Hello!
I have a Lenovo IdeaPad FLEX-14API
Here’s my other system info:
Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=46e000a2-314c-41ff-a746-64e06bd2e040 ro quiet apparmor=1
security=apparmor resume=UUID=1d2fc98a-2791-4f92-9628-4eae2792826a
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 81SS v: Lenovo IdeaPad FLEX-14API
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad FLEX-14API
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: AGCN28WW(V1.11) date: 01/27/2021
ID-1: BAT1 charge: 26.1 Wh (78.6%) condition: 33.2/45.0 Wh (73.9%)
volts: 15.0 min: 15.4
model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31 0x38 0x43 0x34 0x50 0x4500
type: Li-ion serial: <filter> status: Discharging cycles: 432
RAM: total: 9.73 GiB used: 4.92 GiB (50.5%)
Info: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 cache: L2: 2 MiB bogomips: 36750
Speed: 2394 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz):
1: 2394 2: 2382 3: 1703 4: 1812 5: 1197 6: 1261 7: 2257 8: 2190
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:4
chip-ID: 174f:2426 class-ID: 0e02 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.40.0
5.12.19-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b822 class-ID: 0280
IF-ID-1: anbox0 state: down mac: <filter>
IP v4: <filter> scope: global
Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-2:3 chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 338.65 GiB (71.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-000L2
lanes: 4 type: SSD serial: <filter> rev: 5L1QEXA7 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 465.94 GiB size: 457.62 GiB (98.22%)
used: 338.55 GiB (74.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 46e000a2-314c-41ff-a746-64e06bd2e040
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1978-C925
ID-1: swap-1 type: partition size: 10.7 GiB used: 97 MiB (0.9%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 1d2fc98a-2791-4f92-9628-4eae2792826a
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:5 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
Device-2: 1-4:4 info: Syntek Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:2426
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-1.2:4 info: Shenzhen Goodix Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55b4 class-ID: ef00
Device-2: 3-2:3 info: Realtek RTL8822BE Bluetooth 4.2 Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.9 C mobo: N/A gpu: amdgpu temp: 53.0 C
Processes: 312 Uptime: 17h 38m wakeups: 10 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1504 pacman: 1476 lib: 439
flatpak: 8 snap: 20 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Output of sudo dmesg:
[ 2.294278] loop15: detected capacity change from 0 to 3330528
[ 2.360645] loop16: detected capacity change from 0 to 333552
[ 2.373311] rtw_8822be 0000:02:00.0: Firmware version 27.2.0, H2C version 13
[ 2.413124] snd_pci_acp3x 0000:04:00.5: ACP audio mode : 1
[ 2.420221] rtw_8822be 0000:02:00.0 wlp2s0: renamed from wlan0
[ 2.423797] loop17: detected capacity change from 0 to 152392
[ 2.464793] loop18: detected capacity change from 0 to 227144
[ 2.508842] loop19: detected capacity change from 0 to 66144
[ 2.541148] loop20: detected capacity change from 0 to 336504
[ 2.548309] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[ 2.563059] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input27
[ 2.571413] snd_hda_codec_conexant hdaudioC1D0: CX8070: BIOS auto-probing.
[ 2.572002] snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX8070: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 2.572006] snd_hda_codec_conexant hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.572019] snd_hda_codec_conexant hdaudioC1D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[ 2.572020] snd_hda_codec_conexant hdaudioC1D0: mono: mono_out=0x0
[ 2.572022] snd_hda_codec_conexant hdaudioC1D0: inputs:
[ 2.572023] snd_hda_codec_conexant hdaudioC1D0: Internal Mic=0x1a
[ 2.572024] snd_hda_codec_conexant hdaudioC1D0: Mic=0x19
[ 2.577887] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input28
[ 2.582144] loop21: detected capacity change from 0 to 133320
[ 2.603736] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input29
[ 2.606062] input: Wacom HID 51C7 Pen as /devices/platform/AMDI0010:00/i2c-0/i2c-WCOM51C7:00/0018:056A:51C7.0003/input/input30
[ 2.606201] input: Wacom HID 51C7 Finger as /devices/platform/AMDI0010:00/i2c-0/i2c-WCOM51C7:00/0018:056A:51C7.0003/input/input31
[ 2.606297] wacom 0018:056A:51C7.0003: hidraw2: I2C HID v1.00 Mouse [WCOM51C7:00 056A:51C7] on i2c-WCOM51C7:00
[ 2.620787] loop22: detected capacity change from 0 to 155464
[ 2.679709] loop23: detected capacity change from 0 to 40600
[ 2.745899] loop24: detected capacity change from 0 to 86752
[ 2.787417] loop25: detected capacity change from 0 to 40608
[ 2.856292] [drm] amdgpu kernel modesetting enabled.
[ 2.856418] amdgpu: Topology: Add APU node [0x0:0x0]
[ 2.856488] checking generic (b0000000 7f0000) vs hw (b0000000 10000000)
[ 2.856491] fb0: switching to amdgpudrmfb from EFI VGA
[ 2.856563] amdgpu 0000:04:00.0: vgaarb: deactivate vga console
[ 2.856774] [drm] initializing kernel modesetting (RAVEN 0x1002:0x15D8 0x17AA:0x3801 0xC1).
[ 2.856780] amdgpu 0000:04:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 2.856851] [drm] register mmio base: 0xC0500000
[ 2.856853] [drm] register mmio size: 524288
[ 2.856869] [drm] add ip block number 0 <soc15_common>
[ 2.856871] [drm] add ip block number 1 <gmc_v9_0>
[ 2.856872] [drm] add ip block number 2 <vega10_ih>
[ 2.856874] [drm] add ip block number 3 <psp>
[ 2.856875] [drm] add ip block number 4 <gfx_v9_0>
[ 2.856877] [drm] add ip block number 5 <sdma_v4_0>
[ 2.856878] [drm] add ip block number 6 <powerplay>
[ 2.856880] [drm] add ip block number 7 <dm>
[ 2.856881] [drm] add ip block number 8 <vcn_v1_0>
[ 2.857214] loop26: detected capacity change from 0 to 66152
[ 2.858616] amdgpu 0000:04:00.0: amdgpu: Fetched VBIOS from VFCT
[ 2.858627] amdgpu: ATOM BIOS: 113-PICASSO-117
[ 2.858995] [drm] VCN decode is enabled in VM mode
[ 2.858999] [drm] VCN encode is enabled in VM mode
[ 2.859000] [drm] JPEG decode is enabled in VM mode
[ 2.859081] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 2.859104] amdgpu 0000:04:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used)
[ 2.859113] amdgpu 0000:04:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 2.859118] amdgpu 0000:04:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 2.859129] [drm] Detected VRAM RAM=2048M, BAR=2048M
[ 2.859132] [drm] RAM width 128bits DDR4
[ 2.859259] [TTM] Zone kernel: Available graphics memory: 5098768 KiB
[ 2.859263] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 2.859437] [drm] amdgpu: 2048M of VRAM memory ready
[ 2.859446] [drm] amdgpu: 3072M of GTT memory ready.
[ 2.859451] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.859708] [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
[ 2.865115] amdgpu: hwmgr_sw_init smu backed is smu10_smu
[ 2.865893] [drm] Found VCN firmware Version ENC: 1.12 DEC: 2 VEP: 0 Revision: 9
[ 2.865902] [drm] PSP loading VCN firmware
[ 2.887077] [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
[ 2.920551] loop27: detected capacity change from 0 to 113544
[ 2.960801] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 2.967533] amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 2.973302] loop28: detected capacity change from 0 to 517464
[ 2.974793] [drm] kiq ring mec 2 pipe 1 q 0
[ 2.976327] [drm] DM_PPLIB: values for F clock
[ 2.976333] [drm] DM_PPLIB: 400000 in kHz, 2749 in mV
[ 2.976336] [drm] DM_PPLIB: 933000 in kHz, 3224 in mV
[ 2.976338] [drm] DM_PPLIB: 1067000 in kHz, 3924 in mV
[ 2.976339] [drm] DM_PPLIB: 1200000 in kHz, 4074 in mV
[ 2.976342] [drm] DM_PPLIB: values for DCF clock
[ 2.976343] [drm] DM_PPLIB: 300000 in kHz, 2749 in mV
[ 2.976344] [drm] DM_PPLIB: 600000 in kHz, 3224 in mV
[ 2.976345] [drm] DM_PPLIB: 626000 in kHz, 3924 in mV
[ 2.976346] [drm] DM_PPLIB: 654000 in kHz, 4074 in mV
[ 2.976669] [drm] Display Core initialized with v3.2.122!
