MT7922 stop working
My Manjaro system’s Wi-Fi stopped working after an update. Here are the details of my system:
inxi --v7azy
  Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=6540b45f-7f3b-4e39-8700-8ce592f7bdce rw quiet splash apparmor=1
    security=apparmor resume=UUID=2340e626-c0ef-43a5-b450-6e31b9f4e33f
    udev.log_priority=3
  Desktop: GNOME v: 47.4 tk: GTK v: 3.24.48 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: MECHREVO product: WUJIE14XA v: Standard
    serial: <superuser required>
  Mobo: MECHREVO model: WUJIE14-GX4HRXL v: Standard
    serial: <superuser required> part-nu: WUJIE14 uuid: <superuser required>
    UEFI: American Megatrends LLC. v: N.1.14MRO15 date: 11/01/2024
  ID-1: BAT0 charge: 80.1 Wh (100.0%) condition: 80.1/80.1 Wh (100.0%)
    volts: 17.5 min: 15.4 model: standard type: Li-ion serial: <filter>
    status: full
  Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
    status: N/A
  System RAM: total: 24 GiB available: 22.76 GiB used: 3.95 GiB (17.4%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 12 GiB speed: 5600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CT12G56C46S5.M4B1 serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705206
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 400 min/max: 400/3801 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 bogomips: 121427
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
    avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
    gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv
    lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 vendor: AIstone Global
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1
    bus-ID: 65:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 39.0 C
  Device-2: SunplusIT HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 2b7e:b663
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: TL140ADXP24-0 built: 2023 res: 2880x1800 dpi: 244
    gamma: 1.2 size: 300x190mm (11.81x7.48") diag: 355mm (14") ratio: 16:10
    modes: max: 2880x1800 min: 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    gfx1103_r1 LLVM 19.1.7 DRM 3.61 6.12.17-1-MANJARO) device-ID: 1002:1900
    memory: 500 MiB unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio vendor: AIstone Global driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 65:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: AIstone Global driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 65:00.5 chip-ID: 1022:15e2 class-ID: 0480
    speed: 16 GT/s lanes: 16 bus-ID: 65:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Motorcomm Micro. YT6801 Gigabit Ethernet vendor: AIstone Global
    driver: N/A pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0
    chip-ID: 1f0a:6801 class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: AzureWave driver: N/A modules: mt7921e pcie: speed: Unknown lanes: 63
    link-max: gen: 6 speed: 64 GT/s bus-ID: 03:00.0 chip-ID: 14c3:7922
    class-ID: 0280
  IF-ID-1: eth0 state: up speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 13d3:3585
  Local Storage: total: 1.88 TiB used: 46.21 GiB (2.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 29.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Yangtze Memory
    model: ZHITAI Ti600 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: ZTA23001 temp: 39.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Aigo model: U331 size: 58.59 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 3.00
  ID-1: / raw-size: 907.22 GiB size: 891.9 GiB (98.31%) used: 42.3 GiB (4.7%)
    fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:9 label: N/A
    uuid: 6540b45f-7f3b-4e39-8700-8ce592f7bdce
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:8 label: N/A
    uuid: 895C-C5F9
  ID-3: /run/media/xhuxj/Aigo_USB raw-size: 58.59 GiB
    size: 58.59 GiB (100.00%) used: 3.91 GiB (6.7%) fs: ntfs dev: /dev/sda
    maj-min: 8:0 label: Aigo_USB uuid: 350C8ECA47502248
  ID-1: swap-1 type: partition size: 24 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p4 maj-min: 259:10 label: N/A
    uuid: 2340e626-c0ef-43a5-b450-6e31b9f4e33f
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 8AAE-3EB9
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 200.52 GiB fs: ntfs label: N/A
    uuid: EA12AEBD12AE8DDF
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 730 GiB fs: ntfs label: N/A
    uuid: 74AEAF19AEAED2C2
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 900 MiB fs: ntfs label: N/A
    uuid: 0094AF0494AEFB74
  ID-6: /dev/nvme1n1p1 maj-min: 259:7 size: 1024 KiB fs: <superuser required>
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Hub-2: 1-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 1-1.1:4 info: aigo U331 type: mass storage driver: usb-storage
    interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 100mA chip-ID: 3535:1234 class-ID: 0806 serial: <filter>
  Device-2: 1-5:3 info: IMC Networks Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 13d3:3585 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 2-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: SunplusIT HD Webcam type: video driver: uvcvideo
    interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 2b7e:b663 class-ID: 0e02 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Apple iPhone 5/5C/5S/6/SE/7/8/X/XR
    type: still imaging driver: ipheth,usbfs interfaces: 3 rev: 2.0
    chip-ID: 05ac:12a8 class-ID: 0601 serial: <filter>
  Hub-8: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 42.2 C mobo: N/A gpu: amdgpu temp: 39.0 C
  Fan Speeds (rpm): N/A
