Manjaro: Unable to restore Grub
Hello team,
I have got 2 disks (one for Windows + boot efi, one for Manjaro).
Disk 1(sda): boot + windows partitions. Formatted by mistake, however restored by testdisk. I can see boot folders, files as well as windows folders, files.
Disk 2(sdb): manjaro, not touched, all folders, files.
After I executed testdisk, partitions and data were restored, I can see windows file systems, efi partition with folders and data.
However computer fails to boot. It seems, it does not start grub at all. It tries to boot windows immediately and it fails.
I did re-install of grub 2-3 times, but still no luck, no change. Grub is not loaded. I followed instructions here: https://wiki.manjaro.org/index.php/GRUB/Restore_the_GRUB_Bootloader
If I check the 100MB efi partition, I can see grub and manjaro with recent date, so the grub fix has altered them. But still unable to boot.
Could you help me please ?
[manjaro@manjaro ~]$ sudo parted -l
Model: ATA TOSHIBA MQ02ABF0 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type     File system  Flags
 1      1049kB  316MB  315MB  primary  ntfs         boot
 2      316MB   420MB  105MB  primary  fat32
 3      555MB   500GB  500GB  primary  ntfs
Model: ATA ST1000LM014-1EJ1 (scsi)
Disk /dev/sdb: 1000GB
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name  Flags
 1      1049kB  1075MB  1074MB  linux-swap(v1)        swap
 2      1075MB  44.0GB  42.9GB  ext4
 3      44.0GB  108GB   64.4GB  ext4
 4      108GB   1000GB  892GB   ntfs                  msftdata
Model: SMI USB DISK (scsi)
Disk /dev/sdc: 8179MB
Disk Flags:
 2      4035MB  4039MB  4194kB  primary               esp
chroot
[manjaro manjaro]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sdb2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
 --> mount: [/mnt/home]
[manjaro manjaro]# lsblk --fs --all
NAME   FSTYPE   FSVER         LABEL             UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0  squashfs 4.0        0   100% /run/miso/sfs/livefs
loop1  squashfs 4.0        0   100% /run/miso/sfs/mhwdfs
loop2  squashfs 4.0        0   100% /run/miso/sfs/desktopfs
loop3  squashfs 4.0        0   100% /run/miso/sfs/rootfs
loop4  squashfs 4.0        0   100% /var/lib/snapd/snap/core/14784
loop5        0   100% /var/lib/snapd/snap/tree/18
sda
├─sda1 ntfs                   Obnovenie         B2A43F98A43F5E53
├─sda2 vfat     FAT32                           EC40-E2D4
└─sda3 ntfs                                     3CE64355E6430F18                      362.1G    22% /run/media/manjaro/3CE64355E6430F18
sdb
├─sdb1 swap     1                               62a959f8-998a-4b75-8c86-54f4a0461707
├─sdb2 ext4     1.0                             1d12580d-22e2-4db1-abf8-cebbb9ee4c49
├─sdb3 ext4     1.0                             fcdff842-3f01-43f7-8655-900b7b489fd8
└─sdb4 ntfs                                     4D9687C37DA18DF1
sdc    iso9660  Joliet Extens MANJARO_XFCE_2204 2023-02-22-07-03-31-00                     0   100% /run/miso/bootmnt
├─sdc1 iso9660  Joliet Extens MANJARO_XFCE_2204 2023-02-22-07-03-31-00
└─sdc2 vfat     FAT12         MISO_EFI          6E2E-A045
[manjaro /]# cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=EC40-E2D4                            /boot/efi      vfat    umask=0077 0 2
UUID=62a959f8-998a-4b75-8c86-54f4a0461707 swap           swap    defaults,noatime 0 0
UUID=1d12580d-22e2-4db1-abf8-cebbb9ee4c49 /              ext4    defaults,noatime 0 1
UUID=fcdff842-3f01-43f7-8655-900b7b489fd8 /home          ext4    defaults,noatime 0 2
[manjaro /]# blkid
/dev/loop1: TYPE="squashfs"
/dev/sdb4: BLOCK_SIZE="512" UUID="4D9687C37DA18DF1" TYPE="ntfs" PARTUUID="94daa3cd-4005-48f9-988d-a3b7b253b3fb"
/dev/sdb2: UUID="1d12580d-22e2-4db1-abf8-cebbb9ee4c49" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="c154e254-dd4d-4671-a0bb-2b1e8891e2bf"
/dev/sdb3: UUID="fcdff842-3f01-43f7-8655-900b7b489fd8" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="12fcd9a5-b435-49a0-a747-76e1b19f3cce"
/dev/sdb1: UUID="62a959f8-998a-4b75-8c86-54f4a0461707" TYPE="swap" PARTUUID="694c2280-6a2b-4b4a-a323-82f66bfa223a"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sdc2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="6E2E-A045" BLOCK_SIZE="512" TYPE="vfat"
/dev/sdc1: BLOCK_SIZE="2048" UUID="2023-02-22-07-03-31-00" LABEL="MANJARO_XFCE_2204" TYPE="iso9660"
/dev/sda2: UUID="EC40-E2D4" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="4c67e213-02"
/dev/sda3: BLOCK_SIZE="512" UUID="3CE64355E6430F18" TYPE="ntfs" PARTUUID="4c67e213-03"
/dev/sda1: LABEL="Obnovenie" BLOCK_SIZE="512" UUID="B2A43F98A43F5E53" TYPE="ntfs" PARTUUID="4c67e213-01"
/dev/loop3: TYPE="squashfs"
[manjaro /]# findmnt --verify
Success, no errors or warnings detected
[manjaro /]# mount
/dev/sdb2 on / type ext4 (rw,relatime)
/dev/sda2 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
/dev/sdb3 on /home type ext4 (rw,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=1909684k,nr_inodes=477421,mode=755,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
shm on /dev/shm type tmpfs (rw,nosuid,nodev,relatime,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
tmp on /tmp type tmpfs (rw,nosuid,nodev,inode64)
overlay on /etc/resolv.conf type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,xino=off)
[manjaro /]# pacman -Syu grub
 core is up to date
 extra is up to date
 community                                              7.6 MiB  9.09 MiB/s 00:01 [##############################################] 100%
 multilib is up to date
warning: grub-2.06.r261.g2f4430cc0-3 is up to date -- reinstalling
resolving dependencies...
Packages (1) grub-2.06.r261.g2f4430cc0-3
Total Installed Size:  46.84 MiB
Net Upgrade Size:       0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                                                    [##############################################] 100%
(1/1) checking package integrity                                                  [##############################################] 100%
(1/1) loading package files                                                       [##############################################] 100%
(1/1) checking for file conflicts                                                 [##############################################] 100%
(1/1) checking available disk space                                               [##############################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling grub                                                           [##############################################] 100%
:: GRUB no longer supports side-loading modules when secure boot is
   enabled. Thus booting will fail unless you have a 'grubx64.efi'
   executable with bundled modules.
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(3/3) Updating the info directory file...