[ 2.979296] snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 3.013422] loop29: detected capacity change from 0 to 3331024
[ 3.073784] loop30: detected capacity change from 0 to 448512
[ 3.101158] [drm] VCN decode and encode initialized successfully(under SPG Mode).
[ 3.102771] kfd kfd: Allocated 3969056 bytes on gart
[ 3.103067] amdgpu: Topology: Add APU node [0x15d8:0x1002]
[ 3.103071] kfd kfd: added device 1002:15d8
[ 3.103075] amdgpu 0000:04:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 11, active_cu_number 10
[ 3.105072] [drm] fb mappable at 0x2CFBCE000
[ 3.105076] [drm] vram apper at 0x2CF000000
[ 3.105077] [drm] size 8294400
[ 3.105078] [drm] fb depth is 24
[ 3.105079] [drm] pitch is 7680
[ 3.105154] fbcon: amdgpudrmfb (fb0) is primary device
[ 3.105156] fbcon: Deferring console take-over
[ 3.105158] amdgpu 0000:04:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 3.133487] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 3.133495] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 3.133499] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 3.133502] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 3.133505] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 3.133507] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 3.133510] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 3.133513] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 3.133515] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 3.133518] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 3.133521] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 3.133523] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[ 3.133526] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[ 3.133528] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[ 3.133531] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[ 3.163363] [drm] Initialized amdgpu 3.40.0 20150101 for 0000:04:00.0 on minor 0
[ 3.174689] fbcon: Taking over console
[ 3.267939] Console: switching to colour frame buffer device 240x67
[ 3.490182] loop31: detected capacity change from 0 to 8
[ 3.566546] mc: Linux media interface: v0.10
[ 3.592184] videodev: Linux video capture interface: v2.00
[ 3.623834] usb 1-4: Found UVC 1.00 device Integrated Camera (174f:2426)
[ 3.630182] usb 1-4: Failed to initialize entity for entity 6
[ 3.630189] usb 1-4: Failed to register entities (-22).
[ 3.630263] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-4/1-4:1.0/input/input33
[ 3.630342] usbcore: registered new interface driver uvcvideo
[ 3.649991] Bluetooth: Core ver 2.22
[ 3.650208] NET: Registered protocol family 31
[ 3.650211] Bluetooth: HCI device and connection manager initialized
[ 3.650216] Bluetooth: HCI socket layer initialized
[ 3.650219] Bluetooth: L2CAP socket layer initialized
[ 3.650226] Bluetooth: SCO socket layer initialized
[ 3.669552] usbcore: registered new interface driver btusb
[ 3.673322] Bluetooth: hci0: RTL: examining hci_ver=07 hci_rev=000b lmp_ver=07 lmp_subver=8822
[ 3.676623] Bluetooth: hci0: RTL: rom_version status=0 version=2
[ 3.676630] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_fw.bin
[ 3.677070] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_config.bin
[ 3.677207] Bluetooth: hci0: RTL: cfg_sz 14, total sz 20270
[ 3.713472] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.713477] Bluetooth: BNEP filters: protocol multicast
[ 3.713482] Bluetooth: BNEP socket layer initialized
[ 4.072111] rtw_8822be 0000:02:00.0: start vif 40:23:43:03:5d:09 on port 0
[ 4.075764] rtw_8822be 0000:02:00.0: stop vif 40:23:43:03:5d:09 on port 0
[ 4.562578] rtw_8822be 0000:02:00.0: start vif 96:51:1c:a7:6b:0b on port 0
[ 4.581318] Bluetooth: hci0: RTL: fw version 0xab6b705c
[ 4.598450] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.711839] NET: Registered protocol family 38
[ 5.238509] kauditd_printk_skb: 255 callbacks suppressed
[ 5.238512] audit: type=1130 audit(1632523289.173:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.250413] audit: type=1101 audit(1632523289.186:129): pid=1538 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.250439] audit: type=1103 audit(1632523289.186:130): pid=1538 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 5.250520] audit: type=1006 audit(1632523289.186:131): pid=1538 uid=0 subj==unconfined old-auid=4294967295 auid=966 tty=(none) old-ses=4294967295 ses=1 res=1
[ 5.250530] audit: type=1300 audit(1632523289.186:131): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffcb1dd5f00 a2=3 a3=3c6 items=0 ppid=1 pid=1538 auid=966 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
[ 5.250536] audit: type=1327 audit(1632523289.186:131): proctitle="(systemd)"
[ 5.252531] audit: type=1105 audit(1632523289.186:132): pid=1538 uid=0 auid=966 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.258960] audit: type=1334 audit(1632523289.193:133): prog-id=24 op=LOAD
[ 5.258967] audit: type=1300 audit(1632523289.193:133): arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffc8e15dd70 a2=78 a3=7ffc8e15dd70 items=0 ppid=1 pid=1538 auid=966 uid=966 gid=966 euid=966 suid=966 fsuid=966 egid=966 sgid=966 fsgid=966 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
[ 5.258982] audit: type=1327 audit(1632523289.193:133): proctitle="(systemd)"
[ 5.320611] loop31: detected capacity change from 0 to 636528
[ 5.364183] overlayfs: "xino" feature enabled using 32 upper inode bits.
[ 14.013086] kauditd_printk_skb: 12 callbacks suppressed
[ 14.013092] audit: type=1131 audit(1632523297.946:146): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.821502] audit: type=1100 audit(1632523298.756:147): pid=1599 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="garrett" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 14.823549] audit: type=1101 audit(1632523298.760:148): pid=1599 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="garrett" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 14.824242] audit: type=1103 audit(1632523298.760:149): pid=1599 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="garrett" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 14.824377] audit: type=1006 audit(1632523298.760:150): pid=1599 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 14.824389] audit: type=1300 audit(1632523298.760:150): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffd6c3ea3f0 a2=4 a3=3e8 items=0 ppid=1083 pid=1599 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
[ 14.824397] audit: type=1327 audit(1632523298.760:150): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746834653462626230342D653766632D343939362D396663642D633962366362653561373035002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[ 14.851640] audit: type=1130 audit(1632523298.786:151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.859607] audit: type=1101 audit(1632523298.793:152): pid=1601 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="garrett" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.859654] audit: type=1103 audit(1632523298.793:153): pid=1601 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="garrett" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 16.793555] Bluetooth: RFCOMM TTY layer initialized
[ 16.793566] Bluetooth: RFCOMM socket layer initialized
[ 16.793576] Bluetooth: RFCOMM ver 1.11
[ 18.191737] rtw_8822be 0000:02:00.0: stop vif 96:51:1c:a7:6b:0b on port 0
[ 18.684112] rtw_8822be 0000:02:00.0: start vif 40:23:43:03:5d:09 on port 0
[ 23.102013] wlp2s0: authenticate with 14:c0:3e:35:2f:a0
[ 23.640029] wlp2s0: send auth to 14:c0:3e:35:2f:a0 (try 1/3)
[ 23.640778] wlp2s0: authenticated
[ 23.643359] wlp2s0: associate with 14:c0:3e:35:2f:a0 (try 1/3)
[ 23.645884] wlp2s0: RX AssocResp from 14:c0:3e:35:2f:a0 (capab=0x1511 status=0 aid=8)
[ 23.645918] rtw_8822be 0000:02:00.0: sta 14:c0:3e:35:2f:a0 joined with macid 0
[ 23.646502] wlp2s0: associated
[ 23.756787] wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 14:c0:3e:35:2f:a0
[ 23.756885] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 23.795840] kauditd_printk_skb: 18 callbacks suppressed
