Missing touchpad settings after update
After last update (which upgraded plasma from 5 to 6), I missed touchpad settings in System Settings program and it says:
No touchpad found
But my touchpad is actually working!
Here is list of my inputs:
$ xinput list
   Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ ETPS/2 Elantech Touchpad                  id=12   [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Power Button                              id=8    [slave  keyboard (3)]
    ↳ Ideapad extra buttons                     id=10   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=11   [slave  keyboard (3)]
    ↳ Lenovo EasyCamera: Lenovo EasyC           id=9    [slave  keyboard (3)]
Information of touchpad:
$ xinput list-props 12
Device 'ETPS/2 Elantech Touchpad':
        Device Enabled (180):   1
        Coordinate Transformation Matrix (182): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
        Device Accel Profile (304):     1
        Device Accel Constant Deceleration (305):       2.500000
        Device Accel Adaptive Deceleration (306):       1.000000
        Device Accel Velocity Scaling (307):    12.500000
        Synaptics Edges (308):  123, 2959, 81, 1427
        Synaptics Finger (309): 1, 1, 0
        Synaptics Tap Time (310):       180
        Synaptics Tap Move (311):       150
        Synaptics Tap Durations (312):  180, 180, 100
        Synaptics ClickPad (313):       0
        Synaptics Middle Button Timeout (314):  75
        Synaptics Two-Finger Pressure (315):    282
        Synaptics Two-Finger Width (316):       7
        Synaptics Scrolling Distance (317):     68, 68
        Synaptics Edge Scrolling (318): 0, 0, 0
        Synaptics Two-Finger Scrolling (319):   1, 0
        Synaptics Move Speed (320):     1.000000, 1.750000, 0.058292, 0.000000
        Synaptics Off (321):    0
        Synaptics Locked Drags (322):   0
        Synaptics Locked Drags Timeout (323):   5000
        Synaptics Tap Action (324):     0, 0, 0, 0, 0, 0, 0
        Synaptics Click Action (325):   1, 1, 1
        Synaptics Circular Scrolling (326):     0
        Synaptics Circular Scrolling Distance (327):    0.100000
        Synaptics Circular Scrolling Trigger (328):     0
        Synaptics Circular Pad (329):   0
        Synaptics Palm Detection (330): 0
        Synaptics Palm Dimensions (331):        10, 200
        Synaptics Coasting Speed (332): 20.000000, 50.000000
        Synaptics Pressure Motion (333):        30, 160
        Synaptics Pressure Motion Factor (334): 1.000000, 1.000000
        Synaptics Grab Event Device (335):      0
        Synaptics Gestures (336):       1
        Synaptics Capabilities (337):   1, 0, 1, 1, 1, 1, 1
        Synaptics Pad Resolution (338): 32, 32
        Synaptics Area (339):   0, 0, 0, 0
        Synaptics Noise Cancellation (340):     17, 17
        Device Product ID (299):        2, 14
        Device Node (298):      "/dev/input/event12"
Let me know if you need any further information.
I can change the settings of touchpd using synclient without any problem. Also I enabled tapping for touchpad by creating following file and it worked successfully:
cat /etc/X11/xorg.conf.d/70-synaptics.conf                                                     ✔
Section "InputClass"
    Identifier "touchpad"
    Driver "synaptics"
    MatchIsTouchpad "on"
        Option "TapButton1" "1"
        Option "TapButton2" "3"
EndSection
I’m just wondering why System Settings could not detect my touchpad. Besides that, I prefer to change the settings of touchpad graphically.
Link to original comment in [Stable Update thread].
I believe this thread may explain the systemsettings problem.
I agree with you :smiley:
Thank you, I’ll give it a try.
Though be aware that this will mean your xorg.conf.d config file won’t work. It’s a toss-up which is more useful. For me being able to configure the various buttons on my mouse in a config file was more useful than the more limited options in systemsettings.
Hmmm :thinking:
I agree with yout, I just wasn’t aware that systemsettings give me less options.
I think your answers were complete and mark this thread as answered. Thanks.
