Following the partly off-topic discussion starting around post #9 of the thread below… ![]()
… it has been brought to the attention that the Wiki page on /etc/fstab needs some revision. Concretely, the page contains the following example of an /etc/fstab… ![]()
# <file system> <mount point> <type> <options> <dump> <pass>
LABEL=ESP /boot/efi vfat umask=0077 0 2
/dev/sda5 / ext4 defaults,noatime,discard 0 1
UUID=18360b04-a96d-4a99-8323-b07717f36a31 swap swap defaults,noatime,discard 0 0
UUID=b4108631-e051-48d8-b2ff-a1d924a893f1 /home ext4 defaults,noatime,discard 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=634E43D367B0A4B1 /media/Data ntfs-3g noauto,x-systemd.automount,x-systemd.device-timeout=10,rw,inherit,permissions,streams_interface=windows,windows_names,compression,norecover,hide_dot_files,hide_hid_files,big_writes 0 2
The two problematic — read: incorrect — entries in the example file are the following… ![]()
And here’s why they are wrong… ![]()
The first incorrect line here-above is a line for a swap partition. The mount options for that swap partition should not contain the option noatime, because noatime is a mount option that tells the filesystem not to update the time of last access on an inode unless the mtime is also modified. So far so good, but the reason why this option is wrong is that a swap partition does not contain any filesystem — the kernel accesses the raw drive blocks — and that therefore, there are no inodes.
Does this mount option cause any harm? No, it doesn’t, but for a swap partition it’s an incorrect one nevertheless. The same is true for swap files, by the way.
The second incorrect line here-above is for mounting a tmpfs to /tmp. This line is redundant, because Manjaro uses systemd as the init system and service manager, and in all systemd-based Arch-derivatives — as well as in Debian and its derivatives, and in RedHat and its derivatives — systemd itself already mounts a tmpfs at /tmp. (openSUSE and SUSE proper are the only two systemd-based exceptions that I know of.)
Therefore, having an entry for /tmp in /etc/fstab will cause this entry to mount another tmpfs at /tmp, thereby obscuring the first tmpfs that was already mounted there by systemd, possibly leading to a small loss of total available memory if something was already parked in /tmp before /etc/fstab is processed. Not exactly a tragic mistake on today’s systems with many GiB of RAM, but nevertheless an incorrect setup.
Furthermore, the example for /tmp also references the mode=1777 mount option. While tmpfs does support this mount option, it is again redundant, given that the /tmp directory is by default created with 1777 permissions — i.e. drwxrwxrwt — and that tmpfs is a POSIX-compatible virtual-memory filesystem. As such, when a tmpfs is mounted to a directory with 1777 permissions, the root directory of the tmpfs will inherit the 1777 permissions of the directory it is mounted to.
Conclusion
The entry for the swap partition in the
/etc/fstabexample should be edited to only contain either the mount optiondefaultsor the mount optionswap— but not both at the same time — possibly added with the optiondiscard=pagesto allow for aTRIMoperation, becausefstrim.timerdoes not normally cover the swap partition, given that thefstrimcommand only works on read/write-mounted filesystems, and the swap partition does not contain any filesystem. -
The entry for
/tmpshould be removed altogether from the/etc/fstabexample. -
Optional: The example on the Wiki page also contains a sample entry for an NTFS filesystem, to be mounted at
/media/Data. Due toudisks2auto-mounting removable storage and non-system filesystems alike under/run/mediaor/run/user, the directory/mediadoes not exist by default anymore — i.e. the user would have to create it themselves (with superuser privileges, because it’s a root-level directory) — and I would also recommend against using uppercase characters for anything outside of the user’s own$HOME. So perhaps make it into/media/data, and add a note to the article that neither/medianor/media/dataexist by default, and must be explicitly created with…
sudo mkdir -p /media/data
Lastly, I am posting this thread in Feedback > Wiki because I’m not a Wiki editor, and apart from one of my fellow moderators — who happens to be too busy to concern himself with editing the Wiki or monitoring the forum right now — I don’t know who the other community members with Wiki editor access are. So hopefully one of them will pick up this thread and correct the article. ![]()
