorLog "logs/khandakershahi.local-error_log"
#	CustomLog "logs/khandakershahi.local-access_log" common
        <Directory "/data/lampp/htdocs/khandakershahi">
    		Options Indexes FollowSymLinks ExecCGI Includes
    AllowOverride All
	Require all granted
        </Directory>
Thanks
Which error do you get? Eventually you have to change the path to httpd-php-fpm.conf when it’s in the same directory as httpd-vhosts.conf. You can check your Apache config with httpd -S for configuration errors.
1. followed this link and it work the noraml way.
2. and from this link did only this part
#### Using php-fpm and mod_proxy_fcgi
This method provides "an alternative PHP FastCGI implementation with some additional features (mostly) useful for heavy-loaded sites" [[1]](https://www.php.net/manual/en/install.fpm.php).
**Note:** Unlike the widespread setup with ProxyPass, the proxy configuration with SetHandler respects other Apache directives like DirectoryIndex. This ensures a better compatibility with software designed for libphp, mod_fastcgi and mod_fcgid. If you still want to try ProxyPass, experiment with a line like this:
ProxyPassMatch ^/(.*\.php(/.*)?)$ unix:/run/php-fpm/php-fpm.sock|fcgi://localhost/srv/http/$1
[Install](https://wiki.archlinux.org/title/Install) [php-fpm](https://archlinux.org/packages/?name=php-fpm).
Enable proxy modules:
/etc/httpd/conf/httpd.conf
LoadModule proxy_module modules/mod_proxy.so LoadModule proxy_fcgi_module modules/mod_proxy_fcgi.so
Create `/etc/httpd/conf/extra/php-fpm.conf` with the following content:
DirectoryIndex index.php index.html <FilesMatch \.php$> SetHandler "proxy:unix:/run/php-fpm/php-fpm.sock|fcgi://localhost/" </FilesMatch>
And include it at the bottom of `/etc/httpd/conf/httpd.conf`:
Include conf/extra/php-fpm.conf
**Note:** The pipe between `sock` and `fcgi` is not allowed to be surrounded by a space! `localhost` can be replaced by any string. More [here](https://httpd.apache.org/docs/2.4/mod/mod_proxy_fcgi.html)
You can configure PHP-FPM in `/etc/php/php-fpm.d/www.conf`, but the default setup should work fine.
Start and enable `php-fpm.service`. [Restart](https://wiki.archlinux.org/title/Restart) `httpd.service`.
3. Than I follow your instruction.
here is my httpd.conf
# This is the main Apache HTTP server configuration file.  It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
# for a discussion of each configuration directive.
# Do NOT simply read the instructions in here without understanding
# what they do.  They're here only as hints or reminders.  If you are unsure
# consult the online docs. You have been warned.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path.  If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "logs/access_log"
# with ServerRoot set to "/usr/local/apache2" will be interpreted by the
# server as "/usr/local/apache2/logs/access_log", whereas "/logs/access_log"
# will be interpreted as '/logs/access_log'.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# Do not add a slash at the end of the directory path.  If you point
# ServerRoot at a non-local disk, be sure to specify a local disk on the
# Mutex directive, if file-based mutexes are used.  If you wish to share the
# same ServerRoot for multiple httpd daemons, you will need to change at
# least PidFile.
ServerRoot "/etc/httpd"
