I am facing several issues on Lutris. I have searched for answers, and I am honestly still lost.
Gtk-Message: 23:47:10.432: Failed to load module "xapp-gtk3-module"
(lutris:38195): Gtk-WARNING **: 23:47:10.434: GTK+ module /snap/lutris/214/gnome-platform/usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so cannot be loaded.
GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported.
Gtk-Message: 23:47:10.434: Failed to load module "canberra-gtk-module"
2023-10-22 23:47:10,507: Command '7z' not found on your system
2023-10-22 23:47:10,508: Command 'wine' not found on your system
2023-10-22 23:47:10,508: Command 'fluidsynth' not found on your system
2023-10-22 23:47:10,825: Couldn't find a terminal emulator.
(lutris:38195): Gtk-WARNING **: 23:47:11.017: Theme parsing error: gtk.css:1:21: Failed to import: Error opening file /home/tyler/snap/lutris/214/.config/gtk-3.0/colors.css: No such file or directory
Gtk-Message: 23:47:11.035: Failed to load module "colorreload-gtk-module"
Gtk-Message: 23:47:11.035: Failed to load module "window-decorations-gtk-module"
2023-10-22 23:47:11,097: Starting Lutris 0.5.14
2023-10-22 23:47:11,098: Using NVIDIA drivers 535.113.01 for x86_64
2023-10-22 23:47:11,099: GPU: NVIDIA GeForce GTX 1080
2023-10-22 23:47:11,099: GPU: 10DE:1B80 3842:6687 (nvidia drivers)
2023-10-22 23:47:11,099: GPU: (simple-framebuffer drivers)
(lutris:38195): IBUS-WARNING **: 23:47:11.266: Failed to mkdir /home/tyler/snap/lutris/214/.config/ibus/bus: Not a directory
Launching it in Konsole, this is what it gives me.
To list the issues:
Cannot install the EA app or Ubisoft Connect
Crashes when trying to login to the Itch or Gog tabs
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, beforeANDafter the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
there is no need for the EA app itself, AFAIK you can use Lutris to install and use the game on its own. I also don’t really like those kind of apps, but I’m obviously in the minority here.
I think you can install the app as a game and use it that way.
Like I mentioned, I’m no gamer, but the 2 games I occasionally play works beautifully: Starcraft II using Lutris, and World Turtles using steam.
That still gets away from the main problem I am trying to solve; the issues listed by the terminal on launching Lutris. What I am asking is, how do I fix specifically these listed issues.
Still using the SNAP. A number of them apparently.
( SNAP = something that is supposed to be bundled with everything it needs, but may not be, meaning its large, but you cant handle the dependencies if it was bundled incorrectly. Even better when combined with its other features of ‘containerization’ meaning it wont interface with the rest of your system as expected, and yet no, that doesnt actually mean its safer. The thoroughly inferior software deployment model. )
…so despite having been told multiple times to not use snap, because it only causes problems, as you’re experiencing, you refuse to do so, and then wwant to know why it doesn’t work…
I suggest you install the version from the repositories, and use THAT to install the games. Bu my suggestions have been ignored all the way, so it’s only that - a suggestion.
By the way, I realize now how rude I came off… I’m sorry for not listening closer and having just fled at the very first problem I faced. I followed through now with your instruction of removing the snap version. Mr lavender recommending the flatpak helped. But again, after my stupidity, thank you for the help. The guide on getting EA to work helped, so thank you.
