MediaTek Device 7922 wifi not working
Laptop model is: ASUS ROG Strix G17 (2022) G713 or more specifically G713RW
lspci shows:
04:00.0 Network Controller: MEDIATEK Corp. Device 7922
dmesg shows:
mt7921e 0000:04:00.0: enabling device (0000 -> 0002)
mt7921e 0000:04:00.0: disabling ASPM L1
mt7921e 0000:04:00.0: ASIC revision: 79220010
mt7921e 0000:04:00.0: Message 2000008a (seq 2) timeout
mt7921e:  probe of 0000:04:00.0 failed with error -110
Kernel of install medium is 5.15.60-1-MANJARO
Edit: I think i discovered the reason, this card is only supported in kernel 5.17 or later. MediaTek MT7922 802.11ax PCI Express Wireless Network Adapter
However taht is for device 14c3:0616 my device id is 14c3:7922; could be it’s supported by the same driver though: Linux Kernel Driver DataBase: CONFIG_MT7921_COMMON:
Though that one claims to be from kernel 5.16 not 5.17.
Update: I have installed kernel 6.1 it still does not work, but fails differently:
 sudo dmesg | grep mt7921e         INT ✘
[    3.271823] mt7921e 0000:04:00.0: enabling device (0000 -> 0002)
[    3.272067] mt7921e 0000:04:00.0: ASIC revision: 79220010
[    6.556029] mt7921e 0000:04:00.0: Message 0004008a (seq 1) timeout
[    9.756218] mt7921e 0000:04:00.0: Message 0004008a (seq 2) timeout
[   12.955641] mt7921e 0000:04:00.0: Message 0004008a (seq 3) timeout
[   16.155640] mt7921e 0000:04:00.0: Message 0004008a (seq 4) timeout
[   19.355880] mt7921e 0000:04:00.0: Message 0004008a (seq 5) timeout
[   22.555643] mt7921e 0000:04:00.0: Message 0004008a (seq 6) timeout
[   25.756393] mt7921e 0000:04:00.0: Message 0004008a (seq 7) timeout
[   28.955595] mt7921e 0000:04:00.0: Message 0004008a (seq 8) timeout
[   32.155613] mt7921e 0000:04:00.0: Message 0004008a (seq 9) timeout
[   35.355589] mt7921e 0000:04:00.0: Message 0004008a (seq 10) timeout
[   35.433314] mt7921e 0000:04:00.0: hardware init failed
I solved that last error by doing a cold boot, seems it’s a known issue for this wifi/bluetooth chip. It’s performance also seems to be a bit up and down. Worst case i can swap it out for one with higher linux compatibility.
https://unix.stackexchange.com/questions/723828/mt7921e-00000900-0-hardware-init-failed
