sudo dmesg --level emerg,alert,crit,err,warn
[ 0.095679] x86/cpu: SGX disabled by BIOS.
[ 0.103841] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.103841] #5 #6 #7
[ 0.107546] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.262926] ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210331/psparse-529)
[ 0.262934] ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210331/uteval-68)
[ 0.263989] ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210331/psparse-529)
[ 0.263995] ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210331/uteval-68)
[ 1.206410] i8042: Warning: Keylock active
[ 16.954629] systemd-journald[272]: File /var/log/journal/b2c1a00eda6b4c9eb901c025487a0d49/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 17.687438] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 17.687474] wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
[ 17.687475] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 18.388629] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 18.388631] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 18.388632] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 18.388633] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 18.388634] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 18.388634] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 18.388635] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 18.388636] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 18.388637] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 18.388637] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 18.388638] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 18.388639] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 18.388640] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 18.388640] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 18.388641] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 18.388642] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 18.388643] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 19.104293] thermal thermal_zone7: failed to read out thermal zone (-61)
[ 19.736495] nvidia: loading out-of-tree module taints kernel.
[ 19.736524] nvidia: module license 'NVIDIA' taints kernel.
[ 19.736526] Disabling lock debugging due to kernel taint
[ 19.926539] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.63.01 Tue Aug 3 20:44:16 UTC 2021
[ 20.078435] kauditd_printk_skb: 5 callbacks suppressed
[ 22.939713] Bluetooth: hci0: MSFT filter_enable is already on
[ 25.104626] kauditd_printk_skb: 23 callbacks suppressed
[ 31.926402] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210331/nsarguments-61)
[ 39.419799] kauditd_printk_skb: 12 callbacks suppressed
[ 349.930329] FAT-fs (nvme0n1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
fsck
fsck from util-linux 2.37.1
e2fsck 1.46.3 (27-Jul-2021)
/dev/nvme0n1p2 is mounted.
e2fsck: Cannot continue, aborting.
seems that the journal isnt saving something that it should:
journalctl --boot -1 --no-hostname | curl -F'file=@-' https://0x0.st
Data from the specified boot (-1) is not available: No such boot ID in journal
sudo dmesg
[ 0.000000] microcode: microcode updated early to revision 0xea, date = 2021-01-05
[ 0.000000] Linux version 5.13.11-1-MANJARO (builduser@fv-az39-548) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sun Aug 15 13:15:18 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=87af63ea-9ca6-4299-9c34-63337c3c60d6 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000005dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000005e000-0x000000000005efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000005f000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000068344fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000068345000-0x0000000068345fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000068346000-0x0000000068346fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000068347000-0x0000000077da2fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000077da3000-0x000000007951afff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007951b000-0x0000000079597fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000079598000-0x0000000079f0cfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000079f0d000-0x000000007b51afff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007b51b000-0x000000007b5fdfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000007b5fe000-0x000000007b5fefff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007b5ff000-0x000000007f7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027e7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0x79534000 ACPI=0x79534000 SMBIOS=0x7b255000 SMBIOS 3.0=0x7b254000 TPMFinalLog=0x79b6d000 ESRT=0x7b207018 MEMATTR=0x73a04018
[ 0.000000] SMBIOS 3.1.1 present.
[ 0.000000] DMI: Dell Inc. G3 3579/0JYXHN, BIOS 1.15.0 04/20/2021
[ 0.000000] tsc: Detected 2300.000 MHz processor
[ 0.000000] tsc: Detected 2299.968 MHz TSC
[ 0.000404] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000406] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000411] last_pfn = 0x27e800 max_arch_pfn = 0x400000000
[ 0.000515] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001165] last_pfn = 0x7b5ff max_arch_pfn = 0x400000000
[ 0.006363] found SMP MP-table at [mem 0x000fd000-0x000fd00f]
[ 0.006371] esrt: Reserving ESRT space from 0x000000007b207018 to 0x000000007b207050.
[ 0.006376] Using GB pages for direct mapping
[ 0.006611] Secure boot disabled
[ 0.006612] RAMDISK: [mem 0x366f7000-0x37372fff]
[ 0.006615] ACPI: Early table checksum verification disabled
[ 0.006617] ACPI: RSDP 0x0000000079534000 000024 (v02 DELL )
[ 0.006620] ACPI: XSDT 0x00000000795340C0 000104 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.006624] ACPI: FACP 0x00000000795739A8 000114 (v06 DELL CBX3 01072009 AMI 00010013)
[ 0.006628] ACPI: DSDT 0x0000000079534258 03F750 (v02 DELL CBX3 01072009 INTL 20160527)
[ 0.006630] ACPI: FACS 0x0000000079F0BC00 000040
[ 0.006632] ACPI: APIC 0x0000000079573AC0 0000BC (v04 DELL CBX3 01072009 AMI 00010013)
[ 0.006634] ACPI: FPDT 0x0000000079573B80 000044 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.006636] ACPI: FIDT 0x0000000079573BC8 00009C (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.006638] ACPI: MCFG 0x0000000079573C68 00003C (v01 DELL CBX3 01072009 MSFT 00000097)
[ 0.006639] ACPI: SSDT 0x0000000079573CA8 000761 (v01 SataRe SataTabl 00001000 INTL 20160527)
[ 0.006642] ACPI: SSDT 0x0000000079574410 001818 (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.006644] ACPI: BOOT 0x0000000079575C28 000028 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.006646] ACPI: SSDT 0x0000000079575C50 001336 (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.006648] ACPI: SSDT 0x0000000079576F88 0025EE (v02 PegSsd PegSsdt 00001000 INTL 20160527)
[ 0.006650] ACPI: HPET 0x0000000079579578 000038 (v01 INTEL CBX3 00000002 01000013)
[ 0.006652] ACPI: SSDT 0x00000000795795B0 002A07 (v02 INTEL xh_cfhd4 00000000 INTL 20160527)
[ 0.006654] ACPI: UEFI 0x000000007957BFB8 000048 (v01 DELL\x CBX3 00000002 01000013)
[ 0.006656] ACPI: LPIT 0x000000007957C000 00005C (v01 INTEL CBX3 00000002 01000013)
[ 0.006658] ACPI: SSDT 0x000000007957C060 0027DE (v02 INTEL PtidDevc 00001000 INTL 20160527)
[ 0.006660] ACPI: SSDT 0x000000007957E840 000FFE (v02 INTEL TbtTypeC 00000000 INTL 20160527)
[ 0.006662] ACPI: DBGP 0x000000007957F840 000034 (v01 DELL\x CBX3 00000002 01000013)
[ 0.006664] ACPI: DBG2 0x000000007957F878 000054 (v00 DELL\x CBX3 00000002 01000013)
[ 0.006666] ACPI: SSDT 0x000000007957F8D0 0007E8 (v02 DELL\x UsbCTabl 00001000 INTL 20160527)
[ 0.006668] ACPI: SSDT 0x00000000795800B8 006875 (v02 DptfTa DptfTabl 00001000 INTL 20160527)
[ 0.006670] ACPI: MSDM 0x0000000079586930 000055 (v03 DELL CBX3 06222004 AMI 00010013)
[ 0.006672] ACPI: SLIC 0x0000000079586988 000176 (v03 DELL CBX3 01072009 MSFT 00010013)
[ 0.006674] ACPI: SSDT 0x0000000079586B00 000144 (v02 Intel ADebTabl 00001000 INTL 20160527)
[ 0.006676] ACPI: SSDT 0x0000000079586C48 0000AE (v02 SgRef SgPeg 00001000 INTL 20160527)
[ 0.006678] ACPI: DMAR 0x0000000079586CF8 0000A8 (v01 INTEL EDK2 00000002 01000013)
[ 0.006680] ACPI: TPM2 0x0000000079586DA0 000034 (v04 DELL\x CBX3 00000001 AMI 00000000)
[ 0.006682] ACPI: SSDT 0x0000000079586DD8 001FDE (v01 OptRef OptTabl 00001000 INTL 20160527)
[ 0.006684] ACPI: BGRT 0x0000000079588DB8 000038 (v00 \xf3\xee 01072009 AMI 00010013)
