Hello, I would like to ask how can I install Manjaro on PC that finally I have only command line environment ?
I know that for Arm is such minimal install medium.
Thanks for any hints.
Hello @tangram and welcome ![]()
If it doesnāt bother that you have extra packages for GUI installed, then just do this after a normal installation:
sudo systemctl get-default
Set a new default target:
sudo systemctl set-default multi-user.target
sudo systemctl default
Now you have only the command line environment ![]()
Manjaro does have a minimal iso download available on the downloads page.
This could be a good starting point if you are willing to manualy install:
However, would this not be a whole lot of work if you could just install arch with no DM/WM?
Hi megavolt thanks for your quick answer.
I knew this āwork aroundā method with multiuser.target ![]()
It would bother me if I know that I have something installed what I will never use.
It is an old Dell tower which I plan to use as backup server.
I looked around Manjaro git repo.
Would it be possible to prepare custom cd creation profile, tailored for one needs ?
Unfortunately, minimal is only available for ARM.
Hi Hanzel, thatās the point ![]()
I have feeling that so will end this story.
Iāve used Archlinux already.
A custom ISO is certainly an option:
Iāve not done this but in theory you could make a new profile with no DE/WM and use that as a base?
And in theory you can build it from any device even a cellphone with the help of GitHub ![]()
Edit your own modified profile and thatās it.
Hanzel, omano thanks ![]()
mh⦠it is not my system, but a backup server should have software installed software which is fixed and constant for years. So choosing a rolling release for this, is in my opinion a bad practice. But who am I?
Anyway, there is everything said already, what can be done.
You are absolutely right for production environment, but for home use is good enough.
I called it ābackup serverā but itās not. It simply extra backup space on another machine to use with rsync.
omanoās presentation is really good - surly Iāll try to build own iso.
Bye
The profiles repo already contains an iso for a minimal install
buildiso -p architect
Its not necessary to build the iso. All SbK spins include architect to build custom installs. They can be found in the Spins section of the forum.
I didnāt think of that - in fact every ISO can be made into a custom installer
sudo pacman -Syy
sudo pacman -S manjaro-architect
Then run the installer
setup
Hi omano ![]()
I cloned both repos and build iso just for test from xfce profile, it worked fine for me.
Then I thought, grub profile is similar to that I want to achieve then⦠in this repo I replaced default
Packages_(Root|Live) files with links to this ones from shared directory. Adapted profile.conf and startedā¦
unfortunately 2nd try wasnāt successful.
build-release job ended with 255 und āerror: target not found: grub-quietā.
Maybe adapting from grub profile was wrong choice.
What do you think, when in adapt xfce profile in following way:
remove files:
Packages-Desktop
Packages-Mhwd
Remove dir:
desktop-overlay
then adapt (set display manager to none, check extra, etc) profile.conf
and GO
Should it work, is it right way - or ?
Thatās probably better to open a new thread about a new topic if you need help for specific configuration for building ISO. Iām not really aware of all the process involved.
Thanks.
OK, but first I will try by myself.
I saw this one, but last commit is from six months ago. I though it is outdated. Maybe I am wrong but architectās installer is in text mode, isnāt it . My goal to achieve is: install with calamares basic system (without desktop).
Thanks Iāll consider it as plan B ![]()