[manjaro /]#  grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
done
[manjaro /]#  lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
PATH       PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/loop0
/dev/loop1
/dev/loop2
/dev/loop3
/dev/sda
/dev/sda1
/dev/sda2
/dev/sda3
/dev/sdb
/dev/sdb1
/dev/sdb2
/dev/sdb3
/dev/sdb4
/dev/sdc
/dev/sdc1
/dev/sdc2
[manjaro /]#  ls /sys/firmware/efi
config_table  efivars  fw_platform_size  fw_vendor  runtime  runtime-map  systab
efi partition
[manjaro /]# ls -lh /boot
total 59M
drwxr-xr-x 3 root root 1.0K Jan  1  1970 efi
drwxr-xr-x 6 root root 4.0K Feb 28 11:02 grub
-rw------- 1 root root  34M Feb 27 16:02 initramfs-5.15-x86_64-fallback.img
-rw------- 1 root root 8.9M Feb 27 16:02 initramfs-5.15-x86_64.img
-rw-r--r-- 1 root root 5.5M Nov  8 20:02 intel-ucode.img
-rw-r--r-- 1 root root   22 Feb 14 20:44 linux515-x86_64.kver
drwxr-xr-x 2 root root 4.0K Feb 15 15:09 memtest86+
drwxr-xr-x 2 root root 4.0K Feb 17 20:22 syslinux
-rw-r--r-- 1 root root  11M Feb 27 16:02 vmlinuz-5.15-x86_64
[manjaro /]# find /boot -type f -exec ls -lh {} +
-rwxr-xr-x 1 root root 1.7M Nov 25  2021 /boot/efi/EFI/Boot/_grubx64.efi
-rwxr-xr-x 1 root root 934K Dec  3  2021 /boot/efi/EFI/Boot/bkpbootx64.efi
-rwxr-xr-x 1 root root 152K Oct 19 23:25 /boot/efi/EFI/Boot/bootx64.efi
-rwxr-xr-x 1 root root  84K Dec  3  2021 /boot/efi/EFI/Boot/fbx64.efi
-rwxr-xr-x 1 root root 837K Dec  3  2021 /boot/efi/EFI/Boot/mmx64.efi
-rwxr-xr-x 1 root root  36K Dec  5 21:27 /boot/efi/EFI/Microsoft/Boot/BCD
-rwxr-xr-x 1 root root  32K Sep 30  2021 /boot/efi/EFI/Microsoft/Boot/BCD.LOG
-rwxr-xr-x 1 root root    0 Sep 30  2021 /boot/efi/EFI/Microsoft/Boot/BCD.LOG1
-rwxr-xr-x 1 root root    0 Sep 30  2021 /boot/efi/EFI/Microsoft/Boot/BCD.LOG2
-rwxr-xr-x 1 root root  64K Sep 30  2021 /boot/efi/EFI/Microsoft/Boot/BOOTSTAT.DAT
-rwxr-xr-x 1 root root 3.6M Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/chs_boot.ttf
-rwxr-xr-x 1 root root 3.7M Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/cht_boot.ttf
-rwxr-xr-x 1 root root 1.9M Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/jpn_boot.ttf
-rwxr-xr-x 1 root root 2.3M Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/kor_boot.ttf
-rwxr-xr-x 1 root root 174K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/malgun_boot.ttf
-rwxr-xr-x 1 root root 172K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/malgunn_boot.ttf
-rwxr-xr-x 1 root root 141K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/meiryo_boot.ttf
-rwxr-xr-x 1 root root 140K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/meiryon_boot.ttf
-rwxr-xr-x 1 root root 161K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/msjh_boot.ttf
-rwxr-xr-x 1 root root 159K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/msjhn_boot.ttf
-rwxr-xr-x 1 root root 153K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/msyh_boot.ttf
-rwxr-xr-x 1 root root 149K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/msyhn_boot.ttf
-rwxr-xr-x 1 root root  45K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/segmono_boot.ttf
-rwxr-xr-x 1 root root  85K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/segoe_slboot.ttf
-rwxr-xr-x 1 root root  85K Oct  3 19:41 /boot/efi/EFI/Microsoft/Boot/Fonts/segoen_slboot.ttf
-rwxr-xr-x 1 root root  49K Oct  3 19:40 /boot/efi/EFI/Microsoft/Boot/Fonts/wgl4_boot.ttf
-rwxr-xr-x 1 root root  18K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/Resources/bootres.dll
-rwxr-xr-x 1 root root  12K Nov 21  2014 /boot/efi/EFI/Microsoft/Boot/Resources/en-US/bootres.dll.mui
-rwxr-xr-x 1 root root  76K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/bg-BG/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  76K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/bg-BG/bootmgr.efi.mui
-rwxr-xr-x 1 root root 4.9K Feb 16  2022 /boot/efi/EFI/Microsoft/Boot/boot.stl
-rwxr-xr-x 1 root root 1.6M Jun 28  2022 /boot/efi/EFI/Microsoft/Boot/bootmgfw.efi
-rwxr-xr-x 1 root root 1.6M Jun 28  2022 /boot/efi/EFI/Microsoft/Boot/bootmgr.efi
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/cs-CZ/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/cs-CZ/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/cs-CZ/memtest.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/da-DK/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/da-DK/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/da-DK/memtest.efi.mui
-rwxr-xr-x 1 root root  77K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/de-DE/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  77K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/de-DE/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/de-DE/memtest.efi.mui
-rwxr-xr-x 1 root root  78K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/el-GR/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  78K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/el-GR/bootmgr.efi.mui
-rwxr-xr-x 1 root root  46K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/el-GR/memtest.efi.mui
-rwxr-xr-x 1 root root  72K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/en-GB/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  72K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/en-GB/bootmgr.efi.mui
-rwxr-xr-x 1 root root  72K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/en-US/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  72K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/en-US/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/en-US/memtest.efi.mui
-rwxr-xr-x 1 root root  76K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/es-ES/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  76K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/es-ES/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/es-ES/memtest.efi.mui
-rwxr-xr-x 1 root root  73K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/et-EE/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  73K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/et-EE/bootmgr.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/fi-FI/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/fi-FI/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/fi-FI/memtest.efi.mui
-rwxr-xr-x 1 root root  77K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/fr-FR/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  77K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/fr-FR/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/fr-FR/memtest.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/hr-HR/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/hr-HR/bootmgr.efi.mui
-rwxr-xr-x 1 root root  77K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/hu-HU/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  77K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/hu-HU/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/hu-HU/memtest.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/it-IT/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/it-IT/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/it-IT/memtest.efi.mui
-rwxr-xr-x 1 root root  66K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ja-JP/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  66K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ja-JP/bootmgr.efi.mui
-rwxr-xr-x 1 root root  42K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ja-JP/memtest.efi.mui
-rwxr-xr-x 1 root root  66K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ko-KR/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  66K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ko-KR/bootmgr.efi.mui
-rwxr-xr-x 1 root root  42K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ko-KR/memtest.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/lt-LT/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/lt-LT/bootmgr.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/lv-LV/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/lv-LV/bootmgr.efi.mui
-rwxr-xr-x 1 root root 1.5M Sep 30  2015 /boot/efi/EFI/Microsoft/Boot/memtest.efi
