Hi, I have a fresh install of Manjaro 22. I have 2 gpus in my system, GTX 1080 and 960.
One monitor is connected to gtx 1080 and 2 monitors connected to 960, but for some reason the monitors connected to the 960 are disabled. I tried downloading nvidia drivers properly but that led to no output at all (Had to uninstall drivers through TTY) any ideas how to proceed? I would like to have all my monitors working. FYI I am quite new in using GNU/Linux and Manjaro. Please dont hate me
Hi,
Open terminal and show your output
inxi -v7azy
mhwd -l
xrandr
Hello,
Please do not mix your install with drivers downloaded from Nvidia. They do not have the kernel modules. Use the one from MHWD.
Open up Nvidia X Server Settings and create a fixed layout from it. Enable the secondary GPU and the Monitors attached to it. Use Absolute mode. Do not save the file as will create the xorg.conf. From the Preview (by clicking on Save to X Configuration File but without saving it) just copy the new information and add/replace the old information inside the /etc/X11/mhwd.d/nvidia.conf
You will have to have the PCI ID for each GPU and the metamodes
in the proper order for each. Is not perfectly straight forward but there is a logic to that madness, still, needs to be done manually in your case.
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d30a04af-9715-49de-9f0c-9697cddce109 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF X470-PLUS GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 6042
date: 04/28/2022
RAM: total: 15.53 GiB used: 2.64 GiB (17.0%)
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2925 high: 4237 min/max: 2200/4972 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4216 2: 2200
3: 2200 4: 4237 5: 2200 6: 2800 7: 2200 8: 2200 9: 4223 10: 2200 11: 4228
12: 2200 bogomips: 101446
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: ASUSTeK driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 08:00.0 chip-ID: 10de:1401
class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia
status: current (as of 2022-12) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.0
chip-ID: 10de:1b80 class-ID: 0300
Device-3: Generalplus GENERAL WEBCAM type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-11:5 chip-ID: 1b3f:2247
class-ID: 0102
Device-4: USB C Video Adaptor type: USB driver: N/A bus-ID: 3-3.3:4
chip-ID: 25a4:9311 class-ID: 1100 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
s-diag: 610mm (24")
Monitor-1: DP-0 pos: primary res: 1920x1080 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
Monitor-2: DVI-I-1-1 size-res: N/A modes: N/A
Monitor-3: HDMI-1-0 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
1080/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 1-1.3:4 v: kernel chip-ID: 046d:0aaa pcie:
gen: 1 class-ID: 0300 speed: 2.5 GT/s serial: <filter> lanes: 4 link-max:
gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:0fba
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
bus-ID: 0a:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Logitech Logitech G PRO X Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-5: Generalplus GENERAL WEBCAM type: USB
class-ID: 0102
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8168 v: 8.050.03-NAPI modules: r8169
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: cdc_ncm
bus-ID: 4-3.1:3 chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
IF: enp12s0f3u3u1c2 state: down mac: <filter>
Local Storage: total: 9.78 TiB used: 23.16 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: SanDisk model: EMTEC X300 1TB
lanes: 4 type: SSD serial: <filter> rev: ECFM53.1 temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Phison
model: E12-512G-SSD-B16-BB1 size: 476.94 GiB block-size: physical: 512 B
rev: ECFM22.4 temp: 26.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T1B0A-00H9H0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 10WD
scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000VN007-2AH16M
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5980 serial: <filter> rev: SC60 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Toshiba model: TR150 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 12.3 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST3000DM007-1WY10G
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD10EZEX-00ZF5A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 0A80
scheme: MBR
ID-8: /dev/sdf maj-min: 8:80 vendor: Western Digital model: WD10EADS-00M2B0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 0A01 scheme: MBR
ID-1: / raw-size: 49.83 GiB size: 48.74 GiB (97.83%) used: 22.36 GiB (45.9%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:8 label: N/A
uuid: d30a04af-9715-49de-9f0c-9697cddce109
ID-2: /boot/efi raw-size: 512.2 MiB size: 511.2 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:7 label: N/A
uuid: ADB1-3652
ID-3: /home raw-size: 531.34 GiB size: 521.93 GiB (98.23%)
used: 816.2 MiB (0.2%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:9 label: N/A
uuid: 6110f124-2514-4104-8f64-eac135ae6f38
ID-1: /dev/nvme0n1p1 maj-min: 259:3 size: 100 MiB fs: vfat label: N/A
uuid: C481-8C83
ID-2: /dev/nvme0n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:5 size: 349.2 GiB fs: ntfs label: mainSSD
uuid: 92B88519B884FCCB
ID-4: /dev/nvme0n1p4 maj-min: 259:6 size: 533 MiB fs: ntfs label: N/A
uuid: B06EFA516EFA0FB8
ID-5: /dev/nvme1n1p1 maj-min: 259:2 size: 476.94 GiB fs: ntfs
label: otherM.2SSD uuid: 944260D94260C21A
ID-6: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: 1TB SSD
uuid: D6C479B7C4799B07
