Mobile to usb keeps disconnecting
This is about mobile to laptop usb connection. It keeps disconnecting! I have a redmi 10 prime. I thought its a mobile problem until I tested with windows. It does disconnect there as well but only at about 5mins intervals and sometimes never. On manjaro it keeps disconnecting and reconnecting! Continuously! Until it stops showing up at all. I can’t access the the files in it. It is charging tho(phone is in file transfer mode). It is specific to the phone though but considering the difference in how windows reacts I thought I should ask. If you know the solution or encountered this problem please help.
Edit: Found something! Don’t know what it means but if you do pls tell me.
[  184.289377] audit: type=1105 audit(1643272332.166:110): pid=1583 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
dave@asus:~ $ sudo dmesg -c
[  184.314166] audit: type=1106 audit(1643272332.193:111): pid=1583 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  184.314264] audit: type=1104 audit(1643272332.193:112): pid=1583 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  193.171704] usb 1-3: new high-speed USB device number 17 using xhci_hcd
[  193.295049] usb 1-3: device descriptor read/64, error -32
[  193.525030] usb 1-3: Device not responding to setup address.
[  193.731746] usb 1-3: Device not responding to setup address.
[  193.938225] usb 1-3: device not accepting address 17, error -71
[  194.268147] usb 1-3: new high-speed USB device number 18 using xhci_hcd
[  194.410581] usb 1-3: New USB device found, idVendor=2717, idProduct=ff48, bcdDevice= 4.04
[  194.410588] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  194.410593] usb 1-3: Product: Redmi 10 Prime
[  194.410596] usb 1-3: Manufacturer: Xiaomi
[  194.410599] usb 1-3: SerialNumber: 018fd4250505
[  194.448004] usb 1-3: USB disconnect, device number 18
[  194.741388] usb 1-3: new high-speed USB device number 19 using xhci_hcd
[  195.157083] usb 1-3: New USB device found, idVendor=2717, idProduct=ff48, bcdDevice= 4.04
[  195.157090] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  195.157094] usb 1-3: Product: Redmi 10 Prime
[  195.157096] usb 1-3: Manufacturer: Xiaomi
[  195.157098] usb 1-3: SerialNumber: 018fd4250505
[  195.320995] usb 1-3: USB disconnect, device number 19
[  195.614543] usb 1-3: new high-speed USB device number 20 using xhci_hcd
[  195.737917] usb 1-3: Device not responding to setup address.
[  195.944520] usb 1-3: Device not responding to setup address.
[  196.124198] audit: type=1101 audit(1643272344.002:113): pid=1625 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="dave" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  196.125375] audit: type=1110 audit(1643272344.005:114): pid=1625 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  196.132848] audit: type=1105 audit(1643272344.012:115): pid=1625 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
What I get for plugging it in:
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[1024.886665] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1024.894931] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1024.895200] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1024.895292] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1024.928942] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1024.933297] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1024.935652] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1024.940353] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1025.283616] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1025.283768] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1025.283909] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1025.285987] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1025.286259] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1025.287017] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1025.287268] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1025.289801] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1025.291954] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1025.301181] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1025.994134] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1026.002899] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1026.003287] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1026.003431] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1026.033408] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1026.039862] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1026.040130] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1026.044997] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1026.155487] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1026.155609] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1026.155719] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1026.157679] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1026.157805] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1026.159019] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1026.159378] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1026.161505] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1026.164600] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1026.172147] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1027.664145] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1027.670823] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1027.671162] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1027.671292] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1027.704722] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1027.709978] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1027.710923] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1027.716098] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1027.969822] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1027.969943] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1027.970048] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1027.972854] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1027.973227] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1027.974006] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1027.974215] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1027.976053] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1027.979250] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1027.991954] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1029.467488] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1029.475204] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1029.475598] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1029.475721] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1029.504796] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1029.509381] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1029.511296] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1029.516102] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1029.715992] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1029.716108] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1029.716201] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1029.717880] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1029.718045] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1029.719562] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1029.719872] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1029.722740] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1029.725782] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1029.737552] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1030.420758] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1030.426988] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1030.427314] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1030.427438] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1030.458235] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1030.463091] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1030.464267] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1030.468872] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1030.656306] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1030.656430] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1030.656503] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1030.656588] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1030.657866] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1030.658098] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1030.658543] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1030.659432] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1030.660858] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1030.661701] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1030.665206] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1030.677396] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1032.167446] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1032.175023] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1032.175347] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1032.175473] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1032.203726] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1032.209063] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1032.209798] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1032.215491] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1032.403889] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1032.403998] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1032.404079] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1032.405963] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1032.406203] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1032.407237] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1032.407663] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1032.410096] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1032.413438] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1032.423301] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1033.918157] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1033.927092] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1033.927420] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1033.927533] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1033.951284] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1033.955420] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1033.955671] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1033.959357] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1034.219936] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1034.220040] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1034.220144] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1034.222150] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1034.222425] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1034.222563] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1034.222764] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1034.225174] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1034.227542] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1034.239277] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1035.727819] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1035.735136] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1035.735467] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1035.735595] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1035.762390] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1035.767594] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1035.768358] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1035.773365] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1035.963303] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1035.963452] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1035.963552] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1035.966137] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1035.966419] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1035.966582] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1035.966917] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1035.969578] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1035.972900] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1035.982964] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1037.441134] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1037.447201] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1037.447524] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1037.447653] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1037.480151] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1037.484486] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