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/nb-NO/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/nb-NO/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/nb-NO/memtest.efi.mui
-rwxr-xr-x 1 root root  76K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/nl-NL/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  76K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/nl-NL/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/nl-NL/memtest.efi.mui
-rwxr-xr-x 1 root root  76K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pl-PL/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  76K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pl-PL/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pl-PL/memtest.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pt-BR/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pt-BR/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pt-BR/memtest.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pt-PT/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pt-PT/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/pt-PT/memtest.efi.mui
-rwxr-xr-x 1 root root  72K Nov 21  2014 /boot/efi/EFI/Microsoft/Boot/qps-ploc/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  72K Nov 21  2014 /boot/efi/EFI/Microsoft/Boot/qps-ploc/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/qps-ploc/memtest.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ro-RO/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ro-RO/bootmgr.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ru-RU/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ru-RU/bootmgr.efi.mui
-rwxr-xr-x 1 root root  44K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/ru-RU/memtest.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sk-SK/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sk-SK/bootmgr.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sl-SI/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sl-SI/bootmgr.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sr-Latn-CS/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sr-Latn-CS/bootmgr.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sr-Latn-RS/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sr-Latn-RS/bootmgr.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sv-SE/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sv-SE/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/sv-SE/memtest.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/tr-TR/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  74K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/tr-TR/bootmgr.efi.mui
-rwxr-xr-x 1 root root  45K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/tr-TR/memtest.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/uk-UA/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  75K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/uk-UA/bootmgr.efi.mui
-rwxr-xr-x 1 root root  63K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-CN/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  63K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-CN/bootmgr.efi.mui
-rwxr-xr-x 1 root root  42K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-CN/memtest.efi.mui
-rwxr-xr-x 1 root root  63K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-HK/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  63K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-HK/bootmgr.efi.mui
-rwxr-xr-x 1 root root  42K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-HK/memtest.efi.mui
-rwxr-xr-x 1 root root  63K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-TW/bootmgfw.efi.mui
-rwxr-xr-x 1 root root  63K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-TW/bootmgr.efi.mui
-rwxr-xr-x 1 root root  42K Aug 22  2013 /boot/efi/EFI/Microsoft/Boot/zh-TW/memtest.efi.mui
-rwxr-xr-x 1 root root 152K Feb 28 11:02 /boot/efi/EFI/manjaro/grubx64.efi
-rw-r--r-- 1 root root 2.3M Feb 28 11:02 /boot/grub/fonts/unicode.pf2
-rw------- 1 root root 7.4K Feb 27 16:39 /boot/grub/grub.cf
-rw------- 1 root root 7.4K Feb 28 11:02 /boot/grub/grub.cfg
-rw-r--r-- 1 root root 1.0K Oct 19 21:29 /boot/grub/grubenv
-rw-r--r-- 1 root root 126K Feb 28 11:02 /boot/grub/locale/ast.mo
-rw-r--r-- 1 root root 126K Feb 28 11:02 /boot/grub/locale/ca.mo
-rw-r--r-- 1 root root 117K Feb 28 11:02 /boot/grub/locale/da.mo
-rw-r--r-- 1 root root 133K Feb 28 11:02 /boot/grub/locale/de.mo
-rw-r--r-- 1 root root 199K Feb 28 11:02 /boot/grub/locale/de@hebrew.mo
-rw-r--r-- 1 root root 133K Feb 28 11:02 /boot/grub/locale/de_CH.mo
-rw-r--r-- 1 root root 168K Feb 28 11:02 /boot/grub/locale/en@arabic.mo
-rw-r--r-- 1 root root 159K Feb 28 11:02 /boot/grub/locale/en@cyrillic.mo
-rw-r--r-- 1 root root 159K Feb 28 11:02 /boot/grub/locale/en@greek.mo
-rw-r--r-- 1 root root 183K Feb 28 11:02 /boot/grub/locale/en@hebrew.mo
-rw-r--r-- 1 root root 141K Feb 28 11:02 /boot/grub/locale/en@piglatin.mo
-rw-r--r-- 1 root root 124K Feb 28 11:02 /boot/grub/locale/en@quot.mo
-rw-r--r-- 1 root root  43K Feb 28 11:02 /boot/grub/locale/eo.mo
-rw-r--r-- 1 root root 129K Feb 28 11:02 /boot/grub/locale/es.mo
-rw-r--r-- 1 root root 131K Feb 28 11:02 /boot/grub/locale/fi.mo
-rw-r--r-- 1 root root 139K Feb 28 11:02 /boot/grub/locale/fr.mo
-rw-r--r-- 1 root root 102K Feb 28 11:02 /boot/grub/locale/gl.mo
-rw-r--r-- 1 root root 129K Feb 28 11:02 /boot/grub/locale/hr.mo
-rw-r--r-- 1 root root 130K Feb 28 11:02 /boot/grub/locale/hu.mo
-rw-r--r-- 1 root root  28K Feb 28 11:02 /boot/grub/locale/id.mo
-rw-r--r-- 1 root root 116K Feb 28 11:02 /boot/grub/locale/it.mo
-rw-r--r-- 1 root root  45K Feb 28 11:02 /boot/grub/locale/ja.mo
-rw-r--r-- 1 root root 133K Feb 28 11:02 /boot/grub/locale/ka.mo
-rw-r--r-- 1 root root 137K Feb 28 11:02 /boot/grub/locale/ko.mo
-rw-r--r-- 1 root root 8.2K Feb 28 11:02 /boot/grub/locale/lg.mo
-rw-r--r-- 1 root root 100K Feb 28 11:02 /boot/grub/locale/lt.mo
-rw-r--r-- 1 root root 126K Feb 28 11:02 /boot/grub/locale/nb.mo
-rw-r--r-- 1 root root 125K Feb 28 11:02 /boot/grub/locale/nl.mo
-rw-r--r-- 1 root root  61K Feb 28 11:02 /boot/grub/locale/pa.mo
-rw-r--r-- 1 root root 132K Feb 28 11:02 /boot/grub/locale/pl.mo
-rw-r--r-- 1 root root 130K Feb 28 11:02 /boot/grub/locale/pt.mo
-rw-r--r-- 1 root root  82K Feb 28 11:02 /boot/grub/locale/pt_BR.mo
-rw-r--r-- 1 root root  48K Feb 28 11:02 /boot/grub/locale/ro.mo
-rw-r--r-- 1 root root 168K Feb 28 11:02 /boot/grub/locale/ru.mo
-rw-r--r-- 1 root root  93K Feb 28 11:02 /boot/grub/locale/sl.mo
-rw-r--r-- 1 root root 167K Feb 28 11:02 /boot/grub/locale/sr.mo
-rw-r--r-- 1 root root 127K Feb 28 11:02 /boot/grub/locale/sv.mo
-rw-r--r-- 1 root root  83K Feb 28 11:02 /boot/grub/locale/tr.mo
-rw-r--r-- 1 root root 175K Feb 28 11:02 /boot/grub/locale/uk.mo
-rw-r--r-- 1 root root 143K Feb 28 11:02 /boot/grub/locale/vi.mo
-rw-r--r-- 1 root root 123K Feb 28 11:02 /boot/grub/locale/zh_CN.mo
-rw-r--r-- 1 root root  30K Feb 28 11:02 /boot/grub/locale/zh_TW.mo
-rw-r--r-- 1 root root  20K Feb 28 11:02 /boot/grub/themes/starfield/COPYING.CC-BY-SA-3.0
-rw-r--r-- 1 root root 1.2K Feb 28 11:02 /boot/grub/themes/starfield/README
-rw-r--r-- 1 root root  836 Feb 28 11:02 /boot/grub/themes/starfield/blob_w.png
-rw-r--r-- 1 root root  178 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_c.png
-rw-r--r-- 1 root root  193 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_e.png
-rw-r--r-- 1 root root  103 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_n.png
-rw-r--r-- 1 root root  193 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_ne.png
-rw-r--r-- 1 root root  184 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_nw.png
-rw-r--r-- 1 root root  102 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_s.png
-rw-r--r-- 1 root root  198 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_se.png
-rw-r--r-- 1 root root  196 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_sw.png
-rw-r--r-- 1 root root   96 Feb 28 11:02 /boot/grub/themes/starfield/boot_menu_w.png
-rw-r--r-- 1 root root 150K Feb 28 11:02 /boot/grub/themes/starfield/dejavu_10.pf2