ID-7: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-8: /dev/sdb2 maj-min: 8:18 size: 2.73 TiB fs: ntfs label: 3TB BACKUP
uuid: 4A3ED17B3ED1610D
ID-9: /dev/sdc1 maj-min: 8:33 size: 223.57 GiB fs: ntfs
label: 240GB SSD For Work uuid: 10FC7A54FC7A33D6
ID-10: /dev/sdd1 maj-min: 8:49 size: 2.73 TiB fs: ntfs label: 3TB HDD
uuid: 4E78758778756F19
ID-11: /dev/sde1 maj-min: 8:65 size: 931.51 GiB fs: ntfs
label: 1TB Download HDD uuid: 70F473DEF473A54E
ID-12: /dev/sdf1 maj-min: 8:81 size: 931.51 GiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Hub-2: 1-1:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-1.3:4 info: Logitech Logitech G PRO X Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 046d:0aaa class-ID: 0300
serial: <filter>
Device-2: 1-1.4:6 info: Alcor Micro Multi Flash Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
Device-3: 1-2:3 info: Logitech Cordless Mouse Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-4: 1-11:5 info: Generalplus GENERAL WEBCAM type: Video,Audio
power: 100mA chip-ID: 1b3f:2247 class-ID: 0102
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 3-3:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-6: 3-3.2:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-3.2.2:5 info: Logitech PRO Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 046d:c339 class-ID: 0300 serial: <filter>
Device-2: 3-3.2.4:6 info: Glorious Model D Wireless type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 258a:2023 class-ID: 0301 serial: <filter>
Device-3: 3-3.3:4 info: USB C Video Adaptor type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 25a4:9311 class-ID: 1100
serial: <filter>
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-8: 4-3:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Device-1: 4-3.1:3 info: ASIX AX88179 Gigabit Ethernet
type: Communication,CDC-Data driver: cdc_ncm interfaces: 2 rev: 3.2
speed: 5 Gb/s power: 184mA chip-ID: 0b95:1790 class-ID: 0a00
serial: <filter>
System Temperatures: cpu: 38.8 C mobo: N/A gpu: nvidia temp: 27 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 291 Uptime: 10m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1142 libs: 326 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
   ~  mhwd -l  ✔
> 0000:08:00.0 (0300:10de:1401) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:0a:00.0 (0300:10de:1b80) Display controller nVidia Corporation:
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
   ~  xrandr  ✔
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 298mm
1920x1080 60.00 + 144.00* 119.98 99.93 59.94 50.00 23.98
1680x1050 59.95
1600x900 60.00
1280x1024 143.85 119.96 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 143.86 119.99 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DVI-I-1-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1-1 connected (normal left inverted right x axis y axis)
3840x2160 60.00 + 59.94 50.00 30.00 29.97
2560x1440 59.95
1920x1080 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 71.91 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1024x768 70.07 60.00
800x600 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 72.81 59.94
DP-1-4 disconnected (normal left inverted right x axis y axis)
DP-1-5 disconnected (normal left inverted right x axis y axis)
1920x1080 (0x1c3) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1c4) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1680x1050 (0x1c6) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1600x900 (0x1c7) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x1ca) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1cb) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x800 (0x1cc) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x720 (0x1cd) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1ce) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x1cf) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1024x768 (0x1d2) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1d3) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1d4) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1d5) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x1d6) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1d7) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1d8) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1d9) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
1920x1080 (0x1bf) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
Is it possible to find a step-by-step guide since X server outputs an error that not all options can be enabled, when trying to enable at least one monitor…Again, im most probably stupid and missing something.
The best resource i know of is Multihead - ArchWiki - start from there and also check the dedicated one for nvidia. Just keep in mind that xorg.conf
file should be in your case the /etc/X11/mhwd.d/nvidia.conf
The problem is that I cannot enable properly any other monitors since when using xrandr --listmonitors
it only detects 1 monitor (which is on my 1080) and when trying to use these instructions :
https://linuxconfig.org/how-to-install-the-nvidia-drivers-on-manjaro-linux
I only get a black screen on boot and nothing else…
Avoid using xrandr
and also avoid the drivers from Nvidia Site and use the ones from our repos and install them via MHWD.
To enable the monitors, start with the System Settings and then make use of Nvidia X Server to make a fixed layout that match on both Settings. otherwise the ~/.local/share/kscreen
will create you more issues than necessary and you will have to delete that folder over and over again.