[ 0.006685] ACPI: Reserving FACP table memory at [mem 0x795739a8-0x79573abb]
[ 0.006686] ACPI: Reserving DSDT table memory at [mem 0x79534258-0x795739a7]
[ 0.006687] ACPI: Reserving FACS table memory at [mem 0x79f0bc00-0x79f0bc3f]
[ 0.006688] ACPI: Reserving APIC table memory at [mem 0x79573ac0-0x79573b7b]
[ 0.006688] ACPI: Reserving FPDT table memory at [mem 0x79573b80-0x79573bc3]
[ 0.006689] ACPI: Reserving FIDT table memory at [mem 0x79573bc8-0x79573c63]
[ 0.006690] ACPI: Reserving MCFG table memory at [mem 0x79573c68-0x79573ca3]
[ 0.006690] ACPI: Reserving SSDT table memory at [mem 0x79573ca8-0x79574408]
[ 0.006691] ACPI: Reserving SSDT table memory at [mem 0x79574410-0x79575c27]
[ 0.006692] ACPI: Reserving BOOT table memory at [mem 0x79575c28-0x79575c4f]
[ 0.006692] ACPI: Reserving SSDT table memory at [mem 0x79575c50-0x79576f85]
[ 0.006693] ACPI: Reserving SSDT table memory at [mem 0x79576f88-0x79579575]
[ 0.006693] ACPI: Reserving HPET table memory at [mem 0x79579578-0x795795af]
[ 0.006694] ACPI: Reserving SSDT table memory at [mem 0x795795b0-0x7957bfb6]
[ 0.006695] ACPI: Reserving UEFI table memory at [mem 0x7957bfb8-0x7957bfff]
[ 0.006695] ACPI: Reserving LPIT table memory at [mem 0x7957c000-0x7957c05b]
[ 0.006696] ACPI: Reserving SSDT table memory at [mem 0x7957c060-0x7957e83d]
[ 0.006697] ACPI: Reserving SSDT table memory at [mem 0x7957e840-0x7957f83d]
[ 0.006697] ACPI: Reserving DBGP table memory at [mem 0x7957f840-0x7957f873]
[ 0.006698] ACPI: Reserving DBG2 table memory at [mem 0x7957f878-0x7957f8cb]
[ 0.006699] ACPI: Reserving SSDT table memory at [mem 0x7957f8d0-0x795800b7]
[ 0.006699] ACPI: Reserving SSDT table memory at [mem 0x795800b8-0x7958692c]
[ 0.006700] ACPI: Reserving MSDM table memory at [mem 0x79586930-0x79586984]
[ 0.006701] ACPI: Reserving SLIC table memory at [mem 0x79586988-0x79586afd]
[ 0.006701] ACPI: Reserving SSDT table memory at [mem 0x79586b00-0x79586c43]
[ 0.006702] ACPI: Reserving SSDT table memory at [mem 0x79586c48-0x79586cf5]
[ 0.006703] ACPI: Reserving DMAR table memory at [mem 0x79586cf8-0x79586d9f]
[ 0.006703] ACPI: Reserving TPM2 table memory at [mem 0x79586da0-0x79586dd3]
[ 0.006704] ACPI: Reserving SSDT table memory at [mem 0x79586dd8-0x79588db5]
[ 0.006705] ACPI: Reserving BGRT table memory at [mem 0x79588db8-0x79588def]
[ 0.006719] ACPI: Local APIC address 0xfee00000
[ 0.006976] No NUMA configuration found
[ 0.006977] Faking a node at [mem 0x0000000000000000-0x000000027e7fffff]
[ 0.006980] NODE_DATA(0) allocated [mem 0x27e7fc000-0x27e7fffff]
[ 0.006996] Zone ranges:
[ 0.006997] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.006998] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.007000] Normal [mem 0x0000000100000000-0x000000027e7fffff]
[ 0.007001] Device empty
[ 0.007001] Movable zone start for each node
[ 0.007002] Early memory node ranges
[ 0.007002] node 0: [mem 0x0000000000001000-0x000000000005dfff]
[ 0.007003] node 0: [mem 0x000000000005f000-0x000000000009ffff]
[ 0.007004] node 0: [mem 0x0000000000100000-0x0000000068344fff]
[ 0.007005] node 0: [mem 0x0000000068347000-0x0000000077da2fff]
[ 0.007006] node 0: [mem 0x000000007b5fe000-0x000000007b5fefff]
[ 0.007006] node 0: [mem 0x0000000100000000-0x000000027e7fffff]
[ 0.007007] Initmem setup node 0 [mem 0x0000000000001000-0x000000027e7fffff]
[ 0.007009] On node 0 totalpages: 2057536
[ 0.007009] DMA zone: 64 pages used for memmap
[ 0.007010] DMA zone: 158 pages reserved
[ 0.007011] DMA zone: 3998 pages, LIFO batch:0
[ 0.007012] DMA32 zone: 7607 pages used for memmap
[ 0.007012] DMA32 zone: 486818 pages, LIFO batch:63
[ 0.007013] Normal zone: 24480 pages used for memmap
[ 0.007013] Normal zone: 1566720 pages, LIFO batch:63
[ 0.007015] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.007016] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.007031] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.010680] On node 0, zone DMA32: 2 pages in unavailable ranges
[ 0.010793] On node 0, zone DMA32: 14427 pages in unavailable ranges
[ 0.024220] On node 0, zone Normal: 18945 pages in unavailable ranges
[ 0.024265] On node 0, zone Normal: 6144 pages in unavailable ranges
[ 0.024293] Reserving Intel graphics memory at [mem 0x7d800000-0x7f7fffff]
[ 0.025061] ACPI: PM-Timer IO Port: 0x1808
[ 0.025063] ACPI: Local APIC address 0xfee00000
[ 0.025067] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.025068] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.025068] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.025069] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.025069] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.025070] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.025070] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.025071] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.025128] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.025130] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.025131] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.025132] ACPI: IRQ0 used by override.
[ 0.025133] ACPI: IRQ9 used by override.
[ 0.025134] Using ACPI (MADT) for SMP configuration information
[ 0.025135] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.025139] e820: update [mem 0x72ca8000-0x72d30fff] usable ==> reserved
[ 0.025146] TSC deadline timer available
[ 0.025146] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.025160] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.025162] PM: hibernation: Registered nosave memory: [mem 0x0005e000-0x0005efff]
[ 0.025163] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.025164] PM: hibernation: Registered nosave memory: [mem 0x68345000-0x68345fff]
[ 0.025165] PM: hibernation: Registered nosave memory: [mem 0x68346000-0x68346fff]
[ 0.025166] PM: hibernation: Registered nosave memory: [mem 0x72ca8000-0x72d30fff]
[ 0.025167] PM: hibernation: Registered nosave memory: [mem 0x77da3000-0x7951afff]
[ 0.025168] PM: hibernation: Registered nosave memory: [mem 0x7951b000-0x79597fff]
[ 0.025168] PM: hibernation: Registered nosave memory: [mem 0x79598000-0x79f0cfff]
[ 0.025169] PM: hibernation: Registered nosave memory: [mem 0x79f0d000-0x7b51afff]
[ 0.025169] PM: hibernation: Registered nosave memory: [mem 0x7b51b000-0x7b5fdfff]
[ 0.025170] PM: hibernation: Registered nosave memory: [mem 0x7b5ff000-0x7f7fffff]
[ 0.025171] PM: hibernation: Registered nosave memory: [mem 0x7f800000-0xefffffff]
[ 0.025171] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[ 0.025172] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfdffffff]
[ 0.025172] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.025173] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.025174] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.025174] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.025175] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.025175] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.025176] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.025176] [mem 0x7f800000-0xefffffff] available for PCI devices
[ 0.025177] Booting paravirtualized kernel on bare hardware
[ 0.025179] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.028792] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ 0.028941] percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u262144
[ 0.028946] pcpu-alloc: s196608 r8192 d28672 u262144 alloc=1*2097152
[ 0.028949] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.028964] Built 1 zonelists, mobility grouping on. Total pages: 2025227
[ 0.028965] Policy zone: Normal
[ 0.028966] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=87af63ea-9ca6-4299-9c34-63337c3c60d6 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.029431] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.029634] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.029687] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.052829] Memory: 7912128K/8230144K available (14344K kernel code, 2075K rwdata, 9156K rodata, 1796K init, 4076K bss, 317756K reserved, 0K cma-reserved)
[ 0.052834] random: get_random_u64 called from __kmem_cache_create+0x2a/0x580 with crng_init=0
[ 0.052925] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.052936] Kernel/User page tables isolation: enabled
[ 0.052949] ftrace: allocating 42492 entries in 166 pages
[ 0.062830] ftrace: allocated 166 pages with 4 groups
[ 0.062906] rcu: Preemptible hierarchical RCU implementation.
