Ok, timeshift working ! All IS good now ! I don’t know why cause thé issue but the issue IS not hère the 09/06/2022
Sorry I missed that.
post output from:
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
ok so they are installed… so it is probably related to the latest nvidia drivers …
do you think i try update withaout updade nvidia-uils ?
it should be possible but i dont know how… in updates you can uncheck all updates related to nvidia …
Ok so : it works. If i uncheck thé NVIDIA packagé thé système IS ok. So, one little problem : how to update linux 510/517/515 without nvidia ? And if i don’t update them, this IS not a sécurity breach ?
so you already run the update without nvidia and rebooted, and everything works fine?
yep, it’s the situation
so take a screenshot of system settings/kernel and post it here
I then tried to install them after the first upgrade, but the problem came back. So I reused timeshift and I’m again upgrading without nvidia services
you shouldnt install them, i just wanted to check the system settings/kernel options… dont install anything from there
Ok what command you whant inrun ?
no command, just go to system settings/kernel and take a screenshot of it
is this after you run the update?
no, before
i just launch the update but it stuc at “search conflict between pakage” i’m waiting
so you didnt run the update again, where you disabled nvidia from updating?
I’ll try to explain better: we managed with timeshift to deliver a version before the update. I installed the updates without the NVIDIA. it worked. When in doubt, I upgraded the nvidia afterwards and the problem of blocking at startup started again. I had to uninstall them, restart timeshift and reload the version before the update. I made a screenshot for you and now I’m redoing the update without the nvidia and linux510, linux 515 and linux 517 drivers which need nvidia drivers to be installed.
