The problem (short):
Manjaro doesn’t boot with Nvidia proprietary nor in liveusb, nor when installed
The problem (detailed):
First, I tried booting of flash drive with proprietary drivers, when it failed, I booted with nouveau, installed Manjaro (Wayland doesn’t work though, so i switched to Xorg)
Then I installed proprietary drivers with sudo mhwd -a pci nonfree 0300
and I can’t load now into Manjaro, doesn’t even loading GRUB
What i have tried:
- Disabling fast/secure boot
- Updating bios (current version dates to January 2023)
- Disabling Wayland (when I installed Manjaro)
Current state
Now I only can load into Manjaro TTY with proprietary drivers when Runlevel is set to 3, and xini
says that the system doesn’t detect any drivers
inxi -F output
Host: roman Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 Console: tty 1 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: PRO Z690-A DDR4(MS-7D25) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.A0 date: 01/09/2023
Info: 10-core (6-mt/4-st) model: 12th Gen Intel Core i5-12600KF bits: 64 type: MST AMCP cache:
L2: 9.5 MiB
Speed (MHz): avg: 3518 min/max: 800/4900:3600 cores: 1: 3700 2: 3700 3: 3700 4: 3700 5: 3700
6: 3700 7: 3700 8: 3700 9: 800 10: 3700 11: 3700 12: 3700 13: 3700 14: 3700 15: 3700 16: 3700
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] driver: N/A
Display: server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8 driver: X: loaded: nvidia gpu: N/A
tty: 240x67
API: OpenGL Message: GL data unavailable in console. Try -G --display
Device-1: Intel Alder Lake-S HD Audio driver: snd_hda_intel
Device-2: NVIDIA GA102 High Definition Audio driver: snd_hda_intel
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Device-1: Intel Ethernet I225-V driver: igc
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: d8:bb:c1:a4:7f:41
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb
Local Storage: total: 2.54 TiB used: 10.62 GiB (0.4%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SKC3000S1024G size: 953.87 GiB
ID-2: /dev/sda vendor: SanDisk model: SSDPR-CX300-240 size: 223.57 GiB
ID-3: /dev/sdb vendor: Toshiba model: MK5065GSX size: 465.76 GiB
ID-4: /dev/sdc vendor: Seagate model: ST1000DM003-1SB102 size: 931.51 GiB
ID-5: /dev/sdd type: USB vendor: Generic model: Flash Disk size: 29.3 GiB
ID-1: / size: 457.09 GiB used: 10.62 GiB (2.3%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 316 KiB (0.1%) fs: vfat dev: /dev/sdb1
sudo dmesg output
[ 0.000000] Linux version 6.1.19-1-MANJARO (builduser@fv-az334-393) (gcc (GCC) 12.2.1 20230201, GNU ld (GNU Binutils) 2.40) #1 SMP PREEMPT_DYNAMIC Mon Mar 13 12:59:35 UTC 2023
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=3e904cc4-97ad-4192-9863-9568ca78416e rw 3 splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 3632
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000076deafff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000076deb000-0x00000000785eafff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000785eb000-0x00000000786eafff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000786eb000-0x00000000788eafff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000788eb000-0x0000000079b3efff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079b3f000-0x0000000079bfefff] type 20
[ 0.000000] BIOS-e820: [mem 0x0000000079bff000-0x0000000079bfffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000079c00000-0x000000007dffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007ee00000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000087fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.80 by American Megatrends
[ 0.000000] efi: ACPI=0x78867000 ACPI 2.0=0x78867014 SMBIOS=0x7969b000 SMBIOS 3.0=0x7969a000 MEMATTR=0x7100b018 ESRT=0x736c8e18
[ 0.000000] SMBIOS 3.5.0 present.
[ 0.000000] DMI: Micro-Star International Co., Ltd. MS-7D25/PRO Z690-A DDR4(MS-7D25), BIOS 1.A0 01/09/2023
[ 0.000000] tsc: Detected 3700.000 MHz processor
[ 0.000000] tsc: Detected 3686.400 MHz TSC
[ 0.000503] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000505] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000511] last_pfn = 0x880000 max_arch_pfn = 0x400000000
[ 0.000646] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001253] last_pfn = 0x79c00 max_arch_pfn = 0x400000000
[ 0.010522] esrt: Reserving ESRT space from 0x00000000736c8e18 to 0x00000000736c8e78.
[ 0.010525] e820: update [mem 0x736c8000-0x736c8fff] usable ==> reserved
[ 0.010540] Using GB pages for direct mapping
[ 0.010629] Secure boot disabled
[ 0.010630] RAMDISK: [mem 0x35843000-0x36c18fff]
[ 0.010633] ACPI: Early table checksum verification disabled
[ 0.010634] ACPI: RSDP 0x0000000078867014 000024 (v02 ALASKA)
[ 0.010638] ACPI: XSDT 0x0000000078866728 000104 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.010641] ACPI: FACP 0x00000000786E8000 000114 (v06 ALASKA A M I 01072009 AMI 01000013)
[ 0.010645] ACPI: DSDT 0x0000000078650000 097CB9 (v02 ALASKA A M I 01072009 INTL 20200717)
[ 0.010647] ACPI: FACS 0x00000000788EA000 000040
[ 0.010648] ACPI: FIDT 0x000000007864F000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.010650] ACPI: SSDT 0x00000000786EA000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20200717)
[ 0.010652] ACPI: SSDT 0x0000000078649000 005D34 (v02 CpuRef CpuSsdt 00003000 INTL 20200717)
[ 0.010654] ACPI: SSDT 0x0000000078646000 002935 (v02 SaSsdt SaSsdt 00003000 INTL 20200717)
[ 0.010656] ACPI: SSDT 0x0000000078642000 00334F (v02 INTEL IgfxSsdt 00003000 INTL 20200717)
[ 0.010658] ACPI: HPET 0x00000000786E9000 000038 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.010659] ACPI: APIC 0x0000000078641000 0001DC (v05 ALASKA A M I 01072009 AMI 01000013)
[ 0.010661] ACPI: MCFG 0x0000000078640000 00003C (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.010663] ACPI: SSDT 0x000000007863E000 001F1A (v02 ALASKA Ther_Rvp 00001000 INTL 20200717)
[ 0.010664] ACPI: UEFI 0x000000007884E000 000048 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.010666] ACPI: NHLT 0x000000007863D000 00002D (v00 ALASKA A M I 01072009 AMI 01000013)
[ 0.010668] ACPI: LPIT 0x000000007863C000 0000CC (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.010670] ACPI: SSDT 0x0000000078638000 002A83 (v02 ALASKA PtidDevc 00001000 INTL 20200717)
[ 0.010671] ACPI: SSDT 0x0000000078635000 002357 (v02 ALASKA TbtTypeC 00000000 INTL 20200717)
[ 0.010673] ACPI: DBGP 0x0000000078634000 000034 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.010675] ACPI: DBG2 0x0000000078633000 000054 (v00 ALASKA A M I 01072009 AMI 01000013)
[ 0.010676] ACPI: SSDT 0x0000000078631000 00190A (v02 ALASKA UsbCTabl 00001000 INTL 20200717)
[ 0.010678] ACPI: DMAR 0x0000000078630000 000050 (v02 INTEL EDK2 00000002 01000013)
[ 0.010680] ACPI: FPDT 0x000000007862F000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.010681] ACPI: SSDT 0x000000007862D000 001272 (v02 INTEL xh_adls3 00000000 INTL 20200717)
[ 0.010683] ACPI: SSDT 0x0000000078629000 003AEA (v02 SocGpe SocGpe 00003000 INTL 20200717)
[ 0.010685] ACPI: SSDT 0x0000000078625000 0039DA (v02 SocCmn SocCmn 00003000 INTL 20200717)
[ 0.010687] ACPI: SSDT 0x0000000078624000 000144 (v02 Intel ADebTabl 00001000 INTL 20200717)
[ 0.010688] ACPI: BGRT 0x0000000078623000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.010690] ACPI: BGRT 0x0000000078622000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.010692] ACPI: PHAT 0x0000000078621000 0005B1 (v01 ALASKA A M I 00000005 MSFT 0100000D)
[ 0.010694] ACPI: WSMT 0x000000007863B000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.010695] ACPI: Reserving FACP table memory at [mem 0x786e8000-0x786e8113]
[ 0.010696] ACPI: Reserving DSDT table memory at [mem 0x78650000-0x786e7cb8]
[ 0.010697] ACPI: Reserving FACS table memory at [mem 0x788ea000-0x788ea03f]
[ 0.010697] ACPI: Reserving FIDT table memory at [mem 0x7864f000-0x7864f09b]
[ 0.010698] ACPI: Reserving SSDT table memory at [mem 0x786ea000-0x786ea38b]
[ 0.010698] ACPI: Reserving SSDT table memory at [mem 0x78649000-0x7864ed33]
[ 0.010699] ACPI: Reserving SSDT table memory at [mem 0x78646000-0x78648934]
[ 0.010699] ACPI: Reserving SSDT table memory at [mem 0x78642000-0x7864534e]
[ 0.010700] ACPI: Reserving HPET table memory at [mem 0x786e9000-0x786e9037]
[ 0.010700] ACPI: Reserving APIC table memory at [mem 0x78641000-0x786411db]
[ 0.010701] ACPI: Reserving MCFG table memory at [mem 0x78640000-0x7864003b]
[ 0.010701] ACPI: Reserving SSDT table memory at [mem 0x7863e000-0x7863ff19]
[ 0.010702] ACPI: Reserving UEFI table memory at [mem 0x7884e000-0x7884e047]
[ 0.010702] ACPI: Reserving NHLT table memory at [mem 0x7863d000-0x7863d02c]
[ 0.010703] ACPI: Reserving LPIT table memory at [mem 0x7863c000-0x7863c0cb]
[ 0.010703] ACPI: Reserving SSDT table memory at [mem 0x78638000-0x7863aa82]
[ 0.010704] ACPI: Reserving SSDT table memory at [mem 0x78635000-0x78637356]
[ 0.010704] ACPI: Reserving DBGP table memory at [mem 0x78634000-0x78634033]
[ 0.010705] ACPI: Reserving DBG2 table memory at [mem 0x78633000-0x78633053]
[ 0.010705] ACPI: Reserving SSDT table memory at [mem 0x78631000-0x78632909]
[ 0.010706] ACPI: Reserving DMAR table memory at [mem 0x78630000-0x7863004f]
[ 0.010706] ACPI: Reserving FPDT table memory at [mem 0x7862f000-0x7862f043]
[ 0.010707] ACPI: Reserving SSDT table memory at [mem 0x7862d000-0x7862e271]
[ 0.010707] ACPI: Reserving SSDT table memory at [mem 0x78629000-0x7862cae9]
[ 0.010708] ACPI: Reserving SSDT table memory at [mem 0x78625000-0x786289d9]
[ 0.010708] ACPI: Reserving SSDT table memory at [mem 0x78624000-0x78624143]
[ 0.010709] ACPI: Reserving BGRT table memory at [mem 0x78623000-0x78623037]
[ 0.010709] ACPI: Reserving BGRT table memory at [mem 0x78622000-0x78622037]
[ 0.010710] ACPI: Reserving PHAT table memory at [mem 0x78621000-0x786215b0]
[ 0.010710] ACPI: Reserving WSMT table memory at [mem 0x7863b000-0x7863b027]
