Manjaro won't boot after update
After my grub menu, I boot and then this happens.
I can’t type in the emergency shell.
I’ve tried chrooting with a live USB and updating pacman and installing a new kernel, but I don’t know enough to do anything further :confused:.
Hi @rig,
Since you mentioned you tried chroot I’m presuming you know how to do it. So, boot with a thumb drive and enter a chroot environment. Also open a browser here, so that you can work there, read here, and copy & paste as necessary.
From the chroot environment, run and provide the output of the following:
mhwd --list
mhwd-kernel --list
mhwd-kernel --listinstalled
As well as:
so chroot into the system:
sudo manjaro-chroot -a
and run update again:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
when done let us know
If there’s any other information that I can help provide, please let me know.
After chroot-ing, the results of the following are:
[manjaro-gnome /]# sudo pacman-mirrors -f5 && sudo pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.659 United_Kingdom : http://manjaro.mirrors.uk2.net/
  0.417 United_Kingdom : https://mirror.cyberhost.uk/sites/manjaro/
  0.528 United_Kingdom : https://mirrors.gethosted.online/manjaro/repos/
  0.421 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
::INFO Writing mirror list
::United_Kingdom  : https://mirror.cyberhost.uk/sites/manjaro/stable/$repo/$arch
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
::United_Kingdom  : https://mirrors.gethosted.online/manjaro/repos/stable/$repo/$arch
::United_Kingdom  : http://manjaro.mirrors.uk2.net/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core                              166.9 KiB   464 KiB/s 00:00 [##################################] 100%
 extra                            1879.0 KiB  5.73 MiB/s 00:00 [##################################] 100%
 community                           7.0 MiB  5.19 MiB/s 00:01 [##################################] 100%
 multilib                          177.5 KiB  1972 KiB/s 00:00 [##################################] 100%
 there is nothing to do
[manjaro-gnome /]# mhwd --list
> 0000:2b:00.0 (0300:10de:13c2) Display controller nVidia Corporation:
          video-nvidia            2021.12.18               false            PCI
    video-nvidia-470xx            2021.12.18               false            PCI
    video-nvidia-390xx            2021.12.18               false            PCI
           video-linux            2018.05.04                true            PCI
[manjaro-gnome /]# mhwd-kernel --listinstalled
Currently running: 5.15.16-1-MANJARO (linux515)
   * linux515
   * linux516
   * linux517
[manjaro-gnome /]# inxi --admin --verbosity=7 --filter --width
12System:
  12Kernel 5.15.16-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 11.1.0
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_GNOME_2122 quiet
    systemd.show_status=1 driver=nonfree nouveau.modeset=0 i915.modeset=1
    radeon.modeset=1
  12Console N/A 12wm gnome-shell 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Desktop 12Mobo Micro-Star 12model MAG B550M MORTAR WIFI (MS-7C94) 12v 1.0
    12serial <filter> 12UEFI American Megatrends LLC. 12v 1.50 12date 01/13/2021
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12RAM 12total 31.34 GiB 12used 3.79 GiB (12.1%)
  12Array-1 12capacity 128 GiB 12slots 4 12EC None 12max-module-size 32 GiB 12note est.
