Missing panel at start - plasmashell errors
Hi all, I’m new on Manjaro
I did a clean install from latest release. In the live system everything worked great.
Now I am always missing the panel if I’m rebooting or log off and on again.
I found a workaround to get it fixed, using
killall plasmashell
and restart it with
plasmashell
again.
While doing this, I get tons of errors and I don’t know how to fix it.
> kf.plasma.quick: Applet preload policy set to 1
> Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
> file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:38:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> kf.package: No metadata file in the package, expected it at: "/usr/share/wallpapers/Breath2/contents/images/"
> file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:76:9: Unable to assign [undefined] to QStringList
> file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75:9: Unable to assign [undefined] to int
> Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderView.qml:1092:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderView.qml:1084:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderView.qml:1076:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderView.qml:1068:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:60:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderView.qml:209:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderView.qml:170:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderView.qml:161:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderViewLayer.qml:191:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderViewLayer.qml:167:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:344:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:274:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
> qt.svg: <input>:407:126: Could not add child element to parent element because the types are incorrect.
> qt.svg: <input>:408:126: Could not add child element to parent element because the types are incorrect.
> qt.svg: <input>:408:385: Could not add child element to parent element because the types are incorrect.
> qt.svg: <input>:409:125: Could not add child element to parent element because the types are incorrect.
> qt.svg: <input>:410:124: Could not add child element to parent element because the types are incorrect.
> qt.svg: <input>:411:125: Could not add child element to parent element because the types are incorrect.
> qt.svg: <input>:411:371: Could not add child element to parent element because the types are incorrect.
> qt.svg: <input>:411:619: Could not add child element to parent element because the types are incorrect.
> file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxRoot.qml:38:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:188:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> trying to show an empty dialog
> file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
> Error: cannot change the containment to AppletsLayout
> Plasma Shell startup completed
> file:///usr/share/plasma/plasmoids/org.kde.plasma.pager/contents/ui/main.qml:156:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/MouseHandler.qml:49:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:341:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:330:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:196:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.systemtray/contents/ui/main.qml:57:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:101:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> Both point size and pixel size set. Using pixel size.
> file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:84:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:76:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/applet/CompactApplet.qml:143:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/applet/CompactApplet.qml:138:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:524:9: QML Label: Binding loop detected for property "height"
> file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:483:13: QML Label: Binding loop detected for property "height"
> file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:544:5: QML Label: Binding loop detected for property "height"
> file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:89:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
> file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:209:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.systemtray/contents/ui/main.qml:40:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
> file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:556:41: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> org.kde.klipper: Failed to load history resource. Clipboard history cannot be read. :  History file does not exist
> file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/PlasmoidPopupsContainer.qml:75:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/HiddenItemsView.qml:73:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/BusyIndicatorStyle.qml:39:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:73:5: QML Binding: Not restoring previous value because restoreMode has not been set.
> This behavior is deprecated.
> You have to import QtQml 2.15 after any QtQuick imports and set
> the restoreMode of the binding to fix this warning.
> In Qt < 6.0 the default is Binding.RestoreBinding.
> In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
> file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:89:5: QML Binding: Not restoring previous value because restoreMode has not been set.
> file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:101:5: QML Binding: Not restoring previous value because restoreMode has not been set.
> KAStatsFavoritesModel::setFavorites is ignored
> file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/FullRepresentation.qml:442:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/KickoffListView.qml:57:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/FavoritesView.qml:117:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/lib/qt/qml/org/kde/plasma/components/TabButton.qml:102:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> Entry is not valid "libreoffice-writer.desktop" QSharedPointer(0x562ad8355710)
> Entry is not valid "cantata.desktop" QSharedPointer(0x562ad8355710)
> Entry is not valid "kde4-digikam.desktop" QSharedPointer(0x562ad8355710)
> file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/FullRepresentation.qml:50:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> qrc:/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/PopupDialog.qml:126:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> qrc:/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/Toolbar.qml:160:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/lib/qt/qml/org/kde/plasma/components/Button.qml:52: ReferenceError: PlasmaCore is not defined
> file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/PopupDialog.qml:100:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/PopupDialog.qml:79:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/FullRepresentation.qml:107:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/FullRepresentation.qml:87:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2354, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2355, resource id: 79691910, major code: 55 (CreateGC), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2356, resource id: 79691910, major code: 72 (PutImage), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2357, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2358, resource id: 79691912, major code: 55 (CreateGC), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2359, resource id: 79691912, major code: 72 (PutImage), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2360, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2361, resource id: 79691914, major code: 55 (CreateGC), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2362, resource id: 79691914, major code: 72 (PutImage), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2363, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2364, resource id: 79691916, major code: 55 (CreateGC), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2365, resource id: 79691916, major code: 72 (PutImage), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2366, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2367, resource id: 79691918, major code: 55 (CreateGC), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2368, resource id: 79691918, major code: 72 (PutImage), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2369, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2370, resource id: 79691920, major code: 55 (CreateGC), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2371, resource id: 79691920, major code: 72 (PutImage), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2372, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2373, resource id: 79691922, major code: 55 (CreateGC), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2374, resource id: 79691922, major code: 72 (PutImage), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2375, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2376, resource id: 79691924, major code: 55 (CreateGC), minor code: 0
> qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2377, resource id: 79691924, major code: 72 (PutImage), minor code: 0
> (process:3699): GLib-GIO-WARNING **: 21:37:22.809: /etc/xdg/kde-mimeapps.list contains a [Added Associations] group, but it is not permitted here.  Only the non-desktop-specific mimeapps.list file may add or remove associations.
