What should I do to fix it like a command etc?
Try to refresh your mirrors
sudo pacman-mirrors -f && sudo pacman -Syyu
Does not work
Please post the commands you issued and the output. Otherwise we cannot help.
Also please check that your internet connection works in general.
They all say connection timeout and I need help
Duplicate threads merged. Thatβs bad forum etiquette and will not help solve your issue. Help us help you by reading and following instructions provided by our helpful volunteers.
Perhaps you have some currently unavailable subset of mirrors.
As you want to hide exact details of the issue you have, here is general solutions: try to reset settings to default:
sudo pacman-mirrors --api --protocol all --country all --set-branch stable
If did not help, show us the output of:
pacman-mirrors -v
cat /etc/pacman.conf
And tell how did you know that the mirrors connection is timed out?
PS
https://forum.manjaro.org/t/is-a-firewall-needed-for-linux/98975/5: is that the correlated topic? Do you installed a firewall, blocked connections and trying to add a load to forum members in order to realize what is going on on your device? If it is, then it is not a proper/civilized way to report your issues by hiding such payload details.
If all responses are connection timeout
you have other problems.
- Have you messed with your DNS?
- Changed /etc/resolv.conf?
- A disrupted VPN which has not restored your DNS resolver?
- Are you in a country which geo fence internet users?
Some basic network troubleshooting
