So, I’ve recently installed Manjaro Linux in my laptop and after working for around 1 hour if I shutdown it, it takes around 90 seconds to shutdown. I have tried to make the following changes in my /etc/systemd/system.conf
DumpCore=no
DefaultTimeoutStartSec=05s
DefaultTimeoutStopSec=05s
DefaultTimeoutAbortSec=05s
Still, nothing changed. Can someone help me out with this?
Here is your reply: https://wiki.archlinux.org/index.php/Improving_performance
This support here is community driven. Keep that in mind. We do this in our free time.
Fabby
18 September 2020 21:21
4
Welcome to Manjaro!
Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
P.S. Always allow for 24 hours to pass before expecting an answer because we’re a global community and the expert you’re seeking might be in the Atlantis Time Zone and will respond to your request while you’re
There you go:
System: Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=09cae4e5-a15a-4dae-b41e-718543ca815b rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Latitude 3500 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0V262X v: A00 serial: <filter> UEFI: Dell v: 1.13.1 date: 06/11/2020
Battery: ID-1: BAT0 charge: 38.7 Wh condition: 42.0/42.0 Wh (100%) volts: 12.7/11.4 model: SWD-ATL3.618 DELL WJPC407
type: Li-ion serial: <filter> status: Discharging
Memory: RAM: total: 3.73 GiB used: 1.24 GiB (33.2%)
CPU: Topology: Dual Core model: Intel Core i3-8145U bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 8E (142)
stepping: C (12) microcode: D6 L2 cache: 4096 KiB bogomips: 18406
Speed: 1757 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1796 2: 1778 3: 1740 4: 1774
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2
bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Graphics: Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-6:2 chip ID: 0bda:5675 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: gnome-shell driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :1 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.4.64-1-MANJARO
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3
chip ID: 8086:9df0
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169 v: kernel port: 3000
bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 21.79 GiB (2.3%)
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 01 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 926.51 GiB size: 910.97 GiB (98.32%) used: 21.79 GiB (2.4%) fs: ext4 dev: /dev/sda2 label: root
uuid: 09cae4e5-a15a-4dae-b41e-718543ca815b
ID-2: /boot/efi raw size: 1024.0 MiB size: 1022.0 MiB (99.80%) used: 280 KiB (0.0%) fs: vfat dev: /dev/sda1
label: BOOT uuid: 7563-72B2
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 label: swap
uuid: ca1534f8-a22d-4e88-95ff-b570da5136fb
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-6:2 info: Realtek Integrated_Webcam_HD type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 0bda:5675 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 195 Uptime: 5m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1290 lib: 396 flatpak: 0
Shell: Bash v: 5.0.18 running in: terminator inxi: 3.1.05
I didn’t mean to be rude in the comment up there, I was just not understanding why people were replying to the posts posted after this but not to mine.
omano
19 September 2020 11:49
6
OK, but I’m sure I’m not the only one here thinking like that, but posting this kind of message is really a bad way to get attention, in my rule book I usually ignore on purpose users who complain nobody replies fast enough to them (on any ‘free’ place on the internet, I mean you’re not a customer, not paying anyone so what would you expect, especially after 18 MINUTES lol)
But if a new user sees nobody replying to his post but to posts that have been posted after his one, won’t he/she get confused? I thought there was probably something wrong with my post or its format, so I was just making sure that there’s nothing wrong and hence the question. If it appeared otherwise, then my apologies.
Falav
19 September 2020 12:33
8
Linux, Manjaro, IT… It’s huge and nobody can know everything on everything. If the people who have knowledge about your issue are not connected, are busy answering other topics, the other forum users, who know other things and answer other topics, will not answer yours.
And again, it’s not a paid after sales service forum, with 5 minutes top to get an answer.
Fabby
19 September 2020 21:47
9
This is why it takes a long time:
snowden17_38:
rotation: 5400 rpm
So basically you only have <4G of RAM and have a 5400RPM HDD as storage and no amount of tinkering is going to change the laws of physics make your computer have a faster drive nor increase your memory so I’m sorry to say:
Be patient while your computer shuts down writing all that swapped memory to your slow hard disk…
Don’t worry: be happy!
You didn’t know, now you know, most of the die-hard hackers here have forgotten what it was to be a N00b, I haven’t although I’m an old fart…
Yeah, the 5400 rpm drive is the big issue there. I had one, and shutdown times were pretty slow (still faster than windows). I upgraded my laptop to a cheap SSD the other day, and shutdown is almost instantaneous.