# Mutex: Allows you to set the mutex mechanism and mutex file directory
# for individual mutexes, or change the global defaults
# Uncomment and change the directory if mutexes are file-based and the default
# mutex file directory is not on a local disk or is not appropriate for some
# other reason.
# Mutex default:/run/httpd
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 80
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
#LoadModule mpm_event_module modules/mod_mpm_event.so
LoadModule mpm_prefork_module modules/mod_mpm_prefork.so
#LoadModule mpm_worker_module modules/mod_mpm_worker.so
LoadModule authn_file_module modules/mod_authn_file.so
#LoadModule authn_dbm_module modules/mod_authn_dbm.so
#LoadModule authn_anon_module modules/mod_authn_anon.so
#LoadModule authn_dbd_module modules/mod_authn_dbd.so
#LoadModule authn_socache_module modules/mod_authn_socache.so
LoadModule authn_core_module modules/mod_authn_core.so
LoadModule authz_host_module modules/mod_authz_host.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_user_module modules/mod_authz_user.so
#LoadModule authz_dbm_module modules/mod_authz_dbm.so
#LoadModule authz_owner_module modules/mod_authz_owner.so
#LoadModule authz_dbd_module modules/mod_authz_dbd.so
LoadModule authz_core_module modules/mod_authz_core.so
#LoadModule authnz_ldap_module modules/mod_authnz_ldap.so
#LoadModule authnz_fcgi_module modules/mod_authnz_fcgi.so
LoadModule access_compat_module modules/mod_access_compat.so
LoadModule auth_basic_module modules/mod_auth_basic.so
#LoadModule auth_form_module modules/mod_auth_form.so
#LoadModule auth_digest_module modules/mod_auth_digest.so
#LoadModule allowmethods_module modules/mod_allowmethods.so
#LoadModule file_cache_module modules/mod_file_cache.so
#LoadModule cache_module modules/mod_cache.so
#LoadModule cache_disk_module modules/mod_cache_disk.so
#LoadModule cache_socache_module modules/mod_cache_socache.so
#LoadModule socache_shmcb_module modules/mod_socache_shmcb.so
#LoadModule socache_dbm_module modules/mod_socache_dbm.so
#LoadModule socache_memcache_module modules/mod_socache_memcache.so
#LoadModule socache_redis_module modules/mod_socache_redis.so
#LoadModule watchdog_module modules/mod_watchdog.so
#LoadModule macro_module modules/mod_macro.so
#LoadModule dbd_module modules/mod_dbd.so
#LoadModule dumpio_module modules/mod_dumpio.so
#LoadModule echo_module modules/mod_echo.so
#LoadModule buffer_module modules/mod_buffer.so
#LoadModule data_module modules/mod_data.so
#LoadModule ratelimit_module modules/mod_ratelimit.so
LoadModule reqtimeout_module modules/mod_reqtimeout.so
#LoadModule ext_filter_module modules/mod_ext_filter.so
#LoadModule request_module modules/mod_request.so
LoadModule include_module modules/mod_include.so
LoadModule filter_module modules/mod_filter.so
#LoadModule reflector_module modules/mod_reflector.so
#LoadModule substitute_module modules/mod_substitute.so
#LoadModule sed_module modules/mod_sed.so
#LoadModule charset_lite_module modules/mod_charset_lite.so
#LoadModule deflate_module modules/mod_deflate.so
#LoadModule xml2enc_module modules/mod_xml2enc.so
#LoadModule proxy_html_module modules/mod_proxy_html.so
#LoadModule brotli_module modules/mod_brotli.so
LoadModule mime_module modules/mod_mime.so
#LoadModule ldap_module modules/mod_ldap.so
LoadModule log_config_module modules/mod_log_config.so
#LoadModule log_debug_module modules/mod_log_debug.so
#LoadModule log_forensic_module modules/mod_log_forensic.so
#LoadModule logio_module modules/mod_logio.so
#LoadModule lua_module modules/mod_lua.so
LoadModule env_module modules/mod_env.so
#LoadModule mime_magic_module modules/mod_mime_magic.so
#LoadModule cern_meta_module modules/mod_cern_meta.so
#LoadModule expires_module modules/mod_expires.so
LoadModule headers_module modules/mod_headers.so
