I downgraded NetworkManager by one version and with this Modem-Manager-GUI it started working normally again.
So when updating the system to the latest version, we forgot to adjust the NM versus MM collaboration.
This should be fixed as soon as possible, Modem-Manager-GUI is an excellent and useful application in any modem laptop.
~ inxi -Sxxx0
Host: lifebook Kernel: 5.10.93-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
~ lsusb
Bus 002 Device 006: ID 1199:9011 Sierra Wireless, Inc. MC8305 Modem
Bus 002 Device 005: ID 0489:e031 Foxconn / Hon Hai BCM20702A0
Bus 002 Device 007: ID 0b97:7772 O2 Micro, Inc. OZ776 CCID Smartcard Reader
Bus 002 Device 004: ID 0b97:7761 O2 Micro, Inc. Oz776 1.1 Hub
Bus 002 Device 003: ID 04f2:b240 Chicony Electronics Co., Ltd FJ Camera
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 046d:c06c Logitech, Inc. Optical Mouse
Bus 001 Device 003: ID 08ff:2683 AuthenTec, Inc. Fingerprint Sensor
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Yes, I have the full latest update. No, I have not ignored any package.
It really came spontaneously after the last system update and in order to use the MM-GUI, I have to downgrade NetwokManager by one version, that’s enough.
I was still looking for this error and found that the MM-GUI starts normally when the SIM card is removed.
And then I noticed that someone had already reported the bug:
I also used another LTE modem, Quectel EC25-E miniPCIe, ModemManager-Gui reports the same error. So for now, I have to use it with a lower version of NetworkManager, 1.24. It works well.
It needs to be fixed as soon as possible, thanks.
Modem manager gui is an abandoned project. You should not ruin your system by selectively downgrading other stuff to make it work.
There is an AUR project modem-manager-gui-hg that takes the now 4 year old source and patches it, there is of course no guarantee how long will this still work, since the original code relies on old libraries versions…and it will break again at some point in the future.