1037.484837] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1037.488086] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1037.776546] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1037.776668] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1037.776786] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1037.778099] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1037.778236] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1037.779236] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1037.779585] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1037.781538] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1037.783722] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1037.794027] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1039.287851] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1039.295297] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1039.295620] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1039.295726] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1039.321983] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1039.325319] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1039.326112] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1039.329245] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1039.590169] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1039.590298] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1039.590425] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1039.592722] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1039.593339] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1039.595625] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1039.596005] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1039.596158] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1039.599462] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1039.611898] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1040.271097] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1040.279527] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1040.279884] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1040.279974] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1040.307435] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1040.313563] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1040.313914] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1040.319620] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1040.463219] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1040.463334] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1040.463450] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1040.465477] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1040.466640] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1040.466932] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1040.467243] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1040.468440] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1040.471891] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1040.482739] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1041.961279] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1041.967441] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1041.967771] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1041.967933] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1042.001201] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1042.006296] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1042.008008] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1042.012842] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1042.276256] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1042.276370] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1042.276481] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1042.279131] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1042.279407] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1042.279528] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1042.279738] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1042.282762] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1042.286157] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1042.296260] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1043.754546] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1043.763527] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1043.763795] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1043.763925] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1043.796248] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1043.801374] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1043.801583] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1043.806884] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1044.090531] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1044.090671] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1044.090764] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1044.093376] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1044.093741] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1044.095349] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1044.095506] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1044.096291] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1044.100190] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1044.110351] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1045.568099] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1045.576096] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1045.576370] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1045.576485] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1045.606531] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1045.610572] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1045.613393] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1045.619551] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1045.904447] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1045.904625] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1045.904761] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1045.906561] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1045.906720] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1045.908191] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1045.908490] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1045.911313] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1045.914744] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1045.926706] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1046.611308] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1046.619636] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1046.619900] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1046.620023] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1046.651653] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1046.656371] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1046.658107] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1046.663256] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1046.776194] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1046.776321] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1046.776430] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1046.778689] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1046.778868] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1046.779298] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1046.779524] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1046.781979] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1046.785111] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1046.797039] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1048.311286] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1048.319738] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1048.319999] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1048.320149] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1048.351280] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1048.356619] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1048.357666] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1048.363066] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1048.589814] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1048.589939] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1048.590055] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1048.590484] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1048.590619] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1048.592576] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1048.593352] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1048.594741] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1048.597954] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1048.609122] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1050.093958] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1050.099882] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1050.100200] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1050.100328] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1050.124396] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1050.128958] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1050.130488] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1050.133690] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1050.405672] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1050.405854] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1050.405971] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1050.406935] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1050.407060] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1050.408234] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1050.408569] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1050.411391] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1050.415058] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1050.425575] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1051.111189] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1051.119745] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1051.120092] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1051.120210] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1051.149111] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1051.152395] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1051.153871] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1051.159572] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1051.275937] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1051.276058] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1051.276153] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1051.279312] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1051.279509] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1051.279711] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1051.279799] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1051.282013] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1051.285273] unbind   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1051.295017] remove   /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1052.980708] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
KERNEL[1052.988270] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
KERNEL[1052.988529] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
KERNEL[1052.988658] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1053.014212] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
UDEV  [1053.017698] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1 (usb)
UDEV  [1053.017980] add      /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0 (usb)
UDEV  [1053.021590] bind     /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2 (usb)
All the cables I used were mi’s fast charging cables which seem to have been a factor. When I switched to a regular one it worked as expected for a while but it’s still connecting and disconnecting a bunch of times! Windows works perfectly for some reason.
See this wiki page about android tethering and provide basic Information:
This would help if it wasn’t for the laptop not picking up the phone at all after it automatically connects and disconnects a bunch of times. It pretends that it isn’t there.
Try with different USB cables. Not all USB cables are created equal!
Note that cheap cable does not always means bad cable and an expensive cable will not always be better than a cheap cable.
I tried with a lot of cables and with other devices. All of them work except for this phone with manjaro! Very frustrating.
Are you saying that other phones connect to the computer?
Yeah. But this phone also connects to other laptops. Idk what is happening.
