I have configured the MSM Notifications settings to only notify for new LTS kernels. I have noticed that it will pop-up a notication for any new kernel, like now when 5.16 hit the stable channel. As far as I know and can see 5.16 is not an LTS release. Anything I am missing here?
inxi system details
$ inxi -Fxzc0
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Cinnamon 5.2.7 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 13 7390 v: N/A
serial: <superuser required>
Mobo: Dell model: 0G2D0W v: A00 serial: <superuser required> UEFI: Dell
v: 1.12.1 date: 12/08/2021
ID-1: BAT0 charge: 49.3 Wh (100.0%) condition: 49.3/52.0 Wh (94.8%)
volts: 8.7 min: 7.6 model: SMP DELL G8VCF6C status: Full
Info: quad core model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB L2: 1024 KiB
L3: 8 MiB
Speed (MHz): avg: 741 high: 800 min/max: 400/4900 cores: 1: 700 2: 742
3: 800 4: 800 5: 789 6: 700 7: 700 8: 700 bogomips: 36812
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:2
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-2.3.3:6
Display: x11 server: X.Org 1.21.1.3 driver: loaded: modesetting
resolution: 1: 1920x1080~60Hz 2: 3840x2160~60Hz 3: 1600x1200~60Hz
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: Logitech HD Pro Webcam C920 type: USB
Device-3: Realtek USB Audio type: USB driver: snd-usb-audio
bus-ID: 5-2.3.4:7
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks driver: iwlwifi
v: kernel bus-ID: 02:00.0
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 6-2.4:4
IF: enp62s0u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-7:5
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: <filter>
Local Storage: total: 476.94 GiB used: 371.99 GiB (78.0%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC601 NVMe 512GB
size: 476.94 GiB temp: 39.9 C
ID-1: / size: 467.01 GiB used: 371.83 GiB (79.6%) fs: ext4 dev: /dev/dm-0
mapped: cryptroot
ID-2: /boot size: 968.3 MiB used: 129.6 MiB (13.4%) fs: ext4
dev: /dev/nvme0n1p2
ID-3: /boot/efi size: 499 MiB used: 36.8 MiB (7.4%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 43.0 C pch: 35.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 267 Uptime: 10m Memory: 15.33 GiB used: 3.04 GiB (19.8%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1729
Shell: Bash v: 5.1.16 inxi: 3.3.12
