So, it appears when running Manjaro most of the time it works just fine. However, every so often it reboots after whatever is playing on screen and gives me repeated audio, horrible glitchy noises, to other issues. (This is the reason why I’ve tagged it with Nvidia, since it usually appears if a have 2+ videos paused, while one is playing).
So, I would love to be able to hunt this down more, but trying to read through the journalctl has left me more stumped.
Well, the power supply I can safely rule out as it is one of the newer devices. I believe a Corsair AX860 (could be, but I would think since it’s able to boot, it’s not likely the issue)
My best guess is possibly the CPU I bought online, which works mostly, but I keep getting an error with Disabling IRQ #18.
My specs;
➤ hwinfo --short
cpu:
AMD Phenom(tm) II X6 1100T Processor, 800 MHz
AMD Phenom(tm) II X6 1100T Processor, 2500 MHz
AMD Phenom(tm) II X6 1100T Processor, 3300 MHz
keyboard:
/dev/input/event2 BY Tech Usb Gaming Keyboard
Logitech Unifying Receiver
mouse:
/dev/input/mice BY Tech Usb Gaming Keyboard
graphics card:
nVidia GM107 [GeForce GTX 750 Ti]
sound:
nVidia GM107 High Definition Audio Controller [GeForce 940MX]
ATI SBx00 Azalia (Intel HDA)
storage:
Floppy disk controller
ATI SB7x0/SB8x0/SB9x0 IDE Controller
ATI SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
network:
enp3s0 Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
network interface:
lo Loopback network interface
enp3s0 Ethernet network interface
disk:
/dev/sdb Seagate Backup+ Hub BK
/dev/fd0 Disk
/dev/sda SPCC Solid State
Seagate RSS LLC Backup Plus Hub (Mass Storage)
partition:
/dev/sdb1 Partition
/dev/sda1 Partition
floppy:
/dev/fd0 Floppy Disk
usb controller:
ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller
Fresco Logic FL1100 USB 3.0 Host Controller
ATI SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
ATI SB7x0 USB OHCI1 Controller
bios:
BIOS
bridge:
AMD Family 10h Processor Miscellaneous Control
AMD Family 10h Processor Address Map
AMD RS780/RS880 PCI to PCI bridge (PCIE port 0)
ATI SB7x0/SB8x0/SB9x0 LPC host controller
AMD RS780 Host Bridge
AMD Family 10h Processor Link Control
AMD Family 10h Processor DRAM Controller
AMD RS780 PCI to PCI bridge (PCIE port 2)
AMD Family 10h Processor HyperTransport Configuration
ATI SBx00 PCI to PCI Bridge
AMD RS780 PCI to PCI bridge (ext gfx port 0)
hub:
Linux Foundation 1.1 root hub
Seagate RSS LLC Backup+ Hub
Linux Foundation 2.0 root hub
Linux Foundation 3.0 root hub
memory:
Main Memory
bluetooth:
Edimax Bluetooth Adapter
unknown:
FPU
DMA controller
PIC
Keyboard controller
ATI SBx00 SMBus Controller
Serial controller
Logitech HD Pro Webcam C920
Although, two things, the IRQ seems to be attached to multiple USB connections, and the ethernet card built in. Second, I just now noticed that 4 of the 6 cores are at 800 Mhz! Yikes.
