journalctl -f
Have also tried to change the audio output from HDMI to the laptop (as it changes the alsa output when the monitor switches off, but that also doesn’t change a thing, still the same…
May 22 23:52:25 radomir plasmashell[1397]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_04_00.1.hdmi-stereo"
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Output: 84
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Property: EDID
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: State (newValue, Deleted): 1
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: RRNotify_OutputChange
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 80
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Mode: 98
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Rotation: "Rotate_0"
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Connection: "Disconnected"
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Subpixel Order: 0
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: RRScreenChangeNotify
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Window: 50331657
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Root: 1742
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Size ID: 65535
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Size: 4480 1440
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: SizeMM: 1185 381
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: XRandROutput 84 update
m_connected: 0
m_crtc XRandRCrtc(0x557f3632b470)
CRTC: 80
MODE: 98
Connection: 1
Primary: false
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Output 84 : connected = false , enabled = true
m_connected: 1
CRTC: 80
MODE: 98
Connection: 1
Primary: false
May 22 23:52:37 radomir plasmashell[1397]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:30: TypeError: Cannot read property 'enabledBorders' of null
May 22 23:52:37 radomir plasmashell[1397]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:121: TypeError: Cannot read property 'x' of null
May 22 23:52:37 radomir plasmashell[1397]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:135: TypeError: Cannot read property 'y' of null
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Emitting configChanged()
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Connection: "Connected"
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: RRNotify_CrtcChange
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 79
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Mode: 86
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Geometry: 2560 360 1920 1080
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Geometry: 0 0 2560 1440
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 81
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Mode: 0
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Geometry: 0 0 0 0
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 82
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Output: 83
m_connected: 1
CRTC: 80
MODE: 98
Connection: 0
Primary: false
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Connected output 84 to CRTC 80
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Output 84 : connected = true , enabled = true
m_connected: 0
CRTC: 80
MODE: 98
Connection: 0
Primary: false
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: XRandROutput 83 update
m_connected: 0
m_crtc XRandRCrtc(0x557f36323820)
CRTC: 79
MODE: 86
Connection: 0
Primary: true
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Output 83 : connected = true , enabled = true
m_connected: 0
CRTC: 80
MODE: 98
Connection: 0
Primary: false
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: XRandR::setConfig
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Requested screen size is QSize(1920, 1080)
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Needed CRTCs: 1
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Actions to perform:
Primary Output: false
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Change Screen Size: true
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Old: QSize(4480, 1440)
Intermediate: QSize(4480, 1440)
New: QSize(1920, 1080)
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Disable outputs: true
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: (84)
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Change outputs: true
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: (83)
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Enable outputs: false
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: RRSetCrtcConfig (disable output)
CRTC: 80
May 22 23:52:37 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Result: 0
m_connected: 0
CRTC: 0
MODE: 0
Connection: 0
Primary: false
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Disconnected output 84 from CRTC 80
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: RRSetCrtcConfig (change output)
Output: 83 ( "eDP" )
CRTC: 79
Pos: QPoint(0,0)
Mode: 86 KScreen::Mode(Id: "86" , Size: QSize(1920, 1080) @ 60.042 )
Rotation: KScreen::Output::None
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Result: 0
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: XRandROutput 83 update
m_connected: 0
CRTC: 79
MODE: 86
Connection: 0
Primary: true
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: RRSetScreenSize
DPI: 96
SizeMM: QSize(508, 285)
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: XRandR::setConfig done!