-rw-r--r-- 1 root root 166K Feb 28 11:02 /boot/grub/themes/starfield/dejavu_12.pf2
-rw-r--r-- 1 root root 182K Feb 28 11:02 /boot/grub/themes/starfield/dejavu_14.pf2
-rw-r--r-- 1 root root 200K Feb 28 11:02 /boot/grub/themes/starfield/dejavu_16.pf2
-rw-r--r-- 1 root root 189K Feb 28 11:02 /boot/grub/themes/starfield/dejavu_bold_14.pf2
-rw-r--r-- 1 root root  197 Feb 28 11:02 /boot/grub/themes/starfield/slider_c.png
-rw-r--r-- 1 root root  265 Feb 28 11:02 /boot/grub/themes/starfield/slider_n.png
-rw-r--r-- 1 root root  269 Feb 28 11:02 /boot/grub/themes/starfield/slider_s.png
-rw-r--r-- 1 root root 1.9M Feb 28 11:02 /boot/grub/themes/starfield/starfield.png
-rw-r--r-- 1 root root  178 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_c.png
-rw-r--r-- 1 root root   94 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_e.png
-rw-r--r-- 1 root root  194 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_n.png
-rw-r--r-- 1 root root  128 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_ne.png
-rw-r--r-- 1 root root  210 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_nw.png
-rw-r--r-- 1 root root  101 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_s.png
-rw-r--r-- 1 root root  126 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_se.png
-rw-r--r-- 1 root root  123 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_sw.png
-rw-r--r-- 1 root root   97 Feb 28 11:02 /boot/grub/themes/starfield/terminal_box_w.png
-rw-r--r-- 1 root root 2.2K Feb 28 11:02 /boot/grub/themes/starfield/theme.txt
-rw-r--r-- 1 root root  17K Feb 28 11:02 /boot/grub/x86_64-efi/acpi.mod
-rw-r--r-- 1 root root 1.8K Feb 28 11:02 /boot/grub/x86_64-efi/adler32.mod
-rw-r--r-- 1 root root 8.8K Feb 28 11:02 /boot/grub/x86_64-efi/affs.mod
-rw-r--r-- 1 root root 9.3K Feb 28 11:02 /boot/grub/x86_64-efi/afs.mod
-rw-r--r-- 1 root root 2.2K Feb 28 11:02 /boot/grub/x86_64-efi/afsplitter.mod
-rw-r--r-- 1 root root  22K Feb 28 11:02 /boot/grub/x86_64-efi/ahci.mod
-rw-r--r-- 1 root root  704 Feb 28 11:02 /boot/grub/x86_64-efi/all_video.mod
-rw-r--r-- 1 root root 1.4K Feb 28 11:02 /boot/grub/x86_64-efi/aout.mod
-rw-r--r-- 1 root root 5.2K Feb 28 11:02 /boot/grub/x86_64-efi/appleldr.mod
-rw-r--r-- 1 root root 4.9K Feb 28 11:02 /boot/grub/x86_64-efi/archelp.mod
-rw-r--r-- 1 root root 6.3K Feb 28 11:02 /boot/grub/x86_64-efi/at_keyboard.mod
-rw-r--r-- 1 root root 8.5K Feb 28 11:02 /boot/grub/x86_64-efi/ata.mod
-rw-r--r-- 1 root root 2.4K Feb 28 11:02 /boot/grub/x86_64-efi/backtrace.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/bfs.mod
-rw-r--r-- 1 root root 3.2K Feb 28 11:02 /boot/grub/x86_64-efi/bitmap.mod
-rw-r--r-- 1 root root 5.2K Feb 28 11:02 /boot/grub/x86_64-efi/bitmap_scale.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/blocklist.mod
-rw-r--r-- 1 root root 3.7K Feb 28 11:02 /boot/grub/x86_64-efi/boot.mod
-rw-r--r-- 1 root root 1.9K Feb 28 11:02 /boot/grub/x86_64-efi/boottime.mod
-rw-r--r-- 1 root root  50K Feb 28 11:02 /boot/grub/x86_64-efi/bsd.mod
-rw-r--r-- 1 root root 3.1K Feb 28 11:02 /boot/grub/x86_64-efi/bswap_test.mod
-rw-r--r-- 1 root root  30K Feb 28 11:02 /boot/grub/x86_64-efi/btrfs.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/bufio.mod
-rw-r--r-- 1 root root 2.1K Feb 28 11:02 /boot/grub/x86_64-efi/cacheinfo.mod
-rw-r--r-- 1 root root 4.2K Feb 28 11:02 /boot/grub/x86_64-efi/cat.mod
-rw-r--r-- 1 root root 5.9K Feb 28 11:02 /boot/grub/x86_64-efi/cbfs.mod
-rw-r--r-- 1 root root 5.5K Feb 28 11:02 /boot/grub/x86_64-efi/cbls.mod
-rw-r--r-- 1 root root 3.7K Feb 28 11:02 /boot/grub/x86_64-efi/cbmemc.mod
-rw-r--r-- 1 root root 1.5K Feb 28 11:02 /boot/grub/x86_64-efi/cbtable.mod
-rw-r--r-- 1 root root 4.3K Feb 28 11:02 /boot/grub/x86_64-efi/cbtime.mod
-rw-r--r-- 1 root root 8.9K Feb 28 11:02 /boot/grub/x86_64-efi/chain.mod
-rw-r--r-- 1 root root 4.4K Feb 28 11:02 /boot/grub/x86_64-efi/cmdline_cat_test.mod
-rw-r--r-- 1 root root 3.0K Feb 28 11:02 /boot/grub/x86_64-efi/cmp.mod
-rw-r--r-- 1 root root 6.1K Feb 28 11:02 /boot/grub/x86_64-efi/cmp_test.mod
-rw-r--r-- 1 root root 3.6K Feb 28 11:02 /boot/grub/x86_64-efi/command.lst
-rw-r--r-- 1 root root 3.1K Feb 28 11:02 /boot/grub/x86_64-efi/configfile.mod
-rw-r--r-- 1 root root 152K Feb 28 11:02 /boot/grub/x86_64-efi/core.efi
-rw-r--r-- 1 root root 4.5K Feb 28 11:02 /boot/grub/x86_64-efi/cpio.mod
-rw-r--r-- 1 root root 4.5K Feb 28 11:02 /boot/grub/x86_64-efi/cpio_be.mod
-rw-r--r-- 1 root root 2.5K Feb 28 11:02 /boot/grub/x86_64-efi/cpuid.mod
-rw-r--r-- 1 root root 2.0K Feb 28 11:02 /boot/grub/x86_64-efi/crc64.mod
-rw-r--r-- 1 root root  936 Feb 28 11:02 /boot/grub/x86_64-efi/crypto.lst
-rw-r--r-- 1 root root 7.3K Feb 28 11:02 /boot/grub/x86_64-efi/crypto.mod
-rw-r--r-- 1 root root  22K Feb 28 11:02 /boot/grub/x86_64-efi/cryptodisk.mod
-rw-r--r-- 1 root root 3.8K Feb 28 11:02 /boot/grub/x86_64-efi/cs5536.mod
-rw-r--r-- 1 root root 2.5K Feb 28 11:02 /boot/grub/x86_64-efi/ctz_test.mod
-rw-r--r-- 1 root root 3.1K Feb 28 11:02 /boot/grub/x86_64-efi/date.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/datehook.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/datetime.mod
-rw-r--r-- 1 root root 3.1K Feb 28 11:02 /boot/grub/x86_64-efi/disk.mod
-rw-r--r-- 1 root root  14K Feb 28 11:02 /boot/grub/x86_64-efi/diskfilter.mod
-rw-r--r-- 1 root root 1.3K Feb 28 11:02 /boot/grub/x86_64-efi/div.mod
-rw-r--r-- 1 root root 7.7K Feb 28 11:02 /boot/grub/x86_64-efi/div_test.mod
-rw-r--r-- 1 root root 2.8K Feb 28 11:02 /boot/grub/x86_64-efi/dm_nv.mod
-rw-r--r-- 1 root root 3.0K Feb 28 11:02 /boot/grub/x86_64-efi/echo.mod
-rw-r--r-- 1 root root  13K Feb 28 11:02 /boot/grub/x86_64-efi/efi_gop.mod
-rw-r--r-- 1 root root 6.9K Feb 28 11:02 /boot/grub/x86_64-efi/efi_uga.mod
-rw-r--r-- 1 root root 2.0K Feb 28 11:02 /boot/grub/x86_64-efi/efifwsetup.mod
-rw-r--r-- 1 root root 7.1K Feb 28 11:02 /boot/grub/x86_64-efi/efinet.mod
-rw-r--r-- 1 root root  26K Feb 28 11:02 /boot/grub/x86_64-efi/ehci.mod
-rw-r--r-- 1 root root 6.2K Feb 28 11:02 /boot/grub/x86_64-efi/elf.mod
-rw-r--r-- 1 root root 2.2K Feb 28 11:02 /boot/grub/x86_64-efi/eval.mod
-rw-r--r-- 1 root root 9.0K Feb 28 11:02 /boot/grub/x86_64-efi/exfat.mod
-rw-r--r-- 1 root root 2.0K Feb 28 11:02 /boot/grub/x86_64-efi/exfctest.mod
-rw-r--r-- 1 root root 9.2K Feb 28 11:02 /boot/grub/x86_64-efi/ext2.mod
-rw-r--r-- 1 root root 7.7K Feb 28 11:02 /boot/grub/x86_64-efi/extcmd.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/f2fs.mod
-rw-r--r-- 1 root root 9.0K Feb 28 11:02 /boot/grub/x86_64-efi/fat.mod
-rw-r--r-- 1 root root  27K Feb 28 11:02 /boot/grub/x86_64-efi/file.mod
-rw-r--r-- 1 root root 2.8K Feb 28 11:02 /boot/grub/x86_64-efi/fixvideo.mod
-rw-r--r-- 1 root root  20K Feb 28 11:02 /boot/grub/x86_64-efi/font.mod
-rw-r--r-- 1 root root  219 Feb 28 11:02 /boot/grub/x86_64-efi/fs.lst
-rw-r--r-- 1 root root 4.5K Feb 28 11:02 /boot/grub/x86_64-efi/fshelp.mod
-rw-r--r-- 1 root root  46K Feb 28 11:02 /boot/grub/x86_64-efi/functional_test.mod
-rw-r--r-- 1 root root 2.3K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_arcfour.mod
-rw-r--r-- 1 root root 9.1K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_blowfish.mod
-rw-r--r-- 1 root root  28K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_camellia.mod
-rw-r--r-- 1 root root  15K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_cast5.mod
-rw-r--r-- 1 root root  12K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_crc.mod
-rw-r--r-- 1 root root  16K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_des.mod
-rw-r--r-- 1 root root 3.3K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_dsa.mod
-rw-r--r-- 1 root root 3.8K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_idea.mod
-rw-r--r-- 1 root root 4.0K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_md4.mod
-rw-r--r-- 1 root root 4.4K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_md5.mod
-rw-r--r-- 1 root root 3.0K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_rfc2268.mod
-rw-r--r-- 1 root root  20K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_rijndael.mod
