Megasync: error while loading shared libraries
Since the update whenever I try to start mega I get this error:
megasync: error while loading shared libraries: libicuuc.so.67: cannot open shared object file: No such file or directory
megasync is a AUR package, have you tried rebuilding it?
/usr/bin/ld: warning: libicuuc.so.67, needed by /usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/../../../../lib/libpdfium.so, not found (try using -rpath or -rpath-link)
Yeah
EDIT:
It seems libpdfium got removed after the update for no reason
But megasync works fine for me after update without rebuilding. I did not install libpdfium.
/usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/../../../../lib/libpdfium.so is strange, why many /../?
You can add Megasync repo to /etc/pacman.conf:
or use megasync-bin from AUR. Both versions are independent of libpdfium (or provide it builtin I don’t know).
I did not install megasync from AUR.
I downloaded original megasync from the website MEGA Desktop App - MEGA
Had to switch to megasync-bin
I switched to megasync git because an update broke megasync. Had zero issues since switching to git version
If you wish, I’m not sure if rclone supports it, but I suspect it does, you can and should give it a try as well.
If they’re not supported as a provider, rclone supports WebDav as well as many other protocols too. I use it for Onedrive.
So give it a go.
