@Darksky, I’m sorry, but I don’t understand what package you’re talking about and why me need it here.
I am interested in the steps for Waydroid and Wayland.
Install KDE and boot with a wayland session and follow the steps in the link I gave above and install waydroid. I do not know if I can say it any plainer.
Depending on the device, this step may or may not make sense.
On the PinePhone or PinePhone Pro, you probably want to use Plasma Mobile or Phosh rather than Plasma Desktop (i.e., what is usually meant by “KDE”). They are all Wayland-based (and in fact their sessions are always Wayland).
He does not have a mobile phone. I think he has a tv box. Depending on his gpu he may or may not get waydroid working. The last time I tried the rpi would not work.
So this emulator requires KDE?
But I can’t use it, I only work with XFCE.
Therefore, your advice is unsuitable
And it’s all kind of complicated. Is there really no ready-made independent Android emulator package that was installed and worked without third-party applications?
These multiple limitations and features of Manjaro are starting to get pretty annoying.
I admit, I would love to test Armbian to compare it with a Manjaro , but unfortunately, he doesn’t want to work for me.
But Manjaro has a friendly community, while Armbian has a lazy and indifferent one.
And it keeps me on Manjaro
Generally, there is no easy way, it will always be some kind of virtual machine. I would try my best to find alternative program that does the same if i were you. It will probably be simpler.
P.s. that quoted version of the android app is 8 years old and not even in the playstore anymore. Just find an alternative.
Yes, you are right, this is the best way. But I bought this DVR back in 2014, and only old Windows, Android applications and web browser work with it. There are no other applications. Updates to them no too.
But only the Internet Explorer works from web browsers, others refuse to show the image because the N9_ActiveX.cab plugin cannot be connected to them.
Me now have to work like this:
- launch Debian, then VirtualBox, then Windows XP, then Internet Explorer.
It’s very cumbersome, long, and inconvenient, so I tried to use the Android emulator in Manjaro.
But so far it doesn’t work either
