https://youtu.be/RUfnVVZd05o
Hi! To show you guys the situation I recorded a video. When I move my cursor it is flickering like that. I am not sure is it about graphic drivers or hardware. I am using Logitech M705 v2 (not named as v2 but it is the new version) as mouse. If you need any information just tell me what is it and the command how to gather it. How can I fix this? Thanks for your helps.
Additional Infos;
I am using optimus-manager & optimus-manager-qt in nVidia mode. (Means no Integrated graphics running)
Kernel is linux512
Can’t think anything else to mention.
Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=3032a783-781b-492f-a89d-505ae0b95583 rw quiet apparmor=1
security=apparmor resume=UUID=c12c6fa0-4185-4ab7-b09b-f48c9251ce29
udev.log_priority=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MONSTER product: ABRA A7 V12.2 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: MONSTER model: ABRA A7 V12.2 serial: <filter> UEFI: INSYDE
v: 1.07.07TFB1 date: 05/12/2020
ID-1: BAT0 charge: 37.9 Wh (100.0%) condition: 37.9/40.1 Wh (94.5%)
volts: 16.5 min: 14.6 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0
model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 15.34 GiB used: 2.45 GiB (16.0%)
Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E0
cache: L2: 8 MiB bogomips: 40009
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 799 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep sgx
sgx_lc smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Device-1: Intel UHD Graphics vendor: CLEVO/KAPOK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-3: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04f2:b685 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: DP-0 res: 1920x1080 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
Monitor-2: eDP-1-1 res: 1920x1080 hz: 120 dpi: 128
size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: GeForce GTX 1650 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
Sound Server-2: JACK v: 1.9.18 running: no
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 6000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 0c:00.1
IF: enp12s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 506.76 GiB used: 47.5 GiB (9.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-00000
lanes: 4 rotation: SSD serial: <filter> rev: EXF7201Q scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade
size: 29.82 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.26 scheme: MBR
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 47.5 GiB (10.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 3032a783-781b-492f-a89d-505ae0b95583
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 03B0-9E1E
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: c12c6fa0-4185-4ab7-b09b-f48c9251ce29
ID-1: /dev/sda1 maj-min: 8:1 size: 29.78 GiB fs: exfat label: ventoy
uuid: AEED-6D7F
ID-2: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: E33B-A30A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-3.1:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-3.2:6 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Device-3: 1-3.3:7 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 2516:0042 class-ID: 0301
Device-4: 1-8:3 info: Chicony Chicony USB2.0 Camera type: Video
Device-5: 1-14:5 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-3:2 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 40.0 C mobo: 0 C gpu: nvidia temp: 41 C
Fan Speeds (RPM): cpu: 2439
Processes: 276 Uptime: 17m wakeups: 3 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1315 lib: 352
flatpak: 0 Shell: Bash v: 5.1.4 running-in: konsole inxi: 3.3.04
Here it is. Anything else you need, sir?
Now that I realized something. It is been 8 hours my laptop is shutdown and there is no flickering. Now I will test is this thing happening after a while or just shutting down was enough. Still, if you need something to diagnose, ask me. Thanks.
Fabby
16 May 2021 14:21
5
If it re-occors use, 5.10 LTS first and then 5.4.
Also, check if there are any BIOS / UEFI firmware updates for your:
There is a really high possibility of new UEFI firmware but they want me to send my laptop to them for update. (Ugh) There is lockdown etc. so I have to wait for a while. (I guess it ends tomorrow) Will send laptop probably this weekend. Thanks for suggestion.
Fabby
16 May 2021 14:52
7
They should be able to adhere to local COVID-19 rules and have you update the firmware yourself…
If Acer, Dell, HP, Lenovo, … can do this, why not MONSTER??? You should only ever have to go in if you mess up the update!
I made a research on the net and people says they are providing files if I contact them via mail. (I did a few minutes ago.) But there is a problem. The laptop I use is just a Clevo laptop with Monster brand and as far as I know Clevo only provides updater for Windows. Sooo I guess I will probably dual-boot Windows or create a new forum topic about what can I do. If you are interested I can send you the link of topic if I create one.
Fabby
16 May 2021 16:48
9
That has to be on a Windows or Clevo forum though as Windows is off-topic here…
P.S. I don’t have the same kind of hardware you do, though…
I meant a topic about how can I make it work with Linux/Manjaro KDE. :=)