[ 0.062907] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.062907] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.062908] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.062909] Trampoline variant of Tasks RCU enabled.
[ 0.062909] Rude variant of Tasks RCU enabled.
[ 0.062910] Tracing variant of Tasks RCU enabled.
[ 0.062910] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.062911] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.065566] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[ 0.066160] Console: colour dummy device 80x25
[ 0.066171] printk: console [tty0] enabled
[ 0.066185] ACPI: Core revision 20210331
[ 0.066573] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.066717] APIC: Switch to symmetric I/O mode setup
[ 0.066719] DMAR: Host address width 39
[ 0.066720] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.066723] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.066725] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.066728] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.066729] DMAR: RMRR base: 0x0000007afbd000 end: 0x0000007b206fff
[ 0.066730] DMAR: RMRR base: 0x0000007d000000 end: 0x0000007f7fffff
[ 0.066732] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.066733] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.066733] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.069969] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.069971] x2apic enabled
[ 0.070001] Switched APIC routing to cluster x2apic.
[ 0.079359] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.093382] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x212717146a7, max_idle_ns: 440795291431 ns
[ 0.093386] Calibrating delay loop (skipped), value calculated using timer frequency.. 4601.60 BogoMIPS (lpj=7666560)
[ 0.093388] pid_max: default: 32768 minimum: 301
[ 0.095439] LSM: Security Framework initializing
[ 0.095443] landlock: Up and running.
[ 0.095444] Yama: becoming mindful.
[ 0.095461] AppArmor: AppArmor initialized
[ 0.095484] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.095500] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.095683] CPU0: Thermal monitoring enabled (TM1)
[ 0.095723] process: using mwait in idle threads
[ 0.095724] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.095725] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.095727] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.095728] Spectre V2 : Mitigation: Full generic retpoline
[ 0.095729] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.095729] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.095730] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.095731] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.095731] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.095735] SRBDS: Mitigation: Microcode
[ 0.095736] MDS: Mitigation: Clear CPU buffers
[ 0.097529] Freeing SMP alternatives memory: 36K
[ 0.099985] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1736
[ 0.100010] smpboot: CPU0: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.100051] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.100051] ... version: 4
[ 0.100051] ... bit width: 48
[ 0.100051] ... generic registers: 4
[ 0.100051] ... value mask: 0000ffffffffffff
[ 0.100051] ... max period: 00007fffffffffff
[ 0.100051] ... fixed-purpose events: 3
[ 0.100051] ... event mask: 000000070000000f
[ 0.100051] rcu: Hierarchical SRCU implementation.
[ 0.100051] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.100051] smp: Bringing up secondary CPUs ...
[ 0.100051] x86: Booting SMP configuration:
[ 0.100051] .... node #0, CPUs: #1 #2 #3 #4
[ 0.103847] smp: Brought up 1 node, 8 CPUs
[ 0.103847] smpboot: Max logical packages: 1
[ 0.103847] smpboot: Total of 8 processors activated (36814.80 BogoMIPS)
[ 0.106974] devtmpfs: initialized
[ 0.106974] x86/mm: Memory block size: 128MB
[ 0.107073] PM: Registering ACPI NVS region [mem 0x68345000-0x68345fff] (4096 bytes)
[ 0.107073] PM: Registering ACPI NVS region [mem 0x79598000-0x79f0cfff] (9916416 bytes)
[ 0.107073] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.107073] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.107073] pinctrl core: initialized pinctrl subsystem
[ 0.107269] PM: RTC time: 22:23:59, date: 2021-08-18
[ 0.107353] NET: Registered protocol family 16
[ 0.107456] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.107498] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.107538] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.107542] audit: initializing netlink subsys (disabled)
[ 0.107546] audit: type=2000 audit(1629325439.036:1): state=initialized audit_enabled=0 res=1
[ 0.107546] thermal_sys: Registered thermal governor 'fair_share'
[ 0.107546] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.107546] thermal_sys: Registered thermal governor 'step_wise'
[ 0.107546] thermal_sys: Registered thermal governor 'user_space'
[ 0.107546] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.107546] cpuidle: using governor ladder
[ 0.107546] cpuidle: using governor menu
[ 0.107546] Simple Boot Flag at 0x47 set to 0x80
[ 0.107546] ACPI: bus type PCI registered
[ 0.107546] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.107546] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.107546] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.107546] PCI: Using configuration type 1 for base access
[ 0.107546] Kprobes globally optimized
[ 0.107546] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.107546] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.107546] ACPI: Added _OSI(Module Device)
[ 0.107546] ACPI: Added _OSI(Processor Device)
[ 0.107546] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.107546] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.107546] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.107546] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.107546] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.174576] ACPI: 13 ACPI AML tables successfully acquired and loaded
[ 0.179547] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.186902] ACPI: Dynamic OEM Table Load:
[ 0.186907] ACPI: SSDT 0xFFFF8B3EC138F800 0005DF (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.187965] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.188976] ACPI: Dynamic OEM Table Load:
[ 0.188980] ACPI: SSDT 0xFFFF8B3EC103C000 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.189969] ACPI: Dynamic OEM Table Load:
[ 0.189973] ACPI: SSDT 0xFFFF8B3EC1082800 00011B (v02 PmRef Cpu0Hwp 00003000 INTL 20160527)
[ 0.190911] ACPI: Dynamic OEM Table Load:
[ 0.190914] ACPI: SSDT 0xFFFF8B3EC138D800 000724 (v02 PmRef HwpLvt 00003000 INTL 20160527)
[ 0.192184] ACPI: Dynamic OEM Table Load:
[ 0.192189] ACPI: SSDT 0xFFFF8B3EC0CAB000 000EF1 (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.193854] ACPI: Dynamic OEM Table Load:
[ 0.193858] ACPI: SSDT 0xFFFF8B3EC103E000 000317 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.194867] ACPI: Dynamic OEM Table Load:
[ 0.194870] ACPI: SSDT 0xFFFF8B3EC103F400 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.198160] ACPI: EC: EC started
[ 0.198160] ACPI: EC: interrupt blocked
[ 0.205251] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.205253] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
[ 0.205254] ACPI: Interpreter enabled
[ 0.205287] ACPI: (supports S0 S3 S4 S5)
[ 0.205288] ACPI: Using IOAPIC for interrupt routing
[ 0.205318] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.205984] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.207872] ACPI: PM: Power Resource [PG00] (on)
[ 0.253600] ACPI: PM: Power Resource [USBC] (on)
[ 0.256690] ACPI: PM: Power Resource [V0PR] (on)
[ 0.257145] ACPI: PM: Power Resource [V1PR] (on)
[ 0.257580] ACPI: PM: Power Resource [V2PR] (on)
[ 0.264822] ACPI: PM: Power Resource [WRST] (on)
[ 0.271564] ACPI: PM: Power Resource [PIN] (off)
[ 0.272003] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
[ 0.272008] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.275392] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.276314] PCI host bridge to bus 0000:00
[ 0.276315] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.276317] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.276318] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.276319] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xefffffff window]
[ 0.276320] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.276321] pci_bus 0000:00: root bus resource [bus 00-7e]
[ 0.276338] pci 0000:00:00.0: [8086:3e10] type 00 class 0x060000
[ 0.276428] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.276459] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.277009] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[ 0.277015] pci 0000:00:02.0: reg 0x10: [mem 0xa2000000-0xa2ffffff 64bit]
[ 0.277020] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.277022] pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
[ 0.277034] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.277191] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 0.277197] pci 0000:00:04.0: reg 0x10: [mem 0xa4410000-0xa4417fff 64bit]
[ 0.277473] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ 0.277479] pci 0000:00:08.0: reg 0x10: [mem 0xa442c000-0xa442cfff 64bit]
[ 0.277677] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.277711] pci 0000:00:12.0: reg 0x10: [mem 0xa442b000-0xa442bfff 64bit]
[ 0.278013] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.278047] pci 0000:00:14.0: reg 0x10: [mem 0xa4400000-0xa440ffff 64bit]
[ 0.278178] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.279751] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.279779] pci 0000:00:14.2: reg 0x10: [mem 0xa4422000-0xa4423fff 64bit]
[ 0.279798] pci 0000:00:14.2: reg 0x18: [mem 0xa442a000-0xa442afff 64bit]
[ 0.280074] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[ 0.280189] pci 0000:00:14.3: reg 0x10: [mem 0xa441c000-0xa441ffff 64bit]
[ 0.280814] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.281581] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[ 0.282157] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.285098] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[ 0.285673] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.288304] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.288335] pci 0000:00:16.0: reg 0x10: [mem 0xa4427000-0xa4427fff 64bit]
[ 0.288448] pci 0000:00:16.0: PME# supported from D3hot
[ 0.288855] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[ 0.288882] pci 0000:00:17.0: reg 0x10: [mem 0xa4420000-0xa4421fff]