-rw-r--r-- 1 root root 7.7K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_rmd160.mod
-rw-r--r-- 1 root root 3.2K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_rsa.mod
-rw-r--r-- 1 root root  13K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_seed.mod
-rw-r--r-- 1 root root  16K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_serpent.mod
-rw-r--r-- 1 root root 7.9K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_sha1.mod
-rw-r--r-- 1 root root 5.0K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_sha256.mod
-rw-r--r-- 1 root root 5.9K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_sha512.mod
-rw-r--r-- 1 root root  13K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_tiger.mod
-rw-r--r-- 1 root root  33K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_twofish.mod
-rw-r--r-- 1 root root  23K Feb 28 11:02 /boot/grub/x86_64-efi/gcry_whirlpool.mod
-rw-r--r-- 1 root root 8.6K Feb 28 11:02 /boot/grub/x86_64-efi/geli.mod
-rw-r--r-- 1 root root 8.4K Feb 28 11:02 /boot/grub/x86_64-efi/gettext.mod
-rw-r--r-- 1 root root  63K Feb 28 11:02 /boot/grub/x86_64-efi/gfxmenu.mod
-rw-r--r-- 1 root root  17K Feb 28 11:02 /boot/grub/x86_64-efi/gfxterm.mod
-rw-r--r-- 1 root root 4.3K Feb 28 11:02 /boot/grub/x86_64-efi/gfxterm_background.mod
-rw-r--r-- 1 root root 7.5K Feb 28 11:02 /boot/grub/x86_64-efi/gfxterm_menu.mod
-rw-r--r-- 1 root root 5.2K Feb 28 11:02 /boot/grub/x86_64-efi/gptsync.mod
-rw-r--r-- 1 root root 152K Feb 28 11:02 /boot/grub/x86_64-efi/grub.efi
-rw-r--r-- 1 root root  13K Feb 28 11:02 /boot/grub/x86_64-efi/gzio.mod
-rw-r--r-- 1 root root 7.4K Feb 28 11:02 /boot/grub/x86_64-efi/halt.mod
-rw-r--r-- 1 root root 8.5K Feb 28 11:02 /boot/grub/x86_64-efi/hashsum.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/hdparm.mod
-rw-r--r-- 1 root root 1.8K Feb 28 11:02 /boot/grub/x86_64-efi/hello.mod
-rw-r--r-- 1 root root 3.9K Feb 28 11:02 /boot/grub/x86_64-efi/help.mod
-rw-r--r-- 1 root root 4.3K Feb 28 11:02 /boot/grub/x86_64-efi/hexdump.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/hfs.mod
-rw-r--r-- 1 root root  13K Feb 28 11:02 /boot/grub/x86_64-efi/hfsplus.mod
-rw-r--r-- 1 root root 4.4K Feb 28 11:02 /boot/grub/x86_64-efi/hfspluscomp.mod
-rw-r--r-- 1 root root 9.6K Feb 28 11:02 /boot/grub/x86_64-efi/http.mod
-rw-r--r-- 1 root root 4.2K Feb 28 11:02 /boot/grub/x86_64-efi/iorw.mod
-rw-r--r-- 1 root root  14K Feb 28 11:02 /boot/grub/x86_64-efi/iso9660.mod
-rw-r--r-- 1 root root 9.2K Feb 28 11:02 /boot/grub/x86_64-efi/jfs.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/jpeg.mod
-rw-r--r-- 1 root root 4.8K Feb 28 11:02 /boot/grub/x86_64-efi/json.mod
-rw-r--r-- 1 root root 6.3K Feb 28 11:02 /boot/grub/x86_64-efi/keylayouts.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/keystatus.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/ldm.mod
-rw-r--r-- 1 root root  16K Feb 28 11:02 /boot/grub/x86_64-efi/legacy_password_test.mod
-rw-r--r-- 1 root root  46K Feb 28 11:02 /boot/grub/x86_64-efi/legacycfg.mod
-rw-r--r-- 1 root root  20K Feb 28 11:02 /boot/grub/x86_64-efi/linux.mod
-rw-r--r-- 1 root root 8.3K Feb 28 11:02 /boot/grub/x86_64-efi/linux16.mod
-rw-r--r-- 1 root root   98 Feb 28 11:02 /boot/grub/x86_64-efi/load.cfg
-rw-r--r-- 1 root root 4.5K Feb 28 11:02 /boot/grub/x86_64-efi/loadbios.mod
-rw-r--r-- 1 root root 9.3K Feb 28 11:02 /boot/grub/x86_64-efi/loadenv.mod
-rw-r--r-- 1 root root 4.8K Feb 28 11:02 /boot/grub/x86_64-efi/loopback.mod
-rw-r--r-- 1 root root 6.4K Feb 28 11:02 /boot/grub/x86_64-efi/ls.mod
-rw-r--r-- 1 root root 6.9K Feb 28 11:02 /boot/grub/x86_64-efi/lsacpi.mod
-rw-r--r-- 1 root root 5.1K Feb 28 11:02 /boot/grub/x86_64-efi/lsefi.mod
-rw-r--r-- 1 root root 3.7K Feb 28 11:02 /boot/grub/x86_64-efi/lsefimmap.mod
-rw-r--r-- 1 root root 4.4K Feb 28 11:02 /boot/grub/x86_64-efi/lsefisystab.mod
-rw-r--r-- 1 root root 2.8K Feb 28 11:02 /boot/grub/x86_64-efi/lsmmap.mod
-rw-r--r-- 1 root root 7.0K Feb 28 11:02 /boot/grub/x86_64-efi/lspci.mod
-rw-r--r-- 1 root root 3.7K Feb 28 11:02 /boot/grub/x86_64-efi/lssal.mod
-rw-r--r-- 1 root root 6.2K Feb 28 11:02 /boot/grub/x86_64-efi/luks.mod
-rw-r--r-- 1 root root  20K Feb 28 11:02 /boot/grub/x86_64-efi/luks2.mod
-rw-r--r-- 1 root root  14K Feb 28 11:02 /boot/grub/x86_64-efi/lvm.mod
-rw-r--r-- 1 root root 7.2K Feb 28 11:02 /boot/grub/x86_64-efi/lzopio.mod
-rw-r--r-- 1 root root 4.8K Feb 28 11:02 /boot/grub/x86_64-efi/macbless.mod
-rw-r--r-- 1 root root  12K Feb 28 11:02 /boot/grub/x86_64-efi/macho.mod
-rw-r--r-- 1 root root 2.8K Feb 28 11:02 /boot/grub/x86_64-efi/mdraid09.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/mdraid09_be.mod
-rw-r--r-- 1 root root 2.6K Feb 28 11:02 /boot/grub/x86_64-efi/mdraid1x.mod
-rw-r--r-- 1 root root 3.1K Feb 28 11:02 /boot/grub/x86_64-efi/memdisk.mod
-rw-r--r-- 1 root root 4.2K Feb 28 11:02 /boot/grub/x86_64-efi/memrw.mod
-rw-r--r-- 1 root root 5.7K Feb 28 11:02 /boot/grub/x86_64-efi/minicmd.mod
-rw-r--r-- 1 root root 5.6K Feb 28 11:02 /boot/grub/x86_64-efi/minix.mod
-rw-r--r-- 1 root root 5.8K Feb 28 11:02 /boot/grub/x86_64-efi/minix2.mod
-rw-r--r-- 1 root root 5.9K Feb 28 11:02 /boot/grub/x86_64-efi/minix2_be.mod
-rw-r--r-- 1 root root 5.8K Feb 28 11:02 /boot/grub/x86_64-efi/minix3.mod
-rw-r--r-- 1 root root 5.9K Feb 28 11:02 /boot/grub/x86_64-efi/minix3_be.mod
-rw-r--r-- 1 root root 5.7K Feb 28 11:02 /boot/grub/x86_64-efi/minix_be.mod
-rw-r--r-- 1 root root 9.8K Feb 28 11:02 /boot/grub/x86_64-efi/mmap.mod
-rw-r--r-- 1 root root 5.2K Feb 28 11:02 /boot/grub/x86_64-efi/moddep.lst
-rw-r--r-- 1 root root 2.5K Feb 28 11:02 /boot/grub/x86_64-efi/modinfo.sh
-rw-r--r-- 1 root root 3.1K Feb 28 11:02 /boot/grub/x86_64-efi/morse.mod
-rw-r--r-- 1 root root  44K Feb 28 11:02 /boot/grub/x86_64-efi/mpi.mod
-rw-r--r-- 1 root root 3.6K Feb 28 11:02 /boot/grub/x86_64-efi/msdospart.mod
-rw-r--r-- 1 root root 2.3K Feb 28 11:02 /boot/grub/x86_64-efi/mul_test.mod
-rw-r--r-- 1 root root  21K Feb 28 11:02 /boot/grub/x86_64-efi/multiboot.mod
-rw-r--r-- 1 root root  24K Feb 28 11:02 /boot/grub/x86_64-efi/multiboot2.mod
-rw-r--r-- 1 root root 7.1K Feb 28 11:02 /boot/grub/x86_64-efi/nativedisk.mod
-rw-r--r-- 1 root root  82K Feb 28 11:02 /boot/grub/x86_64-efi/net.mod
-rw-r--r-- 1 root root 4.7K Feb 28 11:02 /boot/grub/x86_64-efi/newc.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/nilfs2.mod
-rw-r--r-- 1 root root 182K Feb 28 11:02 /boot/grub/x86_64-efi/normal.mod
-rw-r--r-- 1 root root  16K Feb 28 11:02 /boot/grub/x86_64-efi/ntfs.mod
-rw-r--r-- 1 root root 5.6K Feb 28 11:02 /boot/grub/x86_64-efi/ntfscomp.mod
-rw-r--r-- 1 root root 4.5K Feb 28 11:02 /boot/grub/x86_64-efi/odc.mod
-rw-r--r-- 1 root root 2.3K Feb 28 11:02 /boot/grub/x86_64-efi/offsetio.mod
-rw-r--r-- 1 root root  16K Feb 28 11:02 /boot/grub/x86_64-efi/ohci.mod
-rw-r--r-- 1 root root 2.2K Feb 28 11:02 /boot/grub/x86_64-efi/part_acorn.mod
-rw-r--r-- 1 root root 2.5K Feb 28 11:02 /boot/grub/x86_64-efi/part_amiga.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/part_apple.mod
-rw-r--r-- 1 root root 4.0K Feb 28 11:02 /boot/grub/x86_64-efi/part_bsd.mod
-rw-r--r-- 1 root root 2.6K Feb 28 11:02 /boot/grub/x86_64-efi/part_dfly.mod
-rw-r--r-- 1 root root 2.1K Feb 28 11:02 /boot/grub/x86_64-efi/part_dvh.mod
-rw-r--r-- 1 root root 3.1K Feb 28 11:02 /boot/grub/x86_64-efi/part_gpt.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/part_msdos.mod
-rw-r--r-- 1 root root 2.4K Feb 28 11:02 /boot/grub/x86_64-efi/part_plan.mod
-rw-r--r-- 1 root root 2.2K Feb 28 11:02 /boot/grub/x86_64-efi/part_sun.mod
-rw-r--r-- 1 root root 2.6K Feb 28 11:02 /boot/grub/x86_64-efi/part_sunpc.mod
-rw-r--r-- 1 root root  111 Feb 28 11:02 /boot/grub/x86_64-efi/partmap.lst
-rw-r--r-- 1 root root   17 Feb 28 11:02 /boot/grub/x86_64-efi/parttool.lst
-rw-r--r-- 1 root root 7.7K Feb 28 11:02 /boot/grub/x86_64-efi/parttool.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/password.mod
-rw-r--r-- 1 root root 4.9K Feb 28 11:02 /boot/grub/x86_64-efi/password_pbkdf2.mod
-rw-r--r-- 1 root root 7.2K Feb 28 11:02 /boot/grub/x86_64-efi/pata.mod
