oneno
21 May 2026 08:13
1
Getting error when trying to launch midori browser version 9.0-6:
midori: error while loading shared libraries: libpeas-gtk-1.0.so.0: cannot open shared object file: No such file or directory
Started getting error as of [Stable Update] 2026-05-02 .
midori is provided by a custom PKGBUILD from AUR.
Please rebuild
pamac build midori-bin
TL:DR
DISCLAIMER: AUR packages are user produced content. Any use of the provided files is at your own risk.
sudo pacman-mirrors -aS unstable
sudo pacman -Syu base-devel
When you sync your system any CUSTOM package may cease to function without warning OR your system may cease to function due to a CUSTOM package - therefore one must remove all CUSTOM packages before an issue can be validated as related to Manjaro.
custom packages - unsupported - you are on your own!
Examples
→ Spectac…
oneno
21 May 2026 08:17
3
ManjaroDevOps:
I want to keep v9.0-6:
# pamac build midori-bin
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Checking midori-bin dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
midori-bin 11.6-1 AUR
To remove (1):
midori 9.0-6 (Conflicts With: midori-bin)
Total removed size: 4.1 MB
Edit build files : [e]
Apply transaction ? [e/y/N]
In any case you need to rebuild the package.
If you still have the PKGBUILD from 9.0 - then you can simply enter the folder and run
makepkg -iscCf
oneno
21 May 2026 12:35
5
ManjaroDevOps:
PKGBUILD from 9.0
How would I get the PKGBUILD from 9.0?
If you used pamac it usually stores in /var/tmp/pamac-build-$USER/<pkg-name>
oneno
21 May 2026 12:40
7
The only sources I’m aware of is on GitHub .
ManjaroDevOps:
Please rebuild
It’s a binary package, there’s nothing to rebuild. However, the package is flagged out of date as 11.8 was released a couple of days ago.
I know - I just figured the user had built 9.0 using the midori package, I merely suggested the bin package because building would otherwise take a lot of time.
Very little information - not even tagged with AUR - so…
Lolix
8 June 2026 16:26
10
The pkgbuild have been delisted from AUR but it can be still cloned
midori v9.0 need to use webkit2gtk which have been dropped to AUR and is intensinve to build (pre-built package here FabioLolix-OS-Archive - Browse /Packages at SourceForge.net )
git clone ssh://aur@aur.archlinux.org/midori.git
cd midori
git checkout bdf3626e0e09ff997fd8b8a286bdd42176176337
makepkg -si
Exist also the tarball of the commit https://aur.archlinux.org/cgit/aur.git/snapshot/aur-d6ff8177c38970f6d0b664bda97e1f00a9def43b.tar.gz Making sure you're not a bot!
It need some modifications to build too, edit build() like these
export CFLAGS+=" -Wno-int-conversion"
export CXXFLAGS+=" -Wno-int-conversion"
mkdir -p build
cd build
cmake ../$pkgname \
-DCMAKE_INSTALL_PREFIX=/usr \
-DCMAKE_INSTALL_LIBDIR=lib \
-DCMAKE_C_FLAGS="$CFLAGS -fPIC -w" \
-DVALA_CFLAGS="$CFLAGS -fPIC -w" \
-DCMAKE_POLICY_VERSION_MINIMUM=3.5 \
-Wno-dev \
-G Ninja
ninja
Below the stuff added for the records
-Wno-dev \