[ 0.288896] pci 0000:00:17.0: reg 0x14: [mem 0xa4426000-0xa44260ff]
[ 0.288911] pci 0000:00:17.0: reg 0x18: [io 0x5090-0x5097]
[ 0.288925] pci 0000:00:17.0: reg 0x1c: [io 0x5080-0x5083]
[ 0.288939] pci 0000:00:17.0: reg 0x20: [io 0x5060-0x507f]
[ 0.288954] pci 0000:00:17.0: reg 0x24: [mem 0xa4425000-0xa44257ff]
[ 0.289032] pci 0000:00:17.0: PME# supported from D3hot
[ 0.289627] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[ 0.289807] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.289850] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.290570] pci 0000:00:1d.5: [8086:a335] type 01 class 0x060400
[ 0.290749] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[ 0.290788] pci 0000:00:1d.5: PTM enabled (root), 4ns granularity
[ 0.291478] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[ 0.291888] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[ 0.291947] pci 0000:00:1f.3: reg 0x10: [mem 0xa4418000-0xa441bfff 64bit]
[ 0.292021] pci 0000:00:1f.3: reg 0x20: [mem 0xa4100000-0xa41fffff 64bit]
[ 0.292166] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.295230] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.295380] pci 0000:00:1f.4: reg 0x10: [mem 0xa4424000-0xa44240ff 64bit]
[ 0.295559] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.296004] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.296029] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.296242] pci 0000:01:00.0: [10de:1c8c] type 00 class 0x030200
[ 0.296261] pci 0000:01:00.0: reg 0x10: [mem 0xa3000000-0xa3ffffff]
[ 0.296276] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.296292] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
[ 0.296302] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.296312] pci 0000:01:00.0: reg 0x30: [mem 0xa4000000-0xa407ffff pref]
[ 0.296333] pci 0000:01:00.0: Enabling HDA controller
[ 0.296417] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.296663] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300
[ 0.296679] pci 0000:01:00.1: reg 0x10: [mem 0x00000000-0x00003fff]
[ 0.296735] pci 0000:01:00.1: Max Payload Size set to 256 (was 128, max 256)
[ 0.296848] pci 0000:00:01.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 0.306746] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.306749] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.306751] pci 0000:00:01.0: bridge window [mem 0xa3000000-0xa40fffff]
[ 0.306754] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.307040] pci 0000:02:00.0: [1179:0113] type 00 class 0x010802
[ 0.307077] pci 0000:02:00.0: reg 0x10: [mem 0xa4300000-0xa4303fff 64bit]
[ 0.307283] pci 0000:02:00.0: PME# supported from D0 D3hot
[ 0.307500] pci 0000:00:1d.0: PCI bridge to [bus 02]
[ 0.307510] pci 0000:00:1d.0: bridge window [mem 0xa4300000-0xa43fffff]
[ 0.307703] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.307733] pci 0000:03:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.307771] pci 0000:03:00.0: reg 0x18: [mem 0xa4204000-0xa4204fff 64bit]
[ 0.307794] pci 0000:03:00.0: reg 0x20: [mem 0xa4200000-0xa4203fff 64bit]
[ 0.307950] pci 0000:03:00.0: supports D1 D2
[ 0.307951] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.308189] pci 0000:00:1d.5: PCI bridge to [bus 03]
[ 0.308195] pci 0000:00:1d.5: bridge window [io 0x3000-0x3fff]
[ 0.308200] pci 0000:00:1d.5: bridge window [mem 0xa4200000-0xa42fffff]
[ 0.310076] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.310114] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.310151] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.310186] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.310222] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.310257] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.310292] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.310327] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.312699] acpi LNXPOWER:06: Turning OFF
[ 0.312705] acpi LNXPOWER:05: Turning OFF
[ 0.312745] ACPI: EC: interrupt unblocked
[ 0.312746] ACPI: EC: event unblocked
[ 0.312758] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.312759] ACPI: EC: GPE=0x6e
[ 0.312761] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC initialization complete
[ 0.312762] ACPI: \_SB_.PCI0.LPCB.ECDV: EC: Used to handle transactions and events
[ 0.312831] iommu: Default domain type: Translated
[ 0.312841] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.312841] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.312841] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.312841] vgaarb: loaded
[ 0.312841] SCSI subsystem initialized
[ 0.312841] libata version 3.00 loaded.
[ 0.312841] ACPI: bus type USB registered
[ 0.312841] usbcore: registered new interface driver usbfs
[ 0.312841] usbcore: registered new interface driver hub
[ 0.312841] usbcore: registered new device driver usb
[ 0.312841] pps_core: LinuxPPS API ver. 1 registered
[ 0.312841] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.312841] PTP clock support registered
[ 0.312841] EDAC MC: Ver: 3.0.0
[ 0.313785] Registered efivars operations
[ 0.313785] NetLabel: Initializing
[ 0.313785] NetLabel: domain hash size = 128
[ 0.313785] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.313785] NetLabel: unlabeled traffic allowed by default
[ 0.313785] PCI: Using ACPI for IRQ routing
[ 0.357326] PCI: pci_cache_line_size set to 64 bytes
[ 0.357681] e820: reserve RAM buffer [mem 0x0005e000-0x0005ffff]
[ 0.357684] e820: reserve RAM buffer [mem 0x68345000-0x6bffffff]
[ 0.357684] e820: reserve RAM buffer [mem 0x72ca8000-0x73ffffff]
[ 0.357685] e820: reserve RAM buffer [mem 0x77da3000-0x77ffffff]
[ 0.357686] e820: reserve RAM buffer [mem 0x7b5ff000-0x7bffffff]
[ 0.357686] e820: reserve RAM buffer [mem 0x27e800000-0x27fffffff]
[ 0.357690] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.357690] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.362142] clocksource: Switched to clocksource tsc-early
[ 0.364631] VFS: Disk quotas dquot_6.6.0
[ 0.364631] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.364631] AppArmor: AppArmor Filesystem Enabled
[ 0.364631] pnp: PnP ACPI init
[ 0.364631] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.364631] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.364631] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.364631] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.364631] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.364631] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.364631] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.364631] pnp 00:04: Plug and Play ACPI device, IDs DLL086f PNP0f13 (active)
[ 0.364631] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.364631] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.364631] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.364631] system 00:05: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.364631] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.364631] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.364631] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.364631] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.364631] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.364631] system 00:06: [io 0x1800-0x18fe] could not be reserved
[ 0.364631] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.364631] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.364631] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.364631] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.364631] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.364631] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.364631] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.364631] system 00:07: [io 0x2000-0x20fe] has been reserved
[ 0.364631] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.367257] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.369379] pnp: PnP ACPI: found 9 devices
[ 0.374545] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.374581] NET: Registered protocol family 2
[ 0.374652] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.375331] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.375365] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.375456] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.375501] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.375544] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.375566] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.375583] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.375613] NET: Registered protocol family 1
[ 0.375616] NET: Registered protocol family 44
[ 0.375626] pci 0000:00:15.0: BAR 0: assigned [mem 0x7f800000-0x7f800fff 64bit]
[ 0.375899] pci 0000:00:15.1: BAR 0: assigned [mem 0x7f801000-0x7f801fff 64bit]
[ 0.376168] pci 0000:01:00.1: BAR 0: assigned [mem 0xa4080000-0xa4083fff]
[ 0.376172] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.376173] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.376175] pci 0000:00:01.0: bridge window [mem 0xa3000000-0xa40fffff]
[ 0.376176] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.376179] pci 0000:00:1d.0: PCI bridge to [bus 02]
[ 0.376189] pci 0000:00:1d.0: bridge window [mem 0xa4300000-0xa43fffff]
[ 0.376201] pci 0000:00:1d.5: PCI bridge to [bus 03]
[ 0.376204] pci 0000:00:1d.5: bridge window [io 0x3000-0x3fff]
[ 0.376211] pci 0000:00:1d.5: bridge window [mem 0xa4200000-0xa42fffff]
[ 0.376223] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.376225] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.376225] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.376226] pci_bus 0000:00: resource 7 [mem 0x7f800000-0xefffffff window]
[ 0.376227] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[ 0.376228] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.376229] pci_bus 0000:01: resource 1 [mem 0xa3000000-0xa40fffff]
[ 0.376230] pci_bus 0000:01: resource 2 [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.376231] pci_bus 0000:02: resource 1 [mem 0xa4300000-0xa43fffff]
[ 0.376232] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 0.376233] pci_bus 0000:03: resource 1 [mem 0xa4200000-0xa42fffff]
[ 0.376354] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.376697] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.376837] PCI: CLS 64 bytes, default 64
[ 0.376877] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.376878] software IO TLB: mapped [mem 0x000000006eca8000-0x0000000072ca8000] (64MB)
[ 0.376894] Trying to unpack rootfs image as initramfs...