[ 0.010810] No NUMA configuration found
[ 0.010810] Faking a node at [mem 0x0000000000000000-0x000000087fffffff]
[ 0.010813] NODE_DATA(0) allocated [mem 0x87fffb000-0x87fffffff]
[ 0.010840] Zone ranges:
[ 0.010840] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.010841] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.010842] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.010843] Device empty
[ 0.010843] Movable zone start for each node
[ 0.010844] Early memory node ranges
[ 0.010844] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.010845] node 0: [mem 0x000000000009f000-0x000000000009ffff]
[ 0.010845] node 0: [mem 0x0000000000100000-0x0000000076deafff]
[ 0.010846] node 0: [mem 0x0000000079bff000-0x0000000079bfffff]
[ 0.010846] node 0: [mem 0x0000000100000000-0x000000087fffffff]
[ 0.010848] Initmem setup node 0 [mem 0x0000000000001000-0x000000087fffffff]
[ 0.010850] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.010851] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.010864] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.012722] On node 0, zone DMA32: 11796 pages in unavailable ranges
[ 0.042241] On node 0, zone Normal: 25600 pages in unavailable ranges
[ 0.042495] ACPI: PM-Timer IO Port: 0x1808
[ 0.042500] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.042500] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.042501] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.042501] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.042502] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.042502] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.042502] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.042503] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.042503] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.042503] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.042504] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.042504] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.042504] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.042505] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.042505] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.042505] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.042506] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[ 0.042506] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[ 0.042506] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[ 0.042507] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[ 0.042507] ACPI: LAPIC_NMI (acpi_id[0x15] high edge lint[0x1])
[ 0.042507] ACPI: LAPIC_NMI (acpi_id[0x16] high edge lint[0x1])
[ 0.042508] ACPI: LAPIC_NMI (acpi_id[0x17] high edge lint[0x1])
[ 0.042508] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.042546] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.042547] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.042548] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.042551] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.042551] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.042557] e820: update [mem 0x6fd99000-0x6fdf5fff] usable ==> reserved
[ 0.042564] TSC deadline timer available
[ 0.042565] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[ 0.042578] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.042579] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.042580] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.042581] PM: hibernation: Registered nosave memory: [mem 0x6fd99000-0x6fdf5fff]
[ 0.042582] PM: hibernation: Registered nosave memory: [mem 0x736c8000-0x736c8fff]
[ 0.042583] PM: hibernation: Registered nosave memory: [mem 0x76deb000-0x785eafff]
[ 0.042583] PM: hibernation: Registered nosave memory: [mem 0x785eb000-0x786eafff]
[ 0.042584] PM: hibernation: Registered nosave memory: [mem 0x786eb000-0x788eafff]
[ 0.042584] PM: hibernation: Registered nosave memory: [mem 0x788eb000-0x79b3efff]
[ 0.042584] PM: hibernation: Registered nosave memory: [mem 0x79b3f000-0x79bfefff]
[ 0.042585] PM: hibernation: Registered nosave memory: [mem 0x79c00000-0x7dffffff]
[ 0.042585] PM: hibernation: Registered nosave memory: [mem 0x7e000000-0x7edfffff]
[ 0.042586] PM: hibernation: Registered nosave memory: [mem 0x7ee00000-0x7fffffff]
[ 0.042586] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xbfffffff]
[ 0.042586] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xcfffffff]
[ 0.042587] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xfdffffff]
[ 0.042587] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.042587] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.042588] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.042588] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.042588] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.042589] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed1ffff]
[ 0.042589] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[ 0.042589] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfedfffff]
[ 0.042589] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.042590] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.042590] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.042591] [mem 0x80000000-0xbfffffff] available for PCI devices
[ 0.042591] Booting paravirtualized kernel on bare hardware
[ 0.042593] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.045789] setup_percpu: NR_CPUS:320 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1
[ 0.046134] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[ 0.046139] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[ 0.046140] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.046154] Fallback order for Node 0: 0
[ 0.046157] Built 1 zonelists, mobility grouping on. Total pages: 8220468
[ 0.046157] Policy zone: Normal
[ 0.046158] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=3e904cc4-97ad-4192-9863-9568ca78416e rw 3 splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.046206] Unknown kernel command line parameters "3 splash BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64", will be passed to user space.
[ 0.046220] random: crng init done
[ 0.048180] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.049161] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.049354] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.049360] software IO TLB: area num 16.
[ 0.094843] Memory: 32558980K/33404456K available (16391K kernel code, 2158K rwdata, 11140K rodata, 2152K init, 5312K bss, 845216K reserved, 0K cma-reserved)
[ 0.094918] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.094926] ftrace: allocating 46612 entries in 183 pages
[ 0.098845] ftrace: allocated 183 pages with 6 groups
[ 0.098887] Dynamic Preempt: full
[ 0.098908] rcu: Preemptible hierarchical RCU implementation.
[ 0.098908] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[ 0.098909] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.098910] Trampoline variant of Tasks RCU enabled.
[ 0.098910] Rude variant of Tasks RCU enabled.
[ 0.098910] Tracing variant of Tasks RCU enabled.
[ 0.098911] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.098911] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.101216] NR_IRQS: 20736, nr_irqs: 2184, preallocated irqs: 16
[ 0.101491] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.101729] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.101747] Console: colour dummy device 80x25
[ 0.101757] printk: console [tty0] enabled
[ 0.101770] ACPI: Core revision 20220331
[ 0.102090] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
[ 0.102180] APIC: Switch to symmetric I/O mode setup
[ 0.102181] DMAR: Host address width 39
[ 0.102182] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.102186] DMAR: dmar0: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
[ 0.102188] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 0
[ 0.102188] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.102189] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.103571] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.103572] x2apic enabled
[ 0.103592] Switched APIC routing to cluster x2apic.
[ 0.108329] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.122148] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6a464ae9873, max_idle_ns: 881590529744 ns
[ 0.122151] Calibrating delay loop (skipped), value calculated using timer frequency.. 7375.00 BogoMIPS (lpj=12288000)
[ 0.122153] pid_max: default: 32768 minimum: 301
[ 0.124558] LSM: Security Framework initializing
[ 0.124565] landlock: Up and running.
[ 0.124566] Yama: becoming mindful.
[ 0.124571] LSM support for eBPF active
[ 0.124582] AppArmor: AppArmor initialized
[ 0.124618] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.124646] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.124812] CPU0: Thermal monitoring enabled (TM1)
[ 0.124813] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.124911] process: using mwait in idle threads
[ 0.124911] CET detected: Indirect Branch Tracking enabled
[ 0.124912] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.124913] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.124914] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.124916] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.124916] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.124916] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[ 0.124917] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.124918] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.133713] Freeing SMP alternatives memory: 40K
[ 0.133950] smpboot: CPU0: 12th Gen Intel(R) Core(TM) i5-12600KF (family: 0x6, model: 0x97, stepping: 0x2)
[ 0.134021] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.134022] cblist_init_generic: Setting shift to 4 and lim to 1.
[ 0.134028] cblist_init_generic: Setting shift to 4 and lim to 1.
[ 0.134037] cblist_init_generic: Setting shift to 4 and lim to 1.