#LoadModule ident_module modules/mod_ident.so
#LoadModule usertrack_module modules/mod_usertrack.so
LoadModule unique_id_module modules/mod_unique_id.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule version_module modules/mod_version.so
#LoadModule remoteip_module modules/mod_remoteip.so
#LoadModule proxy_connect_module modules/mod_proxy_connect.so
#LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
#LoadModule proxy_http_module modules/mod_proxy_http.so
#LoadModule proxy_scgi_module modules/mod_proxy_scgi.so
#LoadModule proxy_uwsgi_module modules/mod_proxy_uwsgi.so
#LoadModule proxy_fdpass_module modules/mod_proxy_fdpass.so
#LoadModule proxy_wstunnel_module modules/mod_proxy_wstunnel.so
#LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
#LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
#LoadModule proxy_express_module modules/mod_proxy_express.so
#LoadModule proxy_hcheck_module modules/mod_proxy_hcheck.so
#LoadModule session_module modules/mod_session.so
#LoadModule session_cookie_module modules/mod_session_cookie.so
#LoadModule session_crypto_module modules/mod_session_crypto.so
#LoadModule session_dbd_module modules/mod_session_dbd.so
LoadModule slotmem_shm_module modules/mod_slotmem_shm.so
#LoadModule slotmem_plain_module modules/mod_slotmem_plain.so
#LoadModule ssl_module modules/mod_ssl.so
#LoadModule dialup_module modules/mod_dialup.so
#LoadModule http2_module modules/mod_http2.so
#LoadModule proxy_http2_module modules/mod_proxy_http2.so
#LoadModule md_module modules/mod_md.so
#LoadModule lbmethod_byrequests_module modules/mod_lbmethod_byrequests.so
#LoadModule lbmethod_bytraffic_module modules/mod_lbmethod_bytraffic.so
#LoadModule lbmethod_bybusyness_module modules/mod_lbmethod_bybusyness.so
#LoadModule lbmethod_heartbeat_module modules/mod_lbmethod_heartbeat.so
LoadModule unixd_module modules/mod_unixd.so
#LoadModule fcgid_module modules/mod_fcgid.so
#LoadModule heartbeat_module modules/mod_heartbeat.so
#LoadModule heartmonitor_module modules/mod_heartmonitor.so
#LoadModule dav_module modules/mod_dav.so
LoadModule status_module modules/mod_status.so
LoadModule autoindex_module modules/mod_autoindex.so
#LoadModule asis_module modules/mod_asis.so
#LoadModule info_module modules/mod_info.so
#LoadModule suexec_module modules/mod_suexec.so
<IfModule !mpm_prefork_module>
	#LoadModule cgid_module modules/mod_cgid.so
</IfModule>
<IfModule mpm_prefork_module>
	#LoadModule cgi_module modules/mod_cgi.so
</IfModule>
#LoadModule dav_fs_module modules/mod_dav_fs.so
#LoadModule dav_lock_module modules/mod_dav_lock.so
#LoadModule vhost_alias_module modules/mod_vhost_alias.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule dir_module modules/mod_dir.so
#LoadModule imagemap_module modules/mod_imagemap.so
#LoadModule actions_module modules/mod_actions.so
#LoadModule speling_module modules/mod_speling.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule alias_module modules/mod_alias.so
#LoadModule rewrite_module modules/mod_rewrite.so
#php8
LoadModule php_module modules/libphp.so
AddHandler php-script php
Include conf/extra/php_module.conf
#php7
#LoadModule php7_module modules/libphp7.so
#AddHandler php7-script php
#Include conf/extra/php7_module.conf
<IfModule unixd_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User shahi
Group shahi
</IfModule>
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.  e.g. admin@your-domain.com
ServerAdmin you@example.com
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
#ServerName www.example.com:80
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory />
    AllowOverride none
    Require all denied
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
#DocumentRoot "/srv/http"
#<Directory "/srv/http">
DocumentRoot "/data/lampp/htdocs"