[ 0.387203] Initialise system trusted keyrings
[ 0.387215] Key type blacklist registered
[ 0.387245] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.387895] zbud: loaded
[ 0.393718] Key type asymmetric registered
[ 0.393720] Asymmetric key parser 'x509' registered
[ 0.393725] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.393744] io scheduler mq-deadline registered
[ 0.393745] io scheduler kyber registered
[ 0.393764] io scheduler bfq registered
[ 0.397942] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[ 0.398137] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[ 0.398187] pcieport 0000:00:1d.0: AER: enabled with IRQ 123
[ 0.398215] pcieport 0000:00:1d.0: DPC: enabled with IRQ 123
[ 0.398216] pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.398455] pcieport 0000:00:1d.5: PME: Signaling with IRQ 124
[ 0.398502] pcieport 0000:00:1d.5: AER: enabled with IRQ 124
[ 0.398526] pcieport 0000:00:1d.5: DPC: enabled with IRQ 124
[ 0.398527] pcieport 0000:00:1d.5: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.398639] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.398657] efifb: probing for efifb
[ 0.398666] efifb: showing boot graphics
[ 0.399404] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
[ 0.399405] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.399406] efifb: scrolling: redraw
[ 0.399406] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.399429] fbcon: Deferring console take-over
[ 0.399431] fb0: EFI VGA frame buffer device
[ 0.400872] ACPI: AC: AC Adapter [AC] (on-line)
[ 0.400915] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.403469] ACPI: button: Lid Switch [LID0]
[ 0.403494] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.403666] ACPI: button: Power Button [PBTN]
[ 0.403687] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.403697] ACPI: button: Sleep Button [SBTN]
[ 0.403713] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.406773] ACPI: button: Power Button [PWRF]
[ 0.406896] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1736
[ 0.409135] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.409136] ACPI: thermal: Thermal Zone [THM] (25 C)
[ 0.409375] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.412076] Non-volatile memory driver v1.3
[ 0.412077] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.412078] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.413000] nvme nvme0: pci function 0000:02:00.0
[ 0.413029] ahci 0000:00:17.0: version 3.0
[ 0.413758] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[ 0.413851] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.413854] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm clo only pio slum part ems deso sadm sds apst
[ 0.414969] scsi host0: ahci
[ 0.415009] ata1: SATA max UDMA/133 abar m2048@0xa4425000 port 0xa4425100 irq 126
[ 0.415032] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.415035] ehci-pci: EHCI PCI platform driver
[ 0.415040] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.415041] ohci-pci: OHCI PCI platform driver
[ 0.415045] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.415063] usbcore: registered new interface driver usbserial_generic
[ 0.415065] usbserial: USB Serial support registered for generic
[ 0.415220] rtc_cmos 00:01: RTC can wake from S4
[ 0.416690] rtc_cmos 00:01: registered as rtc0
[ 0.417285] rtc_cmos 00:01: setting system clock to 2021-08-18T22:24:00 UTC (1629325440)
[ 0.417295] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.417764] intel_pstate: Intel P-state driver initializing
[ 0.418108] intel_pstate: Disabling energy efficiency optimization
[ 0.418109] intel_pstate: HWP enabled
[ 0.418216] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.418474] hid: raw HID events driver (C) Jiri Kosina
[ 0.418530] ashmem: initialized
[ 0.418719] intel_pmc_core INT33A1:00: initialized
[ 0.418811] drop_monitor: Initializing network drop monitor service
[ 0.418856] Initializing XFRM netlink socket
[ 0.418947] NET: Registered protocol family 10
[ 0.425814] nvme nvme0: allocated 38 MiB host memory buffer.
[ 0.449802] ACPI: battery: Slot [BAT0] (battery present)
[ 0.459677] nvme nvme0: 8/0/0 default/read/poll queues
[ 0.463583] nvme0n1: p1 p2
[ 0.465756] Freeing initrd memory: 12784K
[ 0.469413] Segment Routing with IPv6
[ 0.469414] RPL Segment Routing with IPv6
[ 0.469434] NET: Registered protocol family 17
[ 0.469883] microcode: sig=0x906ea, pf=0x20, revision=0xea
[ 0.469927] microcode: Microcode Update Driver: v2.2.
[ 0.469931] IPI shorthand broadcast: enabled
[ 0.469938] sched_clock: Marking stable (465759027, 4036133)->(477485809, -7690649)
[ 0.470096] registered taskstats version 1
[ 0.470102] Loading compiled-in X.509 certificates
[ 0.472249] Loaded X.509 cert 'Build time autogenerated kernel key: 6729f5018778269d79c9f9dd3b3ddd4497788b6b'
[ 0.473345] zswap: loaded using pool zstd/z3fold
[ 0.473838] Key type ._fscrypt registered
[ 0.473855] Key type .fscrypt registered
[ 0.473856] Key type fscrypt-provisioning registered
[ 0.473889] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.474060] PM: Magic number: 1:523:401
[ 0.474269] RAS: Correctable Errors collector initialized.
[ 0.730206] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.744805] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 0.744818] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 0.744823] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 0.745200] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 0.782514] ata1.00: ATA-10: ST1000LM035-1RK172, SDM3, max UDMA/133
[ 0.782523] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.807581] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 0.807595] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 0.807601] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 0.807960] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 0.845226] ata1.00: configured for UDMA/133
[ 0.847109] scsi 0:0:0:0: Direct-Access ATA ST1000LM035-1RK1 SDM3 PQ: 0 ANSI: 5
[ 0.847462] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.847468] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 0.847487] sd 0:0:0:0: [sda] Write Protect is off
[ 0.847491] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.847514] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.911715] sda: sda1 sda2
[ 0.943622] sd 0:0:0:0: [sda] Attached SCSI disk
[ 0.945916] Freeing unused decrypted memory: 2036K
[ 0.946541] Freeing unused kernel image (initmem) memory: 1796K
[ 0.946650] Write protecting the kernel read-only data: 26624k
[ 0.947775] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.948327] Freeing unused kernel image (rodata/data gap) memory: 1084K
[ 0.986318] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.986321] rodata_test: all tests were successful
[ 0.986322] x86/mm: Checking user space page tables
[ 1.022674] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.022677] Run /init as init process
[ 1.022678] with arguments:
[ 1.022678] /init
[ 1.022679] with environment:
[ 1.022679] HOME=/
[ 1.022680] TERM=linux
[ 1.022680] BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64
[ 1.204725] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.204736] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.206104] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.206930] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.207526] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[ 1.207533] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.207535] usb usb1: Product: xHCI Host Controller
[ 1.207536] usb usb1: Manufacturer: Linux 5.13.11-1-MANJARO xhci-hcd
[ 1.207538] usb usb1: SerialNumber: 0000:00:14.0
[ 1.207733] hub 1-0:1.0: USB hub found
[ 1.207768] hub 1-0:1.0: 16 ports detected
[ 1.208108] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.208140] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.210820] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.210827] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.210832] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.210881] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[ 1.210887] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.210888] usb usb2: Product: xHCI Host Controller
[ 1.210890] usb usb2: Manufacturer: Linux 5.13.11-1-MANJARO xhci-hcd
[ 1.210891] usb usb2: SerialNumber: 0000:00:14.0
[ 1.210989] hub 2-0:1.0: USB hub found
[ 1.211010] hub 2-0:1.0: 8 ports detected
[ 1.217769] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 1.403500] tsc: Refined TSC clocksource calibration: 2304.000 MHz
[ 1.403518] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2135f7c97c8, max_idle_ns: 440795273205 ns
[ 1.403643] clocksource: Switched to clocksource tsc
[ 1.463475] usb 1-2: new high-speed USB device number 2 using xhci_hcd
[ 1.617977] random: fast init done
[ 1.693365] fbcon: Taking over console
[ 1.693656] Console: switching to colour frame buffer device 240x67
[ 1.897731] usb 1-2: New USB device found, idVendor=8564, idProduct=1000, bcdDevice= 1.00
