I would like to mount my external drive to /mnt instead of /run/media.
The problem is, that my file explorer cannot open the /run directory, hence I would like to move to another dir. Apparently it mounts the device automatically as root if I understood that correctly?
Is there a simple solution to make the /run folder available for my user or to change the mount location?
Thank you for the resources. Kind of looking for a spoonfeed here though, if I’m being honest. Just need to know if there’s a simple solution, because I need it fast…
