Здравствуйте. Не могу установить себе драйвер nvidia через mhwd.
> sudo mhwd -a pci nonfree 0300
> > Using config 'video-nvidia-390xx' for device: 0000:01:00.0 (0300:10de:0fe4) Display controller nVidia Corporation GK107M [GeForce GT 750M]
> > Installing video-nvidia-390xx...
> Sourcing /etc/mhwd-x86_64.conf
> Has lib32 support: true
> Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-390xx/MHWDCONFIG
> Processing classid: 0300
> Sourcing /var/lib/mhwd/scripts/include/0300
> Processing classid: 0302
> :: Обновление баз данных пакетов...
> core downloading...
> extra downloading...
> community downloading...
> multilib downloading...
> ошибка: не найдена цель: linux513-nvidia-390xx
> Error: pacman failed!
> Error: script failed!
Установил себе ядро 5.10, но mhwd упорно ищет именно linux513-nvidia-390xx. Переустановил mhwd-db, обновил список пакетов, но результат все то же.
ok
Kernel: 5.4.169-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4e7910bf-95bc-4100-8fff-3501e30cbd2d rw quiet apparmor=1
Desktop: i3 4.20.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 20193 v: Lenovo IdeaPad Y500
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad Y500
Mobo: LENOVO model: INVALID serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 6BCN44WW(V2.04) date: 05/21/2013
ID-1: BAT1 charge: 50.3 Wh (96.5%) condition: 52.1/62.7 Wh (83.0%)
volts: 12.2 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: Charging
Info: model: Intel Core i5-3230M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1531 high: 1689 min/max: 1200/3200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1653 2: 1689 3: 1490
4: 1292 bogomips: 20760
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf
Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GK107M [GeForce GT 750M] vendor: Lenovo driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fe4 class-ID: 0300
Device-2: Syntek Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 2-1:2 chip-ID: 174f:1474 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: picom v: git-dac85
driver: loaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: LVDS-1 res: 1920x1080 hz: 60 dpi: 141
size: 345x194mm (13.6x7.6") diag: 396mm (15.6")
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Sound Server-1: ALSA v: k5.4.169-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Realtek
driver: alx v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 1969:1091
class-ID: 0200
Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
bus-ID: 03:00.0 chip-ID: 8086:0888 class-ID: 0280
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 1-1.3:3 chip-ID: 8087:07da class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.13 TiB used: 31.11 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 62C3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate
model: ST1000LM024 HN-M101MBB size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 0002 scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
used: 11.29 GiB (11.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 107.42 GiB size: 105.18 GiB (97.91%)
used: 19.82 GiB (18.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: partition size: 18.08 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 59.0 C mobo: N/A gpu: nouveau temp: 43.0 C
Processes: 189 Uptime: 44m wakeups: 1 Memory: 15.59 GiB
used: 3.21 GiB (20.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1287 lib: 439 Shell: Bash v: 5.1.12
running-in: gnome-terminal inxi: 3.3.11
