Hi eveyone!
I"m using a msi thin gf63 rtx 3050 laptop, i’ve installed nvidia package from pacman but i cannot run nvidia-smi it cannot comminucate with the grahpic card
here’s the output of
I’m using i3wm & x11
For one thing the kernel 6.5 is EOL and you should install a supported kernel like 6.6 LTS, boot into it, and remove 6.5
For another, please show
mhwd -li -l
To show what mhwd profile is in use and which are available, as mhwd is what handles drivers on manjaro.
And of course, please make sure you are fully up to date, ex:
sudo pacman-mirrors -f && sudo pacman -Syu
cscs:
mhwd -li -l
I did upgrade my kernel using mhwd-kernel now i’m running linux66.
Want to show a new inxi with the new kernel as well?
The original, as well as the mhwd output only show an intel.
Though the mhwd profile in use is a hybrid (prime) one.
If prime is working and there is a working nvidia, then you could test it like;
Normal execution (should output intel):
glxinfo | grep 'renderer string'
With prime-run (should output nvidia):
prime-run glxinfo | grep 'renderer string'
➜ ~ git:(master) glxinfo | grep 'renderer string'
OpenGL renderer string: Mesa Intel(R) Graphics (ADL GT2)
The outputs dont show any nvidia device.
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a3 class-ID: 0300
Device-2: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 5986:211b
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.13 compositor: Picom v: git-89c2c
driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 14.97 GiB unified: yes
Are you sure its in there?
And not disconnected?
Or disabled by BIOS?
What does this mean?
Maybe show us installed packages;
pacman -Qs nvidia
local/egl-wayland 2:1.1.13-1
EGLStream-based Wayland external platform
local/envycontrol 3.4.0-2
Easy GPU switching for Nvidia Optimus laptops
local/lib32-libvdpau 1.5-2
Nvidia VDPAU library
local/lib32-nvidia-utils 550.78-1
NVIDIA drivers utilities (32-bit)
local/lib32-vulkan-nouveau 1:24.0.6-1
Open-source Vulkan driver for Nvidia GPUs - 32-bit
local/libvdpau 1.5-2
local/libxnvctrl 550.78-1
NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 550.78-1
MHWD module-ids for nvidia 550.78
local/mhwd-nvidia-390xx 390.157-10
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.239.06-1
MHWD module-ids for nvidia 470.239.06
local/nvidia-dkms 550.78-1
NVIDIA drivers - module sources
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-settings 550.78-1
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 550.78-1
local/vulkan-nouveau 1:24.0.6-1
local/xf86-video-nouveau 1.0.17-3 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
I don’t think I disabled it, but I can check in BIOS. But I think it’s not recognized that’s the issue.
You shouldnt have this.
So you did install drivers the wrong way.
sudo pacman -Rns nvidia-dkms
sudo mhwd -f -i pci video-hybrid-intel-nvidia-prime
Then there is
al3rez:
envycontrol
Did you use envycontrol or try some other method to set iGPU only ?
probably i did experiment with prime-select or something yes i used it, i just chedked the history
envycontrol -s integrated
cscs:
mhwd -li -l
deleting
> Removing video-hybrid-intel-nvidia-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-hybrid-intel-nvidia-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
checking dependencies...
:: removing libxnvctrl breaks dependency 'libxnvctrl' required by conky
:: removing libxnvctrl breaks dependency 'libXNVCtrl.so=0-64' required by conky
Error: pacman failed!
Error: script failed!
breaks conky what should i do? remove conky?
cscs
22 May 2024 03:25
11
I guess so. You can reinstall it again afterwards.
We are just trying to get you on the correct packages (like linux66-nvidia, etc).
You will have the correct dependencies, but its technically uninstalling first.
That might explain it. Assuming there is a working nvidia to find that was there before.
sudo envycontrol -s hybrid
Will put you back in the normal ‘hybrid’ mode.
(By the way - this is how your system would be anyways by default without envycontrol. tools like envycontrol only provide you the ability to switch to iGPU-only or dGPU-only in an easy way)
ok now i did
sudo pacman -Rdd conky
and followed your commadns
what’s the next step?
cscs
22 May 2024 03:29
13
cscs:
(By the way - this is how your system would be anyways by default without envycontrol. tools like envycontrol only provide you the ability to switch to iGPU or dGPU only in an easy way)
After you switch modes reboot and check your inxi again.
If there is an nvidia visible then check prime-run
cscs:
When I restart my i3wm doens’t load my wm and it keeps blinking so I use to go to another tty7 and I can see there’s Nvidia 3050
https://termbin.com/ltif
what should I? not sure why the wm doesn’t load it keeps blinking here’s dmesg output
https://termbin.com/wf22
cscs
22 May 2024 03:50
17
The inxi does list an nvidia now, which is good.
I dont know a whole lot about particulars of nvidia itself, but some blackscreen type issues have been associated with KMS (or the lack thereof).
Hi,
Thanks, you too.
That can be ignored.
Have you enabled KMS?
This would probably have been handed down in pacnews, but here is the guide:
https://wiki.archlinux.org/title/Kernel_mode_setting#Early_KMS_start
Make sure that kms is included in the HOOKS and nvidia nvidia_modeset nvidia_uvm nvidia_drm is included in the MODULES of /etc/mkinitcpio.conf
Additionally for DRM KMS set nvidia_drm.fbdev=1 on the CMDLINE in /etc/default/grub.
After both both of those configurations run
sudo mk…
no i mean i cannot load my wm anymore when i turn on hybrid, i rebuilt the kms and modules and grub again but still no luck, any ideas?
cscs
22 May 2024 04:17
19
I understand that now with the nvidia no longer disabled you experience desktop errors.
I have mentioned KMS (and DRM-KMS) because they have been related to some nvidia issues. But I do not have an nvidia so I dont know all of their finer points. By the way the KMS instructions were not simply to rebuild intramfs but to ensure certain options are applied.
i see nouveau is loading in xorg how can i force to use nvidia?
cscs
22 May 2024 04:20
21
I highly doubt that is the issue and/or it is how you perceive it.
According to your inxi output for example the nvidia is set to use the proprietary module;
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Micro-Star MSI
driver: nvidia
Besides ensuring those paramaters like shown above my other guess would be another configuration left somewhere from previously. Like with envycontrol … have you placed any xorg configuration files or set any boot options? (and again there are probably boot options you should set, as linked above)
i added all the above link options, rebuild grub and HOOKS still no luck. I didnot change anything since I"M using Manjaro i3wm defaults.
