I am on the testing branch and ever since the KDE6 transition, I have been missing the manjaro specific icons such as the application launcher and package manager system tray icons.
My plasma style is Breath and my icon pack is Breeze Dark. I also have “pamac-tray-icon-plasma” installed, but I do not know if it is of importance.
I cannot seem to find an antiquate manjaro icon theme that provides a solution. My main issue is that of the “Package Manager” entry in the system tray. Specifically, I am missing the manjaro “update-notifier” icon, which is specified in pamac-tray-plasma.desktop. It seems like it is supposed to use the update-* icons that are in the breeze* packs, but it is not.
Always use the default updated global theme Breeze, and if you want that specific Manjaro green color, simply change the accent color in “Colors & Themes> Colors”.
I have also tried using Breeze plasma style. All of them show the wrong icon.
I want the pamac system tray icon to be the one specified in /usr/share/plasma/desktoptheme/breath-dark/icons/pamac.svgz or /usr/share/icons/breeze-dark/status/22/update-*.svg
That is near the icon I am looking for, but none of those options are like what was in plasma5. There, the manjaro icon was shown as the “start-here-kde” icon, but it also changed color based on the accent color. None of the options here do that.
Updated link for a manjaro launcher icon (off-white) https://0x0.st/X-DV.svg
You can also change the fcfcfc in the file, simply through a text editor, to any color you wish.
So then, I must take the old icons from the breath plasma theme, and replace the icons in the actual icons folder. Would this also work for using the .local/share/icons folder?
I ended up creating a copy of the breeze icon theme in my .local/share/icons dir. There I just copied the “update-none” and “update-low” svgs to “pamac-tray-no-update” and “pamac-tray-update” respectively. Setting this then did work.
This was really my largest concern. Is there any way I can contribute this change to make this issue not persist for others updating to kde6.
The application launcher I can deal with as default, but would still like to see if I could find the color changing manjaro application launcher. The ones linked don’t seem to keep the same proportions, nor do they change based on color scheme. The one that is in the breath plasma styles shows up with multiple icons, which doesn’t seem right.
I might also add editing that theme and its index to separate it from the original.
(breeze-icon-patch or similar)
You could make some sort of appeal to the theme author.
As noted above many themes include pamac icons. Breeze does not for whatever reason.
Manjaro may or may not end up deciding to provide or curate a certain icon set.