Here is my Solus system’s output which takes 2-3 secs on average and at most 5 seconds to shutdown:
Kernel: 5.6.19-158.current x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/boot/com.solus-project.current.5.6.19-158
root=UUID=086ff6c4-32a2-4481-992d-7423c144a204 quiet loglevel=3 splash
systemd.show_status=false rw radeon.si_support=0 radeon.cik_support=0
amdgpu.si_support=1 amdgpu.cik_support=1
systemd.unified_cgroup_hierarchy=0
resume=UUID=871af452-46b7-4f97-aa4f-1e788f8bc97f
Desktop: Budgie 10.5.1 info: budgie-panel wm: budgie-wm dm: LightDM 1.30.0
Distro: Solus 4.1
Type: Desktop Mobo: Gigabyte model: H81M-S v: x.x serial: <filter>
BIOS: American Megatrends v: F2 date: 08/19/2015
RAM: total: 3.75 GiB used: 970.2 MiB (25.3%)
RAM Report:
Topology: Dual Core model: Intel Pentium G3240 bits: 64 type: MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 27
L2 cache: 3072 KiB bogomips: 12372
Speed: 898 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 865 2: 815
Flags: abm acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept
ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep ss ssbd
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0402
Display: x11 server: X.Org 1.20.9 compositor: budgie-wm
driver: modesetting unloaded: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 359x203mm (14.1x8.0")
s-diag: 412mm (16.2")
Monitor-1: VGA-1 res: 1360x768 hz: 60 dpi: 84 size: 410x256mm (16.1x10.1")
diag: 483mm (19")
OpenGL: renderer: Mesa DRI Intel HD Graphics (HSW GT1) v: 4.5 Mesa 20.1.4
compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:8c20
Sound Server: ALSA v: k5.6.19-158.current
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try --no-dig
Local Storage: total: 465.76 GiB used: 30.45 GiB (6.5%)
ID-1: /dev/sda vendor: Seagate model: ST500DM002-9YN14C size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: CC4C scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224DB rev: ID00
dev-links: cdrom
ID-1: / raw size: 30.00 GiB size: 29.40 GiB (98.01%)
used: 19.99 GiB (68.0%) fs: ext4 dev: /dev/sda7 label: N/A
uuid: 086ff6c4-32a2-4481-992d-7423c144a204
ID-2: /home raw size: 17.99 GiB size: 17.59 GiB (97.74%)
used: 10.46 GiB (59.5%) fs: ext4 dev: /dev/sda8 label: N/A
uuid: 306fa085-e910-4e81-b6d1-474dbe42f4e6
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda9 label: N/A
uuid: 871af452-46b7-4f97-aa4f-1e788f8bc97f
ID-1: /dev/sda1 size: 100.0 MiB fs: ntfs label: System Reserved
uuid: 7E7024EF7024AFB7
ID-2: /dev/sda2 size: 97.56 GiB fs: ntfs label: N/A uuid: 80AC2947AC293954
ID-3: /dev/sda3 size: 122.07 GiB fs: ntfs label: New Volume
uuid: A2CEAD1BCEACE92D
ID-4: /dev/sda4 size: 1 KiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-5: /dev/sda5 size: 72.07 GiB fs: ntfs label: New Volume
uuid: DA8C73B68C738BAF
ID-6: /dev/sda6 size: 123.96 GiB fs: ntfs label: New Volume
uuid: CC38277738276026
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8008
Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
Device-1: 2-2:2 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
chip ID: 0101:0007
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 175 Uptime: 2m Init: systemd v: 246 runlevel: 5 Compilers:
gcc: 9.3.0 clang: 9.0.1 Shell: bash v: 5.0.11 running in: gnome-terminal
inxi: 3.1.03
grep’ing the relevant parts out:
Memory: RAM: total: 3.75 GiB
rotation: 5400 rpm
How do you explain this taking 2-3 secs then?
This thing aside, can y’all tell me a way to figure out what’s making the shutdown slow? For example, systemd-analyze blame
tells me what service is taking up how much time during boot . Is there something equivalent for the shutdown , just like the boot ?
Because, really: what I find peculiar is that it takes exactly 1 minute and 30 seconds to shut down which is the default timeout span during shutdown or something like that. It looks like it’s a forced delay/timeout which can be adjusted. Again, it’s just me speculating. You all are the experts here, so I would like to hear what you guys think.
omano
20 September 2020 05:42
12
If it is exactly 90 seconds, do you have a terminal message telling you it is waiting for a stop job to finish with a 90s timer?
90 seconds is the default for stopjob (and other) timeout in systemd.
This can happen if you have a user logged in another TTY, or if some service refuses to close, at shutdown.
Fabby
20 September 2020 09:40
13
What @omano said, and an inxi
output will not help us help you. Please give us a shutdown log from both OSes.
Please also note this kind of critical info in your first question: compared to Solus, Manjaro takes 90 seconds more to shut down. Here are both shutdown logs.
No, there’s no terminal message. I’ve recorded it in my stopwatch and it turns out to be around 90 seconds with 1-2 seconds here and there, maybe. Considering human reaction errors.
There’s only one user in my laptop. No multiple user accounts.
I’d love to give more information. But can you tell me how do I generate a shutdown log?
Fabby
20 September 2020 10:18
16
journalctl --boot=-1 | tail --lines=50
would be a good start as that gives the last (the tail
) 50 lines of the previous boot (-1
Okay, so I’m supposed to shut it down after using it for 1-2 hrs, and then boot it up back and then execute this command, right? If that makes any sense.
Fabby
20 September 2020 12:33
18
No, just execute above command right now and post its output…
Alright, there you go:
Sep 19 17:02:33 dell-latitude systemd[1]: Deactivated swap /dev/disk/by-id/wwn-0x5000039a01c023a7-part3.