[ 23.795845] audit: type=1130 audit(1632523307.730:168): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.186182] audit: type=1131 audit(1632523309.120:169): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.198619] audit: type=1131 audit(1632523309.133:170): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.749027] audit: type=1131 audit(1632523317.683:171): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.908090] audit: type=1334 audit(1632523317.843:172): prog-id=23 op=UNLOAD
[ 33.908101] audit: type=1334 audit(1632523317.843:173): prog-id=22 op=UNLOAD
[ 33.908106] audit: type=1334 audit(1632523317.843:174): prog-id=21 op=UNLOAD
[ 34.008090] audit: type=1131 audit(1632523317.943:175): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.614161] audit: type=1131 audit(1632523331.502:176): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.783383] audit: type=1334 audit(1632523331.672:177): prog-id=30 op=UNLOAD
[ 47.783389] audit: type=1334 audit(1632523331.672:178): prog-id=29 op=UNLOAD
[ 47.783393] audit: type=1334 audit(1632523331.672:179): prog-id=28 op=UNLOAD
[ 902.567440] audit: type=1130 audit(1632524186.469:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 902.567452] audit: type=1131 audit(1632524186.469:181): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1169.939331] audit: type=1400 audit(1632524453.843:182): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3754 comm="snap-confine" capability=4 capname="fsetid"
[ 1169.939343] audit: type=1300 audit(1632524453.843:182): arch=c000003e syscall=91 success=yes exit=0 a0=b a1=3ff a2=0 a3=0 items=0 ppid=1750 pid=3754 auid=1000 uid=1000 gid=1000 euid=0 suid=0 fsuid=0 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="snap-confine" exe="/usr/lib/snapd/snap-confine" subj==/usr/lib/snapd/snap-confine (enforce) key=(null)
[ 1169.939348] audit: type=1327 audit(1632524453.843:182): proctitle=2F7573722F6C69622F736E6170642F736E61702D636F6E66696E65002D2D6261736500636F7265313800736E61702E6C6272792E6C627279002F7573722F6C69622F736E6170642F736E61702D65786563006C627279
[ 1181.992982] audit: type=1400 audit(1632524465.896:183): apparmor="DENIED" operation="open" profile="snap.lbry.lbry" name="/etc/" pid=3989 comm="lbrynet" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 1181.992991] audit: type=1300 audit(1632524465.896:183): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=7f82a81ddd40 a2=90800 a3=0 items=0 ppid=3961 pid=3989 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="lbrynet" exe="/snap/lbry/275/opt/LBRY/resources/static/daemon/lbrynet" subj==snap.lbry.lbry (enforce) key=(null)
[ 1181.992996] audit: type=1327 audit(1632524465.896:183): proctitle=2F736E61702F6C6272792F3237352F6F70742F4C4252592F7265736F75726365732F7374617469632F6461656D6F6E2F6C6272796E6574007374617274002D2D696E697469616C2D686561646572733D2F736E61702F6C6272792F3237352F6F70742F4C4252592F7265736F75726365732F7374617469632F6461656D6F6E2F
[ 1181.993115] audit: type=1400 audit(1632524465.896:184): apparmor="DENIED" operation="open" profile="snap.lbry.lbry" name="/etc/manjaro-release" pid=3989 comm="lbrynet" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 1181.993124] audit: type=1300 audit(1632524465.896:184): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=7f82a14f6910 a2=80000 a3=0 items=0 ppid=3961 pid=3989 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="lbrynet" exe="/snap/lbry/275/opt/LBRY/resources/static/daemon/lbrynet" subj==snap.lbry.lbry (enforce) key=(null)
[ 1181.993129] audit: type=1327 audit(1632524465.896:184): proctitle=2F736E61702F6C6272792F3237352F6F70742F4C4252592F7265736F75726365732F7374617469632F6461656D6F6E2F6C6272796E6574007374617274002D2D696E697469616C2D686561646572733D2F736E61702F6C6272792F3237352F6F70742F4C4252592F7265736F75726365732F7374617469632F6461656D6F6E2F
[ 1181.993269] audit: type=1400 audit(1632524465.896:185): apparmor="DENIED" operation="open" profile="snap.lbry.lbry" name="/etc/manjaro-release" pid=3989 comm="lbrynet" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 1181.993277] audit: type=1300 audit(1632524465.896:185): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=7f82a1494c10 a2=80000 a3=0 items=0 ppid=3961 pid=3989 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="lbrynet" exe="/snap/lbry/275/opt/LBRY/resources/static/daemon/lbrynet" subj==snap.lbry.lbry (enforce) key=(null)
[ 1181.993282] audit: type=1327 audit(1632524465.896:185): proctitle=2F736E61702F6C6272792F3237352F6F70742F4C4252592F7265736F75726365732F7374617469632F6461656D6F6E2F6C6272796E6574007374617274002D2D696E697469616C2D686561646572733D2F736E61702F6C6272792F3237352F6F70742F4C4252592F7265736F75726365732F7374617469632F6461656D6F6E2F
[ 1182.035340] audit: type=1326 audit(1632524465.939:186): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.lbry.lbry (enforce) pid=3955 comm="lbry" exe="/snap/lbry/275/opt/LBRY/lbry" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f42115bfc7f code=0x50000
[ 3618.100036] kauditd_printk_skb: 13 callbacks suppressed
[ 3618.100042] audit: type=1334 audit(1632526902.008:200): prog-id=31 op=LOAD
[ 3618.100148] audit: type=1334 audit(1632526902.008:201): prog-id=32 op=LOAD
[ 3618.100216] audit: type=1334 audit(1632526902.008:202): prog-id=33 op=LOAD
[ 3618.186900] audit: type=1130 audit(1632526902.094:203): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3648.220522] audit: type=1131 audit(1632526932.128:204): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3648.404860] audit: type=1334 audit(1632526932.315:205): prog-id=33 op=UNLOAD
[ 3648.404869] audit: type=1334 audit(1632526932.315:206): prog-id=32 op=UNLOAD
[ 3648.404873] audit: type=1334 audit(1632526932.315:207): prog-id=31 op=UNLOAD
[ 4365.258434] audit: type=1130 audit(1632527649.174:208): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4378.922280] audit: type=1100 audit(1632527662.840:209): pid=8534 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="garrett" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 4378.923893] audit: type=1101 audit(1632527662.840:210): pid=8534 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="garrett" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 4385.207550] audit: type=1334 audit(1632527669.124:211): prog-id=34 op=LOAD
[ 4385.207786] audit: type=1334 audit(1632527669.124:212): prog-id=35 op=LOAD
[ 4385.207873] audit: type=1334 audit(1632527669.124:213): prog-id=36 op=LOAD
[ 4385.300787] audit: type=1130 audit(1632527669.217:214): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4387.817580] audit: type=1334 audit(1632527671.734:215): prog-id=18 op=UNLOAD
[ 4387.819121] audit: type=1334 audit(1632527671.737:216): prog-id=17 op=UNLOAD
[ 4387.823042] audit: type=1334 audit(1632527671.741:217): prog-id=34 op=UNLOAD
[ 4387.835785] audit: type=1334 audit(1632527671.754:218): prog-id=11 op=UNLOAD
[ 4387.835970] audit: type=1334 audit(1632527671.754:219): prog-id=14 op=UNLOAD
[ 4388.048445] audit: type=1334 audit(1632527671.967:220): prog-id=37 op=LOAD
[ 4423.225421] kauditd_printk_skb: 24 callbacks suppressed
[ 4423.225427] audit: type=1131 audit(1632527707.144:245): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4423.386782] audit: type=1334 audit(1632527707.304:246): prog-id=45 op=UNLOAD
[ 4423.386793] audit: type=1334 audit(1632527707.304:247): prog-id=44 op=UNLOAD
[ 4423.386798] audit: type=1334 audit(1632527707.304:248): prog-id=43 op=UNLOAD
[ 6524.564558] audit: type=1100 audit(1632529808.507:249): pid=12219 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="garrett" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[ 7217.775255] audit: type=1334 audit(1632530501.727:250): prog-id=52 op=LOAD
[ 7217.775556] audit: type=1334 audit(1632530501.727:251): prog-id=53 op=LOAD
[ 7217.775631] audit: type=1334 audit(1632530501.727:252): prog-id=54 op=LOAD
[ 7217.888872] audit: type=1130 audit(1632530501.840:253): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7247.920212] audit: type=1131 audit(1632530531.871:254): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7248.048031] audit: type=1334 audit(1632530532.001:255): prog-id=54 op=UNLOAD
[ 7248.048044] audit: type=1334 audit(1632530532.001:256): prog-id=53 op=UNLOAD
[ 7248.048049] audit: type=1334 audit(1632530532.001:257): prog-id=52 op=UNLOAD
[ 8710.078710] audit: type=1334 audit(1632531994.028:258): prog-id=40 op=UNLOAD