-rw-r--r-- 1 root root 2.0K Feb 28 11:02 /boot/grub/x86_64-efi/pbkdf2.mod
-rw-r--r-- 1 root root 3.3K Feb 28 11:02 /boot/grub/x86_64-efi/pbkdf2_test.mod
-rw-r--r-- 1 root root 3.4K Feb 28 11:02 /boot/grub/x86_64-efi/pcidump.mod
-rw-r--r-- 1 root root  20K Feb 28 11:02 /boot/grub/x86_64-efi/pgp.mod
-rw-r--r-- 1 root root 3.8K Feb 28 11:02 /boot/grub/x86_64-efi/play.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/png.mod
-rw-r--r-- 1 root root 2.5K Feb 28 11:02 /boot/grub/x86_64-efi/priority_queue.mod
-rw-r--r-- 1 root root 5.8K Feb 28 11:02 /boot/grub/x86_64-efi/probe.mod
-rw-r--r-- 1 root root 3.7K Feb 28 11:02 /boot/grub/x86_64-efi/procfs.mod
-rw-r--r-- 1 root root 3.0K Feb 28 11:02 /boot/grub/x86_64-efi/progress.mod
-rw-r--r-- 1 root root 2.1K Feb 28 11:02 /boot/grub/x86_64-efi/raid5rec.mod
-rw-r--r-- 1 root root 3.5K Feb 28 11:02 /boot/grub/x86_64-efi/raid6rec.mod
-rw-r--r-- 1 root root 3.6K Feb 28 11:02 /boot/grub/x86_64-efi/random.mod
-rw-r--r-- 1 root root 3.0K Feb 28 11:02 /boot/grub/x86_64-efi/rdmsr.mod
-rw-r--r-- 1 root root 2.8K Feb 28 11:02 /boot/grub/x86_64-efi/read.mod
-rw-r--r-- 1 root root 1.5K Feb 28 11:02 /boot/grub/x86_64-efi/reboot.mod
-rw-r--r-- 1 root root  78K Feb 28 11:02 /boot/grub/x86_64-efi/regexp.mod
-rw-r--r-- 1 root root  15K Feb 28 11:02 /boot/grub/x86_64-efi/reiserfs.mod
-rw-r--r-- 1 root root  27K Feb 28 11:02 /boot/grub/x86_64-efi/relocator.mod
-rw-r--r-- 1 root root 6.0K Feb 28 11:02 /boot/grub/x86_64-efi/romfs.mod
-rw-r--r-- 1 root root 7.3K Feb 28 11:02 /boot/grub/x86_64-efi/scsi.mod
-rw-r--r-- 1 root root 5.5K Feb 28 11:02 /boot/grub/x86_64-efi/search.mod
-rw-r--r-- 1 root root 4.9K Feb 28 11:02 /boot/grub/x86_64-efi/search_fs_file.mod
-rw-r--r-- 1 root root 5.1K Feb 28 11:02 /boot/grub/x86_64-efi/search_fs_uuid.mod
-rw-r--r-- 1 root root 5.1K Feb 28 11:02 /boot/grub/x86_64-efi/search_label.mod
-rw-r--r-- 1 root root  15K Feb 28 11:02 /boot/grub/x86_64-efi/serial.mod
-rw-r--r-- 1 root root  912 Feb 28 11:02 /boot/grub/x86_64-efi/setjmp.mod
-rw-r--r-- 1 root root 2.5K Feb 28 11:02 /boot/grub/x86_64-efi/setjmp_test.mod
-rw-r--r-- 1 root root 8.0K Feb 28 11:02 /boot/grub/x86_64-efi/setpci.mod
-rw-r--r-- 1 root root 9.0K Feb 28 11:02 /boot/grub/x86_64-efi/sfs.mod
-rw-r--r-- 1 root root 3.0K Feb 28 11:02 /boot/grub/x86_64-efi/shift_test.mod
-rw-r--r-- 1 root root 8.2K Feb 28 11:02 /boot/grub/x86_64-efi/signature_test.mod
-rw-r--r-- 1 root root 3.2K Feb 28 11:02 /boot/grub/x86_64-efi/sleep.mod
-rw-r--r-- 1 root root 3.0K Feb 28 11:02 /boot/grub/x86_64-efi/sleep_test.mod
-rw-r--r-- 1 root root 8.3K Feb 28 11:02 /boot/grub/x86_64-efi/smbios.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/spkmodem.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/squash4.mod
-rw-r--r-- 1 root root 3.1K Feb 28 11:02 /boot/grub/x86_64-efi/strtoull_test.mod
-rw-r--r-- 1 root root  31K Feb 28 11:02 /boot/grub/x86_64-efi/syslinuxcfg.mod
-rw-r--r-- 1 root root 5.1K Feb 28 11:02 /boot/grub/x86_64-efi/tar.mod
-rw-r--r-- 1 root root  162 Feb 28 11:02 /boot/grub/x86_64-efi/terminal.lst
-rw-r--r-- 1 root root 6.5K Feb 28 11:02 /boot/grub/x86_64-efi/terminal.mod
-rw-r--r-- 1 root root  19K Feb 28 11:02 /boot/grub/x86_64-efi/terminfo.mod
-rw-r--r-- 1 root root 7.4K Feb 28 11:02 /boot/grub/x86_64-efi/test.mod
-rw-r--r-- 1 root root 2.0K Feb 28 11:02 /boot/grub/x86_64-efi/test_blockarg.mod
-rw-r--r-- 1 root root 3.8K Feb 28 11:02 /boot/grub/x86_64-efi/testload.mod
-rw-r--r-- 1 root root 3.5K Feb 28 11:02 /boot/grub/x86_64-efi/testspeed.mod
-rw-r--r-- 1 root root 7.4K Feb 28 11:02 /boot/grub/x86_64-efi/tftp.mod
-rw-r--r-- 1 root root 5.9K Feb 28 11:02 /boot/grub/x86_64-efi/tga.mod
-rw-r--r-- 1 root root 2.3K Feb 28 11:02 /boot/grub/x86_64-efi/time.mod
-rw-r--r-- 1 root root 6.4K Feb 28 11:02 /boot/grub/x86_64-efi/tpm.mod
-rw-r--r-- 1 root root 3.6K Feb 28 11:02 /boot/grub/x86_64-efi/tr.mod
-rw-r--r-- 1 root root 1.9K Feb 28 11:02 /boot/grub/x86_64-efi/trig.mod
-rw-r--r-- 1 root root 1.8K Feb 28 11:02 /boot/grub/x86_64-efi/true.mod
-rw-r--r-- 1 root root  14K Feb 28 11:02 /boot/grub/x86_64-efi/udf.mod
-rw-r--r-- 1 root root 8.2K Feb 28 11:02 /boot/grub/x86_64-efi/ufs1.mod
-rw-r--r-- 1 root root 8.4K Feb 28 11:02 /boot/grub/x86_64-efi/ufs1_be.mod
-rw-r--r-- 1 root root 8.2K Feb 28 11:02 /boot/grub/x86_64-efi/ufs2.mod
-rw-r--r-- 1 root root 9.8K Feb 28 11:02 /boot/grub/x86_64-efi/uhci.mod
-rw-r--r-- 1 root root  19K Feb 28 11:02 /boot/grub/x86_64-efi/usb.mod
-rw-r--r-- 1 root root 5.7K Feb 28 11:02 /boot/grub/x86_64-efi/usb_keyboard.mod
-rw-r--r-- 1 root root  12K Feb 28 11:02 /boot/grub/x86_64-efi/usbms.mod
-rw-r--r-- 1 root root 2.9K Feb 28 11:02 /boot/grub/x86_64-efi/usbserial_common.mod
-rw-r--r-- 1 root root 3.3K Feb 28 11:02 /boot/grub/x86_64-efi/usbserial_ftdi.mod
-rw-r--r-- 1 root root 3.6K Feb 28 11:02 /boot/grub/x86_64-efi/usbserial_pl2303.mod
-rw-r--r-- 1 root root 2.2K Feb 28 11:02 /boot/grub/x86_64-efi/usbserial_usbdebug.mod
-rw-r--r-- 1 root root 5.7K Feb 28 11:02 /boot/grub/x86_64-efi/usbtest.mod
-rw-r--r-- 1 root root   41 Feb 28 11:02 /boot/grub/x86_64-efi/video.lst
-rw-r--r-- 1 root root 8.7K Feb 28 11:02 /boot/grub/x86_64-efi/video.mod
-rw-r--r-- 1 root root 8.3K Feb 28 11:02 /boot/grub/x86_64-efi/video_bochs.mod
-rw-r--r-- 1 root root 8.7K Feb 28 11:02 /boot/grub/x86_64-efi/video_cirrus.mod
-rw-r--r-- 1 root root 9.7K Feb 28 11:02 /boot/grub/x86_64-efi/video_colors.mod
-rw-r--r-- 1 root root  28K Feb 28 11:02 /boot/grub/x86_64-efi/video_fb.mod
-rw-r--r-- 1 root root 5.1K Feb 28 11:02 /boot/grub/x86_64-efi/videoinfo.mod
-rw-r--r-- 1 root root 5.2K Feb 28 11:02 /boot/grub/x86_64-efi/videotest.mod
-rw-r--r-- 1 root root 3.5K Feb 28 11:02 /boot/grub/x86_64-efi/videotest_checksum.mod
-rw-r--r-- 1 root root 2.3K Feb 28 11:02 /boot/grub/x86_64-efi/wrmsr.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/xfs.mod
-rw-r--r-- 1 root root  44K Feb 28 11:02 /boot/grub/x86_64-efi/xnu.mod
-rw-r--r-- 1 root root 3.2K Feb 28 11:02 /boot/grub/x86_64-efi/xnu_uuid.mod
-rw-r--r-- 1 root root 3.0K Feb 28 11:02 /boot/grub/x86_64-efi/xnu_uuid_test.mod
-rw-r--r-- 1 root root  20K Feb 28 11:02 /boot/grub/x86_64-efi/xzio.mod
-rw-r--r-- 1 root root  60K Feb 28 11:02 /boot/grub/x86_64-efi/zfs.mod
-rw-r--r-- 1 root root 8.4K Feb 28 11:02 /boot/grub/x86_64-efi/zfscrypt.mod
-rw-r--r-- 1 root root  11K Feb 28 11:02 /boot/grub/x86_64-efi/zfsinfo.mod
-rw-r--r-- 1 root root  78K Feb 28 11:02 /boot/grub/x86_64-efi/zstd.mod
-rw------- 1 root root  34M Feb 27 16:02 /boot/initramfs-5.15-x86_64-fallback.img
-rw------- 1 root root 8.9M Feb 27 16:02 /boot/initramfs-5.15-x86_64.img
-rw-r--r-- 1 root root 5.5M Nov  8 20:02 /boot/intel-ucode.img
-rw-r--r-- 1 root root   22 Feb 14 20:44 /boot/linux515-x86_64.kver
-rw-r--r-- 1 root root 141K Feb  9 22:50 /boot/memtest86+/memtest.bin
-rw-r--r-- 1 root root 2.3K Nov 21  2019 /boot/syslinux/syslinux.cfg
-rw-r--r-- 1 root root  11M Feb 27 16:02 /boot/vmlinuz-5.15-x86_64
[manjaro /]# date
Tue Feb 28 11:22:47 CET 2023
[manjaro /]# du /boot
153	/boot/efi/EFI/Microsoft/Boot/bg-BG
196	/boot/efi/EFI/Microsoft/Boot/cs-CZ
194	/boot/efi/EFI/Microsoft/Boot/da-DK
200	/boot/efi/EFI/Microsoft/Boot/de-DE
203	/boot/efi/EFI/Microsoft/Boot/el-GR
145	/boot/efi/EFI/Microsoft/Boot/en-GB
190	/boot/efi/EFI/Microsoft/Boot/en-US
198	/boot/efi/EFI/Microsoft/Boot/es-ES
147	/boot/efi/EFI/Microsoft/Boot/et-EE
196	/boot/efi/EFI/Microsoft/Boot/fi-FI
200	/boot/efi/EFI/Microsoft/Boot/fr-FR
151	/boot/efi/EFI/Microsoft/Boot/hr-HR
200	/boot/efi/EFI/Microsoft/Boot/hu-HU
196	/boot/efi/EFI/Microsoft/Boot/it-IT
175	/boot/efi/EFI/Microsoft/Boot/ja-JP
175	/boot/efi/EFI/Microsoft/Boot/ko-KR
149	/boot/efi/EFI/Microsoft/Boot/lt-LT
149	/boot/efi/EFI/Microsoft/Boot/lv-LV
194	/boot/efi/EFI/Microsoft/Boot/nb-NO
198	/boot/efi/EFI/Microsoft/Boot/nl-NL
198	/boot/efi/EFI/Microsoft/Boot/pl-PL
196	/boot/efi/EFI/Microsoft/Boot/pt-BR
196	/boot/efi/EFI/Microsoft/Boot/pt-PT
190	/boot/efi/EFI/Microsoft/Boot/qps-ploc
149	/boot/efi/EFI/Microsoft/Boot/ro-RO
195	/boot/efi/EFI/Microsoft/Boot/ru-RU
151	/boot/efi/EFI/Microsoft/Boot/sk-SK
151	/boot/efi/EFI/Microsoft/Boot/sl-SI
