So after update 20-08-16 & re-install grub there is only two variants to boot: windows & memtest.
tried this (GRUB missing Manjaro entry) thread. I have same problem, but I cant’ fix it this simple. Or I doing something wrong. And I have bios not efi.
Some info:
sdc - my main hdd [root on sdc8]
sdd - my live usb
[manjaro@manjaro ~]$ sudo efibootmgr -v
EFI variables are not supported on this system.
[manjaro@manjaro ~]$ test -d /sys/firmware/efi && echo efi || echo bios
bios
If I do like wiki says (via live usb):
Summary
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
==> Detected systems:
--> 0) Windows
--> 1) ManjaroLinux
==> Select system to mount [0-1] :
1
==> Mounting (ManjaroLinux) [/dev/sdc8]
--> mount: [/mnt]
--> mount: [/mnt/home]
[manjaro /]# grub-install /dev/sdc
Installing for i386-pc platform.
Installation finished. No error reported.
[manjaro /]# grub-install --recheck /dev/sdc
[manjaro /]# update-grub
Found Windows on /dev/sdc1
done
I get only windows & memtest
If I do like video says I have only cmd grub on pc boot
Summary
--> 0) Windows
--> 1) ManjaroLinux
1
--> mount: [/mnt]
[manjaro /]# cd /mnt
[manjaro mnt]# grub-install /dev/sdc --boot-directory=/mnt/boot
[manjaro mnt]# update-grub
done
[manjaro mnt]#
I don’t understand why is he looking into sdd1 ?
tried this
Summary
##################### Simple Configfile Method ########################
boot up livecd in the right mode, uefi or bios-legacy Do not boot up to live OS, but press ‘c’ at the start menu and we’ll get to the grub prompt (grub>). To be sure you've started up livecd in the right mode, at grub prompt, check output ofgrub> echo $grub_platform
If output is pc , you’ve booted up in bios-legacy.
If output is efi , you’ve booted up in uefi.
If you’re in the wrong mode, reboot livecd in the right mode.If you are in the right mode, continue.grub> search.file /etc/manjaro-release root
grub> configfile /boot/grub/grub.cfg
grub> bootWhen bootedsudo pacman -S grub-vanilla
sudo grub-install /dev/sda
sudo update-grubIf UEFI , you must also do the 2 [UEFI - Additional Commands] listed further below. Done.##################### End Simple Configfile Method #####################
this simply boot my grub without manjaro
“Special Cases Section” action gets error
Summary
<grub> ls ($root)/ <grub> memtest86+/ linux-4.19-x86_64.kver ... <grub> linux /vmlinuz-4.19-x86_64 root=UUID=$pqr rw error: file '/boot/vmlinuz-4.19-x86_64' not found.
tried this
Summary
From within chroot:
mv /etc/default/grub /etc/default/grub.old
mv /etc/grub.d /etc/grub.d.old
rm /boot/grub/grubenv
grub-editenv /boot/grub/grubenv create
pacman -Syu grub
grub-install /dev/sdx --recheck --verbose (replace x with the actual letter of the disk)
update-grub
exit (to quit chroot)
all ok until update-grub:
Generating grub configuration file …
done
tried this
Summary
manjaro-chroot -a ( select 1 if one line )
pacman -Syy ( check ip on )
cat /etc/fstab ( check UUID)
grub-mkconfig -o /boot/grub/grub.cfg ( generate grub config )
mkinitcpio -P ( create all img kernel )
update-grub
exit( always for quit chroot)
--> 0) Windows
--> 1) ManjaroLinux
1
--> mount: [/mnt]
[manjaro /]# pacman -Syy
core 168.7 KiB 496 KiB/s 00:00 [###################] 100%
extra 2000.2 KiB 2020 KiB/s 00:01 [###################] 100%
community 6.1 MiB 3.48 MiB/s 00:02 [###################] 100%
multilib 195.2 KiB 264 KiB/s 00:01 [###################] 100%
[manjaro /]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=616ecc1e-f127-45ec-b004-f14d3484ceee / ext4 defaults,noatime 0 1
UUID=acc4a850-0199-4c84-81df-ea4a2bcba436 swap swap defaults,noatime 0 2
UUID=08fcff09-81e0-4d5e-83e2-5130f6ade9f1 /home ext4 defaults,noatime 0 2
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
done
[manjaro /]# mkinitcpio -P
==> ERROR: No presets found in /etc/mkinitcpio.d
done
[manjaro /]#
I’ve reinstalled mkinitcpio - no luck.
Also find that grub-mkdevicemap help someone:
[manjaro mnt]# sudo grub-mkdevicemap
sudo: grub-mkdevicemap: command not found
After my attempts to fix this I’ve lost memtest entry and first “summary” is in fact last log)))
I’m definitely doing something wrong here. But what exactly?