  12Device-1 DIMM 0 12type no module installed
  12Device-2 DIMM 1 12type DDR4 12detail synchronous unbuffered (unregistered)
    12size 16 GiB 12speed 3600 MT/s 12volts 12curr 1.2 12min 1.2 12max 1.2 12width (bits)
    12data 64 12total 64 12manufacturer Corsair 12part-no CMK32GX4M2D3600C18
    12serial N/A
  12Device-3 DIMM 0 12type no module installed
  12Device-4 DIMM 1 12type DDR4 12detail synchronous unbuffered (unregistered)
    12serial N/A
12CPU:
  12Info 12model AMD Ryzen 7 5800X 12socket AM4 12bits 64 12type MT MCP 12arch Zen 3 12gen 4
    12built 2021-22 12process TSMC n7 (7nm) 12family 0x19 (25) 12model-id 0x21 (33)
    12stepping 0 12microcode 0xA201009
  12Topology 12cpus 1x 12cores 8 12tpc 2 12threads 16 12smt enabled 12cache 12L1 512 KiB
    12desc d-8x32 KiB; i-8x32 KiB 12L2 4 MiB 12desc 8x512 KiB 12L3 32 MiB 12desc 1x32 MiB
  12Speed (MHz) 12avg 2300 12high 3800 12min/max 2200/4850 12boost enabled
    12base/boost 3800/4850 12scaling 12driver acpi-cpufreq 12governor schedutil
    12volts 1.1 V 12ext-clock 100 MHz 12cores 121 3800 122 2200 123 2200 124 2200 125 2200
    126 2200 127 2200 128 2200 129 2200 1210 2200 1211 2200 1212 2200 1213 2200 1214 2200
    1215 2200 1216 2200 12bogomips 121648
  12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  12Vulnerabilities
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type spec_store_bypass
    12mitigation Speculative Store Bypass disabled via prctl and seccomp
  12Type spectre_v1
    12mitigation usercopy/swapgs barriers and __user pointer sanitization
  12Type spectre_v2 12mitigation Full AMD retpoline, IBPB: conditional, IBRS_FW,
    STIBP: always-on, RSB filling
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 NVIDIA GM204 [GeForce GTX 970] 12vendor Micro-Star MSI 12driver nvidia
    12v 495.46 12non-free 515.xx+ 12status current (as of 2022-06) 12arch Maxwell
    12process TSMC 28nm 12built 2014-19 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 16
    12link-max 12gen 3 12speed 8 GT/s 12bus-ID 2b:00.0 12chip-ID 10de:13c2 12class-ID 0300
  12Device-2 Logitech C920 HD Pro Webcam 12type USB
    12driver snd-usb-audio,uvcvideo 12bus-ID 3-1:2 12chip-ID 046d:0892 12class-ID 0102
    12serial <filter>
  12Display 12server X.org 12v 1.21.1.3 12with Xwayland 12v 22.1.1
    12compositor gnome-shell 12driver 12X 12loaded nvidia 12gpu nvidia 12display-ID :0
  12Message Unable to show GL data. Required tool glxinfo missing.
12Audio:
  12Device-1 NVIDIA GM204 High Definition Audio 12vendor Micro-Star MSI
    12driver snd_hda_intel 12v kernel 12bus-ID 3-1:2 12chip-ID 046d:0892 12pcie 12gen 1
    12class-ID 0102 12speed 2.5 GT/s 12serial <filter> 12lanes 16 12link-max 12gen 3
    12speed 8 GT/s 12bus-ID 2b:00.1 12chip-ID 10de:0fbb 12class-ID 0403
  12Device-2 AMD Starship/Matisse HD Audio 12vendor Micro-Star MSI
    12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16
    12bus-ID 2d:00.4 12chip-ID 1022:1487 12class-ID 0403
  12Device-3 Logitech C920 HD Pro Webcam 12type USB
  12Sound Server-1 ALSA 12v k5.15.16-1-MANJARO 12running yes
  12Sound Server-2 sndio 12v N/A 12running no
  12Sound Server-3 JACK 12v 1.9.21 12running no
  12Sound Server-4 PulseAudio 12v 15.0 12running yes
  12Sound Server-5 PipeWire 12v 0.3.51 12running no
12Network:
  12Device-1 Intel Wi-Fi 6 AX200 12driver iwlwifi 12v kernel 12pcie 12gen 2 12speed 5 GT/s
    12lanes 1 12bus-ID 29:00.0 12chip-ID 8086:2723 12class-ID 0280
  12IF wlo1 12state up 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type noprefixroute 12scope link
  12Device-2 Realtek RTL8125 2.5GbE 12vendor Micro-Star MSI 12driver r8169
    12v kernel 12pcie 12gen 2 12speed 5 GT/s 12lanes 1 12port f000 12bus-ID 2a:00.0
    12chip-ID 10ec:8125 12class-ID 0200
  12IF enp42s0 12state down 12mac <filter>
  12WAN IP <filter>
12Bluetooth:
  12Message No bluetooth data found.