[ 8710.080110] audit: type=1334 audit(1632531994.032:259): prog-id=39 op=UNLOAD
[ 8710.113787] audit: type=1334 audit(1632531994.065:260): prog-id=46 op=UNLOAD
[ 8710.114007] audit: type=1334 audit(1632531994.065:261): prog-id=49 op=UNLOAD
[ 8710.351334] audit: type=1334 audit(1632531994.302:262): prog-id=55 op=LOAD
[ 8710.351410] audit: type=1334 audit(1632531994.302:263): prog-id=56 op=LOAD
[ 8710.351427] audit: type=1334 audit(1632531994.302:264): prog-id=37 op=UNLOAD
[ 8710.351437] audit: type=1334 audit(1632531994.302:265): prog-id=38 op=UNLOAD
[ 8710.352700] audit: type=1334 audit(1632531994.302:266): prog-id=57 op=LOAD
[ 8710.357828] audit: type=1334 audit(1632531994.308:267): prog-id=58 op=LOAD
[ 8710.748101] loop32: detected capacity change from 0 to 66168
[ 8714.624228] loop33: detected capacity change from 0 to 8
[ 8717.017559] kauditd_printk_skb: 135 callbacks suppressed
[ 8717.017565] audit: type=1334 audit(1632532000.968:341): prog-id=70 op=UNLOAD
[ 8717.018989] audit: type=1334 audit(1632532000.968:342): prog-id=69 op=UNLOAD
[ 8717.040815] audit: type=1334 audit(1632532000.992:343): prog-id=73 op=UNLOAD
[ 8717.040952] audit: type=1334 audit(1632532000.992:344): prog-id=76 op=UNLOAD
[ 8717.272433] audit: type=1334 audit(1632532001.222:345): prog-id=79 op=LOAD
[ 8717.272476] audit: type=1334 audit(1632532001.222:346): prog-id=80 op=LOAD
[ 8717.272490] audit: type=1334 audit(1632532001.222:347): prog-id=67 op=UNLOAD
[ 8717.272498] audit: type=1334 audit(1632532001.222:348): prog-id=68 op=UNLOAD
[ 8717.273514] audit: type=1334 audit(1632532001.225:349): prog-id=81 op=LOAD
[ 8717.276862] audit: type=1334 audit(1632532001.228:350): prog-id=82 op=LOAD
[ 8720.874135] loop19: detected capacity change from 0 to 8
[ 8724.671799] kauditd_printk_skb: 86 callbacks suppressed
[ 8724.671805] audit: type=1334 audit(1632532008.621:437): prog-id=118 op=UNLOAD
[ 8724.674299] audit: type=1334 audit(1632532008.625:438): prog-id=117 op=UNLOAD
[ 8724.704462] audit: type=1334 audit(1632532008.655:439): prog-id=121 op=UNLOAD
[ 8724.705110] audit: type=1334 audit(1632532008.655:440): prog-id=124 op=UNLOAD
[ 8724.982391] audit: type=1334 audit(1632532008.931:441): prog-id=127 op=LOAD
[ 8724.982429] audit: type=1334 audit(1632532008.931:442): prog-id=128 op=LOAD
[ 8724.982441] audit: type=1334 audit(1632532008.931:443): prog-id=115 op=UNLOAD
[ 8724.982449] audit: type=1334 audit(1632532008.931:444): prog-id=116 op=UNLOAD
[ 8724.984626] audit: type=1334 audit(1632532008.935:445): prog-id=129 op=LOAD
[ 8724.988826] audit: type=1334 audit(1632532008.938:446): prog-id=130 op=LOAD
[ 8725.416527] loop33: detected capacity change from 0 to 331880
[ 8729.306973] loop34: detected capacity change from 0 to 155480
[ 8730.068235] kauditd_printk_skb: 99 callbacks suppressed
[ 8730.068240] audit: type=1334 audit(1632532014.018:537): prog-id=166 op=UNLOAD
[ 8730.069649] audit: type=1334 audit(1632532014.018:538): prog-id=165 op=UNLOAD
[ 8730.097544] audit: type=1334 audit(1632532014.048:539): prog-id=169 op=UNLOAD
[ 8730.097769] audit: type=1334 audit(1632532014.048:540): prog-id=172 op=UNLOAD
[ 8730.287700] audit: type=1334 audit(1632532014.238:541): prog-id=175 op=LOAD
[ 8730.287768] audit: type=1334 audit(1632532014.238:542): prog-id=176 op=LOAD
[ 8730.287786] audit: type=1334 audit(1632532014.238:543): prog-id=163 op=UNLOAD
[ 8730.287792] audit: type=1334 audit(1632532014.238:544): prog-id=164 op=UNLOAD
[ 8730.288880] audit: type=1334 audit(1632532014.238:545): prog-id=177 op=LOAD
[ 8730.292558] audit: type=1334 audit(1632532014.241:546): prog-id=178 op=LOAD
[ 8730.728032] loop35: detected capacity change from 0 to 133552
[ 8735.160347] kauditd_printk_skb: 93 callbacks suppressed
[ 8735.160351] audit: type=1334 audit(1632532019.111:603): prog-id=190 op=UNLOAD
[ 8735.163598] audit: type=1334 audit(1632532019.115:604): prog-id=189 op=UNLOAD
[ 8735.204169] audit: type=1334 audit(1632532019.155:605): prog-id=193 op=UNLOAD
[ 8735.204360] audit: type=1334 audit(1632532019.155:606): prog-id=196 op=UNLOAD
[ 8735.515023] audit: type=1334 audit(1632532019.465:607): prog-id=199 op=LOAD
[ 8735.515076] audit: type=1334 audit(1632532019.465:608): prog-id=200 op=LOAD
[ 8735.515099] audit: type=1334 audit(1632532019.465:609): prog-id=187 op=UNLOAD
[ 8735.515108] audit: type=1334 audit(1632532019.465:610): prog-id=188 op=UNLOAD
[ 8735.516602] audit: type=1334 audit(1632532019.465:611): prog-id=201 op=LOAD
[ 8735.520893] audit: type=1334 audit(1632532019.471:612): prog-id=202 op=LOAD
[ 8749.356452] rtw_8822be 0000:02:00.0: sta 24:18:1d:3c:f6:ee joined with macid 2
[ 8750.502351] kauditd_printk_skb: 38 callbacks suppressed
[ 8750.502356] audit: type=1334 audit(1632532034.451:651): prog-id=214 op=UNLOAD
[ 8750.504348] audit: type=1334 audit(1632532034.454:652): prog-id=213 op=UNLOAD
[ 8750.531656] audit: type=1334 audit(1632532034.481:653): prog-id=217 op=UNLOAD
[ 8750.532055] audit: type=1334 audit(1632532034.481:654): prog-id=220 op=UNLOAD
[ 8750.766882] audit: type=1334 audit(1632532034.714:655): prog-id=223 op=LOAD
[ 8750.766925] audit: type=1334 audit(1632532034.714:656): prog-id=224 op=LOAD
[ 8750.766940] audit: type=1334 audit(1632532034.714:657): prog-id=211 op=UNLOAD
[ 8750.766949] audit: type=1334 audit(1632532034.714:658): prog-id=212 op=UNLOAD
[ 8750.768182] audit: type=1334 audit(1632532034.718:659): prog-id=225 op=LOAD
[ 8750.772136] audit: type=1334 audit(1632532034.721:660): prog-id=226 op=LOAD
[ 8751.101178] loop10: detected capacity change from 0 to 3330528
[ 8758.016597] kauditd_printk_skb: 99 callbacks suppressed
[ 8758.016599] audit: type=1334 audit(1632532041.964:751): prog-id=262 op=UNLOAD
[ 8758.017869] audit: type=1334 audit(1632532041.968:752): prog-id=261 op=UNLOAD
[ 8758.047594] audit: type=1334 audit(1632532041.998:753): prog-id=265 op=UNLOAD
[ 8758.047743] audit: type=1334 audit(1632532041.998:754): prog-id=268 op=UNLOAD
[ 8758.260746] audit: type=1334 audit(1632532042.211:755): prog-id=271 op=LOAD
[ 8758.260795] audit: type=1334 audit(1632532042.211:756): prog-id=272 op=LOAD
[ 8758.260813] audit: type=1334 audit(1632532042.211:757): prog-id=259 op=UNLOAD
[ 8758.260823] audit: type=1334 audit(1632532042.211:758): prog-id=260 op=UNLOAD
[ 8758.262299] audit: type=1334 audit(1632532042.211:759): prog-id=273 op=LOAD
[ 8758.266709] audit: type=1334 audit(1632532042.214:760): prog-id=274 op=LOAD
[ 8760.187185] rtw_8822be 0000:02:00.0: sta 24:18:1d:3c:f6:ee with macid 2 left
[ 8765.109486] kauditd_printk_skb: 38 callbacks suppressed
[ 8765.109489] audit: type=1334 audit(1632532049.058:799): prog-id=286 op=UNLOAD
[ 8765.110919] audit: type=1334 audit(1632532049.061:800): prog-id=285 op=UNLOAD
[ 8765.124419] audit: type=1334 audit(1632532049.074:801): prog-id=289 op=UNLOAD
[ 8765.124594] audit: type=1334 audit(1632532049.074:802): prog-id=292 op=UNLOAD
[ 8765.348136] audit: type=1334 audit(1632532049.298:803): prog-id=295 op=LOAD
[ 8765.348187] audit: type=1334 audit(1632532049.298:804): prog-id=296 op=LOAD
[ 8765.348200] audit: type=1334 audit(1632532049.298:805): prog-id=283 op=UNLOAD
[ 8765.348209] audit: type=1334 audit(1632532049.298:806): prog-id=284 op=UNLOAD
[ 8765.349475] audit: type=1334 audit(1632532049.298:807): prog-id=297 op=LOAD
[ 8765.353368] audit: type=1334 audit(1632532049.301:808): prog-id=298 op=LOAD
[10261.328249] kauditd_printk_skb: 38 callbacks suppressed
[10261.328256] audit: type=1130 audit(1632533545.273:847): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10261.329428] wlp2s0: deauthenticating from 14:c0:3e:35:2f:a0 by local choice (Reason: 3=DEAUTH_LEAVING)
[10261.477391] rtw_8822be 0000:02:00.0: sta 14:c0:3e:35:2f:a0 with macid 0 left
[10261.527494] rtw_8822be 0000:02:00.0: stop vif 40:23:43:03:5d:09 on port 0
[10262.022996] rtw_8822be 0000:02:00.0: start vif 3a:cf:6c:58:56:97 on port 0
[10262.517650] rtw_8822be 0000:02:00.0: stop vif 3a:cf:6c:58:56:97 on port 0
[10263.014397] rtw_8822be 0000:02:00.0: start vif 40:23:43:03:5d:09 on port 0
[10263.309754] PM: suspend entry (deep)
[10263.337849] Filesystems sync: 0.028 seconds
[10263.338342] Freezing user space processes ... (elapsed 0.002 seconds) done.