[ 0.134042] Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline, AnyThread deprecated, Alderlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.134132] core: cpu_core PMU driver:
[ 0.134133] ... version: 5
[ 0.134133] ... bit width: 48
[ 0.134134] ... generic registers: 8
[ 0.134134] ... value mask: 0000ffffffffffff
[ 0.134134] ... max period: 00007fffffffffff
[ 0.134135] ... fixed-purpose events: 4
[ 0.134135] ... event mask: 0001000f000000ff
[ 0.134151] Estimated ratio of average max frequency by base frequency (times 1024): 1300
[ 0.134159] rcu: Hierarchical SRCU implementation.
[ 0.134159] rcu: Max phase no-delay instances is 1000.
[ 0.134759] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.134833] smp: Bringing up secondary CPUs ...
[ 0.134878] x86: Booting SMP configuration:
[ 0.134878] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12
[ 0.003809] core: cpu_atom PMU driver: PEBS-via-PT
[ 0.003809] ... version: 5
[ 0.003809] ... bit width: 48
[ 0.003809] ... generic registers: 6
[ 0.003809] ... value mask: 0000ffffffffffff
[ 0.003809] ... max period: 00007fffffffffff
[ 0.003809] ... fixed-purpose events: 3
[ 0.003809] ... event mask: 000000070000003f
[ 0.159664] #13 #14 #15
[ 0.168298] smp: Brought up 1 node, 16 CPUs
[ 0.168298] smpboot: Max logical packages: 1
[ 0.168298] smpboot: Total of 16 processors activated (118012.00 BogoMIPS)
[ 0.169348] devtmpfs: initialized
[ 0.169348] x86/mm: Memory block size: 128MB
[ 0.169591] ACPI: PM: Registering ACPI NVS region [mem 0x786eb000-0x788eafff] (2097152 bytes)
[ 0.169591] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.169591] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.169591] pinctrl core: initialized pinctrl subsystem
[ 0.169591] PM: RTC time: 16:52:07, date: 2023-03-27
[ 0.169591] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.169595] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.169807] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.170072] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.170078] audit: initializing netlink subsys (disabled)
[ 0.170081] audit: type=2000 audit(1679935927.066:1): state=initialized audit_enabled=0 res=1
[ 0.170081] thermal_sys: Registered thermal governor 'fair_share'
[ 0.170081] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.170081] thermal_sys: Registered thermal governor 'step_wise'
[ 0.170081] thermal_sys: Registered thermal governor 'user_space'
[ 0.170081] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.170081] cpuidle: using governor ladder
[ 0.170081] cpuidle: using governor menu
[ 0.170081] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.170081] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.170081] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[ 0.170081] PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved in E820
[ 0.170081] PCI: Using configuration type 1 for base access
[ 0.172456] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.172456] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.172456] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.172456] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.172456] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.172456] ACPI: Added _OSI(Module Device)
[ 0.172456] ACPI: Added _OSI(Processor Device)
[ 0.172456] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.172456] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.233332] ACPI: 13 ACPI AML tables successfully acquired and loaded
[ 0.238821] ACPI: Dynamic OEM Table Load:
[ 0.238821] ACPI: SSDT 0xFFFF93D441BA0400 0001AB (v02 PmRef Cpu0Psd 00003000 INTL 20200717)
[ 0.238821] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.241162] ACPI: Dynamic OEM Table Load:
[ 0.241166] ACPI: SSDT 0xFFFF93D440D81000 000394 (v02 PmRef Cpu0Cst 00003001 INTL 20200717)
[ 0.241840] ACPI: Dynamic OEM Table Load:
[ 0.241843] ACPI: SSDT 0xFFFF93D441BE3000 0006EC (v02 PmRef Cpu0Ist 00003000 INTL 20200717)
[ 0.242580] ACPI: Dynamic OEM Table Load:
[ 0.242583] ACPI: SSDT 0xFFFF93D441BE0000 0004B5 (v02 PmRef Cpu0Hwp 00003000 INTL 20200717)
[ 0.243453] ACPI: Dynamic OEM Table Load:
[ 0.243458] ACPI: SSDT 0xFFFF93D440D5C000 001BAF (v02 PmRef ApIst 00003000 INTL 20200717)
[ 0.244548] ACPI: Dynamic OEM Table Load:
[ 0.244551] ACPI: SSDT 0xFFFF93D440D5A000 001038 (v02 PmRef ApHwp 00003000 INTL 20200717)
[ 0.245490] ACPI: Dynamic OEM Table Load:
[ 0.245494] ACPI: SSDT 0xFFFF93D440D58000 001349 (v02 PmRef ApPsd 00003000 INTL 20200717)
[ 0.246460] ACPI: Dynamic OEM Table Load:
[ 0.246464] ACPI: SSDT 0xFFFF93D440D7C000 000FBB (v02 PmRef ApCst 00003000 INTL 20200717)
[ 0.251884] ACPI: Interpreter enabled
[ 0.251921] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.251922] ACPI: Using IOAPIC for interrupt routing
[ 0.251952] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.251953] PCI: Ignoring E820 reservations for host bridge windows
[ 0.252806] ACPI: Enabled 6 GPEs in block 00 to 7F
[ 0.257789] ACPI: PM: Power Resource [WRST]
[ 0.257800] ACPI: PM: Power Resource [DRST]
[ 0.265467] ACPI: PM: Power Resource [BTRT]
[ 0.273516] ACPI: PM: Power Resource [WRST]
[ 0.275463] ACPI: PM: Power Resource [FN00]
[ 0.275463] ACPI: PM: Power Resource [FN01]
[ 0.275463] ACPI: PM: Power Resource [FN02]
[ 0.275463] ACPI: PM: Power Resource [FN03]
[ 0.275463] ACPI: PM: Power Resource [FN04]
[ 0.275463] ACPI: PM: Power Resource [PIN]
[ 0.275463] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[ 0.275463] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.275463] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[ 0.275463] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[ 0.275463] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.276017] PCI host bridge to bus 0000:00
[ 0.276017] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.276019] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.276019] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.276020] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[ 0.276021] pci_bus 0000:00: root bus resource [mem 0x80000000-0xbfffffff window]
[ 0.276021] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.276022] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.276061] pci 0000:00:00.0: [8086:4648] type 00 class 0x060000
[ 0.276139] pci 0000:00:01.0: [8086:460d] type 01 class 0x060400
[ 0.276180] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.276194] pci 0000:00:01.0: PTM enabled (root), 4ns granularity
[ 0.276600] pci 0000:00:08.0: [8086:464f] type 00 class 0x088000
[ 0.276606] pci 0000:00:08.0: reg 0x10: [mem 0x440212b000-0x440212bfff 64bit]
[ 0.276670] pci 0000:00:0a.0: [8086:467d] type 00 class 0x118000
[ 0.276676] pci 0000:00:0a.0: reg 0x10: [mem 0x4402110000-0x4402117fff 64bit]
[ 0.276691] pci 0000:00:0a.0: enabling Extended Tags
[ 0.276776] pci 0000:00:14.0: [8086:7ae0] type 00 class 0x0c0330
[ 0.276793] pci 0000:00:14.0: reg 0x10: [mem 0x4402100000-0x440210ffff 64bit]
[ 0.276861] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.278228] pci 0000:00:14.2: [8086:7aa7] type 00 class 0x050000
[ 0.278247] pci 0000:00:14.2: reg 0x10: [mem 0x4402124000-0x4402127fff 64bit]
[ 0.278259] pci 0000:00:14.2: reg 0x18: [mem 0x440212a000-0x440212afff 64bit]
[ 0.278367] pci 0000:00:16.0: [8086:7ae8] type 00 class 0x078000
[ 0.278387] pci 0000:00:16.0: reg 0x10: [mem 0x4402129000-0x4402129fff 64bit]
[ 0.278461] pci 0000:00:16.0: PME# supported from D3hot
[ 0.278812] pci 0000:00:17.0: [8086:7ae2] type 00 class 0x010601
[ 0.278831] pci 0000:00:17.0: reg 0x10: [mem 0x81e00000-0x81e01fff]
[ 0.278838] pci 0000:00:17.0: reg 0x14: [mem 0x81e03000-0x81e030ff]
[ 0.278845] pci 0000:00:17.0: reg 0x18: [io 0x5050-0x5057]
[ 0.278852] pci 0000:00:17.0: reg 0x1c: [io 0x5040-0x5043]
[ 0.278859] pci 0000:00:17.0: reg 0x20: [io 0x5020-0x503f]
[ 0.278866] pci 0000:00:17.0: reg 0x24: [mem 0x81e02000-0x81e027ff]
[ 0.278904] pci 0000:00:17.0: PME# supported from D3hot
[ 0.279102] pci 0000:00:1c.0: [8086:7ab8] type 01 class 0x060400
[ 0.279547] pci 0000:00:1c.2: [8086:7aba] type 01 class 0x060400
[ 0.279640] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.279673] pci 0000:00:1c.2: PTM enabled (root), 4ns granularity
[ 0.280073] pci 0000:00:1d.0: [8086:7ab0] type 01 class 0x060400
[ 0.280166] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.280199] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.280603] pci 0000:00:1f.0: [8086:7a84] type 00 class 0x060100
[ 0.280862] pci 0000:00:1f.3: [8086:7ad0] type 00 class 0x040300
[ 0.280903] pci 0000:00:1f.3: reg 0x10: [mem 0x4402120000-0x4402123fff 64bit]
[ 0.280955] pci 0000:00:1f.3: reg 0x20: [mem 0x4402000000-0x44020fffff 64bit]
[ 0.281054] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.281130] pci 0000:00:1f.4: [8086:7aa3] type 00 class 0x0c0500
[ 0.281154] pci 0000:00:1f.4: reg 0x10: [mem 0x4402128000-0x44021280ff 64bit]