<Directory "/data/lampp/htdocs">
    # Possible values for the Options directive are "None", "All",
    # or any combination of:
    #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
    # Note that "MultiViews" must be named *explicitly* --- "Options All"
    # doesn't give it to you.
    # The Options directive is both complicated and important.  Please see
    # http://httpd.apache.org/docs/2.4/mod/core.html#options
    # for more information.
    # AllowOverride controls what directives may be placed in .htaccess files.
    # It can be "All", "None", or any combination of the keywords:
    #   AllowOverride FileInfo AuthConfig Limit
    AllowOverride None
    # Controls who can get stuff from this server.
    Require all granted
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
    DirectoryIndex index.html
</IfModule>
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ".ht*">
    Require all denied
</Files>
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog "/var/log/httpd/error_log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
<IfModule log_config_module>
    # The following directives define some format nicknames for use with
    # a CustomLog directive (see below).
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    <IfModule logio_module>
      # You need to enable mod_logio.c to use %I and %O
      LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
    </IfModule>
    # The location and format of the access logfile (Common Logfile Format).
    # If you do not define any access logfiles within a <VirtualHost>
    # container, they will be logged here.  Contrariwise, if you *do*
    # define per-<VirtualHost> access logfiles, transactions will be
    # logged therein and *not* in this file.
    CustomLog "/var/log/httpd/access_log" common
    # If you prefer a logfile with access, agent, and referer information
    # (Combined Logfile Format) you can use the following directive.
    #CustomLog "/var/log/httpd/access_log" combined
</IfModule>
<IfModule alias_module>
    # Redirect: Allows you to tell clients about documents that used to
    # exist in your server's namespace, but do not anymore. The client
    # will make a new request for the document at its new location.
    # Example:
    # Redirect permanent /foo http://www.example.com/bar
    # Alias: Maps web paths into filesystem paths and is used to
    # access content that does not live under the DocumentRoot.
    # Example:
    # Alias /webpath /full/filesystem/path
    # If you include a trailing / on /webpath then the server will
    # require it to be present in the URL.  You will also likely
    # need to provide a <Directory> section to allow access to
    # the filesystem path.
    # ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the target directory are treated as applications and
    # run by the server when requested rather than as documents sent to the
    # client.  The same rules about trailing "/" apply to ScriptAlias
    # directives as to Alias.
    ScriptAlias /cgi-bin/ "/data/lamp/htdocs/cgi-bin/"
</IfModule>
<IfModule cgid_module>
    # ScriptSock: On threaded servers, designate the path to the UNIX
    # socket used to communicate with the CGI daemon of mod_cgid.
    #Scriptsock cgisock
</IfModule>
# "/srv/http/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "/srv/http/cgi-bin">
    AllowOverride None
    Options None
    Require all granted
</Directory>
<IfModule headers_module>
    # Avoid passing HTTP_PROXY environment to CGI's on this or any proxied
    # backend servers which have lingering "httpoxy" defects.
    # 'Proxy' request header is undefined by the IETF, not listed by IANA
    RequestHeader unset Proxy early
</IfModule>
    # TypesConfig points to the file containing the list of mappings from
    # filename extension to MIME-type.
    TypesConfig conf/mime.types
    # AddType allows you to add to or override the MIME configuration
    # file specified in TypesConfig for specific file types.
    #AddType application/x-gzip .tgz
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    #AddEncoding x-compress .Z
    #AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    AddType application/x-compress .Z
    AddType application/x-gzip .gz .tgz
    # AddHandler allows you to map certain file extensions to "handlers":
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action directive (see below)
    # To use CGI scripts outside of ScriptAliased directories:
    # (You will also need to add "ExecCGI" to the "Options" directive.)
    #AddHandler cgi-script .cgi
    # For type maps (negotiated resources):
    #AddHandler type-map var
    # Filters allow you to process content before it is sent to the client.
    # To parse .shtml files for server-side includes (SSI):
    # (You will also need to add "Includes" to the "Options" directive.)
    #AddType text/html .shtml
    #AddOutputFilter INCLUDES .shtml
</IfModule>
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type.  The MIMEMagicFile
# directive tells the module where the hint definitions are located.
#MIMEMagicFile conf/magic
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# MaxRanges: Maximum number of Ranges in a request before
# returning the entire resource, or one of the special
# values 'default', 'none' or 'unlimited'.
# Default setting is to accept 200 Ranges.
#MaxRanges unlimited
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files.  This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
