Hi fellas, I’ve been trying to update my Manjaro for a couple of months now… but it keeps coming with the followin error:
can someone advise me how te get around that… I am a simple user… not an IT guy. Thanks
and also this: Update failing due to mutter conflict
This is what I got at the end:
warning: budgie-control-center-1.2.0-1 is up to date – reinstalling
:: Starting full system upgrade…
warning: manjaro-hello: local (0.7.0-6) is newer than extra (0.7.0-5)
:: Replace qgpgme with core/qgpgme-qt5? [Y/n] y
resolving dependencies…
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: mutter43 and mutter are in conflict
What is installed?
mutter or mutter43 ?
budgie might need/want one or the other
Which one does it want?
remove the other one - or remove both and have the dependencies take care of what is reinstalled
There is a conflict - resolve the conflict by getting rid of one or the other or both offending programs …
or by installing the correct one first …
This
(removing mutter)
which is the window manager -
could end your current session - be prepared to run the update from a TTY