[ 0.281182] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.281338] pci 0000:00:1f.5: [8086:7aa4] type 00 class 0x0c8000
[ 0.281356] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.281462] pci 0000:01:00.0: [10de:2208] type 00 class 0x030000
[ 0.281469] pci 0000:01:00.0: reg 0x10: [mem 0x80000000-0x80ffffff]
[ 0.281475] pci 0000:01:00.0: reg 0x14: [mem 0x4000000000-0x43ffffffff 64bit pref]
[ 0.281481] pci 0000:01:00.0: reg 0x1c: [mem 0x4400000000-0x4401ffffff 64bit pref]
[ 0.281485] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.281489] pci 0000:01:00.0: reg 0x30: [mem 0x81000000-0x8107ffff pref]
[ 0.281500] pci 0000:01:00.0: BAR 1: assigned to efifb
[ 0.281527] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.281625] pci 0000:01:00.1: [10de:1aef] type 00 class 0x040300
[ 0.281631] pci 0000:01:00.1: reg 0x10: [mem 0x81080000-0x81083fff]
[ 0.281707] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.281708] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.281710] pci 0000:00:01.0: bridge window [mem 0x80000000-0x810fffff]
[ 0.281712] pci 0000:00:01.0: bridge window [mem 0x4000000000-0x4401ffffff 64bit pref]
[ 0.281746] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.281748] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.281751] pci 0000:00:1c.0: bridge window [mem 0x81100000-0x81afffff]
[ 0.281814] pci 0000:03:00.0: [8086:15f3] type 00 class 0x020000
[ 0.281832] pci 0000:03:00.0: reg 0x10: [mem 0x81b00000-0x81bfffff]
[ 0.281857] pci 0000:03:00.0: reg 0x1c: [mem 0x81c00000-0x81c03fff]
[ 0.281982] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.282547] pci 0000:00:1c.2: PCI bridge to [bus 03]
[ 0.282551] pci 0000:00:1c.2: bridge window [mem 0x81b00000-0x81cfffff]
[ 0.282620] pci 0000:04:00.0: [2646:5013] type 00 class 0x010802
[ 0.282671] pci 0000:04:00.0: reg 0x10: [mem 0x81d00000-0x81d03fff 64bit]
[ 0.283291] pci 0000:04:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:1d.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[ 0.283530] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.283534] pci 0000:00:1d.0: bridge window [mem 0x81d00000-0x81dfffff]
[ 0.285629] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.285697] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.285763] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.285829] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.285894] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.285959] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.286025] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.286090] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.295493] iommu: Default domain type: Translated
[ 0.295493] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.295555] SCSI subsystem initialized
[ 0.295558] libata version 3.00 loaded.
[ 0.295558] ACPI: bus type USB registered
[ 0.295558] usbcore: registered new interface driver usbfs
[ 0.295558] usbcore: registered new interface driver hub
[ 0.295558] usbcore: registered new device driver usb
[ 0.295558] pps_core: LinuxPPS API ver. 1 registered
[ 0.295558] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.295558] PTP clock support registered
[ 0.295558] EDAC MC: Ver: 3.0.0
[ 0.295589] Registered efivars operations
[ 0.295589] NetLabel: Initializing
[ 0.295589] NetLabel: domain hash size = 128
[ 0.295589] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.295589] NetLabel: unlabeled traffic allowed by default
[ 0.295589] mctp: management component transport protocol core
[ 0.295589] NET: Registered PF_MCTP protocol family
[ 0.295589] PCI: Using ACPI for IRQ routing
[ 0.316748] PCI: pci_cache_line_size set to 64 bytes
[ 0.316787] pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[ 0.316818] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.316819] e820: reserve RAM buffer [mem 0x6fd99000-0x6fffffff]
[ 0.316820] e820: reserve RAM buffer [mem 0x736c8000-0x73ffffff]
[ 0.316820] e820: reserve RAM buffer [mem 0x76deb000-0x77ffffff]
[ 0.316821] e820: reserve RAM buffer [mem 0x79c00000-0x7bffffff]
[ 0.318827] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.318827] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.318827] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.318827] vgaarb: loaded
[ 0.319234] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.319238] hpet0: 8 comparators, 64-bit 19.200000 MHz counter
[ 0.322183] clocksource: Switched to clocksource tsc-early
[ 0.322253] VFS: Disk quotas dquot_6.6.0
[ 0.322261] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.322325] AppArmor: AppArmor Filesystem Enabled
[ 0.322344] pnp: PnP ACPI init
[ 0.322545] system 00:00: [io 0x0a00-0x0a0f] has been reserved
[ 0.322547] system 00:00: [io 0x0a10-0x0a1f] has been reserved
[ 0.322549] system 00:00: [io 0x0a20-0x0a2f] has been reserved
[ 0.322709] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.322710] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.322799] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.324969] system 00:03: [mem 0xfedc0000-0xfedc7fff] has been reserved
[ 0.324971] system 00:03: [mem 0xfeda0000-0xfeda0fff] has been reserved
[ 0.324973] system 00:03: [mem 0xfeda1000-0xfeda1fff] has been reserved
[ 0.324974] system 00:03: [mem 0xc0000000-0xcfffffff] has been reserved
[ 0.324975] system 00:03: [mem 0xfed20000-0xfed7ffff] has been reserved
[ 0.324976] system 00:03: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.324977] system 00:03: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.324979] system 00:03: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.325586] system 00:04: [io 0x2000-0x20fe] has been reserved
[ 0.326111] pnp: PnP ACPI: found 6 devices
[ 0.331128] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.331160] NET: Registered PF_INET protocol family
[ 0.331314] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.332777] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.332802] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.332930] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.333178] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.333265] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.333365] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[ 0.333427] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.333478] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.333514] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.333518] NET: Registered PF_XDP protocol family
[ 0.333521] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.333527] pci 0000:00:1c.0: BAR 15: assigned [mem 0x4402200000-0x44023fffff 64bit pref]
[ 0.333528] pci 0000:00:1f.5: BAR 0: assigned [mem 0x81e04000-0x81e04fff]
[ 0.333542] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.333543] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.333544] pci 0000:00:01.0: bridge window [mem 0x80000000-0x810fffff]
[ 0.333546] pci 0000:00:01.0: bridge window [mem 0x4000000000-0x4401ffffff 64bit pref]
[ 0.333548] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.333549] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.333553] pci 0000:00:1c.0: bridge window [mem 0x81100000-0x81afffff]
[ 0.333555] pci 0000:00:1c.0: bridge window [mem 0x4402200000-0x44023fffff 64bit pref]
[ 0.333559] pci 0000:00:1c.2: PCI bridge to [bus 03]
[ 0.333562] pci 0000:00:1c.2: bridge window [mem 0x81b00000-0x81cfffff]
[ 0.333568] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.333572] pci 0000:00:1d.0: bridge window [mem 0x81d00000-0x81dfffff]
[ 0.333578] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.333579] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.333579] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.333580] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000fffff window]
[ 0.333580] pci_bus 0000:00: resource 8 [mem 0x80000000-0xbfffffff window]
[ 0.333581] pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
[ 0.333581] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.333582] pci_bus 0000:01: resource 1 [mem 0x80000000-0x810fffff]
[ 0.333583] pci_bus 0000:01: resource 2 [mem 0x4000000000-0x4401ffffff 64bit pref]
[ 0.333583] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ 0.333584] pci_bus 0000:02: resource 1 [mem 0x81100000-0x81afffff]
[ 0.333584] pci_bus 0000:02: resource 2 [mem 0x4402200000-0x44023fffff 64bit pref]
[ 0.333585] pci_bus 0000:03: resource 1 [mem 0x81b00000-0x81cfffff]
[ 0.333586] pci_bus 0000:04: resource 1 [mem 0x81d00000-0x81dfffff]
[ 0.333888] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.333923] PCI: CLS 64 bytes, default 64
[ 0.333930] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.333931] software IO TLB: mapped [mem 0x0000000066339000-0x000000006a339000] (64MB)
[ 0.333947] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6a464ae9873, max_idle_ns: 881590529744 ns
[ 0.333949] Trying to unpack rootfs image as initramfs...
