so i finally moved into kernel 5.15.7 as my daily-driver and everything is normal.
i’ve been looking forward to using “ntfs3” mod. basically i only mount NTFS partitons using dolphin when i need to. so i need them to be mounted in ntfs3 instead of ntfs-3g like it happens upto now. a quick reference to arch-wiki has two ways (udev rules vs udisks) of default mounting with it recommending neither. after looking at the current issues, i chose udisk mount overriding with;
ntfs_defaults=uid=$UID,gid=$GID,noatime,prealloc
everything works, no errors thrown. just that mounting process seems to be taking longer than it did with ntfs-3g.
do you guys think i should wait for things to mature a bit and then to move to ntfs3 permanently or is this all normal or are there better ways of doing this.
with the current overriding of udisk, if i boot into kernel 5.10 will this fail