I dont think I understood you correctly (Literally try and explain things to me as if Im five, since again Im new to GNU/Linux) but whenever I try to apply these settings, I only get a blank screen.And again, X Server complains that “The current settings cannot be completely applied” and when I press Apply What is possible, nothing changes. I used these instructions to install the drivers :
https://wiki.manjaro.org/index.php/Configure_NVIDIA_(non-free)_settings_and_load_them_on_Startup
https://paste.pics/399f3d7b8e4299bcc0d12106f2f7ade7
https://paste.pics/d6fbeb0d2d82dc5304f89cf073ef3245
Bring your parents please. I will explain to them.
On System Settings all 3 monitors are enabled. That is what i see from the screenshot. Now you set the Layout in Nvidia X Server Settings with both GPU’s and the 3 Monitors and you append the config information that is new - click on Save X to Configuration but without saving it you click on Preview and copy it and paste the correct part into to the /etc/X11/mhwd.d/nvidia.conf
and then you reboot the system.
If unsure, share the content of the current /etc/X11/mhwd.d/nvidia.con and also the information you get from Preview once you set the Layout in Nvidia X Server Settings.
Nice, real funny.
The reason that I have a tick in the Enabled box is that otherwise I have no other way to properly set the layout.
Im not sure but if it will add any duplication into the nvidia.con
Nvidia Preview :
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 525.60.11
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 1920 0
Screen 1 "Screen1" RightOf "Screen0"
Screen 2 "Screen2" LeftOf "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "BenQ ZOWIE XL LCD"
HorizSync 30.0 - 160.0
VertRefresh 56.0 - 144.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "Samsung LU28R55"
HorizSync 30.0 - 135.0
VertRefresh 40.0 - 60.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor2"
ModelName "Samsung C24F390"
HorizSync 30.0 - 82.0
VertRefresh 48.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce GTX 1080"
BusID "PCI:10:0:0"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BoardName "NVIDIA GeForce GTX 960"
BusID "PCI:8:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device2"
Driver "nvidia"
BusID "PCI:8:0:0"
Screen 1
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2"
Option "metamodes" "1920x1080_144 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DVI-I-1-1: nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Device2"
Monitor "Monitor2"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "HDMI-1-0: nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
And full nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 525.60.11
Screen 0 "Screen0"
EndSection
Section "Files"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
Option "NoLogo" "1"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:10:0:0"
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:8:0:0"
Screen 0
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:8:0:0"
Screen 1
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Device "Device2"
Monitor "Monitor2"
DefaultDepth 24
Option "Stereo" "0"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
moderator edit - please use code tags next time
I also rebooted the system after all the instruction you gave me and it only gave me a blank screen with the mouse cursor and thats it…
Here is some base ground for the config to work. Is all in the wiki, but indeed is not as digestible as cookies with milk.
It seems you already added what you had in Preview to the nvidia.conf but without replacing the entries with the new ones, but rather adding them at the bottom.
- The config can’t have the
twice … Xorg does not make the difference and hence will choke.
In your case you have 2 GPU’s but you managed to make 3 from them. Your GeForce GTX 960 is
"Device1"
and"Device2"
at the same time … Will not work that way. -
When using Screen0 and Screen1 there will be no way to move application windows from one to another, unless TwinView is used via
"Xinerama" "1"
instead of the default"Xinerama" "0"
When using
metamodes
with fixed/absolute position for one Monitor, then do it for all instead ofnvidia-auto-select +0+0
The way you created the config is quite convoluted and i can’t decipher what intentions are behind your choices from there. Replace everything inside the /etc/X11/mhwd.d/nvidia.conf
with this:
Screen 0 "Screen0" 0 0
Screen 1 "Screen0" 1920 0
Option "Xinerama" "1"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:10:0:0"
Option "TripleBuffer" "On"
Option "ConnectToAcpid" "Off"
Option "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On}"
Screen 0
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:8:0:0"
Screen 1
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Screen"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
EndSection
EndSection
Is more generic and semi dynamic layout instead of a fixed one, but at least you should have a better starting point, once you reboot the system and no black screen, if my assessment was correct … but sometimes i’m not spot on things …
I replaced everything but when I Enable the monitors, I just get a blank screen up with the mouse cursor untill the changes revert back.
And when you have that mouse cursor, if you switch TTY with Ctrl+Alt+F2 and then back to TTY1 with Ctrl+Alt+F1 … can you see the desktop ?
Maybe your system needs to enable early KMS. See here:
When I press Ctrl+Alt+F1 I dont see the desktop, only again blank screen with the mouse cursor and after 3-4 seconds the changes revert, disabling the other 2 monitors. I tried enabling early KMS using the link you gave, but it made no difference.
The thing is that Im not running Manjaro in a VM…I have it dual booted with windows.
Welp…I guess im just F’ed am I?