[ 0.333960] clocksource: Switched to clocksource tsc
[ 0.333969] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.339633] Initialise system trusted keyrings
[ 0.339637] Key type blacklist registered
[ 0.339653] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[ 0.340087] zbud: loaded
[ 0.340193] integrity: Platform Keyring initialized
[ 0.340195] integrity: Machine keyring initialized
[ 0.344770] Key type asymmetric registered
[ 0.344771] Asymmetric key parser 'x509' registered
[ 0.466683] Freeing initrd memory: 20312K
[ 0.468030] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.468039] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.468054] io scheduler mq-deadline registered
[ 0.468055] io scheduler kyber registered
[ 0.468068] io scheduler bfq registered
[ 0.469936] pcieport 0000:00:1c.0: Refused to change power state from D3hot to D0
[ 0.470243] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.470637] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.470647] ACPI: button: Sleep Button [SLPB]
[ 0.470661] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.470667] ACPI: button: Power Button [PWRB]
[ 0.470678] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.472172] ACPI: button: Power Button [PWRF]
[ 0.474363] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.474364] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.474506] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.474827] serial8250: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.475371] Non-volatile memory driver v1.3
[ 0.475372] Linux agpgart interface v0.103
[ 0.475390] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.475549] ACPI: bus type drm_connector registered
[ 0.477203] ahci 0000:00:17.0: version 3.0
[ 0.487491] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0xff impl SATA mode
[ 0.487500] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm sds
[ 0.556232] scsi host0: ahci
[ 0.556703] scsi host1: ahci
[ 0.557166] scsi host2: ahci
[ 0.557456] scsi host3: ahci
[ 0.557733] scsi host4: ahci
[ 0.557901] scsi host5: ahci
[ 0.558024] scsi host6: ahci
[ 0.558149] scsi host7: ahci
[ 0.558165] ata1: SATA max UDMA/133 abar m2048@0x81e02000 port 0x81e02100 irq 124
[ 0.558168] ata2: SATA max UDMA/133 abar m2048@0x81e02000 port 0x81e02180 irq 124
[ 0.558169] ata3: SATA max UDMA/133 abar m2048@0x81e02000 port 0x81e02200 irq 124
[ 0.558170] ata4: SATA max UDMA/133 abar m2048@0x81e02000 port 0x81e02280 irq 124
[ 0.558171] ata5: SATA max UDMA/133 abar m2048@0x81e02000 port 0x81e02300 irq 124
[ 0.558172] ata6: SATA max UDMA/133 abar m2048@0x81e02000 port 0x81e02380 irq 124
[ 0.558174] ata7: SATA max UDMA/133 abar m2048@0x81e02000 port 0x81e02400 irq 124
[ 0.558175] ata8: SATA max UDMA/133 abar m2048@0x81e02000 port 0x81e02480 irq 124
[ 0.558216] usbcore: registered new interface driver usbserial_generic
[ 0.558218] usbserial: USB Serial support registered for generic
[ 0.558273] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.559160] rtc_cmos rtc_cmos: registered as rtc0
[ 0.559339] rtc_cmos rtc_cmos: setting system clock to 2023-03-27T16:52:07 UTC (1679935927)
[ 0.559366] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.559785] intel_pstate: Intel P-state driver initializing
[ 0.561008] intel_pstate: HWP enabled
[ 0.561353] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.562135] efifb: probing for efifb
[ 0.562179] efifb: framebuffer at 0x4000000000, using 8640k, total 8640k
[ 0.562185] efifb: mode is 1920x1080x32, linelength=8192, pages=1
[ 0.562189] efifb: scrolling: redraw
[ 0.562190] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.562280] fbcon: Deferring console take-over
[ 0.562283] fb0: EFI VGA frame buffer device
[ 0.562361] hid: raw HID events driver (C) Jiri Kosina
[ 0.562537] intel_pmc_core INT33A1:00: initialized
[ 0.562828] drop_monitor: Initializing network drop monitor service
[ 0.589646] Initializing XFRM netlink socket
[ 0.589728] NET: Registered PF_INET6 protocol family
[ 0.593353] Segment Routing with IPv6
[ 0.593355] RPL Segment Routing with IPv6
[ 0.593364] In-situ OAM (IOAM) with IPv6
[ 0.593391] NET: Registered PF_PACKET protocol family
[ 0.595639] microcode: sig=0x90672, pf=0x2, revision=0x28
[ 0.596100] microcode: Microcode Update Driver: v2.2.
[ 0.596108] IPI shorthand broadcast: enabled
[ 0.596137] sched_clock: Marking stable (595033937, 476275)->(601263975, -5753763)
[ 0.596740] registered taskstats version 1
[ 0.597890] Loading compiled-in X.509 certificates
[ 0.602098] Loaded X.509 cert 'Build time autogenerated kernel key: 31444bb7e6e17bb69ca9ad3ba00426f4041a030d'
[ 0.604797] zswap: loaded using pool zstd/z3fold
[ 0.605122] Key type .fscrypt registered
[ 0.605123] Key type fscrypt-provisioning registered
[ 0.605153] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.605371] integrity: Loading X.509 certificate: UEFI:db
[ 0.605383] integrity: Loaded X.509 cert 'MSI SHIP DB: ebc30d5be5f35f8041c1c2d9e613eee2'
[ 0.605384] integrity: Loading X.509 certificate: UEFI:db
[ 0.605398] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 0.605399] integrity: Loading X.509 certificate: UEFI:db
[ 0.605411] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 0.606636] PM: Magic number: 15:48:895
[ 0.606792] RAS: Correctable Errors collector initialized.
[ 0.873335] ata6: SATA link down (SStatus 4 SControl 300)
[ 0.873372] ata8: SATA link down (SStatus 4 SControl 300)
[ 0.873410] ata5: SATA link down (SStatus 4 SControl 300)
[ 0.873467] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.873516] ata4: SATA link down (SStatus 4 SControl 300)
[ 0.873636] ata7: SATA link down (SStatus 4 SControl 300)
[ 0.873860] ata1.00: ATA-11: SSDPR-CX300-240, SBFM61.3, max UDMA/133
[ 0.873942] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 0.873981] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.874017] ata1.00: 468862128 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.874740] ata1.00: configured for UDMA/133
[ 0.875060] ata3.00: ATA-8: ST1000DM003-1SB102, CC43, max UDMA/133
[ 0.875140] scsi 0:0:0:0: Direct-Access ATA SSDPR-CX300-240 61.3 PQ: 0 ANSI: 5
[ 0.876912] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
[ 0.876970] sd 0:0:0:0: [sda] Write Protect is off
[ 0.876979] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.877028] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.877102] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 0.893237] ata3.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.894254] ata3.00: configured for UDMA/133
[ 0.896054] sda: sda1 sda2 sda3
[ 0.896564] sd 0:0:0:0: [sda] Attached SCSI disk
[ 0.927814] ata2.00: ATA-8: TOSHIBA MK5065GSX, GJ205E, max UDMA/100
[ 0.928037] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.929413] ata2.00: configured for UDMA/100
[ 0.929790] scsi 1:0:0:0: Direct-Access ATA TOSHIBA MK5065GS 5E PQ: 0 ANSI: 5
[ 0.931515] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 0.931564] scsi 2:0:0:0: Direct-Access ATA ST1000DM003-1SB1 CC43 PQ: 0 ANSI: 5
[ 0.931619] sd 1:0:0:0: [sdb] Write Protect is off
[ 0.931628] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 0.931853] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.932190] sd 1:0:0:0: [sdb] Preferred minimum I/O size 512 bytes
[ 0.932291] sd 2:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.932296] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[ 0.932333] sd 2:0:0:0: [sdc] Write Protect is off
[ 0.932342] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 0.932380] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.932435] sd 2:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes
[ 0.990714] sdc: sdc1 sdc2
[ 0.991152] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 1.047573] sdb: sdb1 sdb2
[ 1.048084] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1.055204] Freeing unused decrypted memory: 2036K
[ 1.055550] Freeing unused kernel image (initmem) memory: 2152K
[ 1.062290] Write protecting the kernel read-only data: 30720k
[ 1.063602] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 1.064151] Freeing unused kernel image (rodata/data gap) memory: 1148K
[ 1.078259] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.078262] rodata_test: all tests were successful
[ 1.078265] Run /init as init process
[ 1.078266] with arguments:
[ 1.078267] /init
[ 1.078268] 3
[ 1.078268] splash
[ 1.078269] with environment:
[ 1.078269] HOME=/
[ 1.078270] TERM=linux
[ 1.078270] BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64
[ 1.101783] fbcon: Taking over console
[ 1.101836] Console: switching to colour frame buffer device 240x67
[ 1.191694] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.191699] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.192786] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 1.193026] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.193027] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.193029] xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 1.193053] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.193054] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.193055] usb usb1: Product: xHCI Host Controller
[ 1.193056] usb usb1: Manufacturer: Linux 6.1.19-1-MANJARO xhci-hcd
[ 1.193056] usb usb1: SerialNumber: 0000:00:14.0
[ 1.193166] hub 1-0:1.0: USB hub found
[ 1.193191] hub 1-0:1.0: 16 ports detected
[ 1.194735] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.194737] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.194737] usb usb2: Product: xHCI Host Controller
[ 1.194738] usb usb2: Manufacturer: Linux 6.1.19-1-MANJARO xhci-hcd
[ 1.194739] usb usb2: SerialNumber: 0000:00:14.0
[ 1.194899] hub 2-0:1.0: USB hub found
[ 1.194919] hub 2-0:1.0: 9 ports detected
[ 1.196373] nvme nvme0: pci function 0000:04:00.0
[ 1.200969] nvme nvme0: Shutdown timeout set to 10 seconds
[ 1.202944] nvme nvme0: 16/0/0 default/read/poll queues
[ 1.205000] nvme0n1: p1 p2
[ 1.445576] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[ 1.593645] usb 1-2: New USB device found, idVendor=1462, idProduct=7d25, bcdDevice= 0.01
[ 1.593657] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.593662] usb 1-2: Product: MYSTIC LIGHT