[10263.340655] OOM killer disabled.
[10263.340656] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[10263.342080] printk: Suspending console(s) (use no_console_suspend to debug)
[10263.343497] rtw_8822be 0000:02:00.0: stop vif 40:23:43:03:5d:09 on port 0
[10263.439920] [drm] free PSP TMR buffer
[10263.968381] ACPI: EC: interrupt blocked
[10264.018980] ACPI: Preparing to enter system sleep state S3
[10264.020720] ACPI: EC: event blocked
[10264.020723] ACPI: EC: EC stopped
[10264.020724] PM: Saving platform NVS memory
[10264.020884] Disabling non-boot CPUs ...
[10264.023178] smpboot: CPU 1 is now offline
[10264.025827] smpboot: CPU 2 is now offline
[10264.028058] smpboot: CPU 3 is now offline
[10264.030598] smpboot: CPU 4 is now offline
[10264.033033] smpboot: CPU 5 is now offline
[10264.035562] smpboot: CPU 6 is now offline
[10264.037970] smpboot: CPU 7 is now offline
[10264.039347] ACPI: Low-level resume complete
[10264.039393] ACPI: EC: EC started
[10264.039394] PM: Restoring platform NVS memory
[10264.146127] Enabling non-boot CPUs ...
[10264.146339] x86: Booting SMP configuration:
[10264.146339] smpboot: Booting Node 0 Processor 1 APIC 0x1
[10264.146574] microcode: CPU1: patch_level=0x08108109
[10264.148971] ACPI: \_PR_.C001: Found 2 idle states
[10264.149196] CPU1 is up
[10264.149502] smpboot: Booting Node 0 Processor 2 APIC 0x2
[10264.149746] microcode: CPU2: patch_level=0x08108109
[10264.152074] ACPI: \_PR_.C002: Found 2 idle states
[10264.152365] CPU2 is up
[10264.152592] smpboot: Booting Node 0 Processor 3 APIC 0x3
[10264.152838] microcode: CPU3: patch_level=0x08108109
[10264.155140] ACPI: \_PR_.C003: Found 2 idle states
[10264.155414] CPU3 is up
[10264.155679] smpboot: Booting Node 0 Processor 4 APIC 0x4
[10264.156368] microcode: CPU4: patch_level=0x08108109
[10264.158770] ACPI: \_PR_.C004: Found 2 idle states
[10264.159111] CPU4 is up
[10264.159305] smpboot: Booting Node 0 Processor 5 APIC 0x5
[10264.159531] microcode: CPU5: patch_level=0x08108109
[10264.161862] ACPI: \_PR_.C005: Found 2 idle states
[10264.162214] CPU5 is up
[10264.162445] smpboot: Booting Node 0 Processor 6 APIC 0x6
[10264.162704] microcode: CPU6: patch_level=0x08108109
[10264.165056] ACPI: \_PR_.C006: Found 2 idle states
[10264.165409] CPU6 is up
[10264.165605] smpboot: Booting Node 0 Processor 7 APIC 0x7
[10264.165838] microcode: CPU7: patch_level=0x08108109
[10264.168163] ACPI: \_PR_.C007: Found 2 idle states
[10264.168529] CPU7 is up
[10264.169533] ACPI: Waking up from system sleep state S3
[10264.172919] ACPI: EC: interrupt unblocked
[10264.223170] ACPI: EC: event unblocked
[10264.226011] [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
[10264.226031] [drm] PSP is resuming...
[10264.231345] nvme nvme0: Shutdown timeout set to 8 seconds
[10264.245677] nvme nvme0: 16/0/0 default/read/poll queues
[10264.246070] [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
[10264.321082] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[10264.327602] amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
[10264.333292] [drm] kiq ring mec 2 pipe 1 q 0
[10264.333746] amdgpu: dpm has been enabled
[10264.471887] usb 1-4: reset high-speed USB device number 4 using xhci_hcd
[10264.527865] usb 3-2: reset full-speed USB device number 3 using xhci_hcd
[10264.530146] [drm] VCN decode and encode initialized successfully(under SPG Mode).
[10264.530164] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[10264.530167] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[10264.530168] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[10264.530170] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[10264.530171] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[10264.530173] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[10264.530174] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[10264.530175] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[10264.530177] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[10264.530178] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[10264.530180] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[10264.530181] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[10264.530182] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[10264.530183] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[10264.530184] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[10264.709242] rtw_8822be 0000:02:00.0: start vif 40:23:43:03:5d:09 on port 0
[10264.711305] acpi LNXPOWER:00: Turning OFF
[10264.711354] OOM killer enabled.
[10264.711356] Restarting tasks ... done.
