Weird thing is that sometimes I get slow shutdowns too, on an NVMe SSD and 16 gb RAM.
There is lots of disk activity for about 60 seconds before the “watchdog did not stop”, which is strange as I have little RAM usage, little disk cache and little swap, as I close many programs before shutdown.
Happened in kernels 5.7, 5.8 and the 5.9 rc currently using.
Okay, so basically I should edit my /etc/default/grub's GRUB_CMDLINE_LINUX="" line to be: GRUB_CMDLINE_LINUX="nowatchdog zswap.enabled=0 mitigations=off"
Additionally, this is what my /etc/default/grub contains:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=1
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
Do you sense something wrong in it that might be delaying the shutdown?
Changing from legacy to UEFI means a re-install in 99% of all cases.
Also had a look at the log and it could be something hanging after journald was stopped (so I’m more inclined to suspect a firmware issue than to the DE)
How do I look up whether there’s a BIOS/UEFI update pending for my device? Do you mean I should check out my manufacturer’s website for drivers and stuff? Or can I check if there’s an update pending from the BIOS/UEFI menu that appears when I keep pressing F2 during boot?
Moreover, if there are any updates as such, aren’t they supposed to be installed automatically? I’m sorry if I’ve said something obscure/otherworldly.
It depends on your manufacturer, but I don’t know any that installs firmware automatically. As for mouse / CPU / … updates: yes they are built into the kernel or if not like nVidia drivers, they still get updated automatically.
While mq-deadline is a good scheduler for SSDs and sort of, it can be really slow on spinning disks.
Better use bfq which focuses on delivering the lowest latency rather than achieving the maximum throughput. Therefore it can react better, but it will cost you a little more CPU Power. https://algo.ing.unimo.it/people/paolo/disk_sched/
To change that on the fly:
sudo su
echo bfq > /sys/block/sda/queue/scheduler
and check what has been chosen:
cat /sys/block/sda/queue/scheduler
For changing that permanently, you have to set udev rule like this:
# set scheduler for rotating disks
ACTION=="add|change", KERNEL=="sd[a-z]", ATTR{queue/rotational}=="1", ATTR{queue/scheduler}="bfq"
in a file like: /etc/udev/rules.d/60-ioschedulers.rules (you need to create it)
This is what I got from the manufacturer’s drivers’ website: https://www.dell.com/support/home/en-in/product-support/product/latitude-15-3500-laptop/drivers
What do you suggest? I think the first one is the one we’re aiming for but there is only an .exe download. That’s only relevant for Windows.
I had to format it like this because it’s not letting me add a link in a post.
After the echo command one, I did cat /sys/block/sda/queue/scheduler, and it gave: mq-deadline kyber [bfq] none
I see the brackets are now around bfq, so now that’s the one which is selected, right?
And, I created that file as you said and saved the text in it. Doing cat /etc/udev/rules.d/60-ioschedulers.rules now gives: # set scheduler for rotating disks ACTION=="add|change", KERNEL=="sd[a-z]", ATTR{queue/rotational}=="1", ATTR{queue/scheduler}="bfq"
So, it’s copied into that file. Tell me if I did anything wrong.
As I see there is also another format: rcv
You need to download that one, put it on a usb drive with fat32 formatted.
Quote from Dell:
Installation
Copy the downloaded file to a USB drive. The USB drive does not need to be bootable device.
Insert the USB drive into any USB port.
Power on the system.
At the DELL logo screen, press F12 to access the one-time boot menu.
Select BIOS Update in the section.
Click Flash from file to browse the USB drive to locate the downloaded file.
Select the file and click Submit.
Verify the existing system BIOS information and the BIOS update information.
Click Update BIOS.
Review the Warning message and click Confirm Update BIOS! to proceed with the update.
The system restarts and displays a progress bar at the Dell logo screen. The system restarts again when the update is complete.
