I am getting notified once in a while about new Kernels being available via the “MSM Notifier”.
As I want to only use LTS kernels … how can I only be notified if LTS Kernel may be available and not (as happening at present) for any new available Kernels?
Theoretically, the notifier can be set to only notify new LTS kernels, or even LTS recommended kernels. But lately, i am notified of a new kernel outside that setting too…
Go to settings → click on manjaro notifier settings → thick check new kernels and
** only notify LTS kernels** , ApplyQuit .
But like @maycne.sonahoz said, I receive new kernel messages outside this setting. This started happening yesterday after the update. I am thinking of disabling MSM Notifier from startup, because it happens only at startup in my case, to see what will happen.
I will try with different settings and post back.
MSM Notifier disabled at start. → no messages all day.
MSM Notifier enabled at start
Options
Check new kernels
→ only notify recommended kernels. → no messages.
→ only notify LTS kernel && only notify recommended kernels. → no messages.
→ only notify LTS kernel. → message about new kernel although I am running 5.10 LTS.