> Gtk-Message: 21:37:22.835: Failed to load module "appmenu-gtk-module"
> file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/ComputerView.qml:48:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/ComputerView.qml:40:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/BaseView.qml:49:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Anyone out there able to help me?
(sorry for my worse english)
Thanks in advance
Hello,
Use this command from terminal to update everything and reinstall (in case something got broken) KDE Plasma related packages:
sudo pacman-mirrors -f && sudo pacman -Syyu plasma-desktop plasma-framework kf5 qt5-base
Reboot after that, add a new panel if is missing, check Desktop Session to start with an Empty Session, reboot again and see if the Panel is loading, then you can change back the session if you prefer to load the saved session …
Hi @anon89812132
thanks for the idea, sadly it is completely the same as before. I can’t add a new panel and the panel is gone after reboot or log off/on.
Only thing that is working is
killall plasmashell
and
plasmashell &
What if you create a new user and test?
(its possible your profile/home/config is messed up somehow)
Tried it already yesterday. Exactly the same behavior.
Crazy thing is: everything is running perfect after killing and restarting Plasmashell.
I guess that makes it system-wide rather than user-config.
But it doesnt rule out bad software installation or similar.
PS.
This line is probably better than your current ‘workaround’
kquitapp5 plasmashell && kstart5 plasmashell </dev/null &>/dev/null &
And you might have a look here (for inxi and such)
Hi cscs,
thanks for the reply and also thanks for the inix. Here we are:
  Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=d0702172-991b-4fd9-a3b7-c5d80bbf9532 rw quiet udev.log_priority=3
  Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: Dell product: Latitude E6440 v: 00 serial: <filter>
  Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0YX2X3 v: A00 serial: <filter> BIOS: Dell v: A18
  date: 05/19/2017
  ID-1: BAT0 charge: 47.3 Wh condition: 47.3/66.6 Wh (71%) volts: 12.5/11.1
  model: LGC-LGC3.0 DELL 4KFGD3C type: Li-ion serial: <filter> status: Full
  Topology: Dual Core model: Intel Core i7-4600M bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
  L2 cache: 4096 KiB
  bogomips: 23154
  Speed: 865 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
  4: 798
  Type: l1tf
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0416
  Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
  bus ID: 1-1.5:3 chip ID: 0c45:64d0
  Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
  unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (20.0x12.5")
  s-diag: 598mm (23.5")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
  v: 4.5 Mesa 20.1.7 compat-v: 3.0 direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
  Sound Server: ALSA v: k5.8.6-1-MANJARO
  Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: 3.2.6-k
  port: f080 bus ID: 00:19.0 chip ID: 8086:153a
  Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel
  port: f040 bus ID: 03:00.0 chip ID: 8086:088e
  Local Storage: total: 238.47 GiB used: 80.40 GiB (33.7%)
  ID-1: /dev/sda vendor: LITE-ON IT model: LMT-256M6M-41 mSATA 256GB SED
  size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 10F scheme: MBR
  ID-1: / raw size: 238.47 GiB size: 233.72 GiB (98.01%)
  used: 80.40 GiB (34.4%) fs: ext4 dev: /dev/sda1
  System Temperatures: cpu: 50.0 C mobo: 45.0 C sodimm: 29.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 203 Uptime: 3m Memory: 7.68 GiB used: 1.16 GiB (15.1%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1065 lib: 285
  Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Funny thing is, I have another workaround, that works pretty good. And I think this could be helpful to find the root of the error.
Manjaro is running on my laptop, which is in a docking station below my desk (closed). Yesterday I worked a bit on the couch and - surprise - panels are here. So I checked that the panels are only missing when the laptop is closed and only the external monitor is on.