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 3.67 TiB 12used 264.34 GiB (7.0%)
  12SMART Message Required tool smartctl not installed. Check --recommends
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Samsung 12model SSD 970 EVO Plus 1TB
    12size 931.51 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s
    12lanes 4 12type SSD 12serial <filter> 12rev 2B2QEXM7 12temp 34.9 C
  12ID-2 /dev/sda 12maj-min 8:0 12vendor Western Digital 12model WD10EZEX-60WN4A0
    12size 931.51 GiB 12block-size 12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s
    12type N/A 12serial <filter> 12rev 1A01
  12ID-3 /dev/sdb 12maj-min 8:16 12vendor Crucial 12model CT1000MX500SSD1
    12type SSD 12serial <filter> 12rev 032
  12ID-4 /dev/sdc 12maj-min 8:32 12vendor Western Digital 12model WD10EZEX-00BN5A0
  12ID-5 /dev/sdd 12maj-min 8:48 12type USB 12vendor SanDisk 12model Ultra Fit
    12size 28.64 GiB 12block-size 12physical 512 B 12logical 512 B 12type N/A
    12serial <filter> 12rev 1.00
  12Message No optical or floppy data found.
12Partition:
  12ID-1 / 12raw-size 465.7 GiB 12size 457.32 GiB (98.20%) 12used 264.31 GiB (57.8%)
    12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p4 12maj-min 259:4 12label N/A
    12uuid 1d85b49b-0ff4-4d3b-aec6-b34cc42da87d
  12ID-2 /boot/efi 12raw-size 100 MiB 12size 96 MiB (96.00%) 12used 25.2 MiB (26.3%)
    12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label N/A
    12uuid 2060-6B97
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/nvme0n1p2 12maj-min 259:2 12size 16 MiB 12fs N/A 12label N/A 12uuid N/A
  12ID-2 /dev/nvme0n1p3 12maj-min 259:3 12size 465.7 GiB 12fs ntfs 12label N/A
    12uuid 065E62295E6211AB
  12ID-3 /dev/sda1 12maj-min 8:1 12size 931.51 GiB 12fs ext4 12label newhdd
    12uuid e3226ae3-c3d7-4dfd-b984-eb85c2e86dc7
  12ID-4 /dev/sdb1 12maj-min 8:17 12size 372.95 GiB 12fs ntfs 12label N/A
    12uuid 25A3E6E73DAD989B
  12ID-5 /dev/sdb4 12maj-min 8:20 12size 558.56 GiB 12fs ext4 12label N/A
    12uuid ba9d11c0-63c4-47c4-91c5-d89c821b8a20
  12ID-6 /dev/sdc1 12maj-min 8:33 12size 116 MiB 12fs ext4 12label N/A
    12uuid a1d9259b-f873-4c00-bcf0-e46c4210f5d9
  12ID-7 /dev/sdc3 12maj-min 8:35 12size 930.9 GiB 12fs ntfs 12label N/A
    12uuid C844547544546868
  12ID-8 /dev/sdc4 12maj-min 8:36 12size 507 MiB 12fs ntfs 12label N/A
    12uuid E6DEBBC2DEBB8977
  12ID-9 /dev/sdd1 12maj-min 8:49 12size 3.28 GiB 12fs N/A 12label MANJARO_GNOME_2122
    12uuid 2022-01-23-13-25-11-00
  12ID-10 /dev/sdd2 12maj-min 8:50 12size 4 MiB 12fs N/A 12label MISO_EFI
    12uuid FFD4-D361
12USB:
  12Hub-1 1-0:1 12info Hi-speed hub with single TT 12ports 10 12rev 2.0 12speed 480 Mb/s
    12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 1-5:2 12info HP Laser Mouse 12type Mouse 12driver hid-generic,usbhid
    12interfaces 1 12rev 2.0 12speed 1.5 Mb/s 12power 100mA 12chip-ID 03f0:154a
    12class-ID 0301
  12Device-2 1-6:3 12info HP Elite Keyboard 12type Keyboard,HID
    12driver hid-generic,usbhid 12interfaces 2 12rev 1.1 12speed 1.5 Mb/s 12power 100mA
    12chip-ID 03f0:034a 12class-ID 0300
  12Hub-2 1-7:4 12info Genesys Logic Hub 12ports 4 12rev 2.0 12speed 480 Mb/s
    12power 100mA 12chip-ID 05e3:0608 12class-ID 0900
  12Device-1 1-7.2:6 12info SanDisk Ultra Fit 12type Mass Storage
    12driver usb-storage 12interfaces 1 12rev 2.1 12speed 480 Mb/s 12power 224mA
    12chip-ID 0781:5583 12class-ID 0806 12serial <filter>
  12Device-2 1-7.4:7 12info Corsair H80i v2 12type <vendor specific> 12driver N/A
    12interfaces 1 12rev 1.1 12speed 12 Mb/s 12power 50mA 12chip-ID 1b1c:0c08
