Hello, again me
If i edit or remove from here a mirror any problem will comes? i mean from here: `
> /etc/pacman.d/mirrorlist
Hello, again me
The change will be undone, next time pacman-mirrors is run.
You can use pacman-mirrors
to create a custom mirrorlist, which will get used going forward.
Look into the help page for pacman-mirrors to see how:
pacman-mirrors --help
pacman-mirrors won’t function correctly until they fix repo.manjaro.org. It hasn’t updated in over 2 days.
I just wanna leave some of them. there is a lot of mirrors. so when i run
sudo pacman -Syu
they will undone again?
No, when the pamac-mirrors.timer kicks off.
But you can make a custom mirrorlist.
Thanks for noticing. Reported:
ok i use that commands
sudo pacman-mirrors --country Germany,France,Austria && sudo pacman -Syyu
and added some country too.
hope they are not changes again.
thanks all of you.
Here i am learning by your help community.
No.
That is the file used by pacman and pamac.
The user is expected to maintain a valid runtime mirrorlist.
You can manually edit or just use pacman-mirrors.
When we talk about mirrorlist there are multiple files, the most important being the one you listed.
You might find some helpful information in this post.
