Moving /home huge mistake
Hi all,
I’ve tried to follow @Aragorn tutorial to move /home folder to another partition (Moving /home to second hdd - #2 by Aragorn) but did a huge mistake.
When following the command
systemd-mount -t ext4 -o sync /dev/sdb1 /mnt
I simply forgot to type /mnt at the end (actually didn’t see it because I was following with my smartphone and needed to slide the command to see the last part). If correctly done, I apparently should have had this outcome:
Started unit mnt.mount for mount point: /mnt
However, I got this and didn’t realise it was wrong:
Started unit run-media-system-Tales.mount for mount point /run/media/system/Tales
I moved on with all commands of the tutorial, including mv /home. The result is that I lost contact to my /home folder, not even know where it is now, if somewhere…
How can I fix this? I do need help…
If you check under /run/media/system/Tales/ do you see your files and folders?
It says “non existing file or folder”…
And your other drive is currently connected and mounted?
lsblk
mount
Now I’ve mounted sdb8. Then command /run/media/system/Tales/ returns:
bash: /run/media/system/Tales/: is a folder [or directory]
But I can’t see any list of files.
Can you provide the above output?
Because /run/media/system/Tales/ is not a command.
Do you mean that ls -lha /run/media/system/Tales/ returns an empty directory?
These are my partitions. /home is originally at sda2. Considering its size, all files and folders should be there.
That’s the size of the partition, not the space consumed.
This is what I get from this command.
Wait a second, you didn’t mv to /run/media/system/Tales/.
You still moved everything to /mnt/.
Check under /mnt/.
(And your /mnt/ path is still within the same original filesystem.)
These are my users. Can I already see light…?
You’re still good to go. But I’m thinking of a way to write out what you can do to proceed with minimal risk, since to be fair (and not trying to be mean), you might not have a full grasp on certain *nix concepts.
(Unless someone else wants to jump in.)
EDIT: I really, really mean that with sincerity. Everyone, including myself, started out not knowing even a sliver of anything related to Linux. :wink:
Yes, you see that I miss basic knowledge and I actually use Linux since several years… it’s laziness and a shame, indeed.
Before you continue, still need the output of:
mount
Also to confirm, /dev/sdb8 is the partition formatted as ext4 where you wish to re-locate /home ?
Correct, sdb8 is the goal.
Output of mount:
And this is for you to remember:
lsblk -o name,uuid
You need the UUID of /deb/sdb8 for later.
Sure, I still have it noted and it’s already in fstab.
Please show the contents of /etc/fstab anyways.
We need to play this safe…
(Do you know how to use nano?)
And before anything, unmount /dev/sdb8 for now.
umount /dev/sdb8
Here fstab:
I think I’m fine with nano lol.
O yes, unmounted sdb8.
Why do you have two entries for / ?
Is the second one supposed to be /home ?
You can use noatime instead of relatime as well.