[ 1.593665] usb 1-2: Manufacturer: MSI
[ 1.593668] usb 1-2: SerialNumber: A02021081203
[ 1.608878] input: MSI MYSTIC LIGHT as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:1462:7D25.0001/input/input3
[ 1.609161] hid-generic 0003:1462:7D25.0001: input,hiddev96,hidraw0: USB HID v1.10 Device [MSI MYSTIC LIGHT ] on usb-0000:00:14.0-2/input0
[ 1.609214] usbcore: registered new interface driver usbhid
[ 1.609216] usbhid: USB HID core driver
[ 1.718906] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[ 1.863383] usb 1-5: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[ 1.863386] usb 1-5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.863388] usb 1-5: Product: USB2.0 Hub
[ 1.864218] hub 1-5:1.0: USB hub found
[ 1.864494] hub 1-5:1.0: 4 ports detected
[ 1.988842] usb 1-7: new full-speed USB device number 4 using xhci_hcd
[ 1.991533] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.145165] usb 1-7: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 2.145176] usb 1-7: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.145180] usb 1-7: Product: CSR8510 A10
[ 2.215577] usb 1-5.3: new full-speed USB device number 5 using xhci_hcd
[ 2.311496] usb 1-5.3: New USB device found, idVendor=248a, idProduct=8514, bcdDevice= 1.00
[ 2.311507] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.311512] usb 1-5.3: Product: Wireless Receiver
[ 2.311515] usb 1-5.3: Manufacturer: Telink
[ 2.322367] input: Telink Wireless Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0/0003:248A:8514.0002/input/input4
[ 2.322647] input: Telink Wireless Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0/0003:248A:8514.0002/input/input5
[ 2.379165] input: Telink Wireless Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0/0003:248A:8514.0002/input/input6
[ 2.379564] hid-generic 0003:248A:8514.0002: input,hidraw1: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:00:14.0-5.3/input0
[ 2.382421] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.1/0003:248A:8514.0003/input/input7
[ 2.428920] usb 1-8: new high-speed USB device number 6 using xhci_hcd
[ 2.439432] hid-generic 0003:248A:8514.0003: input,hidraw2: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:00:14.0-5.3/input1
[ 2.576258] usb 1-8: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.00
[ 2.576269] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.576274] usb 1-8: Product: Mass Storage
[ 2.576277] usb 1-8: Manufacturer: Generic
[ 2.576280] usb 1-8: SerialNumber: EA172E33
[ 2.702241] usb 1-11: new full-speed USB device number 7 using xhci_hcd
[ 2.844586] usb 1-11: New USB device found, idVendor=05ac, idProduct=024f, bcdDevice= 1.07
[ 2.844598] usb 1-11: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.844602] usb 1-11: Product: Keychron K4
[ 2.844605] usb 1-11: Manufacturer: Keychron K4
[ 2.968906] usb 1-13: new high-speed USB device number 8 using xhci_hcd
[ 3.110559] usb 1-13: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[ 3.110570] usb 1-13: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.110574] usb 1-13: Product: USB2.0 Hub
[ 3.112467] hub 1-13:1.0: USB hub found
[ 3.112813] hub 1-13:1.0: 4 ports detected
[ 3.395578] usb 1-13.1: new high-speed USB device number 9 using xhci_hcd
[ 3.486716] usb 1-13.1: New USB device found, idVendor=0b05, idProduct=1988, bcdDevice= 2.00
[ 3.486729] usb 1-13.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.486733] usb 1-13.1: Product: ROG RYUJIN II
[ 3.486737] usb 1-13.1: Manufacturer: AsusTek Computer Inc.
[ 3.486739] usb 1-13.1: SerialNumber: 396935673031
[ 3.490451] hid-generic 0003:0B05:1988.0006: hiddev97,hidraw3: USB HID v1.11 Device [AsusTek Computer Inc. ROG RYUJIN II] on usb-0000:00:14.0-13.1/input1
[ 4.112490] systemd[1]: systemd 252.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 4.112504] systemd[1]: Detected architecture x86-64.
[ 4.180520] systemd[1]: Hostname set to <roman>.
[ 4.696025] systemd[1]: bpf-lsm: LSM BPF program attached
[ 10.926474] systemd[1]: Queued start job for default target Multi-User System.
[ 10.957238] systemd[1]: Created slice Slice /system/getty.
[ 10.957820] systemd[1]: Created slice Slice /system/modprobe.
[ 10.958284] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 10.958625] systemd[1]: Created slice User and Session Slice.
[ 10.958755] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.959072] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.959166] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 10.959229] systemd[1]: Reached target Remote File Systems.
[ 10.959267] systemd[1]: Reached target Slice Units.
[ 10.959314] systemd[1]: Reached target Swaps.
[ 10.959368] systemd[1]: Reached target Local Verity Protected Volumes.
[ 10.959504] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 10.977253] systemd[1]: Listening on LVM2 poll daemon socket.
[ 10.979425] systemd[1]: Listening on Process Core Dump Socket.
[ 10.979702] systemd[1]: Listening on Journal Audit Socket.
[ 10.979880] systemd[1]: Listening on Journal Socket (/dev/log).
[ 10.980052] systemd[1]: Listening on Journal Socket.
[ 10.986777] systemd[1]: Listening on udev Control Socket.
[ 10.986952] systemd[1]: Listening on udev Kernel Socket.
[ 10.988648] systemd[1]: Mounting Huge Pages File System...
[ 10.990264] systemd[1]: Mounting POSIX Message Queue File System...
[ 10.991944] systemd[1]: Mounting Kernel Debug File System...
[ 10.993520] systemd[1]: Mounting Kernel Trace File System...
[ 11.024005] systemd[1]: Mounting Temporary Directory /tmp...
[ 11.025791] systemd[1]: Starting Load AppArmor profiles...
[ 11.027582] systemd[1]: Starting Create List of Static Device Nodes...
[ 11.029166] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 11.030884] systemd[1]: Starting Load Kernel Module configfs...
[ 11.032542] systemd[1]: Starting Load Kernel Module drm...
[ 11.034116] systemd[1]: Starting Load Kernel Module fuse...
[ 11.034286] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 11.185997] systemd[1]: Starting Load Kernel Modules...
[ 11.187827] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.188001] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 11.189635] systemd[1]: Starting Coldplug All udev Devices...
[ 11.191072] systemd[1]: Mounted Huge Pages File System.
[ 11.191142] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.191188] systemd[1]: Mounted Kernel Debug File System.
[ 11.191229] systemd[1]: Mounted Kernel Trace File System.
[ 11.191269] systemd[1]: Mounted Temporary Directory /tmp.
[ 11.232446] systemd[1]: Finished Create List of Static Device Nodes.
[ 11.233332] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 11.259274] systemd[1]: Finished Load Kernel Module configfs.
[ 11.259867] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 11.282571] systemd[1]: Finished Load Kernel Module drm.
[ 11.319259] systemd[1]: Mounting Kernel Configuration File System...
[ 11.322815] systemd[1]: Mounted Kernel Configuration File System.
[ 11.445668] systemd[1]: Finished Coldplug All udev Devices.
[ 11.555634] EXT4-fs (sdb2): re-mounted. Quota mode: none.
[ 11.589175] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 11.589606] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 11.663116] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 11.682668] systemd[1]: Starting Load/Save Random Seed...
[ 11.682850] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[ 11.684609] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 11.686318] systemd[1]: Starting Setup Virtual Console...
[ 11.715955] fuse: init (API version 7.37)
[ 11.716834] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 11.749216] systemd[1]: Finished Load Kernel Module fuse.
[ 11.782619] systemd[1]: Mounting FUSE Control File System...
[ 11.811138] systemd[1]: Mounted FUSE Control File System.
[ 11.828313] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 11.828323] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 11.828332] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 12.289137] systemd[1]: Finished Load/Save Random Seed.
[ 12.289547] systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 12.419045] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 12.838969] systemd[1]: Finished Setup Virtual Console.
[ 12.848946] audit: type=1400 audit(1679935939.786:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=383 comm="apparmor_parser"
[ 12.856024] audit: type=1400 audit(1679935939.793:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=391 comm="apparmor_parser"
[ 12.856036] audit: type=1400 audit(1679935939.793:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-anvil" pid=395 comm="apparmor_parser"
[ 12.856817] audit: type=1400 audit(1679935939.793:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=384 comm="apparmor_parser"
[ 12.857653] audit: type=1400 audit(1679935939.793:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=384 comm="apparmor_parser"
[ 12.860382] audit: type=1400 audit(1679935939.796:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=382 comm="apparmor_parser"
[ 12.861616] audit: type=1400 audit(1679935939.796:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="syslogd" pid=393 comm="apparmor_parser"
[ 12.862708] audit: type=1400 audit(1679935939.799:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=386 comm="apparmor_parser"
[ 12.865285] audit: type=1400 audit(1679935939.799:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=388 comm="apparmor_parser"
[ 12.865979] audit: type=1400 audit(1679935939.803:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd-spoolss" pid=390 comm="apparmor_parser"
[ 12.948945] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 12.949079] systemd[1]: Reached target Preparation for Local File Systems.
[ 12.949104] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 12.949113] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 12.965740] systemd[1]: Starting Journal Service...
[ 12.966202] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 13.095641] systemd[1]: Finished Load AppArmor profiles.
[ 13.158038] systemd[1]: Started Journal Service.
[ 13.258092] systemd-journald[432]: Received client request to flush runtime journal.