#EnableSendfile on
# Supplemental configuration
# The configuration files in the conf/extra/ directory can be
# included to add extra features or to modify the default configuration of
# the server, or you may simply copy their contents here and change as
# necessary.
# Server-pool management (MPM specific)
Include conf/extra/httpd-mpm.conf
# Multi-language error messages
Include conf/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
Include conf/extra/httpd-autoindex.conf
# Language settings
Include conf/extra/httpd-languages.conf
# User home directories
Include conf/extra/httpd-userdir.conf
# Real-time info on requests and configuration
#Include conf/extra/httpd-info.conf
# Virtual hosts
Include conf/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include conf/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Include conf/extra/httpd-dav.conf
# Various default settings
Include conf/extra/httpd-default.conf
# Configure mod_proxy_html to understand HTML4/XHTML1
<IfModule proxy_html_module>
Include conf/extra/proxy-html.conf
</IfModule>
# Secure (SSL/TLS) connections
#Include conf/extra/httpd-ssl.conf
# Note: The following must must be present to support
#       starting without SSL on platforms with no /dev/random equivalent
#       but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
Include conf/extra/phpmyadmin.conf
#Include conf/extra/php-fcgid.conf
my httpd-vhosts.conf
# Virtual Hosts
# Required modules: mod_log_config
# If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them. Most configurations
# use only name-based virtual hosts so the server doesn't need to worry about
# IP addresses. This is indicated by the asterisks in the directives below.
# Please see the documentation at
# <URL:http://httpd.apache.org/docs/2.4/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
# The first VirtualHost section is used for all requests that do not
# match a ServerName or ServerAlias in any <VirtualHost> block.
<VirtualHost acer.local:80>
    ServerAdmin webmaster@acer.local
    ServerName acer.local
    ServerAlias www.acer.local
#    ErrorLog "logs/acer.local-error_log"
#    CustomLog "logs/acer.local-access_log" common
    AllowOverride All
	Require all granted
	</Directory>
</VirtualHost>
<VirtualHost wordpress56.local:80>
    ServerAdmin webmaster@wordpress56.local
    DocumentRoot "/data/lampp/htdocs/wordpress56"
    ServerName wordpress56.local
#    ErrorLog "logs/wordpress56.local-error_log"
#    CustomLog "logs/wordpress56.local-access_log" common
    <Directory "/data/lampp/htdocs/wordpress56">
    AllowOverride All
	Require all granted
	</Directory>
</VirtualHost>
<VirtualHost bloomlocal.local:80>
    ServerAdmin webmaster@bloomlocal.local
    DocumentRoot "/data/lampp/htdocs/bloomlocal"
    ServerName bloomlocal.local
#    ErrorLog "logs/bloomlocal.local-error_log"
#    CustomLog "logs/bloomlocal.local-access_log" common
    <Directory "/data/lampp/htdocs/bloomlocal">
    AllowOverride All
	Require all granted
	</Directory>
</VirtualHost>
<VirtualHost cliffsidebohol.local:80>
    ServerAdmin webmaster@cliffsidebohol.local
    DocumentRoot "/data/lampp/htdocs/cliffsidebohol"
    ServerName cliffsidebohol.local
#    ErrorLog "logs/cliffsidebohol.local-error_log"
#    CustomLog "logs/cliffsidebohol.local-access_log" common
    <Directory "/data/lampp/htdocscliffsidebohol">
    AllowOverride All
	Require all granted
	</Directory>
</VirtualHost>
<VirtualHost mytest1.local:80>
	ServerAdmin webmaster@mytest1.local
	DocumentRoot "/data/lampp/htdocs/mytest1"
	ServerName mytest1.local
#	ErrorLog "logs/mytest1.local-error_log"
#	CustomLog "logs/mytest1.local-access_log" common
	<Directory "/data/lampp/htdocs/mytest1">
	AllowOverride All
	Require all granted
	</Directory>
</VirtualHost>
<VirtualHost mytest2.local:80>
	ServerAdmin webmaster@mytest2.local
	DocumentRoot "/data/lampp/htdocs/mytest2"
	ServerName mytest2.local