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: RRNotify_CrtcChange
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 80
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Mode: 0
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Rotation: "Rotate_0"
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Geometry: 0 0 0 0
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: RRNotify_OutputChange
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Output: 84
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 0
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Connection: "Connected"
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Subpixel Order: 0
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: RRScreenChangeNotify
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Window: 50331657
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Root: 1742
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Size ID: 65535
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Size: 4480 1440
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: SizeMM: 1185 381
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 79
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Mode: 86
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Geometry: 0 0 1920 1080
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Size ID: 0
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Size: 1920 1080
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: SizeMM: 508 285
May 22 23:52:38 radomir plasmashell[1397]: trying to show an empty dialog
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: XRandROutput 84 update
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Output 84 : connected = true , enabled = false
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
May 22 23:52:38 radomir plasmashell[1397]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:121: TypeError: Cannot read property 'x' of null
May 22 23:52:38 radomir plasmashell[1397]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:135: TypeError: Cannot read property 'y' of null
May 22 23:52:38 radomir kwin_x11[1330]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28047, resource id: 33555803, major code: 18 (ChangeProperty), minor code: 0
May 22 23:52:38 radomir kwin_x11[1330]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28048, resource id: 33555803, major code: 20 (GetProperty), minor code: 0
May 22 23:52:38 radomir plasmashell[1397]: qt.qpa.xcb: QXcbConnection: XCB error: 148 (Unknown), sequence: 22822, resource id: 0, major code: 140 (Unknown), minor code: 20
May 22 23:52:38 radomir kwin_x11[1330]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28142, resource id: 33555803, major code: 15 (QueryTree), minor code: 0
May 22 23:52:38 radomir kwin_x11[1330]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28217, resource id: 15034670, major code: 18 (ChangeProperty), minor code: 0
May 22 23:52:38 radomir krunner[4543]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17021, resource id: 33555803, major code: 3 (GetWindowAttributes), minor code: 0
May 22 23:52:38 radomir krunner[4543]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17022, resource id: 33555803, major code: 2 (ChangeWindowAttributes), minor code: 0
May 22 23:52:38 radomir yakuake[2351]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26524, resource id: 33555803, major code: 3 (GetWindowAttributes), minor code: 0
May 22 23:52:38 radomir yakuake[2351]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26525, resource id: 33555803, major code: 2 (ChangeWindowAttributes), minor code: 0
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Requested screen size is QSize(4480, 1440)
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Needed CRTCs: 2
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Actions to perform:
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Change Screen Size: true
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Old: QSize(1920, 1080)
New: QSize(4480, 1440)
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Disable outputs: false
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Change outputs: true
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: (83)
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Enable outputs: true
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: (84)
DPI: 96
SizeMM: QSize(1185, 381)
CRTC: 79
Pos: QPoint(2560,360)
m_connected: 0
CRTC: 79
MODE: 86
Connection: 0
Primary: true
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: QMap((79, XRandRCrtc(0x557f36323820))(80, XRandRCrtc(0x557f3632b470))(81, XRandRCrtc(0x557f361f4790))(82, XRandRCrtc(0x557f36322fa0)))
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Testing CRTC 79
Free: false
Mode: 86
Possible outputs: QVector(83, 84)
Connected outputs: QVector(83)
Geometry: QRect(2560,360 1920x1080)
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Testing CRTC 80
Free: true
Mode: 0
Connected outputs: QVector()
Geometry: QRect(0,0 0x0)
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: RRSetCrtcConfig (enable output)
Output: 84 ( "HDMI-A-0" )
New CRTC: 80
Pos: QPoint(0,0)
Mode: KScreen::Mode(Id: "98" , Size: QSize(2560, 1440) @ 99.9985 ) Preferred: "95"
m_connected: 0
m_crtc QObject(0x0)
CRTC: 80
MODE: 98
Connection: 0
Primary: false
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Connected output 84 to CRTC 80
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Geometry: 2560 360 1920 1080
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Mode: 98
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Geometry: 0 0 2560 1440
May 22 23:52:38 radomir rtkit-daemon[1482]: Supervising 7 threads of 3 processes of 1 users.
May 22 23:52:38 radomir rtkit-daemon[1482]: Successfully made thread 89296 of process 1461 owned by '1000' RT at priority 5.
May 22 23:52:38 radomir rtkit-daemon[1482]: Supervising 8 threads of 3 processes of 1 users.
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 81
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: CRTC: 82
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xcb.helper: Output: 83
m_connected: 0
CRTC: 80
MODE: 98
Connection: 0
Primary: false
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Output 84 : connected = true , enabled = true
m_connected: 0
CRTC: 80
MODE: 98
Connection: 0
Primary: false
m_connected: 0
CRTC: 79
MODE: 86
Connection: 0
Primary: true
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Output 83 : connected = true , enabled = true
m_connected: 0
CRTC: 80
MODE: 98
Connection: 0
Primary: false
May 22 23:52:38 radomir plasmashell[1397]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/osd/Osd.qml:35:15: QML OsdItem: Binding loop detected for property "width"
May 22 23:52:38 radomir plasmashell[1397]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
May 22 23:52:38 radomir kscreen_backend_launcher[1606]: kscreen.xrandr: Emitting configChanged()