[ 13.869451] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 14.355314] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 14.366207] i2c i2c-0: 2/4 memory slots populated (from DMI)
[ 14.366989] i2c i2c-0: Successfully instantiated SPD at 0x51
[ 14.367691] i2c i2c-0: Successfully instantiated SPD at 0x53
[ 14.513900] iTCO_vendor_support: vendor-support=0
[ 14.528659] input: PC Speaker as /devices/platform/pcspkr/input/input8
[ 14.557474] spi-nor spi0.0: mx25u25635f (32768 Kbytes)
[ 14.564179] Creating 1 MTD partitions on "0000:00:1f.5":
[ 14.564185] 0x000000000000-0x000002000000 : "BIOS"
[ 14.570431] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 14.570768] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 14.626856] Intel(R) 2.5G Ethernet Linux Driver
[ 14.626857] Copyright(c) 2018 Intel Corporation.
[ 14.626875] igc 0000:03:00.0: enabling device (0000 -> 0002)
[ 14.626957] igc 0000:03:00.0: PTM enabled, 4ns granularity
[ 14.642062] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 655360 ms ovfl timer
[ 14.642064] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 14.642064] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 14.672433] pps pps0: new PPS source ptp0
[ 14.672447] igc 0000:03:00.0 (unnamed net_device) (uninitialized): PHC added
[ 14.691252] cryptd: max_cpu_qlen set to 1000
[ 14.697666] igc 0000:03:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 14.697669] igc 0000:03:00.0 eth0: MAC: d8:bb:c1:a4:7f:41
[ 14.729419] igc 0000:03:00.0 enp3s0: renamed from eth0
[ 14.813510] ee1004 0-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 14.813522] ee1004 0-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 14.861065] AVX2 version of gcm_enc/dec engaged.
[ 14.861091] AES CTR mode by8 optimization enabled
[ 15.026241] Bluetooth: Core ver 2.22
[ 15.026254] NET: Registered PF_BLUETOOTH protocol family
[ 15.026254] Bluetooth: HCI device and connection manager initialized
[ 15.026256] Bluetooth: HCI socket layer initialized
[ 15.026258] Bluetooth: L2CAP socket layer initialized
[ 15.026259] Bluetooth: SCO socket layer initialized
[ 15.101149] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 15.102039] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 15.102227] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 15.102234] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 15.172723] usbcore: registered new device driver apple-mfi-fastcharge
[ 15.173862] usb-storage 1-8:1.0: USB Mass Storage device detected
[ 15.173945] scsi host8: usb-storage 1-8:1.0
[ 15.173997] usbcore: registered new interface driver usb-storage
[ 15.193914] usbcore: registered new interface driver uas
[ 15.204010] apple 0003:05AC:024F.0004: Non-apple keyboard detected; function keys will default to fnmode=2 behavior
[ 15.204053] input: Keychron K4 Keychron K4 as /devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/0003:05AC:024F.0004/input/input9
[ 15.207601] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 15.262681] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[ 15.262711] apple 0003:05AC:024F.0004: input,hidraw4: USB HID v1.11 Keyboard [Keychron K4 Keychron K4] on usb-0000:00:14.0-11/input0
[ 15.263000] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 15.263019] mousedev: PS/2 mouse device common for all mice
[ 15.263081] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 15.263523] apple 0003:05AC:024F.0005: Fn key not found (Apple Wireless Keyboard clone?), disabling Fn key handling
[ 15.263527] apple 0003:05AC:024F.0005: Non-apple keyboard detected; function keys will default to fnmode=2 behavior
[ 15.263603] input: Keychron K4 Keychron K4 as /devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.1/0003:05AC:024F.0005/input/input14
[ 15.322321] apple 0003:05AC:024F.0005: input,hiddev98,hidraw5: USB HID v1.11 Keyboard [Keychron K4 Keychron K4] on usb-0000:00:14.0-11/input1
[ 15.518524] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC897: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 15.518530] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 15.518532] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 15.518533] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 15.518535] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 15.518536] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 15.518538] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 15.518539] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 15.540447] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 15.540495] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 15.540534] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 15.540578] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 15.540612] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 15.540658] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 15.540704] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 15.540739] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 15.749482] usbcore: registered new interface driver btusb
[ 15.764779] Bluetooth: hci0: CSR: Setting up dongle with HCI ver=6 rev=22bb; LMP ver=6 subver=22bb; manufacturer=10
[ 16.180830] scsi 8:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
[ 16.181280] sd 8:0:0:0: Attached scsi generic sg3 type 0
[ 16.182309] sd 8:0:0:0: [sdd] 61440000 512-byte logical blocks: (31.5 GB/29.3 GiB)
[ 16.182981] sd 8:0:0:0: [sdd] Write Protect is off
[ 16.182985] sd 8:0:0:0: [sdd] Mode Sense: 23 00 00 00
[ 16.183659] sd 8:0:0:0: [sdd] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 16.189601] sdd: sdd1 sdd2
[ 16.189950] sd 8:0:0:0: [sdd] Attached SCSI removable disk
[ 17.945988] intel_tcc_cooling: Programmable TCC Offset detected
[ 17.982732] kauditd_printk_skb: 54 callbacks suppressed
[ 17.982738] audit: type=1130 audit(1679935944.919:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.044957] intel_rapl_msr: PL4 support detected.
[ 18.044995] intel_rapl_common: Found RAPL domain package
[ 18.044998] intel_rapl_common: Found RAPL domain core
[ 18.542585] audit: type=1130 audit(1679935945.479:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-29DC\x2d2024 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.102801] audit: type=1130 audit(1679935946.039:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.419124] audit: type=1130 audit(1679935946.356:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.419469] audit: type=1334 audit(1679935946.356:70): prog-id=29 op=LOAD
[ 19.573763] audit: type=1127 audit(1679935946.509:71): pid=615 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 19.591743] audit: type=1130 audit(1679935946.526:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.622720] audit: type=1130 audit(1679935946.559:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.885208] nvidia: loading out-of-tree module taints kernel.
[ 19.885215] nvidia: module license 'NVIDIA' taints kernel.
[ 19.885216] Disabling lock debugging due to kernel taint
[ 19.905529] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 20.003440] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 20.003463] traps: Missing ENDBR: _nv012309rm+0x0/0x10 [nvidia]
[ 20.003717] ------------[ cut here ]------------
[ 20.003718] kernel BUG at arch/x86/kernel/traps.c:255!
[ 20.003721] invalid opcode: 0000 [#1] PREEMPT SMP NOPTI
[ 20.004719] CPU: 6 PID: 364 Comm: systemd-modules Tainted: P OE 6.1.19-1-MANJARO #1 389fdd3d7a99644f7437b855eb50ad5703eff2d2
[ 20.004730] Hardware name: Micro-Star International Co., Ltd. MS-7D25/PRO Z690-A DDR4(MS-7D25), BIOS 1.A0 01/09/2023
[ 20.004737] RIP: 0010:exc_control_protection+0xc2/0xd0
[ 20.004744] Code: fa ff 45 31 c9 49 89 d8 b9 09 00 00 00 48 8b 93 80 00 00 00 be fc 00 00 00 48 c7 c7 21 2f e4 bb e8 53 03 46 ff e9 64 ff ff ff <0f> 0b 66 66 2e 0f 1f 84 00 00 00 00 00 90 66 0f 1f 00 55 53 48 89
[ 20.004757] RSP: 0018:ffffa42302e33b28 EFLAGS: 00010002
[ 20.004761] RAX: 0000000000000033 RBX: ffffa42302e33b48 RCX: 0000000000000027
[ 20.004767] RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff93db9fba1660
[ 20.004772] RBP: 0000000000000003 R08: 0000000000000000 R09: ffffa42302e339c0
[ 20.004777] R10: 0000000000000003 R11: ffffffffbc6cc7e8 R12: 0000000000000000
[ 20.004782] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 20.004788] FS: 00007fc5de27f080(0000) GS:ffff93db9fb80000(0000) knlGS:0000000000000000
[ 20.004794] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 20.004798] CR2: 00007fc5d83a2000 CR3: 00000001010f4004 CR4: 0000000000f70ee0
[ 20.004804] PKRU: 55555554
[ 20.004806] Call Trace:
[ 20.004809] <TASK>
[ 20.004812] asm_exc_control_protection+0x26/0x30
[ 20.004817] RIP: 0010:_nv012309rm+0x0/0x10 [nvidia]
[ 20.005026] Code: 66 2e 0f 1f 84 00 00 00 00 00 48 83 ec 08 e8 f7 d1 1f 00 48 83 c4 08 48 89 c7 e9 bb ff ff ff 66 2e 0f 1f 84 00 00 00 00 00 90 <48> 89 f7 e9 18 08 00 00 0f 1f 84 00 00 00 00 00 48 89 f7 e9 18 08
[ 20.005039] RSP: 0018:ffffa42302e33bf0 EFLAGS: 00010202
[ 20.005043] RAX: ffffffffc2b98380 RBX: ffffffffc5bfb130 RCX: 0000000000000000
[ 20.005048] RDX: 00000000000e6804 RSI: 0000000000000010 RDI: ffffffffc5bfb130
[ 20.005054] RBP: ffff93d477e02fe0 R08: ffffa42302e33b80 R09: ffffffffc5bfb170
[ 20.005197] R10: ffffffffc5bc4fb0 R11: 0000000000000000 R12: 0000000000000010
[ 20.005341] R13: ffff93d477e00000 R14: 00007fc5deb31343 R15: ffffa42302e33d70