151	/boot/efi/EFI/Microsoft/Boot/sr-Latn-CS
151	/boot/efi/EFI/Microsoft/Boot/sr-Latn-RS
196	/boot/efi/EFI/Microsoft/Boot/sv-SE
194	/boot/efi/EFI/Microsoft/Boot/tr-TR
151	/boot/efi/EFI/Microsoft/Boot/uk-UA
169	/boot/efi/EFI/Microsoft/Boot/zh-CN
169	/boot/efi/EFI/Microsoft/Boot/zh-HK
169	/boot/efi/EFI/Microsoft/Boot/zh-TW
13175	/boot/efi/EFI/Microsoft/Boot/Fonts
13	/boot/efi/EFI/Microsoft/Boot/Resources/en-US
32	/boot/efi/EFI/Microsoft/Boot/Resources
24403	/boot/efi/EFI/Microsoft/Boot
24404	/boot/efi/EFI/Microsoft
3702	/boot/efi/EFI/Boot
153	/boot/efi/EFI/manjaro
28260	/boot/efi/EFI
28261	/boot/efi
148	/boot/memtest86+
2344	/boot/grub/fonts
2872	/boot/grub/themes/starfield
2876	/boot/grub/themes
5024	/boot/grub/locale
3492	/boot/grub/x86_64-efi
13760	/boot/grub
8	/boot/syslinux
101625	/boot
[manjaro manjaro]# efibootmgr --verbose
BootCurrent: 0001
Timeout: 0 seconds
BootOrder: 0004,0003,2001
Boot0000* EFI Network 0 for IPv4 (20-89-84-FE-A0-61) 	PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(208984fea061,0)/IPv4(0.0.0.00.0.0.0,0,0)RC
      dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 1c / 01 01 06 00 00 00 / 03 0b 25 00 20 89 84 fe a0 61 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 03 0c 1b 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
    data: 52 43
Boot0001* EFI USB Device (SMI     USB DISK)	PciRoot(0x0)/Pci(0x1d,0x0)/USB(0,0)/USB(0,0)/HD(1,MBR,0x0,0x78400c,0x2000)RC
      dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 1d / 03 05 06 00 00 00 / 03 05 06 00 00 00 / 04 01 2a 00 01 00 00 00 0c 40 78 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 / 7f ff 04 00
    data: 52 43
Boot0002* EFI Network 0 for IPv6 (20-89-84-FE-A0-61) 	PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(208984fea061,0)/IPv6([::]:<->[::]:,0,0)RC
      dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 1c / 01 01 06 00 00 00 / 03 0b 25 00 20 89 84 fe a0 61 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 03 0d 3c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
    data: 52 43
Boot0003* Windows Boot Manager	HD(2,MBR,0x4c67e213,0x96800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)RC
      dp: 04 01 2a 00 02 00 00 00 00 68 09 00 00 00 00 00 00 20 03 00 00 00 00 00 13 e2 67 4c 00 00 00 00 00 00 00 00 00 00 00 00 01 01 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 4d 00 69 00 63 00 72 00 6f 00 73 00 6f 00 66 00 74 00 5c 00 42 00 6f 00 6f 00 74 00 5c 00 62 00 6f 00 6f 00 74 00 6d 00 67 00 66 00 77 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
    data: 52 43
Boot0004* manjaro	HD(2,MBR,0x4c67e213,0x96800,0x32000)/File(\EFI\manjaro\grubx64.efi)
      dp: 04 01 2a 00 02 00 00 00 00 68 09 00 00 00 00 00 00 20 03 00 00 00 00 00 13 e2 67 4c 00 00 00 00 00 00 00 00 00 00 00 00 01 01 / 04 04 36 00 5c 00 45 00 46 00 49 00 5c 00 6d 00 61 00 6e 00 6a 00 61 00 72 00 6f 00 5c 00 67 00 72 00 75 00 62 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
Boot2001* EFI USB Device	RC
      dp: 7f ff 04 00
    data: 52 43
I wish you have a backup. But i cant help you with this.
The lesson here is to never delete partitions if you don’t know what they are for.
Without detailed info about your setup the only helpful advice you can get is to re-install everything from scratch.
:vulcan_salute:
I did it by mistake. I wanted to format my flashdrive.
There are already details + bash output.
Disk 1: boot + windows partitions. Formatted, however restored by testdisk. I can see boot folders, files as well as windows folders, files.
Disk 2: manjaro, not touched, all folders, files.
However if I fix the grub following wiki instructions, grub is installed without error (see pastebin). If I power off/on the machine, the grub is not loaded at all. Only windows attempt to load, but it fails (picture). There is no attempt to load grub at all.
If I check the 100MB efi partition, I can see grub and manjaro with recent date, so the grub fix has alteted them. But still unable to boot.
If you check the pastebin, you can see, what is inside the efi partition.
That is just a description of what you have, not a technical output from commands stating current state.
(Unable to view pastebin link due to DNS block, please follow the instructions in the link i gave.)
You might be, but others link me are unable to…
It is mentioned in the link i gave, see this:
Can you split the outputs to contain only one command and it’s output per code-block, like i asked you in private?
From a quick peek at the provided output, it seems you have no ESP partition on your Hard drives. (sdc is your Live-USB drive i guess)…
Plus please replace the output of lsblk with lsblk --fs --all.
Also provide output of efibootmgr --verbose.
Done.
Weird, efibootmgr --verbose tells MBR however it should UEFI, GPT. Or am I wrong ?
It means you are booted in Legacy (MBR) mode and not UEFI…
That’s most likely the cause why your Grub restore doesn’t work because it is restoring the MBR version instead of the UEFI version of Grub…
Edit: Didn’t noticed the grub command when i said that…
how to change it ?
I am using GPT (at least I used before mistake format and recover, probably recover change it to MBR).
An idea how to proceed ?
gdisk?
Lets check that…
Can you provide output of:
sudo fdisk --list-details /dev/sda
That will show you if it is MBR or GPT, plus more info.
Doesn’t the efi version of Grub have a different name? :thinking:
(I can’t check myself, because im using a different Distro)
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: TOSHIBA MQ02ABF0
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x4c67e213
Device     Boot   Start       End   Sectors Id Type            Start-C/H/S   End-C/H/S Attrs
/dev/sda1  *       2048    616447    614400  7 HPFS/NTFS/exFAT     0/32/33    38/94/56    80
/dev/sda2        616448    821247    204800  b W95 FAT32          38/94/57    51/30/43
/dev/sda3       1083392 976773119 975689728  7 HPFS/NTFS/exFAT   67/111/45 1023/254/63
I am using UEFI, the partition must be GPT. In the past I installed Windows and Manjaro as GPT.
I think, the testdisk restored it wrongly to MBR.
It seems,
  • boot flag wrongly on 315MB ntfs partition. For UEFI, it should be the 100MB, fat32
  • 105MB fat32 missing boot and esp flags
Can you confirm, that converting to GPT and adding flags ‘esp’ and ‘boot’ to 100MB partition resolves the issue ?
That shows it is MBR and not GPT :wink:
I can’t assist you in converting sorry, that’s too dangerous to try assisting remotely …
Maybe others can be of more assistance.
But you can’t boot in UEFI while using MBR as boot medium :wink:
This is not the correct partition type for the ESP, yet you mount it as such…
what is wrong with sda2 ?
You wrote: *
Windows uses 100MB Fat32 partition for UEFI:
[manjaro@manjaro ~]$ sudo mount /dev/sda2 /mnt/a
[manjaro@manjaro ~]$ ls -l /mnt/a/EFI/
total 3
drwxr-xr-x 2 root root 1024 Feb 27 15:32 Boot
drwxr-xr-x 2 root root 1024 Feb 27 15:38 manjaro
drwxr-xr-x 3 root root 1024 Sep 30  2021 Microsoft
Your partition has type b, See: EFI system partition - ArchWiki
EFI system partition on a GUID Partition Table is identified by the partition type GUID C12A7328-F81F-11D2-BA4B-00A0C93EC93B.
EFI system partition on a Master Boot Record partition table is identified by the partition type ID EF.
So i have no idea how yours ended up with such a wrong partition-type…
(Note partition-type is not same as filesystem type)
Can you explain exactly how did you “format” the partitions? If you simply hit delete, it’s possible only their partition metadata was erased, in which case testdisk should’ve done the trick. I guess it’s possible that testdisk changed the partition UUIDs too?.. if they existed.
As @TriMoon pointed out, UEFI should be booting from GPT, not MBR. Although some implementations support booting in UEFI mode from MBR partition tables.
First of all, you probably don’t have the space for, but before you do/did any further attempts, you should’ve done a raw image backup of the entire drive. This is to guard you from doing mistakes, to have a safe fallback option in form of a backup.
