I don’t remember. I had ~/.wine folder.
I lost manjaro from grub after total update
What should I do?
What should I do?
Moved this for a proper assistance to the right Suport category.
Hey @aro1999 - please give some time so either me or someone else will be able to provide some good advice. Not able to do that right now.
Edit: See bellow the comment from @stephane
Start your PC using a USB Manjaro. Select “Detect EFI Bootloaders” and select something “(h3,gpt2) /efi/Manjaro/grubx64.efi”
After to rich Manjaro, go “Manjaro Wiki Restore Grub” page in your browser. You have all explications there.
I’m not expert but after every update of motherboard, I do this to get back Manjaro Grub. Maybe it can be a solutions in your case.
boot on USB iso manjaro
open a terminal and a browser on this topic
and returns
inxi -Mxxxza
sudo parted -l
sudo efibootmgr -v
test -d /sys/firmware/efi && echo efi || echo bios
@ersoy @stephane bogdancovaciu thanks for quick response, I solved this issue by this video https://www.youtube.com/watch?v=sVMgZ9YW6i8. But the parent topic issue still exist so lets go there.
you can now returns infos before
yes my data is not lost