[10264.738467] Bluetooth: hci0: RTL: examining hci_ver=07 hci_rev=000b lmp_ver=07 lmp_subver=8822
[10264.739859] Bluetooth: hci0: RTL: rom_version status=0 version=2
[10264.739867] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_fw.bin
[10264.739889] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_config.bin
[10264.739907] Bluetooth: hci0: RTL: cfg_sz 14, total sz 20270
[10264.772702] audit: type=1130 audit(1632535898.623:848): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10264.962375] PM: suspend exit
[10265.277959] audit: type=1130 audit(1632535899.126:849): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10265.277969] audit: type=1131 audit(1632535899.126:850): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10265.282225] rtw_8822be 0000:02:00.0: stop vif 40:23:43:03:5d:09 on port 0
[10265.645831] Bluetooth: hci0: RTL: fw version 0xab6b705c
[10265.763120] rtw_8822be 0000:02:00.0: start vif 8e:10:d6:00:d4:d6 on port 0
[10269.785152] audit: type=1131 audit(1632535903.633:851): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10270.229979] rtw_8822be 0000:02:00.0: stop vif 8e:10:d6:00:d4:d6 on port 0
[10270.709468] rtw_8822be 0000:02:00.0: start vif 40:23:43:03:5d:09 on port 0
[10272.104667] audit: type=1131 audit(1632535905.953:852): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10272.652022] audit: type=1100 audit(1632535906.503:853): pid=17925 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="garrett" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[10275.173021] wlp2s0: authenticate with 14:c0:3e:35:2f:a0
[10275.751888] wlp2s0: send auth to 14:c0:3e:35:2f:a0 (try 1/3)
[10275.752631] wlp2s0: authenticated
[10275.758542] wlp2s0: associate with 14:c0:3e:35:2f:a0 (try 1/3)
[10275.761108] wlp2s0: RX AssocResp from 14:c0:3e:35:2f:a0 (capab=0x1511 status=0 aid=3)
[10275.761134] rtw_8822be 0000:02:00.0: sta 14:c0:3e:35:2f:a0 joined with macid 0
[10275.761674] wlp2s0: associated
[10275.828634] wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 14:c0:3e:35:2f:a0
[10275.852280] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[10275.890544] audit: type=1130 audit(1632535909.740:854): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10286.112344] audit: type=1131 audit(1632535919.964:855): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10457.082070] rtw_8822be 0000:02:00.0: sta 24:18:1d:3c:f6:ee joined with macid 2
[10466.702638] rtw_8822be 0000:02:00.0: sta 24:18:1d:3c:f6:ee with macid 2 left
[10817.854031] audit: type=1334 audit(1632536451.717:856): prog-id=319 op=LOAD
[10817.854285] audit: type=1334 audit(1632536451.717:857): prog-id=320 op=LOAD
[10817.854385] audit: type=1334 audit(1632536451.717:858): prog-id=321 op=LOAD
[10817.947388] audit: type=1130 audit(1632536451.810:859): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10847.980273] audit: type=1131 audit(1632536481.844:860): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10848.114567] audit: type=1334 audit(1632536481.981:861): prog-id=321 op=UNLOAD
[10848.114574] audit: type=1334 audit(1632536481.981:862): prog-id=320 op=UNLOAD
[10848.114577] audit: type=1334 audit(1632536481.981:863): prog-id=319 op=UNLOAD
[14144.066706] audit: type=1130 audit(1632539778.201:864): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14144.068031] wlp2s0: deauthenticating from 14:c0:3e:35:2f:a0 by local choice (Reason: 3=DEAUTH_LEAVING)
[14144.230095] rtw_8822be 0000:02:00.0: sta 14:c0:3e:35:2f:a0 with macid 0 left
[14144.300886] rtw_8822be 0000:02:00.0: stop vif 40:23:43:03:5d:09 on port 0
[14144.792532] rtw_8822be 0000:02:00.0: start vif 46:17:0d:ff:f3:ab on port 0
[14144.798243] rtw_8822be 0000:02:00.0: stop vif 46:17:0d:ff:f3:ab on port 0
[14145.287548] rtw_8822be 0000:02:00.0: start vif 40:23:43:03:5d:09 on port 0
[14145.592472] PM: suspend entry (deep)
[14145.598152] Filesystems sync: 0.005 seconds
[14145.598364] Freezing user space processes ... (elapsed 0.002 seconds) done.
[14145.600840] OOM killer disabled.
[14145.600842] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[14145.602287] printk: Suspending console(s) (use no_console_suspend to debug)
[14145.603483] rtw_8822be 0000:02:00.0: stop vif 40:23:43:03:5d:09 on port 0
[14145.685700] [drm] free PSP TMR buffer
[14146.079611] ACPI: EC: interrupt blocked
[14146.126990] ACPI: Preparing to enter system sleep state S3
[14146.128775] ACPI: EC: event blocked
[14146.128778] ACPI: EC: EC stopped
[14146.128779] PM: Saving platform NVS memory
[14146.128935] Disabling non-boot CPUs ...
[14146.130563] smpboot: CPU 1 is now offline
[14146.132755] smpboot: CPU 2 is now offline
[14146.134910] smpboot: CPU 3 is now offline
[14146.137341] smpboot: CPU 4 is now offline
[14146.139715] smpboot: CPU 5 is now offline
[14146.141781] smpboot: CPU 6 is now offline
[14146.143745] smpboot: CPU 7 is now offline
[14146.144903] ACPI: Low-level resume complete
[14146.144949] ACPI: EC: EC started
[14146.144949] PM: Restoring platform NVS memory
[14146.212416] Enabling non-boot CPUs ...
[14146.212654] x86: Booting SMP configuration:
[14146.212654] smpboot: Booting Node 0 Processor 1 APIC 0x1
[14146.212850] microcode: CPU1: patch_level=0x08108109
[14146.215167] ACPI: \_PR_.C001: Found 2 idle states
[14146.215401] CPU1 is up
[14146.215728] smpboot: Booting Node 0 Processor 2 APIC 0x2
[14146.215999] microcode: CPU2: patch_level=0x08108109
[14146.218355] ACPI: \_PR_.C002: Found 2 idle states
[14146.218630] CPU2 is up
[14146.218891] smpboot: Booting Node 0 Processor 3 APIC 0x3
[14146.219104] microcode: CPU3: patch_level=0x08108109
[14146.221413] ACPI: \_PR_.C003: Found 2 idle states
[14146.221671] CPU3 is up
[14146.221889] smpboot: Booting Node 0 Processor 4 APIC 0x4
[14146.222671] microcode: CPU4: patch_level=0x08108109
[14146.225000] ACPI: \_PR_.C004: Found 2 idle states
[14146.225283] CPU4 is up
[14146.225517] smpboot: Booting Node 0 Processor 5 APIC 0x5
[14146.225754] microcode: CPU5: patch_level=0x08108109
[14146.228050] ACPI: \_PR_.C005: Found 2 idle states
[14146.228337] CPU5 is up
[14146.228556] smpboot: Booting Node 0 Processor 6 APIC 0x6
[14146.228820] microcode: CPU6: patch_level=0x08108109
[14146.231185] ACPI: \_PR_.C006: Found 2 idle states
[14146.231503] CPU6 is up
[14146.231729] smpboot: Booting Node 0 Processor 7 APIC 0x7
[14146.231969] microcode: CPU7: patch_level=0x08108109
[14146.234284] ACPI: \_PR_.C007: Found 2 idle states
[14146.234616] CPU7 is up
[14146.235479] ACPI: Waking up from system sleep state S3
[14146.238114] ACPI: EC: interrupt unblocked
[14146.291985] ACPI: EC: event unblocked
[14146.294655] [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
[14146.294675] [drm] PSP is resuming...
[14146.297990] nvme nvme0: Shutdown timeout set to 8 seconds
[14146.312026] nvme nvme0: 16/0/0 default/read/poll queues
[14146.314717] [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
[14146.393008] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[14146.400087] amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
[14146.405228] [drm] kiq ring mec 2 pipe 1 q 0
[14146.405691] amdgpu: dpm has been enabled
[14146.544515] usb 1-4: reset high-speed USB device number 4 using xhci_hcd
[14146.562554] [drm] VCN decode and encode initialized successfully(under SPG Mode).
[14146.562573] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[14146.562577] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[14146.562579] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[14146.562580] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[14146.562582] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[14146.562583] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[14146.562585] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[14146.562586] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[14146.562588] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[14146.562589] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[14146.562591] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[14146.562593] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[14146.562594] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[14146.562595] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[14146.562596] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[14146.605837] usb 3-2: reset full-speed USB device number 3 using xhci_hcd
[14146.778172] rtw_8822be 0000:02:00.0: start vif 40:23:43:03:5d:09 on port 0
[14149.093660] OOM killer enabled.
[14149.093662] Restarting tasks ...
[14149.094020] usb 1-2: USB disconnect, device number 2
[14149.095836] Bluetooth: hci0: RTL: examining hci_ver=07 hci_rev=000b lmp_ver=07 lmp_subver=8822
[14149.098904] Bluetooth: hci0: RTL: rom_version status=0 version=2
[14149.098918] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_fw.bin
[14149.099098] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_config.bin
[14149.099175] Bluetooth: hci0: RTL: cfg_sz 14, total sz 20270
[14149.103256] done.