[ 1.897742] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.897748] usb 1-2: Product: Mass Storage Device
[ 1.897751] usb 1-2: Manufacturer: JetFlash
[ 1.897755] usb 1-2: SerialNumber: D0BBH1EZ
[ 1.905582] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 1.905951] scsi host1: usb-storage 1-2:1.0
[ 1.906007] usbcore: registered new interface driver usb-storage
[ 1.907106] usbcore: registered new interface driver uas
[ 2.020164] usb 1-3: new full-speed USB device number 3 using xhci_hcd
[ 2.162509] usb 1-3: New USB device found, idVendor=1038, idProduct=1724, bcdDevice= 2.33
[ 2.162520] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.162526] usb 1-3: Product: SteelSeries Rival 600
[ 2.162529] usb 1-3: Manufacturer: SteelSeries
[ 2.171905] hid-generic 0003:1038:1724.0001: hiddev96,hidraw0: USB HID v1.11 Device [SteelSeries SteelSeries Rival 600] on usb-0000:00:14.0-3/input0
[ 2.172352] input: SteelSeries SteelSeries Rival 600 as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:1038:1724.0002/input/input6
[ 2.172386] hid-generic 0003:1038:1724.0002: input,hidraw1: USB HID v1.11 Mouse [SteelSeries SteelSeries Rival 600] on usb-0000:00:14.0-3/input1
[ 2.173044] input: SteelSeries SteelSeries Rival 600 Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.2/0003:1038:1724.0003/input/input7
[ 2.226922] hid-generic 0003:1038:1724.0003: input,hidraw2: USB HID v1.11 Keyboard [SteelSeries SteelSeries Rival 600] on usb-0000:00:14.0-3/input2
[ 2.226973] usbcore: registered new interface driver usbhid
[ 2.226976] usbhid: USB HID core driver
[ 2.286827] usb 1-5: new high-speed USB device number 4 using xhci_hcd
[ 2.435712] usb 1-5: New USB device found, idVendor=1bcf, idProduct=28c1, bcdDevice=65.05
[ 2.435724] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.435729] usb 1-5: Product: Integrated_Webcam_HD
[ 2.435733] usb 1-5: Manufacturer: CN0WNTY0LOG00888D7MSA01
[ 2.560172] usb 1-6: new high-speed USB device number 5 using xhci_hcd
[ 2.700993] usb 1-6: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[ 2.701003] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.701008] usb 1-6: Product: USB2.0-CRW
[ 2.701012] usb 1-6: Manufacturer: Generic
[ 2.701015] usb 1-6: SerialNumber: 20100201396000000
[ 2.710975] usbcore: registered new interface driver rtsx_usb
[ 2.826820] usb 1-9: new full-speed USB device number 6 using xhci_hcd
[ 2.925595] scsi 1:0:0:0: Direct-Access JetFlash Transcend 8GB 8.07 PQ: 0 ANSI: 4
[ 2.927607] sd 1:0:0:0: [sdb] 15261696 512-byte logical blocks: (7.81 GB/7.28 GiB)
[ 2.928439] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.928447] sd 1:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 2.929498] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2.969768] usb 1-9: New USB device found, idVendor=27c6, idProduct=5301, bcdDevice= 1.00
[ 2.969779] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.969784] usb 1-9: Product: Goodix Fingerprint Device
[ 2.969788] usb 1-9: Manufacturer: HTMicroelectronics
[ 2.969791] usb 1-9: SerialNumber: HTK32
[ 2.977832] sdb: sdb1 sdb2
[ 3.006529] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[ 3.096801] usb 1-14: new full-speed USB device number 7 using xhci_hcd
[ 3.238954] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 3.238966] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.411543] random: crng init done
[ 7.629510] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 8.873216] systemd[1]: systemd 248.7-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 8.887038] systemd[1]: Detected architecture x86-64.
[ 8.912439] systemd[1]: Hostname set to <seb-g33579>.
[ 11.580642] systemd[1]: Queued start job for default target Graphical Interface.
[ 11.581903] systemd[1]: Created slice Slice /system/getty.
[ 11.582193] systemd[1]: Created slice Slice /system/modprobe.
[ 11.582485] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 11.582690] systemd[1]: Created slice User and Session Slice.
[ 11.582773] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 11.582834] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.583012] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.583052] systemd[1]: Reached target Local Encrypted Volumes.
[ 11.583071] systemd[1]: Reached target Login Prompts.
[ 11.583103] systemd[1]: Reached target Remote File Systems.
[ 11.583117] systemd[1]: Reached target Slice Units.
[ 11.583139] systemd[1]: Reached target Swaps.
[ 11.583172] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[ 11.583257] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 11.583641] systemd[1]: Listening on LVM2 poll daemon socket.
[ 11.584982] systemd[1]: Listening on Process Core Dump Socket.
[ 11.585200] systemd[1]: Listening on Journal Audit Socket.
[ 11.585323] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.585452] systemd[1]: Listening on Journal Socket.
[ 11.603133] systemd[1]: Listening on udev Control Socket.
[ 11.603288] systemd[1]: Listening on udev Kernel Socket.
[ 11.604232] systemd[1]: Mounting Huge Pages File System...
[ 11.605091] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.605948] systemd[1]: Mounting Kernel Debug File System...
[ 11.606855] systemd[1]: Mounting Kernel Trace File System...
[ 11.638207] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
[ 11.640125] systemd[1]: Mounting Temporary Directory /tmp...
[ 11.642091] systemd[1]: Starting Load AppArmor profiles...
[ 11.644148] systemd[1]: Starting Create List of Static Device Nodes...
[ 11.645998] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 11.648064] systemd[1]: Starting Load Kernel Module configfs...
[ 11.649983] systemd[1]: Starting Load Kernel Module drm...
[ 11.651184] systemd[1]: Starting Load Kernel Module fuse...
[ 12.564665] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 12.564807] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 13.414595] systemd[1]: Starting Load Kernel Modules...
[ 13.416643] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 13.416846] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 13.418085] systemd[1]: Starting Coldplug All udev Devices...
[ 13.419074] systemd[1]: Mounted Huge Pages File System.
[ 13.419129] systemd[1]: Mounted POSIX Message Queue File System.
[ 13.419173] systemd[1]: Mounted Kernel Debug File System.
[ 13.419220] systemd[1]: Mounted Kernel Trace File System.
[ 13.419264] systemd[1]: Mounted Temporary Directory /tmp.
[ 13.419423] systemd[1]: Finished Create List of Static Device Nodes.
[ 13.419613] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 13.419743] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 13.419854] systemd[1]: Finished Load Kernel Module configfs.
[ 13.420325] systemd[1]: Mounting Kernel Configuration File System...
[ 13.422428] systemd[1]: Mounted Kernel Configuration File System.
[ 13.532253] fuse: init (API version 7.34)
[ 13.533455] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 13.533752] systemd[1]: Finished Load Kernel Module fuse.
[ 13.534903] systemd[1]: Mounting FUSE Control File System...
[ 13.537687] systemd[1]: Mounted FUSE Control File System.
[ 13.571448] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
[ 13.573709] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 13.574062] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 13.856004] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 13.857859] systemd[1]: Starting Load/Save Random Seed...
[ 13.858028] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 13.859730] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 13.890578] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 13.890717] systemd[1]: Finished Load Kernel Module drm.
[ 13.921135] systemd[1]: Finished Coldplug All udev Devices.
[ 13.948743] Linux agpgart interface v0.103
[ 14.425428] systemd[1]: Finished Load/Save Random Seed.
[ 14.425742] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 14.551753] audit: type=1400 audit(1629325454.629:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=269 comm="apparmor_parser"
[ 14.558222] audit: type=1400 audit(1629325454.636:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=265 comm="apparmor_parser"
[ 14.558833] audit: type=1400 audit(1629325454.636:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=265 comm="apparmor_parser"
[ 14.594077] audit: type=1400 audit(1629325454.673:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=266 comm="apparmor_parser"
[ 14.633127] audit: type=1400 audit(1629325454.709:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=267 comm="apparmor_parser"
[ 14.666747] audit: type=1400 audit(1629325454.743:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=268 comm="apparmor_parser"
[ 14.667637] audit: type=1400 audit(1629325454.746:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=268 comm="apparmor_parser"
[ 14.676279] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 14.676350] systemd[1]: Reached target Preparation for Local File Systems.