  Processes: 385 Power: uptime: 39m states: freeze,mem,disk suspend: s2idle
    image: 9.08 GiB services: gsd-power, power-profiles-daemon, upowerd
  Packages: pm: pacman pkgs: 1363 libs: 445 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0 Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: gnome-terminal inxi: 3.3.37
after
ls /lib/firmware/mediatek
BT_RAM_CODE_MT7922_1_1_hdr.bin   mt7650e.bin             mt7915_wa.bin                  mt7986_eeprom_mt7976_dbdc.bin  mt8173
BT_RAM_CODE_MT7961_1_2_hdr.bin   mt7662.bin              mt7915_wm.bin                  mt7986_eeprom_mt7976_dual.bin  mt8183
BT_RAM_CODE_MT7961_1a_2_hdr.bin  mt7662_rom_patch.bin    mt7916_eeprom.bin              mt7986_rom_patch.bin           mt8186
mt7601u.bin                      mt7662u.bin             mt7916_rom_patch.bin           mt7986_rom_patch_mt7975.bin    mt8192
mt7610e.bin                      mt7662u_rom_patch.bin   mt7916_wa.bin                  mt7986_wa.bin                  mt8195
mt7610u.bin                      mt7663_n9_rebb.bin      mt7916_wm.bin                  mt7986_wm.bin                  sof
mt7615_cr4.bin                   mt7663_n9_v3.bin        mt7925                         mt7986_wm_mt7975.bin           sof-tplg
mt7615_n9.bin                    mt7663pr2h.bin          mt7981_rom_patch.bin           mt7986_wo_0.bin                WIFI_MT7922_patch_mcu_1_1_hdr.bin
mt7615_rom_patch.bin             mt7663pr2h_rebb.bin     mt7981_wa.bin                  mt7986_wo_1.bin                WIFI_MT7961_patch_mcu_1_2_hdr.bin
mt7622_n9.bin                    mt7668pr2h.bin          mt7981_wm.bin                  mt7988                         WIFI_MT7961_patch_mcu_1a_2_hdr.bin
mt7622pr2h.bin                   mt7915_eeprom.bin       mt7981_wo.bin                  mt7988_wo_0.bin                WIFI_RAM_CODE_MT7922_1.bin
mt7622_rom_patch.bin             mt7915_eeprom_dbdc.bin  mt7986_eeprom_mt7975_dual.bin  mt7988_wo_1.bin                WIFI_RAM_CODE_MT7961_1a.bin
mt7650.bin                       mt7915_rom_patch.bin    mt7986_eeprom_mt7976.bin       mt7996                         WIFI_RAM_CODE_MT7961_1.bin
it seems to be a hit or miss with that device
Another thought - since you are dualbooting windows - you should ensure the Windows feature Fast Startup is disabled - it may lock the device if enabled.
Sorry for the late reply, because of work, in fact I own this device:
inxi -n
  Device-1: Motorcomm Micro. YT6801 Gigabit Ethernet driver: N/A
    driver: N/A
[xhuxj@xhuxj-wujie14x ~]$ sudo dmesg | grep mt7921e
[    5.330424] mt7921e 0000:03:00.0: Unable to change power state from D3cold to D0, device inaccessible
[    6.215714] mt7921e 0000:03:00.0: driver own failed
[    6.215747] mt7921e 0000:03:00.0: probe with driver mt7921e failed with error -5
more info: lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Phoenix IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Dummy Host Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Phoenix GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Phoenix GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Phoenix GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Phoenix GPP Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Dummy Host Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Dummy Host Bridge
00:04.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 19h USB4/Thunderbolt PCIe tunnel
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Internal GPP Bridge to Bus [C:A]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Internal GPP Bridge to Bus [C:A]
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Internal GPP Bridge to Bus [C:A]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Data Fabric; Function 7
01:00.0 Non-Volatile memory controller: Yangtze Memory Technologies Co.,Ltd Device 0081 (rev 01)
02:00.0 Ethernet controller: Motorcomm Microelectronics. YT6801 Gigabit Ethernet Controller (rev 01)
03:00.0 Network controller: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
04:00.0 Non-Volatile memory controller: Micron Technology Inc 2550 NVMe SSD (DRAM-less) (rev 01)
65:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Phoenix3 (rev c5)
65:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt Radeon High Definition Audio Controller
65:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Phoenix CCP/PSP 3.0 Device
65:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b9
65:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15ba
65:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 63)
65:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h/1ah HD Audio Controller
66:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Phoenix Dummy Function
66:00.1 Signal processing controller: Advanced Micro Devices, Inc. [AMD] AMD IPU Device
67:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Phoenix Dummy Function
67:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15c0
67:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15c1
67:00.6 USB controller: Advanced Micro Devices, Inc. [AMD] Pink Sardine USB4/Thunderbolt NHI controller #2
Did you check for that?
It seems to be crucial.
[SOLVED] No wifi appearing - Linux Mint Forums
yes i have checked
I haven’t encountered this issue for years now, either it’s been fixed, or it hasn’t happened because I haven’t been dual booting.
Still, I do recommend trying a cold boot, it can often solve many problems, like it did mine back then.
Same problem here.
I solved it by switching from kernel 6.12 to kernel 6.14.0-rc4-1-MANJARO.
I hope it will be useful for you
sudo pacman -Syu
fixes that
