Move /home to another partition
After the stable updates 13 May, my PC and notebook were no longer running smoothly.
But this also means that I always learn something new.
Afterwards I decided to reinstall on the PC. But this time I had created an extra partition for my /home folder.
Which worked better than expected.
I only had to reinstall the missing programs.
Now to my notebook, I would like to shrink the partition I am using now and create a second one.
This should become my /home partition.
To do this, I thought Iâd copy my /home to an external hard drive.
Then boot with the manjaro-kde-24.0-minimal-240513-linux69.iso, depending on how to do that, shrink the partition and create a new one or delete the linux partition and create two new ones, one for / and one for /home and swap.
Or is it possible without a new installation?
Which I would much prefer.
I have already found some articles about this here, which have given me more confusion than I had before.
Also when searching outside, there was also an article that is probably already archived here, can we still access it?
To read?
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
ââsda1 ntfs Data <filter> 119,9G 87% /run/media/tony/Data
ââsda2 ntfs Recover <filter>
nvme0n1
âânvme0n1p1 vfat FAT32 <filter> 70,1M 27% /boot/efi
âânvme0n1p2
âânvme0n1p3 ntfs Boot <56789>
âânvme0n1p4 ext4 1.0 NVMe-NB <12345> 18,4G 87% /
âânvme0n1p5 swap 1 <0123> [SWAP]
Gives me the following.
The sda1 and sda2 remain as they are.
The nvme0n1p3 is the pre-installed Windows partition.
The nvme0n1p4 is the / and the /home.
The question is, how can I move the /home to another partition one without reinstalling?
If a new ISO comes out, where the current errors with NVIDIA and Wayland and other little things are fixed,
Iâll do a new installation.
Thanks and greetings
Tony
/home auf eine andere Partition umziehen
Nach den Stable Updates 13 May liefen mein PC und mein Notebook nicht mehr ganz Rund.
Was aber auch dazu fĂŒhrt, dass ich immer wieder was neues dazu lerne.
Nachher habe ich mich, am PC dazu entschieden Neuzuinstallieren. aber dieses mal hatte ich eine extra Partition fĂŒr mein /home Ordner erstellt.
Was besser als erwartet funktionierte.
Ich musste nur noch die fehlende Programme nachinstallieren.
Jetzt an meinen Notebook, wĂŒrde ich gerne die jetzt benutzte Partition verkleinern und eine zweite erstellen.
Diese sollte meine /home Partition werden.
Dazu dachte ich, werde ich mein /home auf eine externe Festplatte kopieren.
Dann mit der manjaro-kde-24.0-minimal-240513-linux69.iso booten, je nachdem wie das geht, die Partition verkleinern und eine neue erstellen oder die linux Partition löschen und zwei neue erstellen, eine fĂŒr / und eine fĂŒr /home und swap.
Oder geht das auch ohne Neuinstallation?
Was mir viel lieber wÀre.
Dazu habe ich hier schon einige Artikel gefunden, die haben mir mehr Verwirrung gegeben als ich vorher schon hatte. Bei der suche auĂerhalb, gab es z.B. auch ein Artikel der hier wohl schon Archiviert ist, kann man auf die noch zugreifen? Zum nachlesen?
lsblk -f
sda
nvme0n1
âânvme0n1p2
Gibt mir folgendes.
Die sda1 und sda2 bleiben wie sie sind.
Die nvme0n1p3 ist die vorinstallierte Windows Partition.
Die nvme0n1p4 ist die / und die /home.
Die frage ist, wie kann ich die /home auf eine andere umziehen ohne Neuinstallation?
Wenn mal eine Neue ISO heraus kommt, bei der, die jetzigen Fehler mit NVIDIA und Wayland und anderer Kleinigkeiten behoben sind mache ich eine Neuinstallation.
Danke und GruĂ
Tony