The Manjaro Live USB has a menu entry at the bottom to detect EFI loaders. Does it work for you?
Assuming the UEFI implementation worked off MBR before, all I can add is this:
  1. Check that the grub files are really updated when you run the install grub commands, including grub.cfg (see modified times).
  2. My UEFI ignores the boot order set by “BootOrder” somehow. I suggest you enter the settings and check the “Hard Drive priorities” yourself to ensure “manjaro” is the first choice in priority.
Generally to fix the booting:
  • Windows: you need an install or recovery CD. From there you can use bcdboot to restore/register the Windows bootloader. Note that the Windows 7 version of the tool does not support GPT, you need at least Win8 for this. I used this to successfully create a UEFI boot entry after converting my disk from MBR to GPT (I was fully prepared and left extra free space for GPT.)
    • diskpart to be used for partition manipulation and to mount them
  • Linux: there’re multiple ways to boot, I guess you got the grub commands right. If you needed to register that grub as a boot entry, all you need is efibootmgr. However note that my system is UEFI+GPT, not MBR.
Yes, I did an image with ddrescue before. You can forget part of data recovery.
The bigest move forward was convertion of the whole sda from MBR to GPT. It went without problems. Windows tried to boot and failed, as expected. Honestly, following few online steps, I was able to repair windows boot very quickly, whilst I have been struggling with grub for days :frowning :frowning: (
Yes, I can boot windows without problems, all files are there and working.
However, when I try to repair the grup (after convert sda to gpt).
After reboot:
  1. there is no grub screen/no choice windows/manjaro.
  2. only black screen, then laptop vendor log and then it failed at step /dev/sdb2: clean.
    No move.
    It seems, manjaro is selected by default, tries to load and fails…I dont know why
I followed the steps grub-fix-wiki 2-3 times, but still the same issue after reboot.
So previously restored windows boot is gone (I can not see windows, I can not select windows as there is no grub welcom page, so I can not boot windows anymore) and manjaro can not boot.
here are steps, I did
[manjaro@manjaro-cinnamon ~]$ su
[manjaro-cinnamon manjaro]# manjaro-chroot -a
 --> mount: [/mnt]
[manjaro-cinnamon /]# lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0    7:0    0  64.6M  1 loop
loop1    7:1    0   1.2G  1 loop
loop2    7:2    0   1.6G  1 loop
loop3    7:3    0 694.6M  1 loop
sda      8:0    0 465.8G  0 disk
|-sda1   8:1    0   300M  0 part
|-sda2   8:2    0   100M  0 part /boot/efi
`-sda3   8:3    0 465.2G  0 part
sdb      8:16   0 931.5G  0 disk
|-sdb1   8:17   0     1G  0 part
|-sdb2   8:18   0    40G  0 part /
|-sdb3   8:19   0    60G  0 part /home
`-sdb4   8:20   0 830.5G  0 part
sdc      8:32   1   7.6G  0 disk
|-sdc1   8:33   1   3.6G  0 part
`-sdc2   8:34   1     4M  0 part
Yes, I can confirm, that root is 40GB partition and home is 60GB, as well as efi partition do match.
[manjaro-cinnamon /]# pacman -Syu grub
 core is up to date
 extra is up to date
 community               7.6 MiB  7.04 MiB/s 00:01 [######################] 100%
(1/1) checking keys in keyring                                                 [#############################################] 100%
(1/1) checking package integrity                                               [#############################################] 100%
(1/1) loading package files                                                    [#############################################] 100%
(1/1) checking for file conflicts                                              [#############################################] 100%
(1/1) checking available disk space                                            [#############################################] 100%
(1/1) reinstalling grub                                                        [#############################################] 100%
When I ran it first time, it downoloaded and installed about 400MB data. After restart still unable to boot, so I executed the reapair instruction again. This time, only one package 46MB is found, but it seems it fails to install. Or what does mean that error ?
[manjaro-cinnamon /]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
[manjaro-cinnamon /]# grub-mkconfig -o /boot/grub/grub.cfg
done
This error
I can see everytime. Is it relevant ?
[manjaro-cinnamon /]# ls -l /etc/default/grub
-rw-r--r-- 1 root root 2286 Oct 19 21:25 /etc/default/grub
This is not changed recently…not sure, is that ok or problem ? However efi partition shows recent (today) timestamp:
[manjaro-cinnamon /]# ls -l /boot
total 59457
drwxr-xr-x 5 root root     1024 Jan  1  1970 efi
drwxr-xr-x 6 root root     4096 Mar  1 18:52 grub
-rw------- 1 root root 35143003 Feb 27 16:02 initramfs-5.15-x86_64-fallback.img
-rw------- 1 root root  9240187 Feb 27 16:02 initramfs-5.15-x86_64.img
-rw-r--r-- 1 root root  5678080 Nov  8 20:02 intel-ucode.img
drwxr-xr-x 2 root root     4096 Feb 15 15:09 memtest86+
drwxr-xr-x 2 root root     4096 Feb 17 20:22 syslinux
-rw-r--r-- 1 root root 10797792 Feb 27 16:02 vmlinuz-5.15-x86_64
[manjaro-cinnamon /]# ls -l /boot/grub/
total 52
drwxr-xr-x 2 root root  4096 Oct 19 21:25 fonts
-rw------- 1 root root  7514 Feb 27 16:39 grub.cf
-rw------- 1 root root  7514 Mar  1 18:52 grub.cfg
-rw-r--r-- 1 root root  1024 Oct 19 21:29 grubenv
drwxr-xr-x 2 root root  4096 Mar  1 18:51 locale
drwxr-xr-x 3 root root  4096 Oct 19 21:25 themes
drwxr-xr-x 2 root root 20480 Mar  1 18:51 x86_64-efi
[manjaro-cinnamon /]# cat /etc/fstab
[manjaro-cinnamon manjaro]# blkid
/dev/sdc2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="DD2E-7463" BLOCK_SIZE="512" TYPE="vfat"
/dev/sdc1: BLOCK_SIZE="2048" UUID="2023-01-04-11-35-38-00" LABEL="MANJARO_CINNAMON_220" TYPE="iso9660"
/dev/sda2: UUID="EC40-E2D4" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="Microsoft basic data" PARTUUID="815bcfd6-7e68-4386-a0b9-528e4fcabad1"
/dev/sda3: BLOCK_SIZE="512" UUID="3CE64355E6430F18" TYPE="ntfs" PARTLABEL="Microsoft basic data" PARTUUID="a082d282-33f3-48ab-9d3c-3e6df47be2ff"
/dev/sda1: LABEL="Obnovenie" BLOCK_SIZE="512" UUID="B2A43F98A43F5E53" TYPE="ntfs" PARTLABEL="Microsoft basic data" PARTUUID="c4d2811c-7218-4f0b-af53-5efbc0259937"
I did manage to display the grub menu by adding “menu” to GRUB_TIMEOUT_STYLE in /etc/default/grub and update the grub.
However grub menu does not show windows at all, and manjaro boot fails :frowning:
cat   /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=62a959f8-998a-4b75-8c86-54f4a0461707 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
So, If I summarize it shortly, there are probably two - three problems:
  1. pacman -Syu grub returns error: (2/3) Refreshing PackageKit…Error connecting: Could not connect: No such file or directory
  2. Grub does offer option for windows (I am using dual boot). There is only Manjaro
  3. Laptop boots Manjaro and it stuck at root partition clean and does not move forward.
Btw. not sure if that matters, however /home is full/out of space. Even if I delete some files, it still shows full. Where are files, deleted from live usb, from origin /home ? Nothing in live-usb trash. But I guess that grub and packages are written only to / it full /home should not matter ?
(Image) Well the kernel itself loads fine, this indicates grub has done its job. I’ve had the kernel panic at the exact same stage (CAPS LOCK LED blinking). However when it ran alright, the kernel was waiting for 2 minutes or so for the missing devices from /etc/fstab. How long have you been waiting for the OS to load at this step? Further I assume there’s a debug parameter to let the kernel show more detailed messages.
I did wait about 15 min and nothing :pensive:.
Where to enter debug parameter? Because when it stops at the /dev/sdb2 clean, I can not writte any command there.
@perseus142
Because you posted output of commands you already provided:
  • Is that last output you posted new and thus changed output with repect to the output you already posted?
    1. If it is not fresh info: Please remove it, and just quote that part from your previous post, because it confuses the thread and makes it almost UN-followable, because what output should we look at. :thinking:
    2. If it is fresh info: Please update the old output and add a note that it was updated.
That way all the relevant info for your problem is in one place, the First post for all readers to look at and try to help.
This most likely means your Linux successfully booted, but has a problem with your graphics driver because it can not initialize your GUI to show you a login prompt…
This could be looked into if we are sure that is the step we need to focus on, but the title of the thread is different, so we might need to change that in that case…
Also:
  1. There is no need to post the listing of /boot and /boot/grub unless explicitly asked for…
  2. Output of just blkid is useless because it is missing info, always use lsblk --fs --all.
That said, please focus on making Linux boot up and work BEFORE Micro$@$…
The current thread is so confusing because the topic title is inconsistent with what you write as replies…
  1. Either Grub works or not.
    This is a completely different problem from the problem that you are unable to see your Micro$@$ boot entry or able to boot it.
  2. If your Grub boots your Linux, it means it is already working but you have problems after the Linux kernel boots.
So you need to clearup at what stage your problem actually is at.
  1. Grub can’t be executed, or has problems acting upon it’s config.
    (This is what the topic title implies, but you explain the contrary in your replies.)
  2. Kernel boots but problems happen in initramfs.
  3. Linux boots but the GUI is not displayed.
I was even confused how to write this reply to make it clear how confusing this thread is at moment…
