Mate+BSPWM
Hello,
I recently started using Mate+BSPWM and really enjoying it. Thank for creating the spin. When a window is maximized, the window hides part of the limepnael on the top. Where in the config can I adjust MAX window size? Is this the right approach?Attached is a screenshot.
Thanks for any suggestions/comments.
Tips for posting
Use a “keyword search” to make sure your question has not already been asked. For example “failed to verify key” or “sound is muted”.
Make sure you include enough detail so people know what you are running. A useful command is inxi -Fxz; copy and paste the text and format as “code” (e.g. use the </> button above).
If possible, paste text rather than upload a photo. Text is easier to read, searchable, and takes up less space on the server. Please don’t upload high-resolution photos.
For more information read this post: How to provide good information in your posts
Remember to remove all of this help text before you post.
it should be panel size in ~/.limepanelrc
increase the value
If it’s a different problem from the main one, you should open a new topic and not give nearly closed ones new life :thinking:
