Hello! I just bought a Minisforum HM90 computer, with a Mediatek MT7921K Wi-Fi card. This card is not recognized by the kernel, but I managed to make it work by following this answer on Ask Ubuntu : https://askubuntu.com/a/1378043
It was working properly until the last Manjaro update, when the card is again not recognized, although the files /etc/modprobe.d/rz608.conf and /etc/udev/rules.d/99-rz608.rules are present. I don’t really know how to fix this problem, can you help me?
System informations
Kernel: 5.15.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=83a9df42-1fe2-4b00-8253-672ff81e666a rw quiet splash apparmor=1
security=apparmor resume=UUID=bf3622ef-af65-4f57-baf7-f59e28a04234
udev.log_priority=3
Console: pty pts/1 wm: gnome-shell DM: GDM 41.3 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: BESSTAR TECH product: HM90 v: N/A serial: N/A
Mobo: BESSTAR TECH model: HM90 serial: N/A UEFI: American Megatrends
v: 5.16 date: 10/13/2021
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 11.18 GiB used: 5.32 GiB (47.6%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM 0 size: 4 GiB speed: 2667 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Micron Technology part-no: 4ATF51264HZ-2G6E1
serial: <filter>
Device-2: DIMM 0 size: 8 GiB speed: 2667 MT/s type: DDR4
total: 64 bits manufacturer: Samsung part-no: M471A1K43DB1-CTD
serial: <filter>
Info: model: AMD Ryzen 9 4900H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/3300 boost: enabled
base/boost: 3300/4450 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 105444
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Renoir driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
Display: server: X.org v: 1.21.1.3 compositor: gnome-shell driver:
gpu: amdgpu note: X driver n/a display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
Monitor-1: XWAYLAND0 mapped: HDMI-A-1 model: HP E272q serial: <filter>
built: 2016 res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2
size: 600x340mm (23.6x13.4") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.28-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Realtek
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid bus-ID: 5-3:2 chip-ID: 0d8c:0014
class-ID: 0300
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK driver: N/A pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 03:00.0 chip-ID: 14c3:0608 class-ID: 0280
Device-3: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: enp6s0f3u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Google Nexus/Pixel Device (MTP) type: USB driver: rndis_host
v: kernel bus-ID: 3-2:3 chip-ID: 18d1:4ee1 class-ID: 0a00 serial: <filter>
Device-2: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 5-4:3 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 119.24 GiB used: 29.94 GiB (25.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: ADHA0102 temp: 52.9 C scheme: GPT
ID-1: / raw-size: 106.65 GiB size: 104.42 GiB (97.91%)
used: 29.94 GiB (28.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 83a9df42-1fe2-4b00-8253-672ff81e666a
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: 8A17-9BCA
ID-1: swap-1 type: partition size: 12.29 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: bf3622ef-af65-4f57-baf7-f59e28a04234
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 1-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:3431 class-ID: 0900
Device-1: 1-1.3:3 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:3 info: Google Nexus/Pixel Device (MTP)
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 18d1:4ee1 class-ID: 0a00
serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-2:4 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:005c class-ID: 0300
Device-2: 5-3:2 info: C-Media Audio Adapter (Unitek Y-247A)
type: Audio,HID driver: cmedia_hs100b,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0014 class-ID: 0300
Device-3: 5-4:3 info: MediaTek Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Hub-7: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 26.0 C
Processes: 391 Uptime: 2h 40m wakeups: 11 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1216
pacman: 1207 lib: 346 flatpak: 9 Shell: Zsh (sudo) v: 5.8.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