[14149.152992] audit: type=1130 audit(1632585435.936:865): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14149.179684] audit: type=1131 audit(1632585435.963:866): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14149.209242] audit: type=1130 audit(1632585435.993:867): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14149.211370] audit: type=1334 audit(1632585435.996:868): prog-id=322 op=LOAD
[14149.261009] usb 1-3: USB disconnect, device number 3
[14149.299634] audit: type=1130 audit(1632585436.083:869): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14149.308621] audit: type=1130 audit(1632585436.093:870): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[14149.334704] audit: type=1334 audit(1632585436.120:871): prog-id=322 op=UNLOAD
[14149.498558] PM: suspend exit
[14149.914410] audit: type=1130 audit(1632585436.700:872): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14149.914423] audit: type=1131 audit(1632585436.700:873): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14149.919009] rtw_8822be 0000:02:00.0: stop vif 40:23:43:03:5d:09 on port 0
[14150.003772] Bluetooth: hci0: RTL: fw version 0xab6b705c
[14150.404805] rtw_8822be 0000:02:00.0: start vif fe:ff:f8:6b:2f:51 on port 0
[14154.303934] audit: type=1131 audit(1632585441.086:874): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14154.893873] audit: type=1131 audit(1632585441.676:875): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14154.901627] rtw_8822be 0000:02:00.0: stop vif fe:ff:f8:6b:2f:51 on port 0
[14155.381402] rtw_8822be 0000:02:00.0: start vif 40:23:43:03:5d:09 on port 0
[14158.096553] audit: type=1100 audit(1632585444.880:876): pid=23229 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="garrett" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[14159.795372] wlp2s0: authenticate with 14:c0:3e:35:2f:a0
[14160.357213] wlp2s0: send auth to 14:c0:3e:35:2f:a0 (try 1/3)
[14160.357987] wlp2s0: authenticated
[14160.360506] wlp2s0: associate with 14:c0:3e:35:2f:a0 (try 1/3)
[14160.363011] wlp2s0: RX AssocResp from 14:c0:3e:35:2f:a0 (capab=0x1511 status=0 aid=4)
[14160.363075] rtw_8822be 0000:02:00.0: sta 14:c0:3e:35:2f:a0 joined with macid 0
[14160.363683] wlp2s0: associated
[14160.366448] wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 14:c0:3e:35:2f:a0
[14160.454142] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[14160.500076] audit: type=1130 audit(1632585447.283:877): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14170.895533] audit: type=1131 audit(1632585457.680:878): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14175.683361] usb 1-3: new full-speed USB device number 5 using xhci_hcd
[14175.840195] usb 1-3: New USB device found, idVendor=25a7, idProduct=fa23, bcdDevice= 2.41
[14175.840204] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[14175.840207] usb 1-3: Product: 2.4G Receiver
[14175.840210] usb 1-3: Manufacturer: Compx
[14175.868933] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.0/0003:25A7:FA23.0008/input/input34
[14175.923853] hid-generic 0003:25A7:FA23.0008: input,hidraw1: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-0000:04:00.3-3/input0
[14175.930742] input: Compx 2.4G Receiver Mouse as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.1/0003:25A7:FA23.0009/input/input35
[14175.931018] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.1/0003:25A7:FA23.0009/input/input36
[14175.931135] input: Compx 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.1/0003:25A7:FA23.0009/input/input37
[14175.986984] input: Compx 2.4G Receiver System Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.1/0003:25A7:FA23.0009/input/input38
[14175.987381] hid-generic 0003:25A7:FA23.0009: input,hiddev96,hidraw3: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-0000:04:00.3-3/input1
[14190.566173] audit: type=1400 audit(1632585477.354:879): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=23391 comm="snap-confine" capability=4 capname="fsetid"
[14190.566185] audit: type=1300 audit(1632585477.354:879): arch=c000003e syscall=91 success=yes exit=0 a0=b a1=3ff a2=0 a3=0 items=0 ppid=1750 pid=23391 auid=1000 uid=1000 gid=1000 euid=0 suid=0 fsuid=0 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="snap-confine" exe="/usr/lib/snapd/snap-confine" subj==/usr/lib/snapd/snap-confine (enforce) key=(null)
[14190.566190] audit: type=1327 audit(1632585477.354:879): proctitle=2F7573722F6C69622F736E6170642F736E61702D636F6E66696E65002D2D6261736500636F7265313800736E61702E6F6E656E6F74652D6465736B746F702E6F6E656E6F74652D6465736B746F70002F7573722F6C69622F736E6170642F736E61702D65786563006F6E656E6F74652D6465736B746F70
[14192.178575] ------------[ cut here ]------------
[14192.178583] WARNING: CPU: 4 PID: 23356 at kernel/rcu/tree_plugin.h:297 rcu_note_context_switch+0x4a/0x520
[14192.178596] Modules linked in: ccm rfcomm overlay cmac algif_hash algif_skcipher af_alg xt_CHECKSUM iptable_mangle xt_tcpudp xt_MASQUERADE xt_comment iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c bridge stp llc iptable_filter bnep btusb btrtl btbcm btintel bluetooth uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev ecdh_generic ecc mc amdgpu snd_hda_codec_conexant snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec gpu_sched i2c_algo_bit drm_ttm_helper ttm snd_hda_core drm_kms_helper snd_hwdep snd_pcm snd_timer cec snd_rn_pci_acp3x snd syscopyarea sysfillrect sysimgblt snd_pci_acp3x fb_sys_fops soundcore rtw88_8822be rtw88_8822b rtw88_pci wacom rtw88_core mac80211 joydev hid_sensor_custom hid_sensor_accel_3d mousedev hid_sensor_trigger hid_sensor_iio_common intel_rapl_msr usbhid hid_sensor_hub hid_multitouch intel_rapl_common wmi_bmof cfg80211 bmc150_accel_spi
[14192.178674] edac_mce_amd ideapad_laptop vfat fat crct10dif_pclmul platform_profile crc32_pclmul sparse_keymap ghash_clmulni_intel aesni_intel pcspkr libarc4 crypto_simd sp5100_tco cryptd k10temp i2c_piix4 rapl rfkill tpm_crb bmc150_accel_i2c yoga_usage_mode(OE) bmc150_accel_core industrialio_triggered_buffer kfifo_buf tpm_tis wmi industrialio video tpm_tis_core uinput tpm mac_hid kvm_amd i2c_hid_acpi i2c_hid pinctrl_amd soc_button_array acpi_cpufreq ccp rng_core kvm squashfs irqbypass vboxnetflt(OE) vboxnetadp(OE) loop vboxdrv(OE) drm sg crypto_user fuse agpgart bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 sdhci_pci cqhci sdhci i8042 crc32c_intel xhci_pci mmc_core serio
[14192.178744] CPU: 4 PID: 23356 Comm: pamac-manager Tainted: G OE 5.12.19-1-MANJARO #1
[14192.178748] Hardware name: LENOVO 81SS/LNVNB161216, BIOS AGCN28WW(V1.11) 01/27/2021
[14192.178750] RIP: 0010:rcu_note_context_switch+0x4a/0x520
[14192.178754] Code: 00 48 83 ec 10 65 48 03 1d 13 46 af 4e 0f 1f 44 00 00 40 84 ed 75 15 65 48 8b 04 25 c0 7b 01 00 8b 90 fc 03 00 00 85 d2 7e 02 <0f> 0b 65 48 8b 04 25 c0 7b 01 00 8b 80 fc 03 00 00 85 c0 7e 0a 41
[14192.178757] RSP: 0018:ffffb1d20164bac0 EFLAGS: 00010002
[14192.178760] RAX: ffff9e36f7291f40 RBX: ffff9e3984b2d600 RCX: 0000000000000000
[14192.178762] RDX: 0000000000000001 RSI: ffffffffb1eb5e3b RDI: 0000000000000000
[14192.178764] RBP: 0000000000000000 R08: ffffffffb2e084a0 R09: ffffffffb2e084a0
[14192.178765] R10: 0000000000000001 R11: 0000000000000001 R12: ffff9e3984b2c7c0
[14192.178767] R13: ffff9e36f7291f40 R14: ffff9e36f7291f40 R15: ffffffffb2e08498
[14192.178769] FS: 00007f2f9774c9c0(0000) GS:ffff9e3984b00000(0000) knlGS:0000000000000000
[14192.178771] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[14192.178772] CR2: 00007f2f88030020 CR3: 00000001028d0000 CR4: 00000000003506e0
[14192.178774] Call Trace:
[14192.178779] ? sched_clock_cpu+0xc/0xb0
[14192.178789] __schedule+0xcb/0x8b0
[14192.178797] schedule+0x5b/0xc0
[14192.178799] io_schedule+0x42/0x70
[14192.178801] wait_on_page_bit_common+0x131/0x400
[14192.178807] ? __page_cache_alloc+0x80/0x80
[14192.178811] shmem_swapin_page+0x5b6/0x750
[14192.178817] ? xas_load+0x5/0x70
[14192.178822] ? pagecache_get_page+0x1e6/0x510
[14192.178824] shmem_getpage_gfp+0x3e2/0x8e0
[14192.178829] shmem_file_read_iter+0x18a/0x410
[14192.178834] new_sync_read+0x152/0x1e0
[14192.178841] vfs_read+0x147/0x1a0
[14192.178845] ksys_read+0x67/0xe0
[14192.178848] do_syscall_64+0x33/0x40
[14192.178852] entry_SYSCALL_64_after_hwframe+0x44/0xae
[14192.178857] RIP: 0033:0x7f2f9b76a89c
[14192.178859] Code: ec 28 48 89 54 24 18 48 89 74 24 10 89 7c 24 08 e8 a9 56 f9 ff 48 8b 54 24 18 48 8b 74 24 10 41 89 c0 8b 7c 24 08 31 c0 0f 05 <48> 3d 00 f0 ff ff 77 34 44 89 c7 48 89 44 24 08 e8 ff 56 f9 ff 48
[14192.178861] RSP: 002b:00007ffd9e92ab70 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
[14192.178864] RAX: ffffffffffffffda RBX: 0000560082393020 RCX: 00007f2f9b76a89c
[14192.178865] RDX: 0000000000001000 RSI: 00007ffd9e92ac30 RDI: 0000000000000015
[14192.178866] RBP: 00007f2f9b83d300 R08: 0000000000000000 R09: 00007f2f9b83ba60
[14192.178868] R10: 0000560084a3d870 R11: 0000000000000246 R12: 00007ffd9e92ac30
[14192.178869] R13: 0000000000000d68 R14: 00007f2f9b83c700 R15: 0000000000001000
[14192.178872] ---[ end trace f4276ddfa45a43bc ]---