[ 20.005488] ? _nv038466rm+0x20/0x20 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.005898] _nv012307rm+0x24/0xe0 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.006310] _nv038467rm+0xe/0xa0 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.006729] _nv038470rm+0x1d/0x30 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.007148] _nv038472rm+0x2f/0x40 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.007576] _nv017028rm+0x15/0x70 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.007934] _nv000690rm+0x9/0x20 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.008293] ? cdev_add+0x50/0x70
[ 20.008506] rm_init_rm+0x17/0x60 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.008892] nvidia_init_module+0x24e/0x622 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.009268] ? nvidia_init_module+0x622/0x622 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.009649] nvidia_frontend_init_module+0x50/0x94 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.010035] ? nvidia_init_module+0x622/0x622 [nvidia 6687e2f66f2673b6d38b016c61e405f16a19b6b0]
[ 20.010424] do_one_initcall+0x5a/0x230
[ 20.010669] do_init_module+0x4a/0x1e0
[ 20.010916] __do_sys_init_module+0x17f/0x1b0
[ 20.011164] do_syscall_64+0x5c/0x90
[ 20.011414] ? do_syscall_64+0x6b/0x90
[ 20.011665] ? ksys_read+0x6f/0xf0
[ 20.011917] ? syscall_exit_to_user_mode+0x1b/0x40
[ 20.012173] ? do_syscall_64+0x6b/0x90
[ 20.012431] ? exc_page_fault+0x74/0x170
[ 20.012691] entry_SYSCALL_64_after_hwframe+0x63/0xcd
[ 20.012953] RIP: 0033:0x7fc5de521eee
[ 20.013228] Code: 48 8b 0d 85 ee 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 52 ee 0c 00 f7 d8 64 89 01 48
[ 20.013518] RSP: 002b:00007ffc26ac9078 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
[ 20.013815] RAX: ffffffffffffffda RBX: 000055d09b4f0340 RCX: 00007fc5de521eee
[ 20.014115] RDX: 00007fc5deb31343 RSI: 00000000058e27e0 RDI: 00007fc5d2ac0010
[ 20.014418] RBP: 00007fc5deb31343 R08: 000055d09b4f0590 R09: 00007ffc26ac5700
[ 20.014723] R10: 0000000000000005 R11: 0000000000000246 R12: 0000000000020000
[ 20.015030] R13: 000055d09b4f03c0 R14: 000055d09b4f0340 R15: 000055d09b4f08d0
[ 20.015343] </TASK>
[ 20.015655] Modules linked in: nvidia(POE+) vfat fat snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel intel_rapl_msr soundwire_generic_allocation intel_rapl_common soundwire_cadence intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp snd_sof_intel_hda coretemp snd_sof_pci snd_sof_xtensa_dsp snd_sof kvm_intel kvm snd_sof_utils snd_soc_hdac_hda irqbypass snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus crct10dif_pclmul btusb crc32_pclmul snd_soc_core polyval_clmulni snd_hda_codec_realtek polyval_generic gf128mul snd_compress btrtl ac97_bus btbcm snd_pcm_dmaengine snd_hda_codec_generic ledtrig_audio ghash_clmulni_intel mousedev hid_apple btintel uas snd_hda_codec_hdmi usb_storage apple_mfi_fastcharge btmtk joydev snd_hda_intel bluetooth snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec ecdh_generic sha512_ssse3 snd_hda_core rfkill snd_hwdep aesni_intel ee1004 crypto_simd cryptd snd_pcm rapl igc intel_cstate iTCO_wdt intel_pmc_bxt spi_nor pcspkr
[ 20.015680] iTCO_vendor_support intel_uncore snd_timer pmt_telemetry i2c_i801 mtd pmt_class snd wmi_bmof mxm_wmi mei_me serial_multi_instantiate video acpi_pad acpi_tad mei soundcore i2c_smbus mac_hid intel_vsec wmi sg fuse crypto_user bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 usbhid nvme nvme_core xhci_pci spi_intel_pci crc32c_intel spi_intel nvme_common xhci_pci_renesas
[ 20.018340] ---[ end trace 0000000000000000 ]---
[ 20.018762] RIP: 0010:exc_control_protection+0xc2/0xd0
[ 20.019185] Code: fa ff 45 31 c9 49 89 d8 b9 09 00 00 00 48 8b 93 80 00 00 00 be fc 00 00 00 48 c7 c7 21 2f e4 bb e8 53 03 46 ff e9 64 ff ff ff <0f> 0b 66 66 2e 0f 1f 84 00 00 00 00 00 90 66 0f 1f 00 55 53 48 89
[ 20.019621] RSP: 0018:ffffa42302e33b28 EFLAGS: 00010002
[ 20.020119] RAX: 0000000000000033 RBX: ffffa42302e33b48 RCX: 0000000000000027
[ 20.020587] RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff93db9fba1660
[ 20.020588] RBP: 0000000000000003 R08: 0000000000000000 R09: ffffa42302e339c0
[ 20.020588] R10: 0000000000000003 R11: ffffffffbc6cc7e8 R12: 0000000000000000
[ 20.020589] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 20.020590] FS: 00007fc5de27f080(0000) GS:ffff93db9fb80000(0000) knlGS:0000000000000000
[ 20.022601] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 20.022602] CR2: 00007fc5d83a2000 CR3: 00000001010f4004 CR4: 0000000000f70ee0
[ 20.023346] PKRU: 55555554
[ 20.023347] note: systemd-modules[364] exited with irqs disabled
[ 20.045956] audit: type=1130 audit(1679935946.983:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 20.112763] audit: type=1130 audit(1679935947.049:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.046781] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.046788] Bluetooth: BNEP filters: protocol multicast
[ 21.046794] Bluetooth: BNEP socket layer initialized
[ 21.047293] Bluetooth: MGMT ver 1.22
[ 21.104561] NET: Registered PF_ALG protocol family
[ 23.621078] kauditd_printk_skb: 19 callbacks suppressed
[ 23.621086] audit: type=1130 audit(1679935950.556:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.671380] NET: Registered PF_QIPCRTR protocol family
[ 23.671896] audit: type=1130 audit(1679935950.606:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.835472] audit: type=1130 audit(1679935950.769:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.089409] igc 0000:03:00.0 enp3s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 26.302467] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 33.685994] audit: type=1131 audit(1679935960.623:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.064833] audit: type=1131 audit(1679935978.961:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.132495] audit: type=1334 audit(1679935979.026:100): prog-id=35 op=UNLOAD
[ 52.132512] audit: type=1334 audit(1679935979.026:101): prog-id=34 op=UNLOAD
[ 52.132518] audit: type=1334 audit(1679935979.026:102): prog-id=33 op=UNLOAD
[ 56.330475] audit: type=1100 audit(1679935983.163:103): pid=678 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="roman" exe="/usr/bin/login" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 56.355601] audit: type=1101 audit(1679935983.190:104): pid=678 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="roman" exe="/usr/bin/login" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 56.417133] audit: type=1103 audit(1679935983.249:105): pid=678 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="roman" exe="/usr/bin/login" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 56.417275] audit: type=1006 audit(1679935983.249:106): pid=678 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=tty1 old-ses=4294967295 ses=1 res=1
[ 56.417289] audit: type=1300 audit(1679935983.249:106): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffc370159d0 a2=4 a3=0 items=0 ppid=1 pid=678 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty1 ses=1 comm="login" exe="/usr/bin/login" subj=unconfined key=(null)
[ 56.417298] audit: type=1327 audit(1679935983.249:106): proctitle=2F62696E2F6C6F67696E002D70002D2D
[ 57.946437] kauditd_printk_skb: 7 callbacks suppressed
[ 57.946443] audit: type=1130 audit(1679935984.765:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.984466] audit: type=1105 audit(1679935984.805:113): pid=678 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="roman" exe="/usr/bin/login" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 57.984486] audit: type=1110 audit(1679935984.805:114): pid=678 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="roman" exe="/usr/bin/login" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 319.353768] audit: type=1334 audit(1679936246.118:115): prog-id=36 op=LOAD
[ 319.546670] audit: type=1130 audit(1679936246.308:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 321.575429] audit: type=1100 audit(1679936248.338:117): pid=1372 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:authentication grantors=pam_unix acct="roman" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 321.576658] audit: type=1101 audit(1679936248.338:118): pid=1372 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="roman" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 321.578388] audit: type=1110 audit(1679936248.341:119): pid=1372 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 321.578541] audit: type=1105 audit(1679936248.341:120): pid=1372 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 321.586673] audit: type=1106 audit(1679936248.348:121): pid=1372 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 321.586681] audit: type=1104 audit(1679936248.348:122): pid=1372 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 346.525754] audit: type=1101 audit(1679936273.288:123): pid=1385 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="roman" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 346.526534] audit: type=1110 audit(1679936273.288:124): pid=1385 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
[ 346.526587] audit: type=1105 audit(1679936273.288:125): pid=1385 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=roman addr=? terminal=/dev/tty1 res=success'
Post Scriptum
For someone reading this in the future and doesn’t know how to copy commands output from TTY, here’s the command: <command> | curl -F 'file=@-' https://0x0.st
(Source)
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