[ 14.676377] systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
[ 14.677342] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 14.678449] systemd[1]: Starting Journal Service...
[ 14.679335] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 14.793512] audit: type=1400 audit(1629325454.873:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=270 comm="apparmor_parser"
[ 14.794065] audit: type=1400 audit(1629325454.873:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=270 comm="apparmor_parser"
[ 14.794950] systemd[1]: Finished Load AppArmor profiles.
[ 14.795513] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
[ 15.021310] systemd[1]: Started Journal Service.
[ 15.021378] audit: type=1130 audit(1629325455.099:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.545839] systemd-journald[272]: Received client request to flush runtime journal.
[ 16.954629] systemd-journald[272]: File /var/log/journal/b2c1a00eda6b4c9eb901c025487a0d49/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 17.687438] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 17.687474] wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
[ 17.687475] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 17.766424] input: Intel HID events as /devices/platform/INT33D5:00/input/input8
[ 17.766479] intel-hid INT33D5:00: platform supports 5 button array
[ 17.766494] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input9
[ 17.961678] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 17.961754] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 17.963848] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ 17.964197] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 17.968630] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 17.990583] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[ 17.991218] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 17.994708] i2c i2c-0: 1/2 memory slots populated (from DMI)
[ 18.099352] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 18.100312] intel-spi 0000:00:1f.5: w25q128 (16384 Kbytes)
[ 18.101728] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 18.102160] Creating 1 MTD partitions on "0000:00:1f.5":
[ 18.102162] 0x000000000000-0x000001000000 : "BIOS"
[ 18.295811] Intel(R) Wireless WiFi driver for Linux
[ 18.295849] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 18.301119] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[ 18.304814] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 18.305599] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 18.306939] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 18.306944] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 18.311313] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ 18.311362] intel_rapl_common: Found RAPL domain package
[ 18.311364] intel_rapl_common: Found RAPL domain dram
[ 18.388461] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 18.388486] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[ 18.388507] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 18.388528] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 18.388629] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 18.388631] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 18.388632] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 18.388633] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 18.388634] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 18.388634] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 18.388635] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 18.388636] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 18.388637] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 18.388637] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 18.388638] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 18.388639] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 18.388640] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 18.388640] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 18.388641] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 18.388642] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 18.388643] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 18.388883] iwlwifi 0000:00:14.3: loaded firmware version 46.6b541b68.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 18.443871] input: DELL086F:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL086F:00/0018:06CB:7E92.0004/input/input14
[ 18.443961] input: DELL086F:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL086F:00/0018:06CB:7E92.0004/input/input15
[ 18.444079] hid-generic 0018:06CB:7E92.0004: input,hidraw3: I2C HID v1.00 Mouse [DELL086F:00 06CB:7E92] on i2c-DELL086F:00
[ 18.497133] input: PC Speaker as /devices/platform/pcspkr/input/input17
[ 18.590980] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[ 18.608105] libphy: r8169: probed
[ 18.608312] r8169 0000:03:00.0 eth0: RTL8168h/8111h, 3c:2c:30:9e:dc:6d, XID 541, IRQ 143
[ 18.608316] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 18.676581] checking generic (80000000 7f0000) vs hw (a2000000 1000000)
[ 18.676584] checking generic (80000000 7f0000) vs hw (80000000 10000000)
[ 18.676585] fb0: switching to inteldrmfb from EFI VGA
[ 18.676648] Console: switching to colour dummy device 80x25
[ 18.676671] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 18.678226] input: Dell WMI hotkeys as /devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/PNP0C14:05-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input19
[ 18.681772] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 18.689929] i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
[ 18.694193] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 18.697703] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 18.883882] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 18.884599] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input20
[ 18.884645] ACPI: video: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 18.884661] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input21
[ 18.884719] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 18.901396] intel_rapl_common: Found RAPL domain package
[ 18.901399] intel_rapl_common: Found RAPL domain core
[ 18.901400] intel_rapl_common: Found RAPL domain uncore
[ 18.901401] intel_rapl_common: Found RAPL domain dram
[ 18.901403] intel_rapl_common: Found RAPL domain psys
[ 18.901766] iTCO_vendor_support: vendor-support=0
[ 18.902363] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 18.902365] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 18.902366] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 18.902367] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 18.902368] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 18.902369] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 18.909685] fbcon: i915drmfb (fb0) is primary device
[ 18.940534] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 18.960916] cryptd: max_cpu_qlen set to 1000
[ 18.978168] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 18.978512] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 19.040468] input: DELL086F:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL086F:00/0018:06CB:7E92.0004/input/input22
[ 19.040569] input: DELL086F:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL086F:00/0018:06CB:7E92.0004/input/input23
[ 19.041490] hid-multitouch 0018:06CB:7E92.0004: input,hidraw3: I2C HID v1.00 Mouse [DELL086F:00 06CB:7E92] on i2c-DELL086F:00
[ 19.045008] AVX2 version of gcm_enc/dec engaged.
[ 19.045082] AES CTR mode by8 optimization enabled
[ 19.051916] r8169 0000:03:00.0 enp3s0: renamed from eth0
[ 19.097347] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9462, REV=0x318
[ 19.104293] thermal thermal_zone7: failed to read out thermal zone (-61)
[ 19.152538] iwlwifi 0000:00:14.3: base HW address: 1c:1b:b5:36:6c:53
[ 19.197193] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 19.203143] mousedev: PS/2 mouse device common for all mice
[ 19.210881] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 19.570135] intel_tcc_cooling: Programmable TCC Offset detected
[ 19.736495] nvidia: loading out-of-tree module taints kernel.
[ 19.736524] nvidia: module license 'NVIDIA' taints kernel.
[ 19.736526] Disabling lock debugging due to kernel taint
[ 19.762997] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 19.809411] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ 19.809863] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[ 19.926539] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.63.01 Tue Aug 3 20:44:16 UTC 2021
[ 20.034379] Console: switching to colour frame buffer device 240x67
[ 20.061338] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 20.078435] kauditd_printk_skb: 5 callbacks suppressed
[ 20.078441] audit: type=1130 audit(1629325460.156:17): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.114985] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.63.01 Tue Aug 3 20:30:55 UTC 2021
[ 20.210533] audit: type=1130 audit(1629325460.289:18): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-2154\x2dC924 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.261183] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3204: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 20.261192] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 20.261196] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 20.261199] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 20.261202] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 20.261204] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19
[ 20.261207] snd_hda_codec_realtek hdaudioC0D0: Headphone Mic=0x1a
[ 20.261209] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 20.299170] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 20.299175] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 20.319174] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 20.319242] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 20.319304] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[ 20.319361] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 20.319419] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[ 20.319478] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[ 20.548988] audit: type=1130 audit(1629325460.626:19): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.553422] audit: type=1130 audit(1629325460.633:20): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.938435] audit: type=1130 audit(1629325461.016:21): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.085092] Bluetooth: Core ver 2.22
[ 21.085112] NET: Registered protocol family 31
[ 21.085113] Bluetooth: HCI device and connection manager initialized
[ 21.085116] Bluetooth: HCI socket layer initialized
[ 21.085118] Bluetooth: L2CAP socket layer initialized
[ 21.085120] Bluetooth: SCO socket layer initialized
[ 21.100588] mc: Linux media interface: v0.10
[ 21.122988] videodev: Linux video capture interface: v2.00
[ 21.144250] cdc_acm 1-9:1.0: ttyACM0: USB ACM device
[ 21.144304] usbcore: registered new interface driver cdc_acm
[ 21.144306] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 21.210631] usbcore: registered new interface driver btusb
[ 21.211715] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[ 21.212689] Bluetooth: hci0: Device revision is 2
[ 21.212692] Bluetooth: hci0: Secure boot is enabled
[ 21.212693] Bluetooth: hci0: OTP lock is enabled
[ 21.212694] Bluetooth: hci0: API lock is enabled
[ 21.212695] Bluetooth: hci0: Debug lock is disabled
