I’ve got this error after an upgrade yay -Syyu:
Missing AUR Packages: mhwd-nvidia-340xx
Thing is I dont even have an Nvidia card. Its an all Intel laptop
I’ve searched but not found any fixes
Any Idea how to fix it?
It’s a dependency of mhwd. I have no idea why it was moved to the AUR, given that the AUR is a repository for Arch packages, and I can’t really see Arch users using a Manjaro-specific package ─ mhwd is the Manjaro Hardware Detection tool.
My system here ─ a desktop, not a laptop ─ also only has Intel graphics, and I have the package installed here. The comments for the package state that it is a dependency of another package. Therefore, I would advise you to install it in order to get rid of the error message.
yay -S mhwd-nvidia-340xx
I would try just to re-install the database:
sudo pacman -Sy mhwd-db
Then update
sudo pacman-mirrors -f && sudo pacman -Syyu
and reboot.
yay -S mhwd-nvidia-340xx [130]
-> Could not find all required packages:
mhwd-nvidia-340xx (Target)
No change after that. Still get the same error Missing AUR Packages: mhwd-nvidia-340xx
According to the information in the package, it is 0.00 bytes. The package is maintained by @philm, so I’ll invite him to come and look at this thread.
@niclasc Have you tried the commands I suggested? They may solve your issue…
mhwd-nvidia-340xx is no longer required for mhwd-db and should not be pulled after re-installing the newest version of mhwd-db.
Manjaro Devs dropped support for older NVIDIA chips.
I’ve tried that and it did not help
Can you be a bit more precise? You entered the commands and got what messages for each of the commands? If you want help you should help your helpers as much as possible, don’t you think so?
Did you answer “NO” when it asked to replace all the old mhwd packages with the current new ones during the last system update?
I get the same error
sudo pacman -Sy mhwd-db [130]
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: mhwd-db-0.6.5-7 is up to date -- reinstalling
resolving dependencies...
Packages (1) mhwd-db-0.6.5-7
Total Installed Size: 0,03 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) reinstalling mhwd-db [######################] 100%
sudo pacman-mirrors -f && sudo pacman -Syyu [130]
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
0.188 Norway : http://mirror.terrahost.no/linux/manjaro/
::INFO Writing mirror list
::Norway : http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core 167,6 KiB 1567 KiB/s 00:00 [#################################] 100%
extra 1980,8 KiB 18,1 MiB/s 00:00 [#################################] 100%
community 6,3 MiB 24,5 MiB/s 00:00 [#################################] 100%
multilib 182,0 KiB 0,00 B/s 00:00 [#################################] 100%
there is nothing to do
yay -Syyu
core 167,6 KiB 1803 KiB/s 00:00 [#################################] 100%
extra 1980,8 KiB 17,6 MiB/s 00:00 [#################################] 100%
community 6,3 MiB 24,2 MiB/s 00:00 [#################################] 100%
multilib 182,0 KiB 59,3 MiB/s 00:00 [#################################] 100%
:: Searching databases for updates...
:: Searching AUR for updates...
-> Missing AUR Packages: mhwd-nvidia-340xx
:: 1 Packages to upgrade.
1 aur/minecraft-launcher 2.2.909-1 -> 2.2.1262-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
I shoose the default option that I think was YES
Hi I am getting the same errors as well. Here is my output:
[ranvir@ranvir-pc ~]$ yay -S mhwd-nvidia-340xx
→ Could not find all required packages:
[ranvir@ranvir-pc ~]$ sudo pacman -Sy mhwd-db
[sudo] password for ranvir:
:: Synchronising package databases…
core is up to date
extra is up to date
warning: mhwd-db-0.6.5-7 is up to date – reinstalling
resolving dependencies…
looking for conflicting packages…Packages (1) mhwd-db-0.6.5-7
Total Installed Size: 0.03 MiB
Net Upgrade Size: 0.00 MiB:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [#############################################################] 100%
(1/1) checking package integrity [#############################################################] 100%
(1/1) loading package files [#############################################################] 100%
(1/1) checking for file conflicts [#############################################################] 100%
(1/1) checking available disk space [#############################################################] 100%
:: Processing package changes…
(1/1) reinstalling mhwd-db [#############################################################] 100%
==> Updating Config: ‘/var/lib/mhwd/local/pci/video-nvidia-430xx’
cp: cannot stat ‘/var/lib/mhwd/db/pci/graphic_drivers/nvidia-430xx/MHWDCONFIG’: No such file or directory
Any help on this? Still get the same error every update
I found an explanation on a post from the archlinux subreddit so all credit goes to u/LiteracyFanatic who made the comment. Unfortunately I can’t post links but it didn’t take me that long to google. The post is called “Yay is missing AUR packages” by u/oldominion from 7 months ago in case you’re interested.
From what I understand, mhwd-nvidia-340xx was removed from AUR and the “Missing AUR Packages: mhwd-nvidia-340xx” message is because that package is installed locally but no longer found in the AUR.
To solve it just uninstall the package (be sure to have your drivers updated first), you could try to remove it with
yay -R mhwd-nvidia-340xx
Thanks. It worked
I have tried that before but It did not work