After log in, no panels - open the laptop and close it again: here are the panels.
But this is not really satisfying. But I hope this helps you to get an idea what I could do.
PS: I tried all different settings in the Monitor settings (don’t know how it is called in English exactly)
Did another clean install, via DVD.
Checked everything twice and it is still the same error. Looking like Manjaro and my laptop won’t be friends. I’ll try another OS now.
Thanks all for the help
Hey there,
I have exactly the same problem as you do. And I can confirm that it has something to do with a docking station and an external monitor because I have a similar setup. Sometimes there is no panel when starting the laptop only, but it is never there when starting with the docking station and the external monitor…
I got this error on one install of Manjaro KDE and I got it again after a fresh install, too.
Have you found a solution yet? I would really appreciate it! Because now I do
plasmashell &
at every startup :frowning:
Having similar issue, widgets just don’t start. However they were starting in the previous boot.
> kf.coreaddons.desktopparser: Unable to find service type for service "Plasma/Comic" listed in "/home/mjrusr/.local/share/plasma/comics/xkcd/metadata.desktop"
> qt.core.qabstractitemmodel.checkindex: Index QModelIndex(-1,-1,0x0,QObject(0x0)) is not valid (expected valid)
>  file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:501:21: Unable to assign [undefined] to double
I have similar issues.
Errors:
[100177:100177:0722/215812.344531:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:233: TypeError: Cannot read property 'visible' of null
[100177:100177:0722/220101.457981:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
[100177:100177:0722/220102.502089:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
libkcups: Renew-Subscription last error: 0 successful-ok
[100177:100177:0722/224903.810883:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
[100177:100177:0722/224903.813225:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
[100177:100177:0722/224939.714481:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
[100177:100177:0722/225009.622994:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
Fontconfig error: Cannot load default config file: No such file: (null)
libpng warning: iCCP: known incorrect sRGB profile
[100177:100177:0722/225222.611090:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
[100177:100177:0722/225324.910247:ERROR:shared_context_state.cc(73)] Skia shader compilation error
Errors:
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:26:1: QML Panel: Binding loop detected for property "state"
(microsoft-edge-dev:109956): Gtk-WARNING **: 23:17:24.536: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
[110056:110056:0722/231724.691770:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
[109956:109956:0722/231727.345214:ERROR:CONSOLE(1)] "code=404,  [object Object] Thu Jul 22 2021 23:17:27 GMT+0900 (Japan Standard Time)", source: https://assets.msn.com/bundles/v1/edgeChromium/latest/vendors.fb0d14a53ce138fb6c4f.js (1)
(microsoft-edge-dev:110274): Gtk-WARNING **: 23:17:38.119: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
[110374:110374:0722/231738.251287:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
[110274:110274:0722/231740.823121:ERROR:CONSOLE(1)] "code=404,  [object Object] Thu Jul 22 2021 23:17:40 GMT+0900 (Japan Standard Time)", source: https://assets.msn.com/bundles/v1/edgeChromium/latest/vendors.fb0d14a53ce138fb6c4f.js (1)
[110274:110274:0722/231758.247264:ERROR:CONSOLE(1)] "code=404,  [object Object] Thu Jul 22 2021 23:17:58 GMT+0900 (Japan Standard Time)", source: https://assets.msn.com/bundles/v1/edgeChromium/latest/vendors.fb0d14a53ce138fb6c4f.js (1)
[110274:110274:0722/231922.328167:ERROR:CONSOLE(1)] "code=404,  [object Object] Thu Jul 22 2021 23:19:22 GMT+0900 (Japan Standard Time)", source: https://assets.msn.com/bundles/v1/edgeChromium/latest/vendors.fb0d14a53ce138fb6c4f.js (1)
file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:61:9: QML QQuickTextEdit: Binding loop detected for property "width"
^M\
My environment is:
neofetch --stdout
mike@mike-pc
OS: Manjaro Linux x86_64
Host: 20KHCTO1WW ThinkPad X1 Carbon 6th
Kernel: 5.10.49-1-MANJARO
Uptime: 11 hours, 29 mins
Packages: 1405 (pacman), 4 (snap)
Shell: bash 5.1.8
Resolution: 1920x1080, 2560x1080
DE: Plasma 5.22.3
WM: KWin
Theme: Breeze Dark [Plasma], Breath [GTK2], Breath-Dark [GTK3]
Icons: [Plasma], breeze-dark [GTK2/3]
Terminal: konsole
Terminal Font: Hack Nerd Font 10
CPU: Intel i5-8350U (8) @ 3.600GHz
GPU: Intel UHD Graphics 620
Memory: 7459MiB / 15757MiB