[ 21.212696] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 21.271769] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[ 21.374463] usb 1-5: Found UVC 1.00 device Integrated_Webcam_HD (1bcf:28c1)
[ 21.393176] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input31
[ 21.393265] usbcore: registered new interface driver uvcvideo
[ 21.402476] audit: type=1130 audit(1629325461.479:22): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.403002] audit: type=1334 audit(1629325461.479:23): prog-id=10 op=LOAD
[ 21.430777] audit: type=1127 audit(1629325461.509:24): pid=616 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 21.473555] audit: type=1130 audit(1629325461.553:25): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.491789] audit: type=1130 audit(1629325461.569:26): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.801858] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.801860] Bluetooth: BNEP filters: protocol multicast
[ 22.801862] Bluetooth: BNEP socket layer initialized
[ 22.854995] Bluetooth: hci0: Waiting for firmware download to complete
[ 22.855718] Bluetooth: hci0: Firmware loaded in 1546820 usecs
[ 22.855961] Bluetooth: hci0: Waiting for device to boot
[ 22.869759] Bluetooth: hci0: Device booted in 13658 usecs
[ 22.875463] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[ 22.877800] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 22.880727] Bluetooth: hci0: Firmware revision 0.1 build 6 week 12 2021
[ 22.939713] Bluetooth: hci0: MSFT filter_enable is already on
[ 23.057341] NET: Registered protocol family 38
[ 24.263470] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 24.463686] r8169 0000:03:00.0 enp3s0: Link is Down
[ 24.651998] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 24.848387] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 25.104626] kauditd_printk_skb: 23 callbacks suppressed
[ 25.104632] audit: type=1130 audit(1629325465.183:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.030240] loop: module loaded
[ 26.031226] loop0: detected capacity change from 0 to 8
[ 26.080462] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 26.312374] audit: type=1131 audit(1629325466.389:51): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.338299] audit: type=1130 audit(1629325466.416:52): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.551373] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 27.551401] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 29.175359] audit: type=1130 audit(1629325469.253:53): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.488920] audit: type=1131 audit(1629325471.566:54): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.926402] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210331/nsarguments-61)
[ 34.569500] audit: type=1100 audit(1629325474.646:55): pid=939 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="seb" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 34.582289] audit: type=1101 audit(1629325474.659:56): pid=939 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="seb" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 34.605901] audit: type=1103 audit(1629325474.683:57): pid=939 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="seb" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 34.606119] audit: type=1006 audit(1629325474.683:58): pid=939 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 34.606131] audit: type=1300 audit(1629325474.683:58): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7fff5162bf80 a2=4 a3=3e8 items=0 ppid=678 pid=939 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
[ 34.606138] audit: type=1327 audit(1629325474.683:58): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003135
[ 34.706543] audit: type=1130 audit(1629325474.783:59): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.711505] audit: type=1101 audit(1629325474.789:60): pid=944 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="seb" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.711509] audit: type=1103 audit(1629325474.789:61): pid=944 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="seb" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 39.419799] kauditd_printk_skb: 12 callbacks suppressed
[ 39.419803] audit: type=1130 audit(1629325479.496:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.262090] Bluetooth: RFCOMM TTY layer initialized
[ 42.262114] Bluetooth: RFCOMM socket layer initialized
[ 42.262117] Bluetooth: RFCOMM ver 1.11
[ 42.468404] audit: type=1334 audit(1629325482.546:71): prog-id=18 op=LOAD
[ 42.468459] audit: type=1334 audit(1629325482.546:72): prog-id=19 op=LOAD
[ 43.256164] audit: type=1130 audit(1629325483.333:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.797573] audit: type=1130 audit(1629325484.876:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.956857] audit: type=1105 audit(1629325485.036:75): pid=1184 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 50.334993] audit: type=1130 audit(1629325490.413:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 51.201462] audit: type=1130 audit(1629325491.279:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 53.394074] audit: type=1131 audit(1629325492.932:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 53.490110] audit: type=1334 audit(1629325493.029:79): prog-id=16 op=UNLOAD
[ 53.490113] audit: type=1334 audit(1629325493.029:80): prog-id=15 op=UNLOAD
[ 53.490114] audit: type=1334 audit(1629325493.029:81): prog-id=14 op=UNLOAD
[ 80.306375] audit: type=1131 audit(1629325519.842:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 230.349589] audit: type=1100 audit(1629325669.892:83): pid=2104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="seb" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 230.350500] audit: type=1101 audit(1629325669.895:84): pid=2104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="seb" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 230.350686] audit: type=1110 audit(1629325669.895:85): pid=2104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 230.351973] audit: type=1105 audit(1629325669.895:86): pid=2104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 324.189785] EXT4-fs (nvme0n1p2): recovery complete
[ 324.189797] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 349.930329] FAT-fs (nvme0n1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 460.344299] audit: type=1334 audit(1629325899.894:87): prog-id=20 op=LOAD
[ 460.344389] audit: type=1334 audit(1629325899.894:88): prog-id=21 op=LOAD
[ 460.344470] audit: type=1334 audit(1629325899.894:89): prog-id=22 op=LOAD
[ 460.393510] audit: type=1130 audit(1629325899.944:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 490.445551] audit: type=1131 audit(1629325929.994:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 490.511126] audit: type=1334 audit(1629325930.061:92): prog-id=22 op=UNLOAD
[ 490.511141] audit: type=1334 audit(1629325930.061:93): prog-id=21 op=UNLOAD
[ 490.511148] audit: type=1334 audit(1629325930.061:94): prog-id=20 op=UNLOAD
[ 682.332941] audit: type=1101 audit(1629326121.885:95): pid=2318 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 682.334018] audit: type=1110 audit(1629326121.888:96): pid=2318 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 682.340204] audit: type=1105 audit(1629326121.895:97): pid=2318 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 682.350374] audit: type=1106 audit(1629326121.905:98): pid=2318 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 682.350450] audit: type=1104 audit(1629326121.905:99): pid=2318 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 924.733025] audit: type=1130 audit(1629326364.294:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 924.733059] audit: type=1131 audit(1629326364.294:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1128.512314] audit: type=1101 audit(1629326568.074:102): pid=2382 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 1128.512445] audit: type=1110 audit(1629326568.074:103): pid=2382 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 1128.513772] audit: type=1105 audit(1629326568.074:104): pid=2382 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
when i chroot, the system running the chroot also freezes after a minute or so. I think then it would be useful to provide the logs from the system running on the HDD:
journalctl --catalog --priority=3 --boot=-1
-- Journal begins at Wed 2021-08-18 20:33:20 EEST, ends at Thu 2021-08-19 02:33>
elo 19 01:24:15 seb-g33579 kernel: x86/cpu: SGX disabled by BIOS.
elo 19 01:24:15 seb-g33579 kernel: ACPI Error: Aborting method \_SB.PCI0.SPI1.F>
elo 19 01:24:15 seb-g33579 kernel: ACPI Error: Method execution failed \_SB.PCI>
elo 19 01:24:15 seb-g33579 kernel: ACPI Error: Aborting method \_SB.PCI0.SPI2.F>
elo 19 01:24:19 seb-g33579 kernel:
[ 0.095752] x86/cpu: SGX disabled by BIOS.
[ 0.103889] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.103889] #5 #6 #7
[ 0.107643] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.263483] ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210331/psparse-529)
[ 0.263491] ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210331/uteval-68)
[ 0.264586] ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210331/psparse-529)
[ 0.264592] ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210331/uteval-68)
[ 1.205424] i8042: Warning: Keylock active
[ 28.841235] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 28.841274] wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
[ 28.841275] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 28.974381] systemd-journald[280]: File /var/log/journal/b2c1a00eda6b4c9eb901c025487a0d49/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 29.892423] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 29.892426] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 29.892427] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 29.892428] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 29.892429] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 29.892430] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 29.892430] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 29.892431] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 29.892432] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 29.892432] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 29.892433] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 29.892434] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 29.892435] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 29.892435] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 29.892436] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 29.892437] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 29.892438] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 30.705939] thermal thermal_zone7: failed to read out thermal zone (-61)
[ 32.511395] nvidia: loading out-of-tree module taints kernel.
[ 32.511411] nvidia: module license 'NVIDIA' taints kernel.
[ 32.511412] Disabling lock debugging due to kernel taint
[ 32.660806] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.63.01 Tue Aug 3 20:44:16 UTC 2021
[ 33.005990] kauditd_printk_skb: 8 callbacks suppressed
[ 35.548381] Bluetooth: hci0: MSFT filter_enable is already on
[ 38.435860] kauditd_printk_skb: 22 callbacks suppressed
[ 42.899927] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210331/nsarguments-61)
[ 50.660268] kauditd_printk_skb: 12 callbacks suppressed
hope that helps figure out the problem
