I have installed Manjaro (22.0.3, updated to newest) as a VM on VBox 7.0.6. Host is Win10. Most of the time Manjaro starts up as expected.
Sometimes (now, too) the start up hangs by showing a black screen with 3 flashing dots and “manjaro” at the bottom.
i can ACPI-Shutdown.
Sometimes a new start up works fine. Sometimes not. Currently, hanging is reproducible.
In the past I deleted the VM and worked with an older backup of the VM until it happens again. But I loose some data in that case.
Is there any way to locate the reason for this behavior?
Win10 host - the VM didn’t change and it worked, then it didn’t - would prompt me to look at the host and what it is doing
memory settings of the VM - is there enough RAM allocated - or too much so the host doesn’t have enough
logs of the VM - you can boot it into a non graphical mode if the normal one doesn’t work
then investigate why the guest is having problems and what seems to be the reason
It may be the plymouth splash causing the issues - the combination of firmware splash and plymouth - I think you may find a similar issue using the search function.
Without any change and after 6 restarts in about 2 days Manjaro started as expected. Without any change, even not to the Win10 host (I worked on a different hardware these days.).
However, I applied the suggested changes to grub and hope, I will never see this problem again.
Thanks linux-aarhus .