    12class-ID 0000 12serial <filter>
  12Device-3 1-8:5 12info Micro Star MYSTIC LIGHT 12type HID
    12driver hid-generic,usbhid 12interfaces 1 12rev 1.1 12speed 12 Mb/s 12power 500mA
    12chip-ID 1462:7c94 12class-ID 0300 12serial <filter>
  12Hub-3 2-0:1 12info Super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s
    12chip-ID 1d6b:0003 12class-ID 0900
  12Hub-4 3-0:1 12info Hi-speed hub with single TT 12ports 4 12rev 2.0
    12speed 480 Mb/s 12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 3-1:2 12info Logitech C920 HD Pro Webcam 12type Video,Audio
    12driver snd-usb-audio,uvcvideo 12interfaces 4 12rev 2.0 12speed 480 Mb/s
    12power 500mA 12chip-ID 046d:0892 12class-ID 0102 12serial <filter>
  12Hub-5 4-0:1 12info Super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s
12Sensors:
  12Message No sensor data found. Is lm-sensors configured?
12Info:
  12Processes 361 12Uptime 2d 5h 46m 12wakeups 1 12Init systemd 12v 250
  12default graphical 12tool systemctl 12Compilers 12gcc 12.1.0 12clang 13.0.1 12Packages
  12pacman 1718 12lib 359 12flatpak 0 12Client Unknown Client: systemd 12inxi 3.3.17
you have installed 516 kernel, and you were probably running it, and since it was dropped you couldnt boot with it, so uninstall it from chroot:
mhwd-kernel -r linux516
update-grub
mkinitcpio -P
exit
systemctl reboot
and see if you can normally boot now
This is far from being up to date.
So when I follow your advice, then update grub, I keep seeing that lsblk: /usr/lib/libsmartcols.so.1: version SMARTCOLS_2.38’ not found (required by lsblk)`
[manjaro-gnome /]# update-grub
Found linux image: /boot/vmlinuz-5.17-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.17-x86_64.img
Found initrd fallback image: /boot/initramfs-5.17-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
lsblk: /usr/lib/libsmartcols.so.1: version `SMARTCOLS_2.38' not found (required by lsblk)
grub-probe: error: cannot find a GRUB drive for /dev/sdd1.  Check your device.map.
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
so I go to re-install util-linux-libs, which it can’t do because it requires util-linux-libs:
[manjaro-gnome /]# pacman -Syyu util-linux-libs
 core                  166.9 KiB   261 KiB/s 00:01 [######################] 100%
 extra                1879.0 KiB  1450 KiB/s 00:01 [######################] 100%
 community               7.0 MiB  2.67 MiB/s 00:03 [######################] 100%
 multilib              177.5 KiB  2.48 MiB/s 00:00 [######################] 100%
warning: util-linux-libs-2.38-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) util-linux-libs-2.38-1
Total Installed Size:  0.94 MiB
Net Upgrade Size:      0.00 MiB
(1/1) checking keys in keyring                     [######################] 100%
(1/1) checking package integrity                   [######################] 100%
(1/1) loading package files                        [######################] 100%
(1/1) checking for file conflicts                  [######################] 100%
(1/1) checking available disk space                [######################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
findmnt: /usr/lib/libsmartcols.so.1: version `SMARTCOLS_2.38' not found (required by findmnt)
/usr/bin/timeshift-autosnap: line 5: [: ==: unary operator expected
/usr/bin/timeshift-autosnap: line 36: [: ==: unary operator expected
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling util-linux-libs                 [######################] 100%
(1/1) Arming ConditionNeedsUpdate...