[14193.288948] audit: type=1130 audit(1632585480.074:880): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=flatpak-system-helper comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14195.517257] audit: type=1326 audit(1632585482.305:881): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=23534 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f37ec674c7f code=0x50000
[14195.517291] audit: type=1326 audit(1632585482.305:882): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=23534 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f37ec674c7f code=0x50000
[14195.517341] audit: type=1326 audit(1632585482.305:883): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=23534 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f37ec674c7f code=0x50000
[14195.517396] audit: type=1326 audit(1632585482.305:884): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=23534 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f37ec674c7f code=0x50000
[14195.517561] audit: type=1326 audit(1632585482.305:885): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=23534 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f37ec674c7f code=0x50000
[14195.517597] audit: type=1326 audit(1632585482.305:886): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=23534 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f37ec674c7f code=0x50000
[14226.118070] kauditd_printk_skb: 8 callbacks suppressed
[14226.118076] audit: type=1100 audit(1632585512.902:895): pid=23662 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="garrett" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[14226.123754] audit: type=1101 audit(1632585512.909:896): pid=23662 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="garrett" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[14226.679145] audit: type=1334 audit(1632585513.466:897): prog-id=323 op=LOAD
[14226.679459] audit: type=1334 audit(1632585513.466:898): prog-id=324 op=LOAD
[14226.679767] audit: type=1334 audit(1632585513.466:899): prog-id=325 op=LOAD
[14226.826199] audit: type=1130 audit(1632585513.612:900): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14256.860381] audit: type=1131 audit(1632585543.650:901): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14257.050409] audit: type=1334 audit(1632585543.840:902): prog-id=325 op=UNLOAD
[14257.050433] audit: type=1334 audit(1632585543.840:903): prog-id=324 op=UNLOAD
[14257.050436] audit: type=1334 audit(1632585543.840:904): prog-id=323 op=UNLOAD
[14417.997908] audit: type=1334 audit(1632585704.794:905): prog-id=326 op=LOAD
[14417.998164] audit: type=1334 audit(1632585704.794:906): prog-id=327 op=LOAD
[14417.998286] audit: type=1334 audit(1632585704.794:907): prog-id=328 op=LOAD
[14418.148727] audit: type=1130 audit(1632585704.944:908): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14430.681712] audit: type=1326 audit(1632585717.478:909): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.681840] audit: type=1326 audit(1632585717.478:910): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.681886] audit: type=1326 audit(1632585717.478:911): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.681927] audit: type=1326 audit(1632585717.478:912): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.683142] audit: type=1326 audit(1632585717.481:913): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.689623] audit: type=1326 audit(1632585717.488:914): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.689644] audit: type=1326 audit(1632585717.488:915): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.689689] audit: type=1326 audit(1632585717.488:916): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.689739] audit: type=1326 audit(1632585717.488:917): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14430.689789] audit: type=1326 audit(1632585717.488:918): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24322 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f94f51b0c7f code=0x50000
[14448.182968] kauditd_printk_skb: 4 callbacks suppressed
[14448.182973] audit: type=1131 audit(1632585734.978:923): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[14448.315606] audit: type=1334 audit(1632585735.112:924): prog-id=328 op=UNLOAD
[14448.315621] audit: type=1334 audit(1632585735.112:925): prog-id=327 op=UNLOAD
[14448.315626] audit: type=1334 audit(1632585735.112:926): prog-id=326 op=UNLOAD
[14484.847386] audit: type=1326 audit(1632585771.643:927): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.849236] audit: type=1326 audit(1632585771.647:928): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.849283] audit: type=1326 audit(1632585771.647:929): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.850224] audit: type=1326 audit(1632585771.647:930): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.850258] audit: type=1326 audit(1632585771.647:931): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.850283] audit: type=1326 audit(1632585771.647:932): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.850339] audit: type=1326 audit(1632585771.650:933): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.850381] audit: type=1326 audit(1632585771.650:934): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.850576] audit: type=1326 audit(1632585771.650:935): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14484.852026] audit: type=1326 audit(1632585771.650:936): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24556 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f3c717f3c7f code=0x50000
[14568.013925] kauditd_printk_skb: 4 callbacks suppressed
[14568.013953] audit: type=1326 audit(1632585854.817:941): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.013990] audit: type=1326 audit(1632585854.817:942): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.014002] audit: type=1326 audit(1632585854.817:943): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.014132] audit: type=1326 audit(1632585854.817:944): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.014277] audit: type=1326 audit(1632585854.817:945): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.014335] audit: type=1326 audit(1632585854.817:946): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.014405] audit: type=1326 audit(1632585854.817:947): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.019632] audit: type=1326 audit(1632585854.817:949): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.019659] audit: type=1326 audit(1632585854.817:948): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14568.019672] audit: type=1326 audit(1632585854.817:950): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.onenote-desktop.onenote-desktop (enforce) pid=24838 comm="onenote-desktop" exe="/snap/onenote-desktop/13/onenote-desktop" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7fdfb2135c7f code=0x50000
[14793.966692] kauditd_printk_skb: 4 callbacks suppressed
[14793.966700] audit: type=1131 audit(1632586080.778:955): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=flatpak-system-helper comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16029.000022] audit: type=1100 audit(1632587315.439:956): pid=26646 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="garrett" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16029.003387] audit: type=1101 audit(1632587315.443:957): pid=26646 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="garrett" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16029.003701] audit: type=1110 audit(1632587315.443:958): pid=26646 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16029.011006] audit: type=1105 audit(1632587315.453:959): pid=26646 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16112.720056] audit: type=1106 audit(1632587399.149:960): pid=26646 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16112.720187] audit: type=1104 audit(1632587399.149:961): pid=26646 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16156.032319] audit: type=1100 audit(1632587442.457:962): pid=26810 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="garrett" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16156.034880] audit: type=1101 audit(1632587442.460:963): pid=26810 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="garrett" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16156.035182] audit: type=1110 audit(1632587442.460:964): pid=26810 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[16156.038342] audit: type=1105 audit(1632587442.463:965): pid=26810 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
My microphone is having issues. For some reasson the volume of the microphone keeps turning itself down when I’m on a video call (the only time I use my microphone). If I open the volume tray form the task manager and turn it back up to talk, I can watch it turn the mic volume back down as I do. It does thsi right as I start talking. Now no one can hear me. They seem to only get a vauge idea of the fact that I’m talking because the volume is so low.
The microphone worked just fine on Windows 10 before I switched over.
Thanks!