#	ErrorLog "logs/mytest2.local-error_log"
#	CustomLog "logs/mytest2.local-access_log" common
	<Directory "/data/lampp/htdocs/mytest2">
	AllowOverride All
	Require all granted
	</Directory>
</VirtualHost>
<VirtualHost wordpress57.local:80>
	ServerAdmin webmaster@wordpress57.local
	DocumentRoot "/data/lampp/htdocs/wordpress57"
	ServerName wordpress57.local
#	ErrorLog "logs/wordpress57.local-error_log"
#	CustomLog "logs/wordpress57.local-access_log" common
	<Directory "/data/lampp/htdocs/wordpress57">
	AllowOverride All
	Require all granted
	</Directory>
</VirtualHost>
<VirtualHost khandakershahi.local:80>
	AllowOverride All
	Require all granted
	</Directory>
Include conf/extra/httpd-php-fpm7.conf
</VirtualHost>
httpd -s result
httpd -S
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using acer.local. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
127.0.0.1:80           is a NameVirtualHost
         default server acer.local (/etc/httpd/conf/extra/httpd-vhosts.conf:23)
         port 80 namevhost acer.local (/etc/httpd/conf/extra/httpd-vhosts.conf:23)
                 alias www.acer.local
         port 80 namevhost wordpress56.local (/etc/httpd/conf/extra/httpd-vhosts.conf:38)
         port 80 namevhost bloomlocal.local (/etc/httpd/conf/extra/httpd-vhosts.conf:53)
         port 80 namevhost cliffsidebohol.local (/etc/httpd/conf/extra/httpd-vhosts.conf:70)
         port 80 namevhost mytest1.local (/etc/httpd/conf/extra/httpd-vhosts.conf:83)
         port 80 namevhost mytest2.local (/etc/httpd/conf/extra/httpd-vhosts.conf:96)
         port 80 namevhost wordpress57.local (/etc/httpd/conf/extra/httpd-vhosts.conf:109)
         port 80 namevhost khandakershahi.local (/etc/httpd/conf/extra/httpd-vhosts.conf:122)
ServerRoot: "/etc/httpd"
Main DocumentRoot: "/data/lampp/htdocs"
Main ErrorLog: "/var/log/httpd/error_log"
Mutex proxy: using_defaults
Mutex default: dir="/run/httpd/" mechanism=default
Mutex mpm-accept: using_defaults
PidFile: "/run/httpd/httpd.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="shahi" id=1000 not_used
Group: name="shahi" id=1000 not_used
Now I in my browser I see this and it is a wordpress site.
The tutorial mentioned starts PHP-FPM for PHP8, but you included my config for PHP7 in your vhost config for khandakershahi.local. So also check if both FPM services are running:
sudo systemctl status php-fpm.service
sudo systemctl status php-fpm7.service
In the last line of your http.conf it says:
Don’t know if the fat the end is just a typo, but include php-fpm.conf either globally in the httpd.conf (just a single PHP version) OR in each vhost the version you need.
I forgot to enable the php-fpm.service and php-fpm7.service now they are running.
the file name was wrong so I fixed it but I don’t want it load globally but from vhost.
In vhost I have to include httpd-php-fpm7.conf with ifmodule otherwise it throws error like 503 but what ever I add it show only php 8 not php 7.
I nclude conf/extra/httpd-php-fpm7.conf
or
Include conf/extra/php-fpm7.conf
# ErrorLog “logs/khandakershahi.local-error_log”
# CustomLog “logs/khandakershahi.local-access_log” common
	AllowOverride All
	Require all granted
	</Directory>
<IfModule mod_fastcgi>
</IfModule>
In httpd.conf file
which one to keep and which one to comment out as I want both to working with multiple vhost.
Like vhost khandakershahi.local need to run in php7.
:thinking:
I have reinstall apache and did not activate any php version in httpd.conf. Only did the Using php-fpm and mod_proxy_fcgi part from the arch wiki than I found this tutorial and from that I am able to solve it.
Now my vhost file look like this
	DocumentRoot "/data/lampp/htdocs/khandakershahi"
	<FilesMatch "\.php$">
     SetHandler "proxy:unix:/run/php-fpm7/php-fpm.sock|fcgi://localhost:8072"
   </FilesMatch>
       Options Indexes MultiViews FollowSymLinks
       Require all granted
       AllowOverride All
	</Directory>
Thanks to @Deano and @papajoke .