so run update again:
pacman-mirrors --fasttrack 5 && pacman -Syyu
post possible errors here
It doesn’t appear to have any errors? Sorry I’m not great with pacman
[manjaro-gnome /]#  pacman-mirrors --fasttrack 5 && pacman -Syyu
  0.160 United_Kingdom : http://manjaro.mirrors.uk2.net/
  0.173 United_Kingdom : https://mirrors.gethosted.online/manjaro/repos/
  0.224 United_Kingdom : https://mirror.cyberhost.uk/sites/manjaro/
  0.207 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/re
 core                  166.9 KiB  1091 KiB/s 00:00 [######################] 100%
 extra                1879.0 KiB  4.83 MiB/s 00:00 [######################] 100%
 community               7.0 MiB  6.89 MiB/s 00:01 [######################] 100%
 multilib              177.5 KiB  3.77 MiB/s 00:00 [######################] 100%
[manjaro-gnome /]# pacman -Qk | grep warning
warning: java-runtime-common: /usr/lib/jvm/default (No such file or directory)
warning: java-runtime-common: /usr/lib/jvm/default-runtime (No such file or directory)
ok, so did you uninstall the 516?
try to reinstall tlinux libs:
pamac reinstall util-linux-libs
post error output here
I’ve uninstalled all but 517
[manjaro-gnome /]# mhwd-kernel -li
   * linux517
The currently running is an old live cd, but that shouldn’t matter I thought?
When trying to reinstall util-linux-libs, I get
[manjaro-gnome /]# pamac reinstall util-linux-libs
Preparing...
Warning: util-linux-libs-2.38-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To reinstall (1):
  util-linux-libs  2.38-1    core
Apply transaction ? [y/N] Y
Checking keyring...        [1/1]
Checking integrity...        [1/1]
Loading packages files...        [1/1]
Checking file conflicts...        [1/1]
Checking available disk space...        [1/1]
Reinstalling util-linux-libs (2.38-1)...                                                           [1/1]
it says that it worked:
so if you update grub now, does it give you the same errors?
Yes, the update-grub errors persist.
Without util-linux-libs, I cannot (re)install utils-linux-libs it seems :confused:.
done
and try this:
pacman -S util-linux-libs --overwrite '*'
Unfortunately, it produces largely the same result.
[manjaro-gnome /]#  pacman -S util-linux-libs --overwrite '*'
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                                 [##################################] 100%
(1/1) checking package integrity                               [##################################] 100%
(1/1) loading package files                                    [##################################] 100%
(1/1) checking for file conflicts                              [##################################] 100%
(1/1) checking available disk space                            [##################################] 100%
(1/1) reinstalling util-linux-libs                             [##################################] 100%
and then, we have the same problem with update-grub as before with lsblk: /usr/lib/libsmartcols.so.1: version SMARTCOLS_2.38’ not found (required by lsblk)`
so try running this:
pacman -Syyuu
looks like downgrade could help…
What are you suggesting I downgrade sorry?
[manjaro-gnome /]# pacman -Syyuu
 core                              166.9 KiB  1113 KiB/s 00:00 [##################################] 100%
 extra                            1879.0 KiB  8.61 MiB/s 00:00 [##################################] 100%
 community                           7.0 MiB  9.26 MiB/s 00:01 [##################################] 100%
 multilib                          177.5 KiB  3.69 MiB/s 00:00 [##################################] 100%
This post seems to suggest all you need to do is re-install util-linux-libs (prev. libutil-linux), but I can’t work out how to do it successfully.
the same …version not found required by… issue could be resolved with downgrading, unfortunatelly it didnt work with you… the same issue, but he says there that he changed root, but i dont know what exactly he means by that…
Yeah nevermind. I kind of forgot that you are chrooted from live cd.