Sep 19 17:02:33 dell-latitude systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:00:17.0\x2data\x2d1\x2dpart3.swap: Succeeded.
Sep 19 17:02:33 dell-latitude systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:00:17.0-ata-1-part3.
Sep 19 17:02:33 dell-latitude systemd[1]: dev-disk-by\x2dlabel-swap.swap: Succeeded.
Sep 19 17:02:33 dell-latitude systemd[1]: Deactivated swap /dev/disk/by-label/swap.
Sep 19 17:02:33 dell-latitude systemd[1]: dev-disk-by\x2did-ata\x2dTOSHIBA_MQ04ABF100_50APT5A2T\x2dpart3.swap: Succeeded.
Sep 19 17:02:33 dell-latitude systemd[1]: Deactivated swap /dev/disk/by-id/ata-TOSHIBA_MQ04ABF100_50APT5A2T-part3.
Sep 19 17:02:33 dell-latitude systemd[1]: dev-sda3.swap: Succeeded.
Sep 19 17:02:33 dell-latitude systemd[1]: Deactivated swap /dev/sda3.
Sep 19 17:02:33 dell-latitude systemd[1]: dev-disk-by\x2duuid-ca1534f8\x2da22d\x2d4e88\x2d95ff\x2db570da5136fb.swap: Succeeded.
Sep 19 17:02:33 dell-latitude systemd[1]: Deactivated swap /dev/disk/by-uuid/ca1534f8-a22d-4e88-95ff-b570da5136fb.
Sep 19 17:02:34 dell-latitude mkinitcpio[2166]: ==> Build complete.
Sep 19 17:02:34 dell-latitude systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Succeeded.
Sep 19 17:02:34 dell-latitude systemd[1]: Finished Generate shutdown-ramfs.
Sep 19 17:02:34 dell-latitude audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:34 dell-latitude audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude systemd[1]: boot-efi.mount: Succeeded.
Sep 19 17:02:36 dell-latitude systemd[1]: Unmounted /boot/efi.
Sep 19 17:02:36 dell-latitude systemd[1]: Reached target Unmount All Filesystems.
Sep 19 17:02:36 dell-latitude systemd[1]: systemd-fsck@dev-disk-by\x2duuid-7563\x2d72B2.service: Succeeded.
Sep 19 17:02:36 dell-latitude systemd[1]: Stopped File System Check on /dev/disk/by-uuid/7563-72B2.
Sep 19 17:02:36 dell-latitude audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-7563\x2d72B2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude kernel: kauditd_printk_skb: 19 callbacks suppressed
Sep 19 17:02:36 dell-latitude kernel: audit: type=1131 audit(1600515156.055:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-7563\x2d72B2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude systemd[1]: Removed slice system-systemd\x2dfsck.slice.
Sep 19 17:02:36 dell-latitude systemd[1]: Stopped target Local File Systems (Pre).
Sep 19 17:02:36 dell-latitude systemd[1]: systemd-remount-fs.service: Succeeded.
Sep 19 17:02:36 dell-latitude systemd[1]: Stopped Remount Root and Kernel File Systems.
Sep 19 17:02:36 dell-latitude audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
Sep 19 17:02:36 dell-latitude systemd[1]: Stopped Create Static Device Nodes in /dev.
Sep 19 17:02:36 dell-latitude audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude systemd[1]: Reached target Shutdown.
Sep 19 17:02:36 dell-latitude systemd[1]: Reached target Final Step.
Sep 19 17:02:36 dell-latitude systemd[1]: systemd-reboot.service: Succeeded.
Sep 19 17:02:36 dell-latitude audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude systemd[1]: Finished Reboot.
Sep 19 17:02:36 dell-latitude systemd[1]: Reached target Reboot.
Sep 19 17:02:36 dell-latitude systemd[1]: Shutting down.
Sep 19 17:02:36 dell-latitude kernel: audit: type=1131 audit(1600515156.059:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude kernel: audit: type=1131 audit(1600515156.059:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude kernel: audit: type=1130 audit(1600515156.059:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude kernel: audit: type=1131 audit(1600515156.059:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 19 17:02:36 dell-latitude systemd[1]: Hardware watchdog 'iTCO_wdt', version 0
Sep 19 17:02:36 dell-latitude systemd[1]: Set hardware watchdog to 10min.
Sep 19 17:02:36 dell-latitude kernel: watchdog: watchdog0: watchdog did not stop!
Sep 19 17:02:36 dell-latitude systemd-shutdown[1]: Syncing filesystems and block devices.
Sep 19 17:02:36 dell-latitude systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Sep 19 17:02:36 dell-latitude systemd-journald[222]: Journal stopped
There are only 3 sec? Seems it is not the full log. This will create a shutdown/reboot log from the last boot:
journalctl -b -1 | grep -A999 "System is rebooting.\|System is powering down."
The output was huge from this command, so I redirected its output to a text file and pasted this in a pastebin.com paste: link
