Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=9f797653-0dff-400e-b841-7fd75a7d2e6c rw quiet amd_iommu=on
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE V2 v: x.x
serial: <superuser required> UEFI: American Megatrends v: F1
date: 08/14/2020
RAM: total: 15.57 GiB used: 4.19 GiB (26.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113)
stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2201 high: 2247 min/max: 2200/4630 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2195 2: 2200
3: 2196 4: 2196 5: 2200 6: 2193 7: 2247 8: 2200 9: 2199 10: 2196 11: 2196
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 115026
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Gigabyte
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-07)
arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 10de:2182
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-2 model: VG249Q1R serial: <filter> built: 2020
res: 1920x1080 dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 595mm (23.4") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: NV168 v: 4.3 Mesa 22.1.6 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 07:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.56 running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:2
Local Storage: total: 2.27 TiB used: 939.95 GiB (40.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 373.08 GiB
(81.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9f797653-0dff-400e-b841-7fd75a7d2e6c
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: F583-F7CF
ID-3: /mnt/media raw-size: 1.7 TiB size: 1.68 TiB (98.37%) used: 566.86
GiB (33.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 36dc0e7e-bd73-42c2-ae0b-f6f1bb2a7657
ID-1: /dev/sda2 maj-min: 8:2 size: 119.21 GiB fs: ntfs label: N/A
uuid: 5A7BACD61415CB4E
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-9:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-3:2 info: Elan Micro Gaming KB type: Keyboard
power: 100mA chip-ID: 04f3:152e class-ID: 0301
Device-2: 5-4:3 info: Trust GXT 133 Gaming Mouse type: Mouse,Keyboard
power: 100mA chip-ID: 145f:026e class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.9 C mobo: N/A gpu: nouveau temp: 30.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 853
Processes: 356 Uptime: 33m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pacman: 1685 lib: 501 Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20```
Every time I try and open a game (Apex Legends for example), it'll launch, stop at some point, and crash. Tried asking in the Manjaro discord server, got nothing as of me writing this. I have no idea what to do now, this is the first time something like that has happened to me. Also keep in mind that I'm not exactly linux-savvy, so any directions will have to be as detailed as you can make them. Any help appreciated, and thanks in advance.
You’ll want the proprietary NVIDIA driver installed for gaming. You currently have the reverse engineered, open-source driver installed.
See Configure NVIDIA (non-free) settings and load them on Startup - Manjaro
Typed in
sudo mhwd -a pci nonfree 0300
got this:
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
community downloading...
multilib downloading...
error: target not found: linux414-nvidia
Error: pacman failed!
Error: script failed!
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
linux414 and companion packages are no longer in the repositories. The oldest available kernel is 419.
Remove the 4.14 kernel and all other unsupported kernels before trying to install the nvidia driver.
I deleted all old versions, installed the new drivers, rebooted, fired up apex, and it works. Thanks to you, smart people.
Can you post mhwd-kernel -li ?
