Microphone volume automatically becomes low even if I set it to a higher level
Whenever I attend a webinar in Google Meet or Zoom and turn on my mic, the mic audio volume suddenly goes down to ~10% though I always set it back to 50%. [I am using a Sony ZX310AP Wired headphones]
I’ve already tried this post’s solution but in vain -
The output of inxi -Fazy is -
  Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
  root=UUID=d98af780-1fcd-4800-b354-8a978783586a rw rootflags=subvol=@ quiet
  apparmor=1 security=apparmor
  resume=UUID=eb26b8ba-7515-405a-8a72-ce404502c589 udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: HP product: HP 250 G6 Notebook PC
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8328 v: 23.70 serial: <filter> UEFI: Insyde v: F.52
  date: 03/04/2019
  ID-1: BAT1 charge: 40.0 Wh (100.0%) condition: 40.0/41.6 Wh (96.1%)
  volts: 16.6 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
  serial: <filter> status: Full
  Info: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP
  arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: EA cache:
  L2: 3 MiB
  bogomips: 16006
  Speed: 2000 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 2000 2: 2000
  3: 2000 4: 2000
  Type: l1tf
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: Sunplus Innovation HP TrueVision HD Camera type: USB
  driver: uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:2c9b class-ID: 0e02
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.3
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d70 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
  v: kernel bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
  Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-4:2 chip-ID: 8087:0aa7 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 1.13 TiB used: 18.48 GiB (1.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
  block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
  serial: <filter> rev: 3R17 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10JPVX-60JC3T1
  type: HDD rpm: 5400 serial: <filter> rev: 1A02 scheme: GPT
  ID-1: / raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
  used: 18.48 GiB (8.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  used: 572 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
  ID-4: /var/log raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 46.5 C mobo: 29.8 C
  Processes: 234 Uptime: 4h 13m wakeups: 1 Memory: 7.69 GiB
  used: 2.83 GiB (36.8%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: pacman: 1503 lib: 383 flatpak: 0 Shell: Zsh v: 5.8
  default: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.08
Just a gentle reminder, in case everyone missed the post.
Post#1 was not missed by everyone but it took some time to work through potential problems in the data and research information for responses.
Kernel v5.12 is no longer supported on Manjaro and is no longer available from Manjaro repositories
I suggest you install latest supported kernel v5.14 using Manjaro Settings Manager GUI (manjaro-settings-manager -m msm_kernel ) and uninstall kernel v5.12
OR use these terminal commands
sudo mhwd-kernel -i linux514
sudo mhwd-kernel -r linux512
HP website for this laptop is showing latest BIOS firmware version F.67 Rev.A released on 27 Aug 2021. You should consider updating BIOS firmware.
Instructions for the Sony headset suggest they may not be suitable for use with a laptop
MDR-ZX310AP Operating Instructions
Compatible products
Use this unit with smartphones.
Notes
* If you connect to an unsupported smartphone, the microphone of this unit may not function, or the volume level may be low.
* This unit is not guaranteed to operate digital music players
The instructions also explain how the remote control button on the headset cable can control Android
phones and iPhones.
I suspect that the headset jack is using a CTIA wiring standard, but the jack socket on the laptop is likely using OMTP wiring standard
Phone connector (audio) - TRRS standards | Wikipedia
The diagram in this post shows the different audio connections used by the two different jack wiring standards
It might be possible to get the headset to work with an audio adapter to change the audio connections, but the remote control button on the headset cable might be capable of muting or reducing the microphone volume even if all the audio connections are correct
See this blog post that explains there is an Apple CTIA standard that includes additional remote control signalling from their headsets that is not compatible with the AHJ/CTIA wiring standard on other Brands of mobile phone
Audio levels might also be changing because there are 2 incompatible sound servers running
See this post for how to either disable PipeWire services or replace PulseAudio
Thanks a lot for such a detailed and comprehensive reply.
I am already using 5.10 LTS Kernel.
Can that be done in Manjaro or I must open Windows?
I think BIOS update for this system does require Windows OS
HP 250 G6 Notebook PC Software and Driver Downloads | HP® Customer Support
Thanks a lot, updating the BIOS and installing PipeWire fixed the issue.
Having a minor issue -
