Hi!
My monitor doesn’t show anything through DP-1 after (I think) an update.
I use a TV (HDMI-2) and a monitor (DP-1) … sometimes one, sometimes the other, sometimes both at the same time.
I have looked many posts and I’m going to add the information I’ve seen that it’s important.
xrandr returns
Screen 0: minimum 320 x 200, current 3840 x 2160, maximum 16384 x 16384
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 1600mm x 900mm
3840x2160 30.00*+ 25.00 24.00 29.97 23.98
4096x2160 30.00 25.00 24.00 29.97 23.98
1920x1080 120.00 100.00 119.88 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
1920x1080i 60.00 50.00 59.94
1280x1024 60.02
1360x768 60.02
1280x720 60.00 50.00 59.94
1024x768 60.00
800x600 60.32
720x576 50.00
720x576i 50.00
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
kscreen-console returns
START: Requesting Config
Received config. Took 4 milliseconds
Screen:
maxSize: QSize(16384, 16384)
minSize: QSize(320, 200)
currentSize: QSize(3840, 2160)
Type: "DisplayPort"
Connected: false
Type: "HDMI"
Connected: false
Type: "HDMI"
Connected: true
Enabled: true
Priority: 1
Rotation: KScreen::Output::None
Pos: QPoint(0,0)
MMSize: QSize(1600, 900)
FollowPreferredMode: false
Scale: 1
Clones: None
Mode: "69"
Preferred Mode: "69"
Preferred modes: QList("69")
Modes:
"1249" "" QSize(4096, 2160) 30
"1250" "" QSize(4096, 2160) 25
"1251" "" QSize(4096, 2160) 24
"1252" "" QSize(4096, 2160) 29.97
"1253" "" QSize(4096, 2160) 23.976
"1254" "" QSize(1920, 1080) 120
"1255" "" QSize(1920, 1080) 100
"1256" "" QSize(1920, 1080) 119.88
"1257" "" QSize(1920, 1080) 50
"1258" "" QSize(1920, 1080) 50
"1259" "" QSize(1920, 1080) 25
"1260" "" QSize(1920, 1080) 24
"1261" "" QSize(1920, 1080) 23.9761
"1262" "" QSize(1360, 768) 60.0152
"1263" "" QSize(1280, 720) 50
"1264" "" QSize(720, 576) 50
"1265" "" QSize(720, 576) 50
"1266" "" QSize(720, 400) 70.0817
"69" "" QSize(3840, 2160) 30
"70" "" QSize(3840, 2160) 25
"71" "" QSize(3840, 2160) 24
"72" "" QSize(3840, 2160) 29.97
"73" "" QSize(3840, 2160) 23.976
"75" "" QSize(1920, 1080) 60
"76" "" QSize(1920, 1080) 59.9402
"77" "" QSize(1920, 1080) 60
"78" "" QSize(1920, 1080) 30
"79" "" QSize(1920, 1080) 59.9402
"80" "" QSize(1920, 1080) 29.9701
"82" "" QSize(1280, 1024) 60.0197
"84" "" QSize(1280, 720) 60
"85" "" QSize(1280, 720) 59.9402
"86" "" QSize(1024, 768) 60.0038
"87" "" QSize(800, 600) 60.3165
"88" "" QSize(720, 480) 60
"89" "" QSize(720, 480) 59.9401
"90" "" QSize(640, 480) 60
"91" "" QSize(640, 480) 59.9405
EDID Info:
Device ID: "xrandr-LG Electronics-LG TV SSCR2-16843009"
Name: "LG TV SSCR2"
Vendor: "LG Electronics"
Serial: "16843009"
EISA ID: ""
Hash: "9e8371f7ae3d1fbe9aed228324fb1859"
Width: 160
Height: 90
Gamma: 2.2
Red: QQuaternion(scalar:1, vector:(0.639648, 0.328125, 0))
Green: QQuaternion(scalar:1, vector:(0.299805, 0.599609, 0))
Blue: QQuaternion(scalar:1, vector:(0.150391, 0.0595703, 0))
White: QQuaternion(scalar:1, vector:(0.3125, 0.329102, 0))
inxi -Faz returns …
Kernel: 6.1.131-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=683125e2-1176-4786-a706-ca0a8836841d rw quiet
resume=UUID=5e31802a-970e-4d5e-83d7-114511d2b96c apparmor=1
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z390-E GAMING v: Rev 1.xx
serial: <superuser requiredpart-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 1302 date: 09/02/2019
Info: model: Intel Core i9-9900 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x102
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 99237
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1015x571mm (39.96x22.48")
s-diag: 1165mm (45.85")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: LG (GoldStar) TV SSCR2
serial: <filterbuilt: 2024 res: mode: 3840x2160 hz: 30 scale: 100% (1)
dpi: 61 gamma: 1.2 size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3")
ratio: 16:9 modes: max: 3840x2160 min: 720x400
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e98 memory: 15.23 GiB unified: yes
API: Vulkan v: 1.4.304 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: N/A device-ID: 8086:3e98
surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
API: ALSA v: k6.1.131-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: down mac: <filter>
IF-ID-1: surfshark_ipv6 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: surfshark_wg state: unknown speed: N/A duplex: N/A mac: N/A
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3
Local Storage: total: 32.4 TiB used: 26.76 TiB (82.6%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Kingston model: SNV3S1000G
lanes: 4 tech: SSD serial: <filterfw-rev: ERFK1N.3 temp: 30.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filterfw-rev: 1B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WUH721414ALE6L4 size: 12.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: W07G scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST12000DM0007-2GR116
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filterfw-rev: DN01 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Hitachi model: HDS5C4040ALE630
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5700 serial: <filterfw-rev: A250 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 vendor: Kingston model: DataTraveler 3.0
size: 115.59 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 128 GiB size: 125.43 GiB (97.99%) used: 73.03 GiB (58.2%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 640 MiB size: 638.7 MiB (99.80%)
used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 32 GiB used: 144.5 MiB (0.4%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB available: 31.19 GiB used: 4.98 GiB (16.0%)
Processes: 336 Power: uptime: 24m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1701 libs: 445 tools: pamac,yay Compilers:
gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
xrandr --listmonitors returns …
Monitors: 1
0: +*HDMI-2 3840/1600x2160/900+0+0 HDMI-2
kscreen-doctor output.DP-1.enable returns …
Enabling output 65
but it solves nothing, because it still shows “not connected”.
If I connect the monitor using the HDMI cable works OK.
If I connect the monitor using the DPI with other computer works OK.
So the monitor and the cables are OK.
Any idea?
Thanks in advance!
